查看: 5740|回复: 4
[求助] Mfgtools-Rel-12.04.01_ER_MX6Q_UPDATER烧录失败
发表于 2014-12-16 13:50:02 | 显示全部楼层 |阅读模式
直接贴上debug内容
U-Boot 2009.08 (May 01 2012 - 21:16:29)
CPU:   Freescale i.MX 6 family 0.0V at 792 MHz
Temperature:   35 C, calibration data 0x56c4bd7d
mx6q pll1: 792MHz
mx6q pll2: 528MHz
mx6q pll3: 480MHz
mx6q pll8: 50MHz
ipg clock     : 66000000Hz
ipg per clock : 66000000Hz
uart clock    : 80000000Hz
cspi clock    : 60000000Hz
ahb clock     : 132000000Hz
axi clock   : 264000000Hz
emi_slow clock: 29333333Hz
ddr clock     : 528000000Hz
usdhc1 clock  : 200000000Hz
usdhc2 clock  : 200000000Hz
usdhc3 clock  : 200000000Hz
usdhc4 clock  : 200000000Hz
nfc clock     : 24000000Hz
Board: MX6Q-SABRELITE:[ POR]
Boot Device: I2C
I2C:   ready
DRAM:   1 GB
MMC:   FSL_USDHC: 0,FSL_USDHC: 1
Using default environment
In:    serial
Out:   serial
Err:   serial
Net:   got MAC address from IIM: 00:00:00:00:00:00
FEC0 [PRIME]
## Booting kernel from Legacy Image at 10800000 ...
   Image Name:   Linux-3.0.15-02291-g046d6b9-dirt
   Image Type:   ARM Linux Kernel Image (uncompressed)
   Data Size:    3121276 Bytes =  3 MB
   Load Address: 10008000
   Entry Point:  10008000
   Verifying Checksum ... OK
## Loading init Ramdisk from Legacy Image at 10c00000 ...
   Image Name:   uboot initramfs rootfs
   Image Type:   ARM Linux RAMDisk Image (gzip compressed)
   Data Size:    4737975 Bytes =  4.5 MB
   Load Address: 00000000
   Entry Point:  00000000
   Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
Linux version 3.0.15-02291-g046d6b9-dirty (b33651@shdroid1) (gcc version 4.4.3 (GCC) ) #165 SMP PREEMPT Wed May 2 13:34:02 CST 2012
CPU: ARMv7 Processor [412fc09a] revision 10 (ARMv7), cr=10c53c7d
CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
Machine: Freescale i.MX 6Quad Sabre-Lite Board
Memory policy: ECC disabled, Data cache writealloc
PERCPU: Embedded 7 pages/cpu @8188c000 s5184 r8192 d15296 u32768
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 210944
Kernel command line: console=ttymxc1,115200 rdinit=/linuxrc
PID hash table entries: 4096 (order: 2, 16384 bytes)
Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Memory: 640MB 192MB = 832MB total
Memory: 832036k/832036k available, 216540k reserved, 0K highmem
Virtual kernel memory layout:
    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
    DMA     : 0xfbe00000 - 0xffe00000   (  64 MB)
    vmalloc : 0xc0800000 - 0xf2000000   ( 792 MB)
    lowmem  : 0x80000000 - 0xc0000000   (1024 MB)
    pkmap   : 0x7fe00000 - 0x80000000   (   2 MB)
    modules : 0x7f000000 - 0x7fe00000   (  14 MB)
      .init : 0x80008000 - 0x80037000   ( 188 kB)
      .text : 0x80037000 - 0x80599214   (5513 kB)
      .data : 0x8059a000 - 0x805dd160   ( 269 kB)
       .bss : 0x805dd184 - 0x80605210   ( 161 kB)
SLUB: Genslabs=13, HWalign=32, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
Preemptible hierarchical RCU implementation.
NR_IRQS:496
MXC GPIO hardware
sched_clock: 32 bits at 3000kHz, resolution 333ns, wraps every 1431655ms
MXC_Early serial console at MMIO 0x21e8000 (options '115200')
bootconsole [ttymxc1] enabled
Console: colour dummy device 80x30
Calibrating delay loop... 1581.05 BogoMIPS (lpj=7905280)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
hw perfevents: enabled with ARMv7 Cortex-A9 PMU driver, 7 counters available
CPU1: Booted secondary processor
CPU2: Booted secondary processor
CPU3: Booted secondary processor
Brought up 4 CPUs
SMP: Total of 4 processors activated (6324.22 BogoMIPS).
print_constraints: dummy:
NET: Registered protocol family 16
print_constraints: vddpu: 725 <--> 1300 mV at 1150 mV fast normal
print_constraints: vddcore: 725 <--> 1300 mV at 1150 mV fast normal
print_constraints: vddsoc: 725 <--> 1300 mV at 1200 mV fast normal
print_constraints: vdd2p5: 2000 <--> 2775 mV at 2400 mV fast normal
print_constraints: vdd1p1: 800 <--> 1400 mV at 1100 mV fast normal
print_constraints: vdd3p0: 2800 <--> 3150 mV at 3000 mV fast normal
hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
hw-breakpoint: 1 breakpoint(s) reserved for watchpoint single-step.
hw-breakpoint: maximum watchpoint size is 4 bytes.
