在线时间1 小时
UID3069336
注册时间2014-10-23
NXP金币0
- 15
- 1970-1-1
使用make imx6_android_defconfig配置的内核
驱动貌似也起来了,但是手动配置ip,ping不通,用netcfg eth0 dhcp显示超时
请问飞思卡尔的FAE这个驱动默认是可以用的么 ?我应该检查哪方面了?谢谢
[ 1.604229] imx-uart.3: ttymxc3 at MMIO 0x21f0000 (irq = 61) is a IMX
[ 1.611060] imx-uart.2: ttymxc2 at MMIO 0x21ec000 (irq = 60) is a IMX
[ 1.617879] imx-uart.1: ttymxc1 at MMIO 0x21e8000 (irq = 59) is a IMX
[ 1.624722] imx-uart.0: ttymxc0 at MMIO 0x2020000 (irq = 58) is a IMX
[ 1.631201] console [ttymxc0] enabled, bootconsole disabled
[ 1.649480] loop: module loaded
[ 1.654218] GPMI NAND driver registered. (IMX)
[ 1.659663] FEC Ethernet Driver
[ 1.665455] fec_enet_mii_bus: probed
[ 1.674851] PPP generic driver version 2.4.2
[ 1.679487] PPP Deflate Compression module registered
[ 1.684563] PPP BSD Compression module registered
[ 1.689707] PPP MPPE Compression module registered
[ 1.694521] NET: Registered protocol family 24
[ 1.698985] PPTP driver version 0.8.5
[ 1.702935] tun: Universal TUN/TAP device driver, 1.6
[ 1.708014] tun: (C) 1999-2004 Max Krasnyansky
[ 1.714698] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.721360] fsl-ehci fsl-ehci.0: Freescale On-Chip EHCI Host Controller
[ 1.728086] fsl-ehci fsl-ehci.0: new USB bus registered, assigned bus number 1
[ 1.764454] fsl-ehci fsl-ehci.0: irq 75, io base 0x02184000
[ 1.784435] fsl-ehci fsl-ehci.0: USB 2.0 started, EHCI 1.00
[ 1.790669] hub 1-0:1.0: USB hub found
[ 1.794456] hub 1-0:1.0: 1 port detected
[ 1.798717] add wake up source irq 72
[ 1.802425] fsl-ehci fsl-ehci.1: Freescale On-Chip EHCI Host Controller
[ 1.809083] fsl-ehci fsl-ehci.1: new USB bus registered, assigned bus number 2
[ 1.844444] fsl-ehci fsl-ehci.1: irq 72, io base 0x02184200
[ 1.864429] fsl-ehci fsl-ehci.1: USB 2.0 started, EHCI 1.00
[ 1.870612] hub 2-0:1.0: USB hub found
[ 1.874373] hub 2-0:1.0: 1 port detected
[ 1.878691] Initializing USB Mass Storage driver...
[ 1.883742] usbcore: registered new interface driver usb-storage
[ 1.889770] USB Mass Storage support registered.
[ 1.894751] usbcore: registered new interface driver usbserial
[ 1.900586] usbserial: USB Serial Driver core
[ 1.905079] USB Serial support registered for pl2303
[ 1.910183] usbcore: registered new interface driver pl2303
[ 1.915773] pl2303: Prolific PL2303 USB to serial adaptor driver
[ 1.921784] ARC USBOTG Device Controller driver (1 August 2005)
[ 1.931084] android_usb gadget: Mass Storage Function, version: 2009/09/11
[ 1.937985] android_usb gadget: Number of LUNs=1
[ 1.942607] lun0: LUN: removable file: (no medium)
[ 1.948014] Gadget Android: controller 'fsl-usb2-udc' not recognized
[ 1.954378] android_usb gadget: android_usb ready
[ 1.959100] Suspend udc for OTG auto detect
[ 1.966615] fsl-usb2-udc: bind to driver android_usb
[ 1.972139] mousedev: PS/2 mouse device common for all mice
[ 1.978198] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[ 1.986124] i2c-core: driver [isl29023] using legacy suspend method
[ 1.992394] i2c-core: driver [isl29023] using legacy resume method
[ 1.999782] using rtc device, snvs_rtc, for alarms
[ 2.004447] snvs_rtc snvs_rtc.0: rtc core: registered snvs_rtc as rtc0
[ 2.011311] i2c /dev entries driver
[ 2.015626] Linux video capture interface: v2.00
[ 2.068535] android_work: did not send uevent (0 0 (null))
[ 2.124616] ov5640_read_reg:write reg error:reg=300a
[ 2.129593] camera ov5640_mipi is not found
[ 2.134202] usbcore: registered new interface driver uvcvideo
[ 2.140078] USB Video Class driver (v1.1.0)
[ 2.144286] android_work: sent uevent USB_STATE=CONNECTED
[ 2.149894] mag3110 2-000e: check mag3110 chip ID
[ 2.154830] mag3110 2-000e: read chip ID 0xfffffffb is not equal to 0xc4!
