查看: 9377|回复: 12
[求助] I.MX6求助:GPU STATE DUMP
发表于 2014-12-18 09:23:12 | 显示全部楼层 |阅读模式
板子是四核的IMX6,
用vitamio长时间播放rtp视频流,可能会出现GPU STATE DUMP,一直打印,系统未挂,哪位大神可以说说是怎么回事吗?一下是具体log
root@android:/ #
root@android:/ #
GPU[0](ChipModel=0x2000 ChipRevision=0x5108):
***   GPU STATE DUMP   ***
  axi      = 0x00000051
  idle     = 0x7FFFFFFA
    FE not idle
    PE not idle
  DMA address is constant, but state is changing:
    0x00000000
    0x00000800
  dmaLow   = 0x40000002
  dmaHigh  = 0x24B2D4A0
  dmaState = 0x00000800
    command state       = 0 (PAR_IDLE_ST)
    command DMA state   = 0 (CMD_IDLE_ST)
    command fetch state = 2 (FET_VALID_ST)
    DMA request state   = 0 (REQ_IDLE_ST)
    cal state           = 0 (CAL_IDLE_ST)
    VE request state    = 0 (VER_IDLE_ST)
  Debug registers of pipe[0]:
    RA debug registers:
      [0x00] 0x00000000
      [0x01] 0x00000000
      [0x02] 0x00000000
      [0x03] 0x00000000
      [0x04] 0x0BFF0000
      [0x05] 0xA00C5000
      [0x06] 0x81BA8000
      [0x07] 0x00000000
      [0x08] 0x00000000
      [0x09] 0x00000000
      [0x0A] 0x00000000
      [0x0B] 0x00000000
      [0x0C] 0x12344321
      [0x0D] 0x12344321
      [0x0E] 0x12344321
      [0x0F] 0x12344321
      signature = 0x12344321 (1 read attempt(s))
    TX debug registers:
      [0x00] 0x00000000
      [0x01] 0x00000000
      [0x02] 0x00000000
      [0x03] 0x00000000
      [0x04] 0x00000000
      [0x05] 0x00000000
      [0x06] 0x00000000
      [0x07] 0x00000000
      [0x08] 0x00000000
      [0x09] 0x00000000
      [0x0A] 0x00000000
      [0x0B] 0x00000000
      [0x0C] 0x00000000
      [0x0D] 0x00000000
      [0x0E] 0x00000000
      [0x0F] 0x00000000
      failed to obtain the signature (read 0x00000000).
    FE debug registers:
      [0x00] 0x24B2D4A8
      [0x01] 0x40000002
      [0x02] 0x24B2D4A0
      [0x03] 0x00000256
      [0x04] 0x00000002
      [0x05] 0x00000007
      [0x06] 0x08089571
      [0x07] 0x00007645
      [0x08] 0x0000000E
      [0x09] 0x00000000
      [0x0A] 0x00000000
      [0x0B] 0x00000000
      [0x0C] 0x00000000
      [0x0D] 0xA4965A94
      [0x0E] 0x0000001D
      [0x0F] 0xBABEF00D
      signature = 0xBABEF00D (1 read attempt(s))
    PE debug registers:
      [0x00] 0x00000000
      [0x01] 0x00000000
      [0x02] 0x00000000
      [0x03] 0x00000000
      [0x04] 0xA0000000
      [0x05] 0xABC00000
      [0x06] 0xBC000000
      [0x07] 0xCDE00000
      [0x08] 0xD04041C0
      [0x09] 0x484045C0
      [0x0A] 0x0D862286
      [0x0B] 0x00000000
      [0x0C] 0xBABEF00D
      [0x0D] 0xBABEF00D
      [0x0E] 0xBABEF00D
      [0x0F] 0xBABEF00D
    DE debug registers:
      [0x00] 0x00000000
      [0x01] 0x00000000
      [0x02] 0x00000000
      [0x03] 0x00000000
      [0x04] 0x00000000
      [0x05] 0x00000000
      [0x06] 0x00000000
      [0x07] 0x00000000
      [0x08] 0x00000000
      [0x09] 0x00000000
      [0x0A] 0x00000000
      [0x0B] 0x00000000
      [0x0C] 0x00000000
      [0x0D] 0x00000000
      [0x0E] 0x00000000
      [0x0F] 0x00000000
    SH debug registers:
      [0x00] 0x80FFEAAB
      [0x01] 0x555F0006
      [0x02] 0x0001FF05
      [0x03] 0x00020AAA
      [0x04] 0x00000000
      [0x05] 0x00002553
      [0x06] 0x00002553
      [0x07] 0x830F0D96
      [0x08] 0x9D0D9C81
      [0x09] 0xF309AF88
      [0x0A] 0x6157FCEA
      [0x0B] 0x00000000
