查看: 6513|回复: 4
[求助] IMX6Q接logitech usb webcam 摄像头无法使用,报如下错误,请帮...
发表于 2014-12-4 14:44:58 | 显示全部楼层 |阅读模式
IMX6Q接logitech usb webcam 摄像头无法使用,报如下错误,请帮高手帮忙解决,谢谢啊!
root@android:/ # ov5642_write_reg:write reg error:reg=3103,val=93
write reg error addr=0x3103
mxc_v4l2_s_param: vidioc_int_s_parm returned an error -1
ERROR: v4l2 capture: mxc_v4l_dqueue timeout enc_counter 0
ERROR: v4l2 capture: VIDIOC_QBUF: buffer already queued
Unhandled fault: external abort on non-linefetch (0x1018) at 0x411ac054
ov5642_write_reg:write reg error:reg=3503,val=7
ov5642_read_reg:write reg error:reg=3500
ov5642_read_reg:write reg error:reg=3501
ov5642_read_reg:write reg error:reg=3502
ov5642_read_reg:write reg error:reg=380e
ov5642_read_reg:write reg error:reg=380f
ov5642_read_reg:write reg error:reg=350b
write reg error addr=0x3503
ov5642_write_reg:write reg error:reg=350b,val=0
ov5642_write_reg:write reg error:reg=3502,val=10
ov5642_write_reg:write reg error:reg=3501,val=0
ov5642_write_reg:write reg error:reg=3500,val=0
ov5642_write_reg:write reg error:reg=3503,val=0
Unhandled fault: external abort on non-linefetch (0x1018) at 0x411a7054
我知道答案 目前已有4人回答
 楼主| 发表于 2014-12-6 21:11:23 | 显示全部楼层
其实就是用ELEMENT14的IMX6Q开发板接罗技的摄像头后出现了如下的错误,有没有谁之前遇到过呢,请知道的帮个忙啊,不甚感激!
root@android:/ #ov5642_write_reg:write reg error:reg=3103,val=93
root@android:/ # ERROR: v4l2 capture: mxc_v4l_dqueue timeout enc_counter 0
发表于 2015-1-15 19:42:53 | 显示全部楼层
successan 发表于 2014-12-6 21:11
其实就是用ELEMENT14的IMX6Q开发板接罗技的摄像头后出现了如下的错误,有没有谁之前遇到过呢,请知道的帮个 ...
问题解决了吗?怎么解决的?
发表于 2015-1-16 15:35:28 | 显示全部楼层
楼主你好,请问你使用的这个camera,驱动你有加进去吗?关于camera部分的移植,建议你参考一下文档:
i.MX_6Dual6Quad_BSP_Porting_Guide.pdf (719.5 KB, 下载次数: 37)
 楼主| 发表于 2015-7-12 15:29:36 | 显示全部楼层
已解决!
GMT+8, 2025-10-22 10:19 , Processed in 0.086220 second(s), 25 queries , MemCache On.
