12
返回列表 发新帖
楼主: spartanc
[求助] HDMI 輸出不能全屏
发表于 2014-11-5 14:36:07 | 显示全部楼层
spartanc 发表于 2014-11-5 13:49
Hi
剛試了一下, 把fbmem=28M
不會崩潰, 但沒畫面,
fbmem=28M可以,不要0。能正常显示说明就OK的了。
发表于 2014-11-5 14:36:55 | 显示全部楼层
欢迎楼主有问题继续在本论坛中交流讨论哈~~
 楼主| 发表于 2014-11-5 15:13:31 | 显示全部楼层
您好
不加0M HDMI會無輸出. 需要fbmem=0M,28M 這樣才有畫面輸出.
等等再試試
謝謝囉
发表于 2014-11-5 17:11:22 | 显示全部楼层
spartanc 发表于 2014-11-5 15:13
您好
我这边试过:
bootargs=console=ttymxc0,115200 init=/init video=mxcfb0:dev=hdmi,1920x1080M@60,bpp=32 video=mxcfb1ff video=mxcfb2ff fbmem=28M androidboot.console=ttymxc0 vmalloc=400M androidboot.hardware=freescale
是显示OK的。建议你再试一下哈。
发表于 2014-11-5 17:11:44 | 显示全部楼层
建议你再试试看哈,有问题再给我回复~~
 楼主| 发表于 2014-11-5 17:41:05 | 显示全部楼层
真怪, 還是不行.
kernel log會一直顯示hdmi cable插上然後拔掉
root@sabresd_6dq:/ #
root@sabresd_6dq:/ # [  179.179191] mxc_hdmi mxc_hdmi: Hotplug interrupt received
[  179.198183] mxc_hdmi mxc_hdmi: phy_int_stat=0x3d, phy_int_pol=0x0
[  179.204549] mxc_hdmi mxc_hdmi: EVENT=plugout
[  179.216507] mxc_hdmi mxc_hdmi: mxc_hdmi_cable_disconnected
[  179.222433] mxc_hdmi mxc_hdmi: mxc_hdmi_phy_disable
[  179.227535] hdmi_disable_overflow_interrupts
[  179.375353] mxc_hdmi mxc_hdmi: Hotplug interrupt received
[  179.388287] mxc_hdmi mxc_hdmi: phy_int_stat=0x3d, phy_int_pol=0x2
[  179.397719] mxc_hdmi mxc_hdmi: EVENT=plugin
[  179.401982] mxc_hdmi mxc_hdmi: mxc_hdmi_cable_connected
[  179.411840] mxc_hdmi mxc_hdmi: mxc_hdmi_read_edid
[  179.444504] cea extent revision 3
[  179.447885] CEA underscan 1
[  179.450754] CEA basicaudio 1
[  179.453750] CEA ycbcr444 1
[  179.456515] CEA ycbcr422 1
[  179.459298] CEA Short desc timmings
[  179.462849] Tagcode 2 Len 15
[  179.465844] Support CEA Format #1
[  179.469234] Support CEA Format #2
[  179.472610] Support CEA Format #3
[  179.475986] Support CEA Format #4
[  179.479425] Support CEA Format #5
[  179.482801] Support CEA Format #6
[  179.486176] Support CEA Format #7
[  179.489761] Support CEA Format #16
[  179.493223] Support CEA Format #17
[  179.496685] Support CEA Format #18
[  179.500155] Support CEA Format #19
[  179.503671] Support CEA Format #20
[  179.507131] Support CEA Format #31
[  179.510601] Tagcode 1 Len 3
[  179.513509] Audio Format Descriptor :  1
[  179.517491] Max Number of Channels  :  2
[  179.521505] Sample Rates            : 07
[  179.525540] Sample Sizes            : 07
[  179.529540] Tagcode 4 Len 3
[  179.532395] Speaker Alloc           : 01
[  179.536431] Tagcode 3 Len 7
[  179.539295] VSD hdmi capability 1
[  179.542669] VSD support ai 0
[  179.545608] VSD support deep color 48bit 0
[  179.549827] VSD support deep color 36bit 1
[  179.553983] VSD support deep color 30bit 1
[  179.558148] VSD support deep color y444 1
[  179.562271] VSD support dvi dual 0
[  179.565732] VSD MAX TMDS CLOCK RATE 225
[  179.569656] CEA long desc timmings
[  179.573175] Aspect ratio: 16:9
[  179.576290]       148 MHz 1920 2008 2052 2200 1080 1084 1089 1125 +HSync +VSync
[  179.582516]
[  179.585494] Aspect ratio: 16:9
[  179.588760]       74 MHz 1920 2008 2052 2200 540 542 547 562 +HSync +VSync