L310 cache controller enabled
l2x0: 16 ways, CACHE_ID 0x410000c7, AUX_CTRL 0x02070000, Cache size: 1048576 B
IMX usb wakeup probe
bio: create slab <bio-0> at 0
print_constraints: vmmc: 3300 mV
SCSI subsystem initialized
spi_imx imx6q-ecspi.0: probed
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
imx-ipuv3 imx-ipuv3.0: IPU DMFC NORMAL mode: 1(0~1), 5B(4,5), 5F(6,7)
imx-ipuv3 imx-ipuv3.1: IPU DMFC NORMAL mode: 1(0~1), 5B(4,5), 5F(6,7)
Advanced Linux Sound Architecture Driver Version 1.0.24.
Bluetooth: Core ver 2.16
NET: Registered protocol family 31
Bluetooth: HCI device and connection manager initialized
Bluetooth: HCI socket layer initialized
Bluetooth: L2CAP socket layer initialized
Bluetooth: SCO socket layer initialized
i2c-core: driver [max17135] using legacy suspend method
i2c-core: driver [max17135] using legacy resume method
Switching to clocksource mxc_timer1
Clockevents: could not switch to one-shot mode:
Clockevents: could not switch to one-shot mode: dummy_timer is not functional.
Could not switch to high resolution mode on CPU 2
Could not switch to high resolution mode on CPU 0
Could not switch to high resolution mode on CPU 1
NET: Registered protocol family 2
IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
TCP bind hash table entries: 65536 (order: 7, 786432 bytes)
TCP: Hash tables configured (established 131072 bind 65536)
TCP reno registered
UDP hash table entries: 512 (order: 2, 16384 bytes)
UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
RPC: Registered named UNIX socket transport module.
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
Unpacking initramfs...
Could not switch to high resolution mode on CPU 3
Freeing initrd memory: 4624K
Static Power Management for Freescale i.MX6
cpaddr = c0884000 suspend_iram_base=c092c000
PM driver module loaded
i.MXC CPU frequency driver
JFFS2 version 2.2. (NAND) 漏 2001-2006 Red Hat, Inc.
msgmni has been set to 1634
cryptodev: driver loaded.
io scheduler noop registered
io scheduler deadline registered
io scheduler cfq registered (default)
mxc_sdc_fb mxc_sdc_fb.0: register mxc display driver ldb
_regulator_get: get() with no identifier
imx-ipuv3 imx-ipuv3.1: IPU DMFC DP HIGH RESOLUTION: 1(0,1), 5B(2~5), 5F(6,7)
Console: switching to colour frame buffer device 128x48
mxc_sdc_fb mxc_sdc_fb.1: register mxc display driver lcd
mxc_sdc_fb mxc_sdc_fb.2: register mxc display driver ldb
mxc_sdc_fb mxc_sdc_fb.3: register mxc display driver ldb
mxc_sdc_fb mxc_sdc_fb.3: ipu1-di1 already in use
mxc_sdc_fb: probe of mxc_sdc_fb.3 failed with error -16
imx-sdma imx-sdma: loaded firmware 1.1
imx-sdma imx-sdma: initialized
Serial: IMX driver
imx-uart.0: ttymxc0 at MMIO 0x2020000 (irq = 58) is a IMX
imx-uart.1: ttymxc1 at MMIO 0x21e8000 (irq = 59) is a IMX
console [ttymxc1] enabled, bootconsole disabled
loop: module loaded
m25p80 spi0.0: sst25vf016b (2048 Kbytes)
Creating 2 MTD partitions on "m25p80":
0x000000000000-0x000000040000 : "bootloader"
0x000000040000-0x000000200000 : "kernel"
vcan: Virtual CAN interface driver
FEC Ethernet Driver
fec_enet_mii_bus: probed
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
ARC USBOTG Device Controller driver (1 August 2005)
add wake up source irq 75
g_file_storage gadget: controller 'fsl-usb2-udc' not recognized
check_parameters:UTP settings are in place now, overriding defaults
g_file_storage gadget: No serial-number string provided!
