查看: 6380|回复: 8
[求助] IMX6Q-SDB use MFGTool download linux
发表于 2014-12-16 15:39:52 | 显示全部楼层 |阅读模式
Sorry I should not post this in English. But I dont have Chinese input method on my working desktop.
I'm new to his development board.
I followed some install guide
https://www.freescale.co
m/files/training_pdf/WBNR_LA13_IMX6QPR_PDF.pdf?lang_cd=en
to install ubuntu onto the board.
I download ubuntu image as oneiric.gz then I changed this to oneiric.tgz
the ucl2.xml and MFGTool2 work fine.
I'm using HDMI. I cannot boot ubuntu from eMMC.
Please help.
Thanks a lot
(you can reply in Chinese. thanks)
我知道答案 目前已有8人回答
 楼主| 发表于 2014-12-16 15:54:48 | 显示全部楼层
omg.... please help...
up up up
My second day and first day of working all spend on configuring the board... so sad
 楼主| 发表于 2014-12-16 16:03:43 | 显示全部楼层
@FSL_TICS_Rita
https://www.nxpic.org.cn/module/ ... =page%3D&page=2
I checked my ucl2.xml is the same as the given one.
And my mfgtool is Mfgtools-Rel-4.1.0_130816_MX6Q_UPDATER
发表于 2014-12-16 17:42:56 | 显示全部楼层
lushl9301 发表于 2014-12-16 16:03
@FSL_TICS_Rita
https://www.nxpic.org.cn/module/forum/forum.php?mod=viewthread&tid=581648&extra=pa ...
楼主你好,请问你u-boot起来了吗?你的boot mode设置的正确吗?
 楼主| 发表于 2014-12-16 17:50:51 | 显示全部楼层
may i ask you how to check debug info during boot?
boot mode should be correct.
But the red LED D3 is on all the time. (different from sdcard boot)
 楼主| 发表于 2014-12-16 20:45:58 | 显示全部楼层
终于回宿舍了,能用自己电脑了。
请问有没有比较完整一点的教程,我可以参考的?我自己找了两份都有些错误。
第一次接触这类的开发板,周围也没有人在搞这个。只能求助论坛了!
我在boot模式下,无法挂载在windows下,怎么得到debug的信息呢?
 楼主| 发表于 2014-12-17 10:45:28 | 显示全部楼层
eMMC boot is not successful.
I tried sdcard mode. It works now~
Thanks a lot ^_^
Have a nice day~
发表于 2014-12-22 09:40:09 | 显示全部楼层
楼主你好,emmc启动也是OK的,这里不知道你使用的是android的BSP还是linux的BSP。在你烧写完成后,断电,将boot mode调为从emmc启动即:SW6改为11010110(1-8bit)。u-boot起来以后,设置u-boot中内核启动参数。然后就是可以正常启动了,有问题,我们再沟通哈~~
发表于 2014-12-22 09:40:45 | 显示全部楼层
欢迎楼主有问题继续在本论坛中交流讨论哈~~
GMT+8, 2025-11-1 18:01 , Processed in 0.108399 second(s), 29 queries , MemCache On.
