在线时间1 小时
UID2070848
注册时间2014-1-20
NXP金币0
- 20
- 1970-1-1
[color=#*********]Hi all,
I meet a problem. In my customer board, referenced from sabreauto-ai board, the eth0 link is not ready. could some one give me some advice? I really confused for some days. the log is as below:
====log below======
root@sabreauto_6q:/ # eth0: Freescale FEC PHY driver [Generic PHY] (mii_bus:phy_addr=1:01, irq=-1)
ADDRCONF(NETDEV_UP): eth0: link is not ready
====log end========
when I input "busybox ifconfig", it print log as below:
root@sabreauto_6q:/ # busybox ifconfig
eth0 Link encap:Ethernet HWaddr 1E:ED:19:27:1A:B3
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
lo Link encap ocal Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:16436 Metric:1
collisions:0 txqueuelen:0
it seems that no ip address is obtained.
However, If I use FSL official Sabreauto-AI referenced board with the same internet wire, it is ok and the board can access internet normally. log is as below:
acc_open
acc_release
init: sys_prop: permission denied uid:1003 name:service.bootanim.exit
PHY: 1:01 - Link is Up - 100/Full
ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
PHY: 1:01 - Link is Down
binder: 2886:2895 refcount change on invalid ref 34
eth0 Link encap:Ethernet HWaddr 00:04:9F:03:0C:C9
inet addr:192.168.2.123 Bcast:192.168.2.255 Mask:255.255.255.0
inet6 addr: fe80::204:9fff:fe03:cc9/64 Scope ink
RX packets:57 errors:0 dropped:0 overruns:0 frame:0
TX packets:61 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:10645 (10.3 KiB) TX bytes:5835 (5.6 KiB)
compared with official referened board, my customer board cannot print the log in red. we have not changed ethnet module, it follows offcial referenced board. could you give some advices please? Any advices are appreciated.. thx a lot.
