查看: 4244|回复: 1
[求助] ltib编译最后一步出现error,怎么破??
发表于 2014-9-24 17:15:21 | 显示全部楼层 |阅读模式
你好, 按照《i.MX6 Ubuntu 12.04上编译LTIB》步骤,配置完开发板和Uboot选项。最后运行到./Ltib时,出现错误:
ivan@ivan-virtual-machine:~/ltib$ ./ltib
Installing: gcc-4.6.2-glibc-2.13-linaro-multilib-2011.12-1.i386.rpm
sudo /opt/freescale/ltib/usr/bin/rpm --dbpath /opt/freescale/ltib/var/lib/rpm -ivh --force --ignorearch /opt/freescale/pkgs/gcc-4.6.2-glibc-2.13-linaro-multilib-2011.12-1.i386.rpm
Failed to install: gcc-4.6.2-glibc-2.13-linaro-multilib-2011.12-1.i386.rpm:
error: failed dependencies:
        /usr/bin/pkg-config   is needed by gcc-4.6.2-glibc-2.13-linaro-multilib-2011.12-1
        /work/build/.build/tools/bin/bash   is needed by gcc-4.6.2-glibc-2.13-linaro-multilib-2011.12-1
        ld-linux.so.2   is needed by gcc-4.6.2-glibc-2.13-linaro-multilib-2011.12-1
        ld-linux.so.2(GLIBC_2.3)   is needed by gcc-4.6.2-glibc-2.13-linaro-multilib-2011.12-1
        libc.so.6(GLIBC_2.0)   is needed by gcc-4.6.2-glibc-2.13-linaro-multilib-2011.12-1
        libc.so.6(GLIBC_2.1)   is needed by gcc-4.6.2-glibc-2.13-linaro-multilib-2011.12-1
        libc.so.6(GLIBC_2.1.3)   is needed by gcc-4.6.2-glibc-2.13-linaro-multilib-2011.12-1
        libc.so.6(GLIBC_2.2)   is needed by gcc-4.6.2-glibc-2.13-linaro-multilib-2011.12-1
        libc.so.6(GLIBC_2.2.3)   is needed by gcc-4.6.2-glibc-2.13-linaro-multilib-2011.12-1
        libc.so.6(GLIBC_2.2.4)   is needed by gcc-4.6.2-glibc-2.13-linaro-multilib-2011.12-1
        libc.so.6(GLIBC_2.3)   is needed by gcc-4.6.2-glibc-2.13-linaro-multilib-2011.12-1
        libdl.so.2(GLIBC_2.0)   is needed by gcc-4.6.2-glibc-2.13-linaro-multilib-2011.12-1
        libdl.so.2(GLIBC_2.1)   is needed by gcc-4.6.2-glibc-2.13-linaro-multilib-2011.12-1
        libexpat.so.1   is needed by gcc-4.6.2-glibc-2.13-linaro-multilib-2011.12-1
        libm.so.6(GLIBC_2.0)   is needed by gcc-4.6.2-glibc-2.13-linaro-multilib-2011.12-1
        libncursesw.so.5   is needed by gcc-4.6.2-glibc-2.13-linaro-multilib-2011.12-1
        libz.so.1   is needed by gcc-4.6.2-glibc-2.13-linaro-multilib-2011.12-1
traceback:
 main::check_toolchain_setup:2554
  main::pre_build_checks:1453
   main:557
Started: Wed Sep 24 16:39:07 2014
Ended:   Wed Sep 24 16:40:19 2014
Elapsed: 72 seconds
Build Failed
Exiting on error or interrupt
环境为VMware10.0.3+ubuntu12.04
不明所以,求助!
我知道答案 目前已有1人回答
发表于 2015-4-2 09:35:13 | 显示全部楼层
use follow command to re-config toolchain.
$./ltib -m config
choose "ARM, gcc-4.4.4, multilib, neon optimized" instand of the default
"ARM, gcc-4.6.2, multilib, neon optimized, gnueabi/eglibc2.13".
GMT+8, 2025-10-29 20:16 , Processed in 0.076024 second(s), 22 queries , MemCache On.