      [0x0C] 0x00000000
      [0x0D] 0x00000000
      [0x0E] 0x3C1A13BC
      [0x0F] 0xDEADBEEF
      signature = 0xDEADBEEF (1 read attempt(s))
    PA debug registers:
      [0x00] 0x800003FF
      [0x01] 0x2629000F
      [0x02] 0x00000808
      [0x03] 0x00000000
      [0x04] 0x00000000
      [0x05] 0x00000000
      [0x06] 0x00000000
      [0x07] 0x00000000
      [0x08] 0x00000000
      [0x09] 0x0000AAAA
      [0x0A] 0x0000AAAA
      [0x0B] 0x0000AAAA
      [0x0C] 0x0000AAAA
      [0x0D] 0x0000AAAA
      [0x0E] 0x0000AAAA
      [0x0F] 0x0000AAAA
      signature = 0x0000AAAA (1 read attempt(s))
    SE debug registers:
      [0x00] 0x00000003
      [0x01] 0x00000003
      [0x02] 0x00000003
      [0x03] 0x00000003
      [0x04] 0x00000003
      [0x05] 0x00000003
      [0x06] 0x00000003
      [0x07] 0x00000003
      [0x08] 0x00000003
      [0x09] 0x00000003
      [0x0A] 0x00000003
      [0x0B] 0x00000003
      [0x0C] 0x00000003
      [0x0D] 0x00000003
      [0x0E] 0x00000003
      [0x0F] 0x00000003
      failed to obtain the signature (read 0x00000003).
    MC debug registers:
      [0x00] 0x00000000
      [0x01] 0x00000000
      [0x02] 0x00000000
      [0x03] 0x00000000
      [0x04] 0x12345678
      [0x05] 0x12345678
      [0x06] 0x12345678
      [0x07] 0x12345678
      [0x08] 0x12345678
      [0x09] 0x12345678
      [0x0A] 0x12345678
      [0x0B] 0x12345678
      [0x0C] 0x12345678
      [0x0D] 0x12345678
      [0x0E] 0x12345678
      [0x0F] 0x12345678
      signature = 0x12345678 (1 read attempt(s))
    HI debug registers:
      [0x00] 0x00000000
      [0x01] 0x00000000
      [0x02] 0x00000000
      [0x03] 0xAAAAAAAA
      [0x04] 0xAAAAAAAA
      [0x05] 0xAAAAAAAA
      [0x06] 0xAAAAAAAA
      [0x07] 0xAAAAAAAA
      [0x08] 0xAAAAAAAA
      [0x09] 0xAAAAAAAA
      [0x0A] 0xAAAAAAAA
      [0x0B] 0xAAAAAAAA
      [0x0C] 0xAAAAAAAA
      [0x0D] 0xAAAAAAAA
      [0x0E] 0xAAAAAAAA
      [0x0F] 0xAAAAAAAA
      signature = 0xAAAAAAAA (1 read attempt(s))
    Other Registers:
      [0x0040] 0x7EFA85F2
      [0x0044] 0x04B58A34
      [0x004C] 0x04B58A34
      [0x0050] 0x40FAF836
      [0x0054] 0x40FAF836
      [0x0058] 0x7EFAD1AC
      [0x005C] 0x75CF2A4A
      [0x0060] 0x75CF31E0
      [0x043C] 0x00000000
      [0x0440] 0x00000000
      [0x0444] 0x00000000
      [0x0414] 0x3C000000
  Debug registers of pipe[1]:
    RA debug registers:
      [0x00] 0x00000000
      [0x01] 0x00000000
      [0x02] 0x00000000
      [0x03] 0x00000000
      [0x04] 0x0BFF0000
      [0x05] 0xA00C5000
      [0x06] 0x81BA8000
      [0x07] 0x00000000
      [0x08] 0x00000000
      [0x09] 0x00000000
      [0x0A] 0x00000000
      [0x0B] 0x00000000
      [0x0C] 0x12344321
      [0x0D] 0x12344321
      [0x0E] 0x12344321
      [0x0F] 0x12344321
    TX debug registers:
      [0x00] 0x00000000
      [0x01] 0x00000000
      [0x02] 0x00000000
      [0x03] 0x00000000
      [0x04] 0x00000000
      [0x05] 0x00000000
      [0x06] 0x00000000
      [0x07] 0x00000000
      [0x08] 0x00000000
      [0x09] 0x00000000
      [0x0A] 0x00000000
      [0x0B] 0x00000000
      [0x0C] 0x00000000
      [0x0D] 0x00000000
      [0x0E] 0x00000000
      [0x0F] 0x00000000
    FE debug registers:
      [0x00] 0x24B2D4A0
      [0x01] 0x380000C8
      [0x02] 0x24B2D4A0
      [0x03] 0x00000256
      [0x04] 0x00000002
