查看: 5400|回复: 1
[求助] 重新编译MFGTOOLS工具使用的U-BOOT和KERNEL时候报错
发表于 2014-10-30 13:56:31 | 显示全部楼层 |阅读模式
按照手册生成MFGTOOLS工具的时候,报的错误。
./ltib --profile config/platform/imx/updater.profile --preconfig config/platform/imx/
imx6q_updater.cf --continue --batch
报错信息如下:
Processing: u-boot-v2009.08
Build path taken because: directory build, build key set, no prebuilt rpm,
rpmbuild --dbpath /home/vmuser/imx6/L3.0.35_4.1.0_130816_source/source_liu/ltib/rootfs//var/lib/rpm --target arm --define '_unpackaged_files_terminate_build 0' --define '_target_cpu arm' --define '__strip strip' --define '_topdir /home/vmuser/imx6/L3.0.35_4.1.0_130816_source/source_liu/ltib/rpm' --define '_prefix /usr' --define '_tmppath /home/vmuser/imx6/L3.0.35_4.1.0_130816_source/source_liu/ltib/tmp' --define '_rpmdir /home/vmuser/imx6/L3.0.35_4.1.0_130816_source/source_liu/ltib/rpm/RPMS'  --define '_mandir /usr/share/man' --define '_sysconfdir /etc' --define '_localstatedir /var' -bc --short-circuit  /home/vmuser/imx6/L3.0.35_4.1.0_130816_source/source_liu/ltib/tmp/u-boot-v2009.08.spec
Building target platforms: arm
Building for target arm
Executing(%build): /bin/sh -e /home/vmuser/imx6/L3.0.35_4.1.0_130816_source/source_liu/ltib/tmp/rpm-tmp.36866
+ umask 022
+ cd /home/vmuser/imx6/L3.0.35_4.1.0_130816_source/source_liu/ltib/rpm/BUILD
+ cd u-boot-2009.08
+ : mx6q_sabresd_mfg_config
+ eval echo
+ echo
+ PKG_U_BOOT_PATH_PRECONFIG=
+ SRC_DIR=/home/vmuser/imx6/L3.0.35_4.1.0_130816_source/source_liu/ltib/rpm/BUILD/u-boot-2009.08
+ BUILD_DIR=/home/vmuser/imx6/L3.0.35_4.1.0_130816_source/source_liu/ltib/rpm/BUILD/u-boot-2009.08
+ [ /home/vmuser/imx6/L3.0.35_4.1.0_130816_source/source_liu/ltib/rpm/BUILD/u-boot-2009.08 != /home/vmuser/imx6/L3.0.35_4.1.0_130816_source/source_liu/ltib/rpm/BUILD/u-boot-2009.08 ]
+ cd /home/vmuser/imx6/L3.0.35_4.1.0_130816_source/source_liu/ltib/rpm/BUILD/u-boot-2009.08
+ [ -n  ]
+ make HOSTCC=ccache /usr/bin/gcc -B/usr/bin/ CROSS_COMPILE=arm-none-linux-gnueabi- O=/home/vmuser/imx6/L3.0.35_4.1.0_130816_source/source_liu/ltib/rpm/BUILD/u-boot-2009.08 mx6q_sabresd_mfg_config
Configuring for mx6q_sabresd_mfg board...
rm: cannot remove `asm-arm/proc': Is a directory
make: *** [mx6q_sabresd_mfg_config] Error 1
error: Bad exit status from /home/vmuser/imx6/L3.0.35_4.1.0_130816_source/source_liu/ltib/tmp/rpm-tmp.36866 (%build)
RPM build errors:
Build time for u-boot-v2009.08: 0 seconds
Failed building u-boot-v2009.08
Processing: kernel-3.0.35
Processing: skell
Processing: base_libs
Processing: busybox
checking if sources have been updated: no
Processing: libtermcap
Processing: zlib
Processing: ncurses
Processing: newfs_msdos
Processing: e2fsprogs
Processing: procps
Processing: util-linux
Processing: hotplug
Processing: lzo
Processing: mtd-utils
Processing: udev
Processing: kobs-ng
Processing: uuc
Processing: sysconfig-mx
Processing: merge
Processing: modeps
f_buildrpms() returned an error, exiting
traceback:
main:572
Started: Thu Oct 30 13:47:37 2014
Ended:   Thu Oct 30 13:47:39 2014
Elapsed: 2 seconds
These packages failed to build:
u-boot-v2009.08
Build Failed
Exiting on error or interrupt
我知道答案 目前已有1人回答
发表于 2014-10-31 09:28:45 | 显示全部楼层
楼主你好,请问你编译前是否将LTIB环境清空呢?
在文档中有说明的:
Keep the LTIB environment clean before you begin to configure and build the firmware.
Then, set up the LTIB environment and configure the file ./config/platform/imx/
imx6q_updater.cf to specify the target firmware.
GMT+8, 2026-4-15 21:25 , Processed in 0.081669 second(s), 23 queries , Redis On.
