在线时间3 小时
UID3081571
注册时间2014-12-8
NXP金币0
 该用户从未签到 新手上路
	积分27
最后登录2015-1-30 |
| Hi every, 我在开发中碰到个问题。 平台是K60M100M+MQX 4.1。 用MQX 4.1里面的SPI测试程序,结果只有一部分正确。这个硬件平台在MQX 3.8下工作正确。
 以下是测试结果。
 -------------- SPI driver example --------------
 This example application demonstrates usage of SPI driver.
 It transfers data to/from external memory over SPI bus.
 The default settings in memory.h apply to TWR-MEM flash memory.
 Test channel is spi2:
 Current baud rate ... 9600000 Hz
 Changing the baud rate to 500000 Hz ... OK
 Current baud rate ... 500000 Hz
 Setting clock mode to SPI_CLK_POL_PHA_MODE0 ... OK
 Getting clock mode ... SPI_CLK_POL_PHA_MODE0
 Setting endian to SPI_DEVICE_BIG_ENDIAN ... OK
 Getting endian ... SPI_DEVICE_BIG_ENDIAN
 Setting transfer mode to SPI_DEVICE_MASTER_MODE ... OK
 Getting transfer mode ... SPI_DEVICE_MASTER_MODE
 Clearing statistics ... OK
 Getting statistics:
 Rx packets:   0
 Tx packets:   0
 Read memory status ... 0x00
 Enable write latch in memory ... OK
 Read memory status ... 0x02
 Write unprotect memory ... OK
 Read memory status ... 0x03
 Erase whole memory chip:
 Erase chip ... OK
 Write byte 0xba to location 0x000000f0 in memory ... done
 Read byte from location 0x000000f0 in memory ... 0xba
 Byte test ... OK
 Getting statistics:
 Rx packets:   9
 Tx packets:   26
 Page write 12 bytes to location 0x000001f0 in memory:
 Hello,World!
 Reading 12 bytes from location 0x000001f0 in memory:
 Hello,World!
 Write short data test ... OK
 Page write 16 bytes to location 0x000002f0 in memory:
 ABCDEFGHIJKLMNOP
 Page write 56 bytes to location 0x00000300 in memory:
 QRSTUVWXYZ1234567890abcdefghijklmnopqrstuvwxyz1234567890
 Reading 72 bytes from location 0x000002f0 in memory:
 QRSTUVWXYZ1234567890abcdefghijklmnopqrstuvwxyz1234567890▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒
 Write long data test ... ERROR
 IO_IOCTL_SPI_READ_WRITE ... OK
 Simultaneous write and read - memory read from 0x000000f0 (10):
 Write: 0x03 0x00 0x00 0xf0 0x00 0x00 0x00 0x00 0x00 0x00
 Read : 0xff 0xff 0xff 0xf0 0xf0 0xf0 0x00 0x51 0x52 0x53
 Simultaneous read/write (data == 0xf0) ... ERROR
 -------------- End of example --------------
 对于长字符串测试,第一次16个字符写在了 0x000002f0, 但是从那个地址读的时候,读出来后面写在 0x00000300的数据。
 simultaneous write全部都错了。
 大家有啥好建议呀?谢谢。