      [0x05] 0x00000000
      [0x06] 0x08089571
      [0x07] 0x00007645
      [0x08] 0x0000000E
      [0x09] 0x00000000
      [0x0A] 0x00000000
      [0x0B] 0x00000000
      [0x0C] 0x00000000
      [0x0D] 0xA4965A94
      [0x0E] 0x0000003E
      [0x0F] 0xBABEF00D
    PE debug registers:
      [0x00] 0x00000000
      [0x01] 0x00000000
      [0x02] 0x00000000
      [0x03] 0x00000000
      [0x04] 0xA0000000
      [0x05] 0xABC00000
      [0x06] 0xBC000000
      [0x07] 0xCDE00000
      [0x08] 0xD04041C0
      [0x09] 0x484045C0
      [0x0A] 0x0D862286
      [0x0B] 0x00000000
      [0x0C] 0xBABEF00D
      [0x0D] 0xBABEF00D
      [0x0E] 0xBABEF00D
      [0x0F] 0xBABEF00D
    DE debug registers:
      [0x00] 0x00000000
      [0x01] 0x00000000
      [0x02] 0x00000000
      [0x03] 0x00000000
      [0x04] 0x00000000
      [0x05] 0x00000000
      [0x06] 0x00000000
      [0x07] 0x00000000
      [0x08] 0x00000000
      [0x09] 0x00000000
      [0x0A] 0x00000000
      [0x0B] 0x00000000
      [0x0C] 0x00000000
      [0x0D] 0x00000000
      [0x0E] 0x00000000
      [0x0F] 0x00000000
    SH debug registers:
      [0x00] 0x80FFEAAB
      [0x01] 0x555F0006
      [0x02] 0x0001FF05
      [0x03] 0x00020AAA
      [0x04] 0x00000000
      [0x05] 0x00002553
      [0x06] 0x00002553
      [0x07] 0x830F0D96
      [0x08] 0x9D0D9C81
      [0x09] 0xF309AF88
      [0x0A] 0x6157FCEA
      [0x0B] 0x00000000
      [0x0C] 0x00000000
      [0x0D] 0x00000000
      [0x0E] 0x3C1A13BC
      [0x0F] 0xDEADBEEF
    PA debug registers:
      [0x00] 0x800003FF
      [0x01] 0x2629000F
      [0x02] 0x00000808
      [0x03] 0x00000000
      [0x04] 0x00000000
      [0x05] 0x00000000
      [0x06] 0x00000000
      [0x07] 0x00000000
      [0x08] 0x00000000
      [0x09] 0x0000AAAA
      [0x0A] 0x0000AAAA
      [0x0B] 0x0000AAAA
      [0x0C] 0x0000AAAA
      [0x0D] 0x0000AAAA
      [0x0E] 0x0000AAAA
      [0x0F] 0x0000AAAA
    SE debug registers:
      [0x00] 0x00000003
      [0x01] 0x00000003
      [0x02] 0x00000003
      [0x03] 0x00000003
      [0x04] 0x00000003
      [0x05] 0x00000003
      [0x06] 0x00000003
      [0x07] 0x00000003
      [0x08] 0x00000003
      [0x09] 0x00000003
      [0x0A] 0x00000003
      [0x0B] 0x00000003
      [0x0C] 0x00000003
      [0x0D] 0x00000003
      [0x0E] 0x00000003
      [0x0F] 0x00000003
    MC debug registers:
      [0x00] 0x00000000
      [0x01] 0x00000000
      [0x02] 0x00000000
      [0x03] 0x00000000
      [0x04] 0x12345678
      [0x05] 0x12345678
      [0x06] 0x12345678
      [0x07] 0x12345678
      [0x08] 0x12345678
      [0x09] 0x12345678
      [0x0A] 0x12345678
      [0x0B] 0x12345678
      [0x0C] 0x12345678
      [0x0D] 0x12345678
      [0x0E] 0x12345678
      [0x0F] 0x12345678
    HI debug registers:
      [0x00] 0x00000000
      [0x01] 0x00000000
      [0x02] 0x00000000
      [0x03] 0xAAAAAAAA
      [0x04] 0xAAAAAAAA
      [0x05] 0xAAAAAAAA
      [0x06] 0xAAAAAAAA
      [0x07] 0xAAAAAAAA
      [0x08] 0xAAAAAAAA
      [0x09] 0xAAAAAAAA
      [0x0A] 0xAAAAAAAA
      [0x0B] 0xAAAAAAAA
      [0x0C] 0xAAAAAAAA
      [0x0D] 0xAAAAAAAA
      [0x0E] 0xAAAAAAAA
      [0x0F] 0xAAAAAAAA
    Other Registers:
      [0x0040] 0xEA968C15
      [0x0044] 0x1E180968
      [0x004C] 0x1E180968
      [0x0050] 0x43C3012D
      [0x0054] 0x43C3012D
      [0x0058] 0xEA96D7BF
