在线时间40 小时
UID132062
注册时间2007-7-16
NXP金币0
- 179
- 1970-1-1
楼主 |
发表于 2014-10-28 13:49:23
显示全部楼层
这个配置是用PE自动生成的,应该不会错吧?我把串口初始化代码贴出来吧,你看看有无错误:
LDD_TDeviceData* AS1_Init(LDD_TUserData *UserDataPtr)
/* Allocate device structure */
AS1_TDeviceDataPtr DeviceDataPrv;
/* {Default RTOS Adapter} Driver memory allocation: Dynamic allocation is simulated by a pointer to the static object */
DeviceDataPrv = &DeviceDataPrv__DEFAULT_RTOS_ALLOC;
/* Clear the transmit counters and pointer */
DeviceDataPrv->OutSentDataNum = 0x00U; /* Clear the counter of sent characters */
DeviceDataPrv->OutDataNumReq = 0x00U; /* Clear the counter of characters to be send by SendBlock() */
DeviceDataPrv->OutDataPtr = NULL; /* Clear the buffer pointer for data to be transmitted */
DeviceDataPrv->UserDataPtr = UserDataPtr; /* Store the RTOS device structure */
/* Allocate interrupt vectors */
/* {Default RTOS Adapter} Set interrupt vector: IVT is static, ISR parameter is passed by the global variable */
INT_UART0__DEFAULT_RTOS_ISRPARAM = DeviceDataPrv;
/* SIM_SCGC4: UART0=1 */
SIM_SCGC4 |= SIM_SCGC4_UART0_MASK;
/* PORTB_PCR3: ISF=0,MUX=3 */
PORTB_PCR3 = (uint32_t)((PORTB_PCR3 & (uint32_t)~(uint32_t)(
PORT_PCR_ISF_MASK |
PORT_PCR_MUX(0x04)
)) | (uint32_t)(
PORT_PCR_MUX(0x03)
/* NVIC_IPR3: PRI_12=0x80 */
NVIC_IPR3 = (uint32_t)((NVIC_IPR3 & (uint32_t)~(uint32_t)(
NVIC_IP_PRI_12(0x7F)
)) | (uint32_t)(
NVIC_IP_PRI_12(0x80)
/* NVIC_ISER: SETENA|=0x1000 */
NVIC_ISER |= NVIC_ISER_SETENA(0x1000);
UART0_PDD_EnableTransmitter(UART0_BASE_PTR, PDD_DISABLE); /* Disable transmitter. */
DeviceDataPrv->SerFlag = 0x00U; /* Reset flags */
/* UART0_C1: LOOPS=0,DOZEEN=0,RSRC=0,M=0,W***E=0,ILT=1,PE=0,PT=0 */
UART0_C1 = UART0_C1_ILT_MASK; /* Set the C1 register */
/* UART0_C3: R8T9=0,R9T8=0,TXDIR=0,TXINV=0,ORIE=0,NEIE=0,FEIE=0,PEIE=0 */
UART0_C3 = 0x00U; /* Set the C3 register */
/* UART0_C4: MAEN1=0,MAEN2=0,M10=0,OSR=0 */
UART0_C4 = UART0_C4_OSR(0x00); /* Set the C4 register */
/* UART0_S2: LBKDIF=0,RXEDGIF=0,MSBF=0,RXINV=0,RWUID=0,BRK13=0,LBKDE=0,RAF=0 */
UART0_S2 = 0x00U; /* Set the S2 register */
SIM_PDD_SetClockSourceUART0(SIM_BASE_PTR, SIM_PDD_UART0_FLL_CLOCK);
UART0_PDD_SetBaudRate(UART0_BASE_PTR, 2500U); /* Set the baud rate register. */
UART0_PDD_SetOversamplingRatio(UART0_BASE_PTR, 3U);
UART0_PDD_EnableSamplingOnBothEdges(UART0_BASE_PTR, PDD_ENABLE);
UART0_PDD_EnableTransmitter(UART0_BASE_PTR, PDD_ENABLE); /* Enable transmitter */
/* Registration of the device structure */
PE_LDD_RegisterDeviceStructure(PE_LDD_COMPONENT_AS1_ID,DeviceDataPrv);
return ((LDD_TDeviceData *)DeviceDataPrv);
