查看: 5060|回复: 8
[已解决] ubuntu 14.04编译P4080PCIE的BSP出现错误,求解呀(已解决)
发表于 2014-11-9 11:40:07 | 显示全部楼层 |阅读模式
电脑安装的是ubuntu 14.04 LTS, 在编译P4080 PCIE 的BSP 的时候出现很多未定义:
+ echo 'Patch #5 (cst-b2.3-Cleanup.-Removed-unused-files-sg_sign-and-sign_es.patch):'
+ patch -p1 -s
+ echo 'Patch #6 (cst-b2.3-Updated-the-command-sign-and-gen_keys.patch):'
+ patch -p1 -s
+ exit 0
Executing(%build): /bin/sh -e /home/i/PCIE/ltib-e500mc-20110415/tmp/rpm-tmp.6508
+ umask 022
+ cd /opt/freescale/ltib/usr/src/rpm/BUILD
+ cd isbc_cst
++ eval echo
+++ echo
+ PKG_CST_PATH_PRECONFIG=
+ CST_SRC_DIR=/opt/freescale/ltib/usr/src/rpm/BUILD/isbc_cst
+ cd /opt/freescale/ltib/usr/src/rpm/BUILD/isbc_cst
+ make USE_LTIB=1 LTIB_LIB_PATH=/opt/freescale/ltib/usr/lib LTIB_INC_PATH=/opt/freescale/ltib/usr/include
gcc -c -g -DSIMICS  -I/opt/freescale/ltib/usr/include sign.c
gcc -L/opt/freescale/ltib/usr/lib -lssl -lcrypto -ldl -o sign sign.o
sign.o: In function `get_size_and_updatehash':
/opt/freescale/ltib/usr/src/rpm/BUILD/isbc_cst/sign.c:184: undefined reference to `SHA256_Update'
sign.o: In function `open_priv_file':
/opt/freescale/ltib/usr/src/rpm/BUILD/isbc_cst/sign.c:254: undefined reference to `PEM_read_RSAPrivateKey'
sign.o: In function `fill_header':
/opt/freescale/ltib/usr/src/rpm/BUILD/isbc_cst/sign.c:298: undefined reference to `SHA256_Update'
sign.o: In function `fill_and_update_sg_tbl':
/opt/freescale/ltib/usr/src/rpm/BUILD/isbc_cst/sign.c:308: undefined reference to `SHA256_Update'
sign.o: In function `printkeyhash':
/opt/freescale/ltib/usr/src/rpm/BUILD/isbc_cst/sign.c:318: undefined reference to `SHA256_Init'
/opt/freescale/ltib/usr/src/rpm/BUILD/isbc_cst/sign.c:319: undefined reference to `SHA256_Update'
/opt/freescale/ltib/usr/src/rpm/BUILD/isbc_cst/sign.c:320: undefined reference to `SHA256_Final'
sign.o: In function `printonlyhash':
/opt/freescale/ltib/usr/src/rpm/BUILD/isbc_cst/sign.c:348: undefined reference to `PEM_read_RSAPublicKey'
/opt/freescale/ltib/usr/src/rpm/BUILD/isbc_cst/sign.c:356: undefined reference to `RSA_size'
/opt/freescale/ltib/usr/src/rpm/BUILD/isbc_cst/sign.c:370: undefined reference to `SHA256_Init'
/opt/freescale/ltib/usr/src/rpm/BUILD/isbc_cst/sign.c:371: undefined reference to `SHA256_Update'
/opt/freescale/ltib/usr/src/rpm/BUILD/isbc_cst/sign.c:372: undefined reference to `SHA256_Final'
/opt/freescale/ltib/usr/src/rpm/BUILD/isbc_cst/sign.c:381: undefined reference to `RSA_free'
sign.o: In function `main':
/opt/freescale/ltib/usr/src/rpm/BUILD/isbc_cst/sign.c:600: undefined reference to `RSA_size'
/opt/freescale/ltib/usr/src/rpm/BUILD/isbc_cst/sign.c:610: undefined reference to `SHA256_Init'
/opt/freescale/ltib/usr/src/rpm/BUILD/isbc_cst/sign.c:636: undefined reference to `SHA256_Update'
/opt/freescale/ltib/usr/src/rpm/BUILD/isbc_cst/sign.c:647: undefined reference to `SHA256_Final'
/opt/freescale/ltib/usr/src/rpm/BUILD/isbc_cst/sign.c:658: undefined reference to `RSA_sign'
/opt/freescale/ltib/usr/src/rpm/BUILD/isbc_cst/sign.c:701: undefined reference to `RSA_free'
collect2: error: ld returned 1 exit status
make: *** [sign] Error 1
error: Bad exit status from /home/i/PCIE/ltib-e500mc-20110415/tmp/rpm-tmp.6508 (%build)
RPM build errors:
Build time for cst: 1 seconds
在网上找了很对地方都没有解决呀!有没有谁跟我碰到一样的问题呀?是怎么解决的?
我知道答案 目前已有8人回答
 楼主| 发表于 2014-11-9 17:28:20 | 显示全部楼层
我已经解决了。
发表于 2014-11-10 14:17:47 | 显示全部楼层
欢迎楼主有问题继续在本论坛中交流哈~~
 楼主| 发表于 2014-11-11 22:14:59 | 显示全部楼层
问题又来了,我编译P4080 PCIE BSP包的时候,看用户指导文档,编译之前要打一个ltib-e500mc-p4080-usdpaa-b2.3.patch,可是这个patch打不上,首先没有这个500mc-sim-b2.3-n710-rcws.patch,我细看了这个patch有很多文件都没有,e500mc-sim-2.2/p4080n710也没有,我这个BSP包是从官网上下载的。解压之后ltib-e500mc-20110415,但用户手册上是ltib-e500mc-20110331,这两个版本相差半个月,是不是patch太新?  我用的是N710_EP的板子。
 楼主| 发表于 2014-11-11 22:15:57 | 显示全部楼层
谁有这个版本的patch?
 楼主| 发表于 2014-11-11 22:38:48 | 显示全部楼层
patch: **** Can't create temporary file pkgs/e500mc-sim-b2.3-n710-rcws.patch.oiWwpFz : Permission denied
 楼主| 发表于 2014-11-11 22:42:43 | 显示全部楼层
原来是没权限,晕倒,我现在在这里自问自答了!,后面总结个帖子,把在ubuntu 14.04 LTS 上的问题总结一下。
    发表于 2014-11-12 11:35:53 | 显示全部楼层
    枕头man 发表于 2014-11-11 22:42
    原来是没权限,晕倒,我现在在这里自问自答了!,后面总结个帖子,把在ubuntu 14.04 LTS 上的 ...
    谢谢楼主与大家分享问题的原因
    欢迎在论坛里发帖与大家分享相关经验!
    发表于 2015-7-15 17:48:16 | 显示全部楼层
    楼主,你第一个问题怎么解决的?我也遇到了
    谢谢
    GMT+8, 2025-10-29 09:00 , Processed in 0.099348 second(s), 29 queries , MemCache On.