      [0x005C] 0x806733DC
      [0x0060] 0x80673B90
      [0x043C] 0x00020000
      [0x0440] 0x00000000
      [0x0444] 0x00000000
      [0x0414] 0x3C000000
[<c0052fc4>] (unwind_backtrace+0x0/0x138) from [<c046e308>] (gckOS_DumpCallStack+0x8/0x10)
[<c046e308>] (gckOS_DumpCallStack+0x8/0x10) from [<c0480ecc>] (gckHARDWARE_DumpGPUState+0x63c/0x834)
[<c0480ecc>] (gckHARDWARE_DumpGPUState+0x63c/0x834) from [<c046d2bc>] (gckOS_Broadcast+0x38/0xe8)
[<c046d2bc>] (gckOS_Broadcast+0x38/0xe8) from [<c0470eac>] (gckKERNEL_Dispatch+0x1020/0x1228)
[<c0470eac>] (gckKERNEL_Dispatch+0x1020/0x1228) from [<c0469670>] (drv_ioctl+0x120/0x270)
[<c0469670>] (drv_ioctl+0x120/0x270) from [<c013e20c>] (do_vfs_ioctl+0x80/0x54c)
[<c013e20c>] (do_vfs_ioctl+0x80/0x54c) from [<c013e710>] (sys_ioctl+0x38/0x5c)
[<c013e710>] (sys_ioctl+0x38/0x5c) from [<c004b900>] (ret_fast_syscall+0x0/0x30)
  axi      = 0x00000051
  idle     = 0x7FFFFFFA
    FE not idle
    PE not idle
    0x00000000
    0x00000800
  dmaLow   = 0x40000002
    RA debug registers:
      [0x00] 0x00000000
      [0x01] 0x00000000
      [0x02] 0x00000000
      [0x03] 0x00000000
      [0x04] 0x0BFF0000
      [0x05] 0xA00C5000
      [0x06] 0x81BA8000
      [0x07] 0x00000000
      [0x08] 0x00000000
      [0x09] 0x00000000
      [0x0A] 0x00000000
      [0x0B] 0x00000000
      [0x0C] 0x12344321
      [0x0D] 0x12344321
      [0x0E] 0x12344321
      [0x0F] 0x12344321
    TX debug registers:
      [0x00] 0x00000000
      [0x01] 0x00000000
      [0x02] 0x00000000
      [0x03] 0x00000000
      [0x04] 0x00000000
      [0x05] 0x00000000
      [0x06] 0x00000000
      [0x07] 0x00000000
      [0x08] 0x00000000
      [0x09] 0x00000000
      [0x0A] 0x00000000
      [0x0B] 0x00000000
      [0x0C] 0x00000000
      [0x0D] 0x00000000
      [0x0E] 0x00000000
      [0x0F] 0x00000000
    FE debug registers:
      [0x00] 0x24B2D4A8
      [0x01] 0x40000002
      [0x02] 0x00000000
      [0x03] 0x00000256
      [0x04] 0x00000002
      [0x05] 0x00000007
      [0x06] 0x08089571
      [0x07] 0x00007645
      [0x08] 0x0000000E
      [0x09] 0x00000000
      [0x0A] 0x00000000
      [0x0B] 0x00000000
      [0x0C] 0x00000000
      [0x0D] 0xA4965A94
      [0x0E] 0x000000AF
      [0x0F] 0xBABEF00D
    PE debug registers:
      [0x00] 0x00000000
      [0x01] 0x00000000
      [0x02] 0x00000000
      [0x03] 0x00000000
      [0x04] 0xA0000000
      [0x05] 0xABC00000
      [0x06] 0xBC000000
      [0x07] 0xCDE00000
      [0x08] 0xD04041C0
      [0x09] 0x484045C0
      [0x0A] 0x0D862286
      [0x0B] 0x00000000
      [0x0C] 0xBABEF00D
      [0x0D] 0xBABEF00D
      [0x0E] 0xBABEF00D
      [0x0F] 0xBABEF00D
    DE debug registers:
      [0x00] 0x00000000
      [0x01] 0x00000000
      [0x02] 0x00000000
      [0x03] 0x00000000
      [0x04] 0x00000000
      [0x05] 0x00000000
      [0x06] 0x00000000
      [0x07] 0x00000000
      [0x08] 0x00000000
      [0x09] 0x00000000
      [0x0A] 0x00000000
      [0x0B] 0x00000000
      [0x0C] 0x00000000
      [0x0D] 0x00000000
      [0x0E] 0x00000000
      [0x0F] 0x00000000
    SH debug registers:
      [0x00] 0x80FFEAAB
      [0x01] 0x555F0006
      [0x02] 0x0001FF05
      [0x03] 0x00020AAA
      [0x04] 0x00000000
      [0x05] 0x00002553
      [0x06] 0x00002553
      [0x07] 0x830F0D96
      [0x08] 0x9D0D9C81
      [0x09] 0xF309AF88
