查看: 9581|回复: 7
[求助] 自主开发板iMX287NANDFLASH烧写问题求教_mfgtools
发表于 2014-11-7 14:35:33 | 显示全部楼层 |阅读模式
有没有大神帮我看一下我遇到的问题:
       我基于iMX287设计了一款板子,NANDFLASH用的是K9F1GU08D,在用mfgtools烧写boot文件时遇到了问题
mfgtools提示更新错误,
1、下面是mfgtool.log的信息:
Friday, November 07, 2014 13:43:22
1 - Panel A Start processing NAND <LIST/>. 1 - Panel A Start <CMD/> type="boot" body="Recovery" file="uce_ivt.sb" timeout="10" text="Booting Update Client Engine.". 1 - Panel A Finished <CMD/> type="boot" body="Recovery" file="uce_ivt.sb" timeout="10" text="Booting Update Client Engine." SUCCESS code=0. 1 - Panel A Start <CMD/> type="find" body="Updater" file="" timeout="180" text="". 1 - Panel A Finished <CMD/> type="find" body="Updater" file="" timeout="180" text="" FAIL code=-65536. Panel A: 2 - Panel A Finished processing NAND <LIST/> : FAIL code=-65536.
2、这是我烧写imx28wince时的串口打印消息
HTLLCBATT:0.44V5ULLCBSP Clock Configuration:    PLL0        =  480000000 Hz    PLL1        =  480000000 Hz    PLL2        =          0 Hz    REF_CPU     =  480000000 Hz    REF_EMI     =  392727272 Hz    REF_IO0     =  480000000 Hz    REF_IO1     =  480000000 Hz    REF_PIX     =  480000000 Hz    REF_HSADC   =  480000000 Hz    REF_GPMI    =  480000000 Hz    REF_PLL     =  480000000 Hz    REF_XTAL    =   24000000 Hz    REF_ENET_PLL=          0 Hz    P_CLK       =  240000000 Hz    H_CLK       =  120000000 Hz    X_CLk       =   24000000 Hz    ETM         =   24000000 Hz    EMI         =  196363636 Hz    SSP0        =   24000000 Hz    SSP1        =   24000000 Hz    SSP2        =   24000000 Hz    SSP3        =   24000000 Hz    GPMI        =   24000000 Hz    HSADC       =   26666666 Hz    LCDIF       =   24000000 Hz    SPDIF       =  120000000 Hz    UTMI0       =  480000000 Hz    UTMI1       =  480000000 Hz    UART24MHZ   =   24000000 Hz    PWM24MHZ    =   24000000 Hz    TIMROT32K   =      32000 HzWindows CE Kernel for ARM (Thumb Enabled) Built on Jul  6 2010 at 14:10:31INFO:OALLogSetZones: dpCurSettings.ulZoneMask: 0xbOALInitCpuHclkClock:Update CPU clock to 454MHz!WARN: Boot arguments not found, use defaults
DeviceId................. MX280
pArgs->flags............. 0xC
pArgs->devLoc.IfcType.... 0
pArgs->devLoc.LogicalLoc. 0x80080000
pArgs->devLoc.PhysicalLoc 0x80080000
pArgs->devLoc.Pin........ 0
pArgs->ip4address........ 0
pDevice->Name............  s
pDevice->ifcType......... 0
pDevice->id.............. 0x80080000
pDevice->resource........ 0
pDevice->type............ 2
pDevice->pDriver......... 0x8048902C
WARN: OALKitlInit: KITL Disabled
reset GPMI moduleenable bch moduleERROR: F:\WINCE600_2\PLATFORM\COMMON\SRC\SOC\COMMON_FSL_V2\NAND\FMDCOMMON\BIG_SECTOR_INTERLEAVE\.\fmd.cpp line 208: No NAND type matched!BOT_InternalInit with Drivers\Active\06UFN_ATTACH with key = Drivers\Active\06
我知道答案 目前已有7人回答
发表于 2014-11-10 09:28:10 | 显示全部楼层
楼主你好,请问你使用的是Linux的BSP还是Wince的BSP呢?
发表于 2014-11-10 09:29:01 | 显示全部楼层
还有你的板子是参考飞思卡尔开发板设计的吗?设计和开发板有哪里不一样?
 楼主| 发表于 2014-11-17 13:06:42 | 显示全部楼层
FSL_TICS_Rita 发表于 2014-11-10 09:29
还有你的板子是参考飞思卡尔开发板设计的吗?设计和开发板有哪里不一样? ...
你好,我用的是wince的BSP,我的板子是参考freescale的iMX28 EVK开发板设计的,另外,我用freescale开发板烧写时也出现了同样的问题,是不是不支持这款NANDFLASH,还是别的原因?
发表于 2014-11-18 15:51:05 | 显示全部楼层
taihejiankang 发表于 2014-11-17 13:06
你好,我用的是wince的BSP,我的板子是参考freescale的iMX28 EVK开发板设计的,另外,我用freescale开发 ...
楼主你好,请问你使用SD卡的话可以正常烧写和启动吗?
 楼主| 发表于 2014-11-20 10:26:58 | 显示全部楼层
我是时博,你之前来过我们公司,你当时用SD卡试了,烧写lunix是没问题的啊
发表于 2014-11-20 15:49:17 | 显示全部楼层
taihejiankang 发表于 2014-11-20 10:26
我是时博,你之前来过我们公司,你当时用SD卡试了,烧写lunix是没问题的啊 ...
请问你开发板上的NAND用的是哪个呢?
发表于 2014-11-20 15:50:12 | 显示全部楼层
估计是别的同事去的。
GMT+8, 2026-4-14 02:02 , Processed in 0.094728 second(s), 29 queries , Redis On.