[ 2.161643] mag3110: probe of 2-000e failed with error -22
[ 2.167255] i2c-core: driver [mag3110] using legacy suspend method
[ 2.173438] i2c-core: driver [mag3110] using legacy resume method
[ 2.180028] imx2-wdt imx2-wdt.0: IMX2+ Watchdog Timer enabled. timeout=60s (nowayout=1)
[ 2.188301] device-mapper: uevent: version 1.0.3
[ 2.193203] device-mapper: ioctl: 4.20.0-ioctl (2011-02-02) initialised: dm-devel@redhat.com
[ 2.201697] usb 2-1: new high speed USB device number 2 using fsl-ehci
[ 2.208554] sdhci: Secure Digital Host Controller Interface driver
[ 2.214771] sdhci: Copyright(c) Pierre Ossman
[ 2.219518] mmc0: SDHCI controller on platform [sdhci-esdhc-imx.3] using DMA
[ 2.229938] mmc1: SDHCI controller on platform [sdhci-esdhc-imx.2] using DMA
[ 2.242228] mmc2: SDHCI controller on platform [sdhci-esdhc-imx.1] using DMA
[ 2.249508] mxc_vdoa mxc_vdoa: i.MX Video Data Order Adapter(VDOA) driver probed
[ 2.259610] VPU initialized
[ 2.268425] mxc_asrc registered
[ 2.271742] Galcore version 4.6.9.9754
[ 2.317474] revserved_memory_account:viv_gpu registerd
[ 2.323329] Thermal calibration data is 0x5654ce69
[ 2.328137] Thermal sensor with ratio = 178
[ 2.344432] Anatop Thermal registered as thermal_zone0
[ 2.349733] anatop_thermal_probe: default cooling device is cpufreq!
[ 2.357296] usbcore: registered new interface driver usbhid
[ 2.362871] usbhid: USB HID core driver
[ 2.367271] hub 2-1:1.0: USB hub found
[ 2.367370] logger: created 256K log 'log_main'
[ 2.367580] logger: created 256K log 'log_events'
[ 2.367790] logger: created 256K log 'log_radio'
[ 2.368004] logger: created 256K log 'log_system'
[ 2.389953] hub 2-1:1.0: 4 ports detected
[ 2.432202] mmc0: new high speed DDR MMC card at address 0001
[ 2.438385] mmcblk0: mmc0:0001 SEM08G 7.39 GiB
[ 2.443108] mmcblk0boot0: mmc0:0001 SEM08G partition 1 2.00 MiB
[ 2.449233] mmcblk0boot1: mmc0:0001 SEM08G partition 2 2.00 MiB
[ 2.459224] mmcblk0: p1 p2 p3 < p5 p6 p7 p8 p9 > p4
[ 2.468243] mmcblk0boot1: unknown partition table
[ 2.475196] mmcblk0boot0: unknown partition table
[ 2.665637] android_work: sent uevent USB_STATE=DISCONNECTED
[ 2.694745] usb 2-1.1: new high speed USB device number 3 using fsl-ehci
[ 2.724743] rt5621 0-001a: Failed to add route HPOUTL->Headphone Jack
[ 2.733374] android_work: sent uevent USB_STATE=CONNECTED
[ 2.740950] android_work: sent uevent USB_STATE=DISCONNECTED
[ 2.747883] asoc: rt5621-hifi imx-ssi.1 mapping ok
[ 2.758009] ALSA device list:
[ 2.762996] #0: alc5621-audio
[ 2.768587] oprofile: using arm/armv7-ca9
[ 2.775731] GACT probability NOT on
[ 2.779228] Mirror/redirect action on
[ 2.782892] u32 classifier
[ 2.785618] Actions configured
[ 2.789023] Netfilter messages via NETLINK v0.30.
[ 2.793766] nf_conntrack version 0.5.0 (12999 buckets, 51996 max)
[ 2.804094] ctnetlink v0.93: registering with nfnetlink.
