查看: 6858|回复: 15
[求助] MK60FX512VLQ15读写内部EEPROM问题
发表于 2014-12-28 12:54:34 | 显示全部楼层 |阅读模式
好像照搬了论坛那个 还是不行啊,那个好像不适用于FX512LQ15              读取地址时提示 串口调试提示:BusFault Interrupt0    BusFault Interrupt0
谢谢!谁有读写成功的,麻烦提供参考一下!
我知道答案 目前已有15人回答
 楼主| 发表于 2014-12-28 12:57:42 | 显示全部楼层
发表于 2014-12-29 09:15:16 | 显示全部楼层
retome 发表于 2014-12-28 12:57
https://www.nxpic.org.cn/module/forum/thread-564360-1-1.html这个好像不适用于fx512lq15
具体flexNVM的分区指令,你要查看K60 150M的用户手册。
还有就是要保证你本身的基础工程要正确。
你现在分区命令用的是什么?
 楼主| 发表于 2014-12-29 13:50:34 | 显示全部楼层
还有就是要保证你本身的基础工程要正确。
你现在 ...
分区命令0x80
 楼主| 发表于 2014-12-29 13:54:55 | 显示全部楼层
/* Define globals for address of counters */
#define LONGWORD_COUNTER_ADDR 0x14000000
#define WORD_COUNTER_ADDR 0x14000004
#define BYTE_COUNTER_ADDR 0x14000006
__RAMFUNC void flexmem_eeprom_init(void)
   SCB_SHCSR|=SCB_SHCSR_BUSFAULTENA_MASK|SCB_SHCSR_MEMFAULTENA_MASK|SCB_SHCSR_USGFAULTENA_MASK;
   //FTFE_FEPROT |=FTFE_FEPROT_EPROT(15);
   //FTFE_FDPROT |=FTFE_FDPROT_DPROT(15);
  partition_flash( EEPROM_8K_8K, DFLASH_SIZE_256);
__RAMFUNC void flexmem_ee32bit_write(uint32 flex_addr,uint32 flex_data)
                  *((uint32 *)(flex_addr)) = flex_data;
                  while(!(FTFE_FCNFG & FTFE_FCNFG_EEERDY_MASK));
void flexmem_ee16bit_write(uint16 flex_addr,uint16 flex_data)
                *((uint16 *)(flex_addr)) = flex_data;
void flexmem_ee8bit_write(uint8 flex_addr,uint8 flex_data)
           *((uint8 *)(flex_addr)) = flex_data;
uint32 flex_ee32bit_read(uint32 flex_addr)
  return (*(uint32 *)(flex_addr));
uint16 flex_ee16bit_read(uint16 flex_addr)
  return (*(uint16 *)(flex_addr));
uint8 flex_ee8bit_read(uint8 flex_addr)
  return (*(uint8 *)(flex_addr));
__RAMFUNC   uint8 partition_flash(uint16 eeprom_size, uint16 dflash_size)
      /* Test to make sure the device is not already partitioned. If it
       * is already partitioned, then return with no action performed.
   //FTFE_FCCOB0 = FTFE_FCCOB0_CCOBn(0x44); // Selects the PGMPART command
     /* Wait for the command to complete */
   //   printf("error:%d\n",FTFE_FSTAT);
    if ((SIM_FCFG1 & SIM_FCFG1_DEPART(0xF)) != 0x00000F00)
         // printf("\nDevice is already partitioned.\n");
          return 0;
      /* Write the FCCOB registers */
      FTFE_FCCOB0 = FTFE_FCCOB0_CCOBn(0x80); // Selects the PGMPART command
      FTFE_FCCOB1 = 0x00;
      FTFE_FCCOB2 = 0x00;
      FTFE_FCCOB3 = 0x00;
      FTFE_FCCOB4 = eeprom_size;
      FTFE_FCCOB5 = dflash_size;
     FTFE_FSTAT |= FTFE_FSTAT_CCIF_MASK;
      while(!(FTFE_FSTAT & FTFE_FSTAT_CCIF_MASK));
      return 1;
 楼主| 发表于 2014-12-29 13:59:50 | 显示全部楼层
还有就是要保证你本身的基础工程要正确。
你现在 ...
  flexmem_ee32bit_write(0x14000006,0x000123);
仿真运行完到这个的时候就会串口调试输出:BusFault Interrupt0    BusFault Interrupt0
再运行这个 printf("%d\n",flex_ee32bit_read(0x14000006)); 居然输出是-625435;居然是负数!
 楼主| 发表于 2014-12-29 14:00:53 | 显示全部楼层
还有就是要保证你本身的基础工程要正确。
你现在 ...
以下就是基础工程的几个函数:
          return 0;
      FTFE_FCCOB1 = 0x00;
      FTFE_FCCOB2 = 0x00;
      FTFE_FCCOB3 = 0x00;
      return 1;
发表于 2014-12-29 14:48:39 | 显示全部楼层
楼主跑看看我这个代码,在RAM中运行; EEPROM大小是2K。
K60FX150_EEPROM.rar (1.02 MB, 下载次数: 43)
 楼主| 发表于 2014-12-29 16:17:26 | 显示全部楼层
灰常感谢FSL_TICS_ZJJ
发表于 2014-12-29 17:02:02 | 显示全部楼层
retome 发表于 2014-12-29 16:17
灰常感谢FSL_TICS_ZJJ
不客气,测试之后把结果告诉我,是否能打印出来。
GMT+8, 2025-11-10 13:57 , Processed in 0.113479 second(s), 31 queries , MemCache On.
