查看: 2861|回复: 1
[分享] KSDK 1.1.0 and KDS 2.0
发表于 2014-12-18 22:36:26 | 显示全部楼层 |阅读模式
I use KSDK 1.1.0 and KDS 2.0, After i create a Kintetis Design Studio project, I select a MQX_KSDK compoents library to add to project, after i change osa1:fsl_os_abstraction OS name from BareMetal to the MQX_KSDK,  mqx_ksdk:MQX_KSDK components have a error "Component name conflicts with another source code module name. (Component name) mqx_ksdk/Component name        Processor Expert Problem"
,i do not know how to To solve this problem
发表于 2014-12-19 09:56:39 | 显示全部楼层
Hi wjffsx,
From your error description, it should be the name confilicts.
Please try to change your  osa1:fsl_os_abstraction OS name to anther name instead of MQX_KSDK, and then build it again.
If still have problem, please let me know!
Regards,
GMT+8, 2025-11-10 13:54 , Processed in 0.112158 second(s), 20 queries , MemCache On.
