查看: 9451|回复: 10
[CodeWarrior] Codewarrior10.5 SDA调试无法下载程序(已解决)
发表于 2014-10-24 13:16:03 | 显示全部楼层 |阅读模式
可以调试,但是无法下载程序到Flash里面, 目前是在飞思卡尔的TRK-KEA8开发板上调试。错误信息提示如下:
Executing Initialization File: G:\Jason20120420-3\Jason\Smartlife\TRK-KEA8\TRK-KEA8_Lab3/Project_Settings/Debugger/init_kinetis.tcl
radix x
cmdwin::eclipse::config hexprefix 0x
cmdwin::eclipse::config MemIdentifier p
thread break: Stopped, 0x0, 0x0, cpuARMLittle, TRK-KEA8_Lab3.elf (state, tid, pid, cpu, target)
cmdwin::eclipse::config MemWidth 32
cmdwin::eclipse::config MemAccess 32
cmdwin::eclipse::config MemSwap off
cmdwin::reg User\/System Mode Registers/LR = 0xFFFFFFFF
cmdwin::reg Breakpoint Unit Registers/BP_COMP0 = 0x0
cmdwin::reg Breakpoint Unit Registers/BP_COMP1 = 0x0
cmdwin::reg Core Debug Registers/DEMCR = 0x1000001
cmdwin::reg Data Watchpoint and Trace Unit Registers/DWT_FUNCTION0 = 0x0
cmdwin::reg Data Watchpoint and Trace Unit Registers/DWT_FUNCTION1 = 0x0
cmdwin::reg Watchdog timer (WDOG)/WDOG_TOVALH = 0x03
cmdwin::reg Watchdog timer (WDOG)/WDOG_TOVALL = 0xE8
cmdwin::reg Watchdog timer (WDOG)/WDOG_CS2 = 0x03
cmdwin::reg Watchdog timer (WDOG)/WDOG_CS1 = 0x23
Starting 3rd party flash programming...
GDI: Mtwks Callback(MTWKS_CB_PROJECTACCESS, Section : STARTUP, Entry : SPECIFY_NETWORKCARD_ENABLED, Value : 0, R) => DI_OK
INF: Copyright 2012 P&E Microcomputer Systems,Inc.
INF: Command Line :"C:\Freescale\CW MCU v10.5\eclipse\..\MCU\bin\de.exe" -noni -language en -ORBendPoint giop:tcp:127.0.0.1: -ORBtraceLevel 0
INF: CMD>RE
INF: Initializing.
INF: Warning 17927. Target MCU mismatch. Download performance limited. See http://www.pemicro.com/opensda/pe_tools.cfm for information on debugging external processors.
INF: Target has been RESET and is active.
INF: CMD>CM C:\Freescale\CW MCU v10.5\MCU\bin\Plugins\support\arm\gdi\P&E\freescale_keazn8m4_pflash.arp
INF: Initializing.
INF: Initialized.
INF: ;version 1.00, 07/19/2013, Copyright P&E Microcomputer Systems, www.pemicro.com [ke_8k_pflash_m0]
INF: ;device freescale, keazn8m4, pflash
INF: ;begin_cs device=$00000000, length=$00002000, ram=$20000000
INF: Loading programming algorithm ...
INF: Done.
INF: CMD>EM
INF: Erasing.
INF: Module has been erased.
INF: Initializing.
INF: Initialized.
INF: Done.
INF: CMD>PM
INF: Programming.
INF: Processing Object File Data ...
INF: .
INF: Programmed.
INF: CMD>VC
INF: Verifying object file CRC-16 to device ranges ...
INF:    block 00000000-000000BF ...
INF: Ok.
INF:    block 00000800-00001FF7 ...
我知道答案 目前已有10人回答
发表于 2014-10-24 14:46:26 | 显示全部楼层
你好,楼主!
需求证一下:
1. 请问你跑的是官方的例程吗?
2. 在跑例程时,有无按照TRK-KEA8的用户指南说明,安装完驱动。
 楼主| 发表于 2014-10-24 15:12:50 | 显示全部楼层
FSL_TICS_ZP 发表于 2014-10-24 14:46
你好,楼主!
需求证一下:
1. 请问你跑的是官方的例程吗?
是例程,之前都可以的,就是后面换了一个新的MCU上去,代理说是一样的。
发表于 2014-10-24 15:41:50 | 显示全部楼层
那就是说你的TRK-KEA8开发板上的MCU已经换过啊?
请问你换的那款MCU呢?
 楼主| 发表于 2014-10-24 16:15:37 | 显示全部楼层
同一个型号的
 楼主| 发表于 2014-10-24 16:16:56 | 显示全部楼层
刚把以前开发板 上的那个MCU换回去同样是无法下载,状态一样。说不是我的开发板上的SDA有问题了呀?
 楼主| 发表于 2014-10-24 16:20:02 | 显示全部楼层
原开发板上的MCU是有程序的,我换到我们的产品板上可以跑, 换回来开发板后无法连接,无法下载。再换到我们产品上也不跑了,程序似乎丢了。
    发表于 2014-10-25 11:02:20 | 显示全部楼层
    应该是程序有问题,进入了死循环或者你把SDA的接口关闭了,你排除一下原因。
     楼主| 发表于 2014-10-26 18:21:00 | 显示全部楼层
    安 发表于 2014-10-25 11:02
    应该是程序有问题,进入了死循环或者你把SDA的接口关闭了,你排除一下原因。 ...
    程序没有问题,都是TRK_KEA8自带的程序, 我是直接导入的的PROJECT,  DEBUG模式都是正常的。  SDA接口关闭??你是指什么? 这个先前都是这样设置和操作的都没问题呀。
    发表于 2014-10-27 09:43:00 | 显示全部楼层
    jason521 发表于 2014-10-26 18:21
    程序没有问题,都是TRK_KEA8自带的程序, 我是直接导入的的PROJECT,  DEBUG模式都是正常的。  SDA接口关 ...
    现在你是变回原来的程序也无法正常的Debug啊,我猜测是SDA电路部分有问题,或者MCU有故障。
    GMT+8, 2025-10-31 17:00 , Processed in 0.110010 second(s), 30 queries , MemCache On.