[  179.594543]
[  179.597519] Aspect ratio: 16:9
[  179.600645]       74 MHz 1280 1390 1430 1650 720 725 730 750 +HSync +VSync
[  179.606427]
[  179.609413] Aspect ratio: 16:9
[  179.612528]       27 MHz 720 736 798 858 480 489 495 525 -HSync -VSync
[  179.617964]
[  179.620964] mxc_hdmi mxc_hdmi: same edid
[  179.624950] mxc_hdmi mxc_hdmi: mxc_hdmi_set_mode
[  179.629653] fb_videomode = 60 1920 1080 6734 148 88 36 4 44 5 3 32 32
[  179.636214] mxc_hdmi mxc_hdmi: mxc_hdmi_set_mode: Video mode same as previous
[  179.643476] mxc_hdmi mxc_hdmi: mxc_hdmi_setup
[  179.647899] fb_videomode = 60 1920 1080 6734 148 88 36 4 44 5 3 32 32
[  179.654465] mxc_hdmi mxc_hdmi: mxc_hdmi_setup - video mode changed
[  179.660715] edid mode
[  179.662965] fb_videomode = 60 1920 1080 6734 148 88 36 4 44 5 3 32 2
[  179.669696] hdmi_disable_overflow_interrupts
[  179.674032] mxc_hdmi mxc_hdmi: CEA mode used vic=16
[  179.679078] mxc_hdmi mxc_hdmi: hdmi_av_composer
[  179.683713] mxc_hdmi mxc_hdmi: final pixclk = 148500000
[  179.689217] mxc_hdmi mxc_hdmi: hdmi_av_composer exit
[  179.694246] mxc_hdmi mxc_hdmi: mxc_hdmi_phy_init
[  179.698936] mxc_hdmi mxc_hdmi: mxc_hdmi_enable_video_path
[  179.704462] mxc_hdmi mxc_hdmi: mxc_hdmi_setup CEA mode
[  179.709675] hdmi_set_clk_regenerator: samplerate=48000  ratio=100  pixelclk=148500000  N=6144  cts=148500
[  179.719382] mxc_hdmi mxc_hdmi: hdmi_enable_audio_clk
[  179.724487] mxc_hdmi mxc_hdmi: set up AVI frame
[  179.729154] mxc_hdmi mxc_hdmi: mxc_hdmi_disable_pins
[  179.734185] hdmi_enable_overflow_interrupts
[  179.738501] mxc_hdmi mxc_hdmi: mxc_hdmi_setup exit
[  179.738505]
[  179.744903] mxc_hdmi mxc_hdmi: mxc_hdmi_cable_connected exit
root@sabresd_6dq:/ # [  184.465394] mxc_hdmi mxc_hdmi: Hotplug interrupt received
[  184.478142] mxc_hdmi mxc_hdmi: phy_int_stat=0x3d, phy_int_pol=0x0
[  184.484354] mxc_hdmi mxc_hdmi: EVENT=plugout
[  184.494655] mxc_hdmi mxc_hdmi: mxc_hdmi_cable_disconnected
[  184.500421] mxc_hdmi mxc_hdmi: mxc_hdmi_phy_disable
[  184.505377] hdmi_disable_overflow_interrupts
[  184.588599] mxc_hdmi mxc_hdmi: Hotplug interrupt received
[  184.608197] mxc_hdmi mxc_hdmi: phy_int_stat=0x3d, phy_int_pol=0x2
[  184.617688] mxc_hdmi mxc_hdmi: EVENT=plugin
[  184.622102] mxc_hdmi mxc_hdmi: mxc_hdmi_cable_connected
[  184.631982] mxc_hdmi mxc_hdmi: mxc_hdmi_read_edid
[  184.665986] cea extent revision 3
[  184.669424] CEA underscan 1
[  184.672301] CEA basicaudio 1
[  184.675325] CEA ycbcr444 1
[  184.678123] CEA ycbcr422 1
[  184.680918] CEA Short desc timmings
[  184.684487] Tagcode 2 Len 15
[  184.687524] Support CEA Format #1
[  184.690919] Support CEA Format #2
[  184.694305] Support CEA Format #3
[  184.697699] Support CEA Format #4
[  184.701413] Support CEA Format #5
[  184.704852] Support CEA Format #6
[  184.708263] Support CEA Format #7
[  184.711879] Support CEA Format #16
[  184.715345] Support CEA Format #17
[  184.718825] Support CEA Format #18
[  184.722289] Support CEA Format #19
[  184.725816] Support CEA Format #20
