查看: 2198|回复: 1
[其他] ubuntu安装LTIB出错
发表于 2014-12-12 20:17:22 | 显示全部楼层 |阅读模式
我用的是Ubuntu13.10,根据文档配置了环境,执行./ltib .出现如下错误: collect2: error: ld returned 1 exit status902 make[2]: *** [dump] Error 1
903 make[2]: Leaving directory `/tmp/rpm-mark/BUILD/rpm-4.0.4/tools'
904 make[1]: *** [all-recursive] Error 1
905 make[1]: Leaving directory `/tmp/rpm-mark/BUILD/rpm-4.0.4'
906 make: *** [all-recursive-am] Error 2
907 error: Bad exit status from /home/mark/LTIB/ltib/tmp/rpm-tmp.cC2Eys (%build)
908
909
910 RPM build errors:
911     Bad exit status from /home/mark/LTIB/ltib/tmp/rpm-tmp.cC2Eys (%build)
912 Build time for rpm-fs: 19 seconds
913
914 Failed building rpm-fs
915 could not glob rpm in: /tmp/rpm-mark/RPMS/x86_64/rpm-fs-* at ./ltib line 2427.
916 traceback:
917  main::check_rpm_setup:2427
918   main::host_checks:1435
919    main:554
920
921
922 Started: Fri Dec 12 17:15:50 2014
923 Ended:   Fri Dec 12 17:16:12 2014
924 Elapsed: 22 seconds
925
926 These packages failed to build:
927 rpm-fs
928
929 Build Failed
930
求帮助
我知道答案 目前已有1人回答
 楼主| 发表于 2014-12-15 11:51:13 | 显示全部楼层
求回复啊
GMT+8, 2025-11-1 06:42 , Processed in 0.076005 second(s), 22 queries , MemCache On.