[ 2.809467] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
[ 2.816580] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
[ 2.825155] xt_time: kernel timezone is -0000
[ 2.831560] IPv4 over IPv4 tunneling driver
[ 2.836339] GRE over IPv4 demultiplexor driver
[ 2.840736] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 2.848424] arp_tables: (C) 2002 David S. Miller
[ 2.855144] TCP cubic registered
[ 2.860543] NET: Registered protocol family 10
[ 2.867865] Mobile IPv6
[ 2.872357] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 2.877917] IPv6 over IPv4 tunneling driver
[ 2.883377] NET: Registered protocol family 17
[ 2.889916] NET: Registered protocol family 15
[ 2.896398] L2TP core driver, V2.0
[ 2.901895] PPPoL2TP kernel driver, V2.0
[ 2.907875] android_work: sent uevent USB_STATE=CONNECTED
[ 2.915427] L2TP IP encapsulation support (L2TPv3)
[ 2.920259] L2TP netlink interface
[ 2.923677] L2TP ethernet pseudowire support (L2TPv3)
[ 2.928756] lib80211: common routines for IEEE802.11 drivers
[ 2.934469] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
[ 2.942341] Bus freq driver module loaded
[ 2.946372] Bus freq driver Enabled
[ 2.951872] DVFS driver module loaded
[ 2.963727] GTP driver installing...
[ 2.968777] GTP Driver Version: V2.2
[ 2.976733] GTP Driver Built@15:28:09, Oct 16 2014
[ 2.984855] GTP I2C Address: 0x5d
[ 2.991488] Failed to request GPIO:204, ERRNO:-16
[ 2.999610] Guitar reset
[ 3.135331] hub 2-1:1.0: unable to enumerate USB device on port 1
[ 3.142293] IC Version: 911_1050
[ 3.199319] cX_MAX: 600, Y_MAX: 1024, TRIGGER: 0x01
[ 3.224462] create proc entry gt9xx_config success
[ 3.230863] input: goodix-ts as /devices/virtual/input/input1
[ 3.236979] Request IRQ failed!ERRNO:-22.
[ 3.244465] GTP works in polling mode.
[ 3.255583] Applied memory size:2562.
[ 3.265692] I2C function: without pre and end cmd!
[ 3.273836] Create proc entry success!
[ 3.281101] snvs_rtc snvs_rtc.0: setting system clock to 1970-01-02 00:21:24 UTC (87684)
[ 3.291786] Freeing init memory: 228K
[ 4.073094] init: cannot find '/system/bin/dbus-daemon', disabling 'dbus'
[ 4.080511] init: cannot find '/system/etc/install-recovery.sh', disabling 'flash_recovery'
[ 4.149101] android_work: sent uevent USB_STATE=DISCONNECTED
[ 4.186743] android_usb: already disabled
[ 4.190999] mtp_bind_config
[ 4.193847] adb_bind_config
[ 4.199598] adb_open
[ 4.216404] android_work: sent uevent USB_STATE=CONNECTED
[ 4.222196] android_work: sent uevent USB_STATE=DISCONNECTED
[ 4.244769] usb 2-1.1: new high speed USB device number 4 using fsl-ehci
root@sabresd_6dq:/ # [ 4.387335] android_work: sent uevent USB_STATE=CONNECTED
[ 4.415453] android_usb gadget: high speed config #1: android
[ 4.423809] android_work: sent uevent USB_STATE=CONFIGURED
[ 9.399048] warning: `rild' uses 32-bit capabilities (legacy support in use)
[ 14.338625] request_suspend_state: wakeup (3->0) at 14114222003 (1970-01-02 00:21:35.550426335 UTC)
[ 14.348093] cpufreq_interactive_input_connect: connect to goodix-ts
[ 14.784198] eth0: Freescale FEC PHY driver [Generic PHY] (mii_bus:phy_addr=1:01, irq=-1)
[ 14.794281] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 15.133629] acc_open
[ 15.135872] acc_release
[ 17.833722] mtp_open
[ 19.238350] cdc_acm 2-1.1:1.0: This device cannot do calls on its own. It is not a modem.
[ 19.249024] cdc_acm 2-1.1:1.0: ttyACM0: USB ACM device
[ 19.257076] cdc_acm 2-1.1:1.2: This device cannot do calls on its own. It is not a modem.
[ 19.268031] cdc_acm 2-1.1:1.2: ttyACM1: USB ACM device
[ 19.275518] cdc_acm 2-1.1:1.4: This device cannot do calls on its own. It is not a modem.
[ 19.286016] cdc_acm 2-1.1:1.4: ttyACM2: USB ACM device
[ 19.295022] cdc_acm 2-1.1:1.6: This device cannot do calls on its own. It is not a modem.
[ 19.305528] cdc_acm 2-1.1:1.6: ttyACM3: USB ACM device
[ 19.318920] cdc_acm 2-1.1:1.8: This device cannot do calls on its own. It is not a modem.