      [0x0A] 0x6157FCEA
      [0x0B] 0x00000000
      [0x0C] 0x00000000
      [0x0D] 0x00000000
      [0x0E] 0x3C1A13BC
      [0x0F] 0xDEADBEEF
    PA debug registers:
      [0x00] 0x800003FF
      [0x01] 0x2629000F
      [0x02] 0x00000808
      [0x03] 0x00000000
      [0x04] 0x00000000
      [0x05] 0x00000000
      [0x06] 0x00000000
      [0x07] 0x00000000
      [0x08] 0x00000000
      [0x09] 0x0000AAAA
      [0x0A] 0x0000AAAA
      [0x0B] 0x0000AAAA
      [0x0C] 0x0000AAAA
      [0x0D] 0x0000AAAA
      [0x0E] 0x0000AAAA
      [0x0F] 0x0000AAAA
    SE debug registers:
      [0x00] 0x00000003
      [0x01] 0x00000003
      [0x02] 0x00000003
      [0x03] 0x00000003
      [0x04] 0x00000003
      [0x05] 0x00000003
      [0x06] 0x00000003
      [0x07] 0x00000003
      [0x08] 0x00000003
      [0x09] 0x00000003
      [0x0A] 0x00000003
      [0x0B] 0x00000003
      [0x0C] 0x00000003
      [0x0D] 0x00000003
      [0x0E] 0x00000003
      [0x0F] 0x00000003
    MC debug registers:
      [0x00] 0x00000000
      [0x01] 0x00000000
      [0x02] 0x00000000
      [0x03] 0x00000000
      [0x04] 0x12345678
      [0x05] 0x12345678
      [0x06] 0x12345678
      [0x07] 0x12345678
      [0x08] 0x12345678
      [0x09] 0x12345678
      [0x0A] 0x12345678
      [0x0B] 0x12345678
      [0x0C] 0x12345678
      [0x0D] 0x12345678
      [0x0E] 0x12345678
      [0x0F] 0x12345678
    HI debug registers:
      [0x00] 0x00000000
      [0x01] 0x00000000
      [0x02] 0x00000000
      [0x03] 0xAAAAAAAA
      [0x04] 0xAAAAAAAA
      [0x05] 0xAAAAAAAA
      [0x06] 0xAAAAAAAA
      [0x07] 0xAAAAAAAA
      [0x08] 0xAAAAAAAA
      [0x09] 0xAAAAAAAA
      [0x0A] 0xAAAAAAAA
      [0x0B] 0xAAAAAAAA
      [0x0C] 0xAAAAAAAA
      [0x0D] 0xAAAAAAAA
      [0x0E] 0xAAAAAAAA
      [0x0F] 0xAAAAAAAA
    Other Registers:
      [0x0040] 0x801143A2
      [0x0044] 0x04B58A34
      [0x004C] 0x04B58A34
      [0x0050] 0x40FAF836
      [0x0054] 0x40FAF836
      [0x0058] 0x80119042
      [0x005C] 0x765A89C9
      [0x0060] 0x765A9153
      [0x043C] 0x00000000
      [0x0440] 0x00000000
      [0x0444] 0x00000000
      [0x0414] 0x3C000000
    RA debug registers:
      [0x00] 0x00000000
      [0x01] 0x00000000
      [0x02] 0x00000000
      [0x03] 0x00000000
      [0x04] 0x0BFF0000
      [0x05] 0xA00C5000
      [0x06] 0x81BA8000
      [0x07] 0x00000000
      [0x08] 0x00000000
      [0x09] 0x00000000
      [0x0A] 0x00000000
      [0x0B] 0x00000000
      [0x0C] 0x12344321
      [0x0D] 0x12344321
      [0x0E] 0x12344321
      [0x0F] 0x12344321
    TX debug registers:
      [0x00] 0x00000000
      [0x01] 0x00000000
      [0x02] 0x00000000
      [0x03] 0x00000000
      [0x04] 0x00000000
      [0x05] 0x00000000
      [0x06] 0x00000000
      [0x07] 0x00000000
      [0x08] 0x00000000
      [0x09] 0x00000000
      [0x0A] 0x00000000
      [0x0B] 0x00000000
      [0x0C] 0x00000000
      [0x0D] 0x00000000
      [0x0E] 0x00000000
      [0x0F] 0x00000000
    FE debug registers:
      [0x00] 0x24B2D4A8
      [0x01] 0x380000C8
      [0x02] 0x00000000
      [0x03] 0x00000256
      [0x04] 0x00000002
      [0x05] 0x00000000
      [0x06] 0x08089571
      [0x07] 0x00007645
      [0x08] 0x0000000E
      [0x09] 0x00000000
      [0x0A] 0x00000000
      [0x0B] 0x00000000
      [0x0C] 0x00000000
      [0x0D] 0xA4965A94
      [0x0E] 0x000000B0