g_file_storage gadget: File-backed Storage Gadget, version: 1 September 2010
g_file_storage gadget: Number of LUNs=1
fsl-usb2-udc: bind to driver g_file_storage
mousedev: PS/2 mouse device common for all mice
egalax_ts 2-0004: egalax_ts: failed to read firmware version
egalax_ts: probe of 2-0004 failed with error -5
using rtc device, snvs_rtc, for alarms
snvs_rtc snvs_rtc.0: rtc core: registered snvs_rtc as rtc0
i2c /dev entries driver
Linux video capture interface: v2.00
mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as video16
mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as video17
mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as video18
mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as video19
mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as video20
imx2-wdt imx2-wdt.0: IMX2+ Watchdog Timer enabled. timeout=60s (nowayout=1)
Bluetooth: Virtual HCI driver ver 1.3
Bluetooth: Generic Bluetooth USB driver ver 0.6
usbcore: registered new interface driver btusb
sdhci: Secure Digital Host Controller Interface driver
sdhci: Copyright(c) Pierre Ossman
mmc0: Unknown controller version (3). You may experience problems.
mmc0: SDHCI controller on platform [sdhci-esdhc-imx.3] using ADMA
mmc1: Unknown controller version (3). You may experience problems.
mmc1: SDHCI controller on platform [sdhci-esdhc-imx.2] using ADMA
mxc_vdoa mxc_vdoa: i.MX Video Data Order Adapter(VDOA) driver probed
VPU initialized
mxc_asrc registered
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
Cirrus Logic CS42888 ALSA SoC Codec Driver
i2c-core: driver [cs42888] using legacy suspend method
i2c-core: driver [cs42888] using legacy resume method
imx_3stack asoc driver
ALSA device list:
  No soundcards found.
TCP cubic registered
NET: Registered protocol family 17
can: controller area network core (rev 20090105 abi 8)
NET: Registered protocol family 29
can: raw protocol (rev 20090105)
g_file_storage gadget: high speed config #1
can: broadcast manager protocol (rev 20090105 t)
Bluetooth: RFCOMM TTY layer initialized
Bluetooth: RFCOMM socket layer initialized
Bluetooth: RFCOMM ver 1.11
Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Bluetooth: BNEP filters: protocol multicast
Bluetooth: HIDP (Human Interface Emulation) ver 1.2
VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
Bus freq driver module loaded
mxc_dvfs_core_probe
DVFS driver module loaded
snvs_rtc snvs_rtc.0: setting system clock to 1970-01-01 01:48:29 UTC (6509)
Freeing init memory: 188K
Starting UTP
ln: /etc/mtab: File exists
disable turn off display
Starting the hotplug events dispatcher udevd
udevd (1923): /proc/1923/oom_adj is deprecated, please use /proc/1923/oom_score_adj instead.
Synthesizing initial hotplug events
uuc 0.4 [built May  1 2012 02:47:36]
UTP: Waiting for device to appear
UTP: file/device node /dev/utp already exists
cpu_id is 0
UTP: received command '$ flash_eraseall /dev/mtd0'
UTP: executing "flash_eraseall /dev/mtd0"
Erasing 4 Kibyte @ 0 --  0 % complete.
Erasing 4 Kibyte @ 1000 --  1 % complete.
Erasing 4 Kibyte @ 2000 --  3 % complete.
Erasing 4 Kibyte @ 3000 --  4 % complete.
Erasing 4 Kibyte @ 4000 --  6 % complete.
Erasing 4 Kibyte @ 5000 --  7 % complete.
Erasing 4 Kibyte @ 6000 --  9 % complete.
Erasing 4 Kibyte @ 7000 -- 10 % complete.
Erasing 4 Kibyte @ 8000 -- 12 % complete.
Erasing 4 Kibyte @ 9000 -- 14 % complete.
Erasing 4 Kibyte @ a000 -- 15 % complete.
Erasing 4 Kibyte @ b000 -- 17 % complete.
Erasing 4 Kibyte @ c000 -- 18 % complete.
Erasing 4 Kibyte @ d000 -- 20 % complete.
Erasing 4 Kibyte @ e000 -- 21 % complete.
Erasing 4 Kibyte @ f000 -- 23 % complete.
Erasing 4 Kibyte @ 10000 -- 25 % complete.
Erasing 4 Kibyte @ 11000 -- 26 % complete.
Erasing 4 Kibyte @ 12000 -- 28 % complete.
Erasing 4 Kibyte @ 13000 -- 29 % complete.
Erasing 4 Kibyte @ 14000 -- 31 % complete.
Erasing 4 Kibyte @ 15000 -- 32 % complete.
Erasing 4 Kibyte @ 16000 -- 34 % complete.
Erasing 4 Kibyte @ 17000 -- 35 % complete.
Erasing 4 Kibyte @ 18000 -- 37 % complete.
Erasing 4 Kibyte @ 19000 -- 39 % complete.
Erasing 4 Kibyte @ 1a000 -- 40 % complete.
Erasing 4 Kibyte @ 1b000 -- 42 % complete.