[ 19.329906] cdc_acm 2-1.1:1.8: ttyAC***: USB ACM device
[ 19.353323] cdc_acm 2-1.1:1.10: This device cannot do calls on its own. It is not a modem.
[ 19.364522] cdc_acm 2-1.1:1.10: ttyACM5: USB ACM device
[ 19.371744] cdc_acm 2-1.1:1.12: This device cannot do calls on its own. It is not a modem.
[ 19.393766] cdc_acm 2-1.1:1.12: ttyACM6: USB ACM device
[ 19.402374] usbcore: registered new interface driver cdc_acm
[ 19.408124] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 19.472314] init: sys_prop: permission denied uid:1003 name:service.bootanim.exit
[ 22.774679] PHY: 1:01 - Link is Up - 100/Full
[ 22.779375] ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
root@sabresd_6dq:/ # [ 30.078185] request_suspend_state: sleep (0->3) at 29853774673 (1970-01-02 00:21:51.289978671 UTC)
[ 30.087198] System suspend.
[ 30.091314] ------------[ cut here ]------------
[ 30.095951] WARNING: at drivers/gpio/gpiolib.c:101 gpio_ensure_requested+0x54/0x1b0()
[ 30.103784] autorequest GPIO-204
[ 30.107012] Modules linked in: cdc_acm printer
[ 30.111528] [] (unwind_backtrace+0x0/0x138) from [] (warn_slowpath_common+0x4c/0x64)
[ 30.121035] [] (warn_slowpath_common+0x4c/0x64) from [] (warn_slowpath_fmt+0x30/0x40)
[ 30.130627] [] (warn_slowpath_fmt+0x30/0x40) from [] (gpio_ensure_requested+0x54/0x1b0)
[ 30.140396] [] (gpio_ensure_requested+0x54/0x1b0) from [] (gpio_direction_output+0xa8/0x2b8)
[ 30.150617] [] (gpio_direction_output+0xa8/0x2b8) from [] (goodix_ts_early_suspend+0x50/0xe8)
[ 30.160914] [] (goodix_ts_early_suspend+0x50/0xe8) from [] (early_suspend+0xc0/0x170)
[ 30.170508] [] (early_suspend+0xc0/0x170) from [] (process_one_work+0x12c/0x494)
[ 30.179661] [] (process_one_work+0x12c/0x494) from [] (worker_thread+0x170/0x3cc)
[ 30.188912] [] (worker_thread+0x170/0x3cc) from [] (kthread+0x80/0x88)
[ 30.197213] [] (kthread+0x80/0x88) from [] (kernel_thread_exit+0x0/0x8)
[ 30.205583] ---[ end trace f3963dcf45781e41 ]---
[ 30.234939] GTP enter sleep!
root@sabresd_6dq:/ # b[ 33.278904] init: untracked pid 3514 exited
[ 33.288262] init: untracked pid 3515 exited
root@sabresd_6dq:/ # busybox [ 34.298339] init: untracked pid 3516 exited
ifcon[ 35.318526] init: untracked pid 3518 exited
fig
eth0 Link encap:Ethernet HWaddr 1E:ED:19:27:1A:B3
inet6 addr: fe80::1ced:19ff:fe27:1ab3/64 Scope ink
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 B) TX bytes:1494 (1.4 KiB)
lo Link encap ocal Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:16436 Metric:1
RX packets:397 errors:0 dropped:0 overruns:0 frame:0
TX packets:397 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:96666 (94.4 KiB) TX bytes:96666 (94.4 KiB)
root@sabresd_6dq:/ # ifc[ 39.550959] init: untracked pid 3565 exited
onfig[ 40.128933] init: untracked pid 3577 exited
acct/ init seapp_contexts
cache/ init.freescale.rc selinux/
config/ init.freescale.usb.rc sepolicy
d/ init.rc storage/
data/ init.trace.rc sys/
default.prop init.usb.rc system/
dev/ mnt/ udisk/
device/ proc/ ueventd.freescale.rc
etc/ property_contexts ueventd.rc
extsd/ root/ vendor/
file_contexts sbin/
fstab.freescale sdcard/
root@sabresd_6dq:/ # ifconfig eth0 192.168.1.128
root@sabresd_6dq:/ # ping 192.168.1.130
PING 192.168.1.130 (192.168.1.130) 56(84) bytes of data.
From 192.168.1.128: icmp_seq=1 Destination Host Unreachable
From 192.168.1.128: icmp_seq=2 Destination Host Unreachable
From 192.168.1.128: icmp_seq=3 Destination Host Unreachable
^C
--- 192.168.1.130 ping statistics ---
6 packets transmitted, 0 received, +3 errors, 100% packet loss, time 5001ms
, pipe 4
1|root@sabresd_6dq:/ #