      [0x0F] 0xBABEF00D
    PE debug registers:
      [0x00] 0x00000000
      [0x01] 0x00000000
      [0x02] 0x00000000
      [0x03] 0x00000000
      [0x04] 0xA0000000
      [0x05] 0xABC00000
      [0x06] 0xBC000000
      [0x07] 0xCDE00000
      [0x08] 0xD04041C0
      [0x09] 0x484045C0
      [0x0A] 0x0D862286
      [0x0B] 0x00000000
      [0x0C] 0xBABEF00D
      [0x0D] 0xBABEF00D
      [0x0E] 0xBABEF00D
      [0x0F] 0xBABEF00D
    DE debug registers:
      [0x00] 0x00000000
      [0x01] 0x00000000
      [0x02] 0x00000000
      [0x03] 0x00000000
      [0x04] 0x00000000
      [0x05] 0x00000000
      [0x06] 0x00000000
      [0x07] 0x00000000
      [0x08] 0x00000000
      [0x09] 0x00000000
      [0x0A] 0x00000000
      [0x0B] 0x00000000
      [0x0C] 0x00000000
      [0x0D] 0x00000000
      [0x0E] 0x00000000
      [0x0F] 0x00000000
    SH debug registers:
      [0x00] 0x80FFEAAB
      [0x01] 0x555F0006
      [0x02] 0x0001FF05
      [0x03] 0x00020AAA
      [0x04] 0x00000000
      [0x05] 0x00002553
      [0x06] 0x00002553
      [0x07] 0x830F0D96
      [0x08] 0x9D0D9C81
      [0x09] 0xF309AF88
      [0x0A] 0x6157FCEA
      [0x0B] 0x00000000
      [0x0C] 0x00000000
      [0x0D] 0x00000000
      [0x0E] 0x3C1A13BC
      [0x0F] 0xDEADBEEF
    PA debug registers:
      [0x00] 0x800003FF
      [0x01] 0x2629000F
      [0x02] 0x00000808
      [0x03] 0x00000000
      [0x04] 0x00000000
      [0x05] 0x00000000
      [0x06] 0x00000000
      [0x07] 0x00000000
      [0x08] 0x00000000
      [0x09] 0x0000AAAA
      [0x0A] 0x0000AAAA
      [0x0B] 0x0000AAAA
      [0x0C] 0x0000AAAA
      [0x0D] 0x0000AAAA
      [0x0E] 0x0000AAAA
      [0x0F] 0x0000AAAA
    SE debug registers:
      [0x00] 0x00000003
      [0x01] 0x00000003
      [0x02] 0x00000003
      [0x03] 0x00000003
      [0x04] 0x00000003
      [0x05] 0x00000003
      [0x06] 0x00000003
      [0x07] 0x00000003
      [0x08] 0x00000003
      [0x09] 0x00000003
      [0x0A] 0x00000003
      [0x0B] 0x00000003
      [0x0C] 0x00000003
      [0x0D] 0x00000003
      [0x0E] 0x00000003
      [0x0F] 0x00000003
    MC debug registers:
      [0x00] 0x00000000
      [0x01] 0x00000000
      [0x02] 0x00000000
      [0x03] 0x00000000
      [0x04] 0x12345678
      [0x05] 0x12345678
      [0x06] 0x12345678
      [0x07] 0x12345678
      [0x08] 0x12345678
      [0x09] 0x12345678
      [0x0A] 0x12345678
      [0x0B] 0x12345678
      [0x0C] 0x12345678
      [0x0D] 0x12345678
      [0x0E] 0x12345678
      [0x0F] 0x12345678
    HI debug registers:
      [0x00] 0x00000000
      [0x01] 0x00000000
      [0x02] 0x00000000
      [0x03] 0xAAAAAAAA
      [0x04] 0xAAAAAAAA
      [0x05] 0xAAAAAAAA
      [0x06] 0xAAAAAAAA
      [0x07] 0xAAAAAAAA
      [0x08] 0xAAAAAAAA
      [0x09] 0xAAAAAAAA
      [0x0A] 0xAAAAAAAA
      [0x0B] 0xAAAAAAAA
      [0x0C] 0xAAAAAAAA
      [0x0D] 0xAAAAAAAA
      [0x0E] 0xAAAAAAAA
      [0x0F] 0xAAAAAAAA
    Other Registers:
      [0x0040] 0xEBAD73E9
      [0x0044] 0x1E180968
      [0x004C] 0x1E180968
      [0x0050] 0x43C3012D
      [0x0054] 0x43C3012D
      [0x0058] 0xEBADC0D1
      [0x005C] 0x80F2A862
      [0x0060] 0x80F2B028
      [0x043C] 0x00000000
      [0x0440] 0x00000000
      [0x0444] 0x00000000
      [0x0414] 0x3C000000
我知道答案 目前已有12人回答
发表于 2014-12-22 11:04:32 | 显示全部楼层
楼主你好,请问你这里使用的是android的哪个版本的BSP?
