在线时间36 小时
UID3056301
注册时间2014-8-30
NXP金币0
 该用户从未签到 高级会员
	积分669
最后登录2015-9-23 |
 Freescale 公司的MCF5301x是 32位ColdFire MPU,具有低功耗,高集成度和连接外设特性以及集成语音CODEC,为用户提供了工业控制中嵌入语音解决方案.MCF5301x在240MHz时的性能高达211 Dhrystone 2.1 MIPS,具有增强性安全数字主控制器(eSDHC)和两个ISO7816智能卡接口,2个10/100以太网MAC,用于加速DES, 3DES, AES, MD5和 SHA-1算法的协处理器.主要用在建筑物自动化,家庭自动化,工厂自动化,接入控制,医疗监视设备,POS系统以及消防和告警系统.本文介绍MCF53017主要特性,方框图以及M53017MOD产品模块特性和详细电路图.
 MCF5301x: Low power MPU with dual Ethernet, USB, and audio sub-system
 The MCF5301x 32 bit ColdFire MPUs combine low power, high integration, and connectivity peripherals with a voice codec to give customers the ideal solution for industrial control with embedded voice applications.
 MCF53017主要特性:
 • Version 3 ColdFire® core with EMAC
 • Up to 211 Dhrystone 2.1 MIPS @ 240 MHz
 • 16 KBytes unified instruction/data cache
 • 128 KBytes internal SRAM with standby power supply support
 • Crossbar switch technology (XBS) for concurrent access to peripherals or RAM from multiple bus masters
 • Enhanced Secure Digital Host Controller (eSDHC)
 – Supports CE-ATA, SD Memory, miniSD Memory, SDIO, miniSDIO, SD Combo, MMC, MMC plus, MMC 4x, and MMC RS cards
 • Two ISO7816 smart card interfaces
 • IC identification module
 • Voice-band audio codec with integrated speaker, microphone, headphone, and handset amplifiers
 • 16- or 32-bit SDR, 16-bit DDR/mobile-DDR SDRAM controller
 • USB 2.0 On-the-Go controller
 • USB host controller
 • 2 10/100 Ethernet MACs
 • Coprocessor for acceleration of the DES, 3DES, AES, MD5, and SHA-1 algorithms
 • Random number generator
 • 16-channel DMA controller
 • Synchronous serial interface
 • 4 periodic interrupt timers
 • 4 32-bit timers with DMA support
 • Real-time clock (RTC) module with standby support
 • DMA-supported serial peripheral interface (DSPI)
 • 3 UARTs
 • I2C bus interface
 MCF53017目标应用:
 Building automation
 Home automation
 Fire and alarm systems
 Access control
 Factory automation
 Medical monitoring equipment
 Point of sale systems
 Intercom and public address systems
  图1.MCF53017方框图
 M53017MOD: MCF53017 Production Module
 Digital Voice solution production module including an NRE free full software and hardware solution specifically designed for low to medium volume production of intercom and public address applications, also suitable for IP telephony, (available in multiples of 5).
 M53017MOD 特性:
 • MCF53017CVMJ240J  processor
 • 64 MB DDR-SDRAM
 • 32 MB NOR Flash
 • Ethernet PHY or Dual PHY
 • VoIP software
 • All licenses for VoIP software use
  图2.M53017MOD产品模块外形图
  图3.M53017MOD产品模块电路图(1)
  图4.M53017MOD产品模块电路图(2)
  图5.M53017MOD产品模块电路图(3)
  图6.M53017MOD产品模块电路图(4)
  图7.M53017MOD产品模块电路图(5)