[  184.729291] Support CEA Format #31
[  184.732754] Tagcode 1 Len 3
[  184.735661] Audio Format Descriptor :  1
[  184.739657] Max Number of Channels  :  2
[  184.743639] Sample Rates            : 07
[  184.747674] Sample Sizes            : 07
[  184.751667] Tagcode 4 Len 3
[  184.754521] Speaker Alloc           : 01
[  184.758563] Tagcode 3 Len 7
[  184.761416] VSD hdmi capability 1
[  184.764789] VSD support ai 0
[  184.767729] VSD support deep color 48bit 0
[  184.771946] VSD support deep color 36bit 1
[  184.776104] VSD support deep color 30bit 1
[  184.780272] VSD support deep color y444 1
[  184.784395] VSD support dvi dual 0
[  184.787856] VSD MAX TMDS CLOCK RATE 225
[  184.791758] CEA long desc timmings
[  184.795276] Aspect ratio: 16:9
[  184.798530]       148 MHz 1920 2008 2052 2200 1080 1084 1089 1125 +HSync +VSync
[  184.804798]
[  184.807720] Aspect ratio: 16:9
[  184.810850]       74 MHz 1920 2008 2052 2200 540 542 547 562 +HSync +VSync
[  184.816683]
[  184.819616] Aspect ratio: 16:9
[  184.822767]       74 MHz 1280 1390 1430 1650 720 725 730 750 +HSync +VSync
[  184.828617]
[  184.831543] Aspect ratio: 16:9
[  184.834661]       27 MHz 720 736 798 858 480 489 495 525 -HSync -VSync
[  184.840110]
[  184.843054] mxc_hdmi mxc_hdmi: same edid
[  184.847041] mxc_hdmi mxc_hdmi: mxc_hdmi_set_mode
[  184.851738] fb_videomode = 60 1920 1080 6734 148 88 36 4 44 5 3 32 32
[  184.858304] mxc_hdmi mxc_hdmi: mxc_hdmi_set_mode: Video mode same as previous
[  184.865555] mxc_hdmi mxc_hdmi: mxc_hdmi_setup
[  184.869986] fb_videomode = 60 1920 1080 6734 148 88 36 4 44 5 3 32 32
[  184.876547] mxc_hdmi mxc_hdmi: mxc_hdmi_setup - video mode changed
[  184.882801] edid mode
[  184.885050] fb_videomode = 60 1920 1080 6734 148 88 36 4 44 5 3 32 2
[  184.891770] hdmi_disable_overflow_interrupts
[  184.896105] mxc_hdmi mxc_hdmi: CEA mode used vic=16
[  184.901243] mxc_hdmi mxc_hdmi: hdmi_av_composer
[  184.905837] mxc_hdmi mxc_hdmi: final pixclk = 148500000
[  184.911199] mxc_hdmi mxc_hdmi: hdmi_av_composer exit
[  184.916226] mxc_hdmi mxc_hdmi: mxc_hdmi_phy_init
[  184.920936] mxc_hdmi mxc_hdmi: mxc_hdmi_enable_video_path
[  184.926461] mxc_hdmi mxc_hdmi: mxc_hdmi_setup CEA mode
[  184.931677] hdmi_set_clk_regenerator: samplerate=48000  ratio=100  pixelclk=148500000  N=6144  cts=148500
[  184.941385] mxc_hdmi mxc_hdmi: hdmi_enable_audio_clk
[  184.946467] mxc_hdmi mxc_hdmi: set up AVI frame
[  184.951131] mxc_hdmi mxc_hdmi: mxc_hdmi_disable_pins
[  184.956215] hdmi_enable_overflow_interrupts
[  184.960476] mxc_hdmi mxc_hdmi: mxc_hdmi_setup exit
[  184.960480]
[  184.966878] mxc_hdmi mxc_hdmi: mxc_hdmi_cable_connected exit
发表于 2014-11-7 10:53:54 | 显示全部楼层
spartanc 发表于 2014-11-5 17:41
真怪, 還是不行.
楼主,请问你板子上跑的Images是你自己编译的还是官网的Demo?
 楼主| 发表于 2014-11-7 13:11:53 | 显示全部楼层
自己編譯的image.
发表于 2014-11-10 11:03:45 | 显示全部楼层
楼主你好,请问你这里是不是需要设置:fbmem=0M,28M ,然后就可以正常工作了呢?
 楼主| 发表于 2014-11-10 13:36:25 | 显示全部楼层
FSL_TICS_Rita
是的, 只要fbmem=0M, 28M就可以正常工作了
GMT+8, 2025-11-2 01:16 , Processed in 0.251060 second(s), 29 queries , MemCache On.