Erasing 4 Kibyte @ 1c000 -- 43 % complete.
Erasing 4 Kibyte @ 1d000 -- 45 % complete.
Erasing 4 Kibyte @ 1e000 -- 46 % complete.
Erasing 4 Kibyte @ 1f000 -- 48 % complete.
Erasing 4 Kibyte @ 20000 -- 50 % complete.
Erasing 4 Kibyte @ 21000 -- 51 % complete.
Erasing 4 Kibyte @ 22000 -- 53 % complete.
Erasing 4 Kibyte @ 23000 -- 54 % complete.
Erasing 4 Kibyte @ 24000 -- 56 % complete.
Erasing 4 Kibyte @ 25000 -- 57 % complete.
Erasing 4 Kibyte @ 26000 -- 59 % complete.
Erasing 4 Kibyte @ 27000 -- 60 % complete.
Erasing 4 Kibyte @ 28000 -- 62 % complete.
Erasing 4 Kibyte @ 29000 -- 64 % complete.
Erasing 4 Kibyte @ 2a000 -- 65 % complete.
Erasing 4 Kibyte @ 2b000 -- 67 % complete.
Erasing 4 Kibyte @ 2c000 -- 68 % complete.
Erasing 4 Kibyte @ 2d000 -- 70 % complete.
Erasing 4 Kibyte @ 2e000 -- 71 % complete.
Erasing 4 Kibyte @ 2f000 -- 73 % complete.
Erasing 4 Kibyte @ 30000 -- 75 % complete.
Erasing 4 Kibyte @ 31000 -- 76 % complete.
Erasing 4 Kibyte @ 32000 -- 78 % complete.
Erasing 4 Kibyte @ 33000 -- 79 % complete.
Erasing 4 Kibyte @ 34000 -- 81 % complete.
Erasing 4 Kibyte @ 35000 -- 82 % complete.
Erasing 4 Kibyte @ 36000 -- 84 % complete.
Erasing 4 Kibyte @ 37000 -- 85 % complete.
Erasing 4 Kibyte @ 38000 -- 87 % complete.
Erasing 4 Kibyte @ 39000 -- 89 % complete.
Erasing 4 Kibyte @ 3a000 -- 90 % complete.
Erasing 4 Kibyte @ 3b000 -- 92 % complete.
Erasing 4 Kibyte @ 3c000 -- 93 % complete.
Erasing 4 Kibyte @ 3d000 -- 95 % complete.
Erasing 4 Kibyte @ 3e000 -- 96 % complete.
Erasing 4 Kibyte @ 3f000 -- 98 % complete.
Erasing 4 Kibyte @ 40000 -- 100 % complete.
UTP: sending Success to kernel for command $ flash_eraseall /dev/mtd0.
utp_poll: pass returned.
UTP: received command 'send'
UTP: sending Success to kernel for command send.
UTP: received command '$ dd if=$FILE of=/dev/mtd0 bs=512'
UTP: executing "dd if=$FILE of=/dev/mtd0 bs=512"
387+1 records in
387+1 records out
198364 bytes (193.7KB) copied, 6.053249 seconds, 32.0KB/s
UTP: sending Success to kernel for command $ dd if=$FILE of=/dev/mtd0 bs=512.
UTP: received command '$ tar xf $FILE '
UTP: executing "tar xf $FILE "
UTP: sending Success to kernel for command $ tar xf $FILE .
UTP: received command '$ sh mksdcard-android.sh /dev/mmcblk0'
UTP: executing "sh mksdcard-android.sh /dev/mmcblk0"
usage mksdcard-android.sh <option> device_node
options:
  -h                displays this help message
  -s                only get partition size
  -np                 not partition.
  -f                 flash android image.
UTP: sending Success to kernel for command $ sh mksdcard-android.sh /dev/mmcblk0.
UTP: received command '$ ls -l /dev/mmc* '
UTP: executing "ls -l /dev/mmc* "
ls: /dev/mmc*: No such file or directory
UTP: sending Non-success to kernel for command $ ls -l /dev/mmc* .
utp_poll: exit with status 256
我知道答案 目前已有4人回答
 楼主| 发表于 2014-12-16 13:50:44 | 显示全部楼层
速求解答!!!!!公司新买的产品
发表于 2014-12-19 18:08:22 | 显示全部楼层
楼主你好,请问你这里使用的哪块板子?
发表于 2014-12-19 18:08:51 | 显示全部楼层
上帝的死亡 发表于 2014-12-16 13:50
速求解答!!!!!公司新买的产品
是飞思卡尔的开发板吗?
发表于 2014-12-22 11:32:52 | 显示全部楼层
楼主你好,请问你问题现在解决了吗?
GMT+8, 2025-10-30 07:46 , Processed in 0.098225 second(s), 25 queries , MemCache On.