发表于 2014-12-22 11:06:57 | 显示全部楼层
楼主你好,你这里使用vitamio播放视频的话,你是如何操作的?我们默认BSP中没有提到关于vitamio的播放。
 楼主| 发表于 2015-4-14 11:05:54 | 显示全部楼层
我的也是imx6四核,用自带播放器api播放,播放了一夜出现的,这是怎么回事啊??
4>GPU[1](ChipModel=0x320 ChipRevision=0x5007):
<4>**************************
<4>***   GPU STATE DUMP   ***
<4>  axi      = 0x00000050
<4>  idle     = 0x7FFFFFFE
<4>    FE not idle
<4>  DMA is running; known addresses are:
<4>    0x243ED0E0
<4>    0x243ED0D8
<4>  dmaLow   = 0x380000C8
<4>  dmaHigh  = 0x00000000
<4>  dmaState = 0x00000800
<4>    command state       = 0 (PAR_IDLE_ST)
<4>    command DMA state   = 0 (CMD_IDLE_ST)
<4>    command fetch state = 2 (FET_VALID_ST)
<4>    DMA request state   = 0 (REQ_IDLE_ST)
<4>    cal state           = 0 (CAL_IDLE_ST)
<4>    VE request state    = 0 (VER_IDLE_ST)
<4>  Debug registers of pipe[0]:
<4>    RA debug registers:
<4>      [0x00] 0x00000000
<4>      [0x01] 0x00000000
<4>      [0x02] 0x00000000
<4>      [0x03] 0x00000000
<4>      [0x04] 0x00000000
<4>      [0x05] 0x00000000
<4>      [0x06] 0x00000000
<4>      [0x07] 0x00000000
<4>      [0x08] 0x00000000
<4>      [0x09] 0x00000000
<4>      [0x0A] 0x00000000
<4>      [0x0B] 0x00000000
<4>      [0x0C] 0x00000000
<4>      [0x0D] 0x00000000
<4>      [0x0E] 0x00000000
<4>      [0x0F] 0x00000000
<4>      failed to obtain the signature (read 0x00000000).
<4>    TX debug registers:
<4>    FE debug registers:
<4>    PE debug registers:
<4>      [0x04] 0xA403C4F1
<4>      [0x05] 0xABC2A001
<4>      [0x06] 0xBC000086
<4>      [0x07] 0xCDE80040
<4>      [0x08] 0xD0000000
<4>      [0x0C] 0xBABEF00D
<4>      [0x0D] 0xBABEF00D
<4>      [0x0E] 0xBABEF00D
<4>      [0x0F] 0xBABEF00D
<4>      signature = 0xBABEF00D (1 read attempt(s))
<4>    DE debug registers:
<4>    SH debug registers:
<4>    PA debug registers:
<4>    SE debug registers:
<4>    MC debug registers:
<4>      [0x02] 0x022F8434
<4>      [0x04] 0x12345678
<4>      [0x05] 0x12345678
<4>      [0x06] 0x12345678
<4>      [0x07] 0x12345678
<4>      [0x08] 0x12345678
<4>      [0x09] 0x12345678
<4>      [0x0A] 0x12345678
<4>      [0x0B] 0x12345678
<4>      [0x0C] 0x12345678
<4>      [0x0D] 0x12345678
<4>      [0x0E] 0x12345678
<4>      [0x0F] 0x12345678
<4>      signature = 0x12345678 (1 read attempt(s))
<4>    HI debug registers:
<4>      [0x03] 0xAAAAAAAA
<4>      [0x04] 0xAAAAAAAA
<4>      [0x05] 0xAAAAAAAA
<4>      [0x06] 0xAAAAAAAA
<4>      [0x07] 0xAAAAAAAA
<4>      [0x08] 0xAAAAAAAA
<4>      [0x09] 0xAAAAAAAA
<4>      [0x0A] 0xAAAAAAAA
<4>      [0x0B] 0xAAAAAAAA
<4>      [0x0C] 0xAAAAAAAA
<4>      [0x0D] 0xAAAAAAAA
<4>      [0x0E] 0xAAAAAAAA
<4>      [0x0F] 0xAAAAAAAA
<4>      signature = 0xAAAAAAAA (1 read attempt(s))
<4>    Other Registers:
<4>      [0x0040] 0x881E6578
<4>      [0x0044] 0x4CD5FE50
<4>      [0x004C] 0xA66AFF28
<4>      [0x0050] 0x6A00B370
<4>      [0x0054] 0x6A00B370
<4>      [0x0058] 0xEBD4B492
<4>      [0x005C] 0xF8CF9AC8
<4>      [0x0060] 0xC5466ADC
<4>      [0x043C] 0x00000040
<4>      [0x0440] 0x28000000
<4>      [0x0444] 0x00000000
<4>      [0x0414] 0x3C000000
<4>  Debug registers of pipe[1]:
<4>      [0x02] 0x000BBC64
<4>      [0x0040] 0x882B2922
<4>      [0x0058] 0xEBE17824
<4>      [0x005C] 0xF8DC5DF8
<4>      [0x0060] 0xC5532E76
<4>[<c0052fc4>] (unwind_backtrace+0x0/0x138) from [<c046e308>] (gckOS_DumpCallStack+0x8/0x10)
<4>[<c046e308>] (gckOS_DumpCallStack+0x8/0x10) from [<c0480ecc>] (gckHARDWARE_DumpGPUState+0x63c/0x834)
<4>[<c0480ecc>] (gckHARDWARE_DumpGPUState+0x63c/0x834) from [<c046d2bc>] (gckOS_Broadcast+0x38/0xe8)
<4>[<c046d2bc>] (gckOS_Broadcast+0x38/0xe8) from [<c0470eac>] (gckKERNEL_Dispatch+0x1020/0x1228)
<4>[<c0470eac>] (gckKERNEL_Dispatch+0x1020/0x1228) from [<c0469670>] (drv_ioctl+0x120/0x270)
<4>[<c0469670>] (drv_ioctl+0x120/0x270) from [<c013e20c>] (do_vfs_ioctl+0x80/0x54c)
<4>[<c013e20c>] (do_vfs_ioctl+0x80/0x54c) from [<c013e710>] (sys_ioctl+0x38/0x5c)
<4>[<c013e710>] (sys_ioctl+0x38/0x5c) from [<c004b900>] (ret_fast_syscall+0x0/0x30)
 楼主| 发表于 2015-4-14 11:31:15 | 显示全部楼层
用的4.2.2
 楼主| 发表于 2015-4-14 11:32:29 | 显示全部楼层
FSL_TICS_Rita 发表于 2014-12-22 11:06
楼主你好,你这里使用vitamio播放视频的话,你是如何操作的?我们默认BSP中没有提到关于vitamio的播放。 ...
注意到 一些文档中提到CTRL+C to exit some GPU
applications may cause "GPU STATE
DUMP".,这个也是这样出现的吗?
发表于 2015-4-24 16:26:33 | 显示全部楼层
DUMP".,这个也是这 ...
这个的话,建议先你试试看。
 楼主| 发表于 2015-4-24 17:20:08 | 显示全部楼层
FSL_TICS_Rita 发表于 2015-4-24 16:26
这个的话,建议先你试试看。
我试过,用android API 循环播放视频,不牵扯到 KILL 问题,也会出现,GPU STATE DUMP,概率很低,不容易看到。最主要的是不知道这个打印信息是代表了什么,是由什么引起的。
    无聊
    2018-9-20 10:55
  • 签到天数: 13 天
    发表于 2015-4-24 17:24:20 | 显示全部楼层
    关注下 怎样和GPU通讯的
     楼主| 发表于 2015-4-24 17:51:23 | 显示全部楼层
    星星-418393 发表于 2015-4-24 17:24
    关注下 怎样和GPU通讯的
    嗯。我会看的。对GPU很不熟悉。现在连GPU STATE DUMP 打印出来的这些日志意思都不知道。
    GMT+8, 2025-10-29 23:07 , Processed in 0.132815 second(s), 30 queries , MemCache On.
