查看: 2259|回复: 1
[求助] 飞思卡尔时钟配置问题
发表于 2015-1-4 15:42:52 | 显示全部楼层 |阅读模式
用的KL05的单片机,时钟初始化的时候就一头雾水了,代码看的头都大了。该怎么配置
void sysinit (void)
        /* Enable all of the port clocks. These have to be enabled to configure
         * pin muxing options, so most code will need all of these on anyway.
        SIM_SCGC5 |= (SIM_SCGC5_PORTA_MASK
                      | SIM_SCGC5_PORTB_MASK
        // releases hold with ACKISO:  Only has an effect if recovering from VLLS1, VLLS2, or VLLS3
        // if ACKISO is set you must clear ackiso before calling pll_init
        //    or pll init hangs waiting for OSC to initialize
        // if osc enabled in low power modes - enable it first before ack
        // if I/O needs to be maintained without glitches enable outputs and modules first before ack.
        if (PMC_REGSC &  PMC_REGSC_ACKISO_MASK)
        PMC_REGSC |= PMC_REGSC_ACKISO_MASK;
#ifdef BOOTLOADER
       SIM_CLKDIV1 = ( 0
                        | SIM_CLKDIV1_OUTDIV1(0)
                        | SIM_CLKDIV1_OUTDIV4(1) );
        mcg_clk_hz =  fee_32OSC();
        uart0_clk_khz = (mcg_clk_hz / 1000); // the UART0 clock frequency will equal the FLL frequency
#else
#if defined(NO_PLL_INIT)
        mcg_clk_hz = 21000000; //FEI mode
        SIM_SOPT2 &= !SIM_SOPT2_PLLFLLSEL_MASK; // clear PLLFLLSEL to select the FLL for this clock source
#else
       /* Ramp up the system clock */
       /* Set the system dividers */
      SIM_CLKDIV1 = ( 0
      // only for demo, reset rtc,user can remove it
      rtc_reset();
      mcg_clk_hz =  fei_fee(CLK0_FREQ_HZ,HIGH_GAIN,CLK0_TYPE);
      if (mcg_clk_hz < 0x100)
         while(1);
       uart0_clk_khz = mcg_clk_hz/1000; // UART0 clock frequency will equal half the PLL frequency
#endif
         * Use the value obtained from the pll_init function to define variables
  * for the core clock in kHz and also the peripheral clock. These
  * variables can be used by other functions that need awareness of the
  * system frequency.
        mcg_clk_khz = mcg_clk_hz / 1000;
       core_clk_khz = mcg_clk_khz / (((SIM_CLKDIV1 & SIM_CLKDIV1_OUTDIV1_MASK) >> 28)+ 1);
        periph_clk_khz = core_clk_khz / (((SIM_CLKDIV1 & SIM_CLKDIV1_OUTDIV4_MASK) >> 16)+ 1);
        /* Enable pin interrupt for the abort button - PTA4 */
        /* This pin could also be used as the NMI interrupt, but since the NMI
         * is level sensitive each button press will cause multiple interrupts.
         * Using the GPIO interrupt instead means we can configure for an edge
         * sensitive interrupt instead = one interrupt per button press.
//        enable_abort_button();
//        clk_out_init();
   /* Enable the pins for the selected SCI */
#ifdef USE_UART0
#ifdef UART_PIN_PTB_1_2_
        /* Enable the SCI1_TXD function on PTC4 */
   PORTB_PCR1 = PORT_PCR_MUX(0x2); // LPSCI is alt3 function for this pin
   /* Enable the SCI1_RXD function on PTC3 */
   PORTB_PCR2 = PORT_PCR_MUX(0x2); // LPSCI is alt3 function for this pin
#else
   PORTB_PCR3 = PORT_PCR_MUX(0x3); // LPSCI is alt3 function for this pin
   PORTB_PCR4 = PORT_PCR_MUX(0x3); // LPSCI is alt3 function for this pin
#endif
        SIM_SOPT2 |= SIM_SOPT2_UART0SRC(1); // select the FLLFLLCLK as UART0 clock source
        uart0_init (TERM_PORT,uart0_clk_khz,TERMINAL_BAUD);
#else
   if (TERM_PORT == UART1_BASE_PTR)
    PORTC_PCR4 = PORT_PCR_MUX(0x3); // SCI is alt3 function for this pin
    PORTC_PCR3 = PORT_PCR_MUX(0x3); // SCI is alt3 function for this pin
        if (TERM_PORT == UART2_BASE_PTR)
                 /* Enable the SCI2_TXD function on PTD3 */
    PORTD_PCR3 = PORT_PCR_MUX(0x3); // SCI is alt3 function for this pin
    /* Enable the SCI2_RXD function on PTD2 */
    PORTD_PCR2 = PORT_PCR_MUX(0x3); // SCI is alt3 function for this pin
   SCI_init (TERM_PORT, periph_clk_khz, TERMINAL_BAUD);
#endif
#endif
void enable_abort_button(void)
    /* Configure the PTA4 pin for its GPIO function */
    PORTA_PCR4 = PORT_PCR_MUX(0x1); // GPIO is alt1 function for this pin
    /* Configure the PTA4 pin for rising edge interrupts */
    PORTA_PCR4 |= PORT_PCR_IRQC(0x9);
    /* Enable the associated IRQ in the NVIC */
    enable_irq(30);
我知道答案 目前已有1人回答
 楼主| 发表于 2015-1-4 15:48:12 | 显示全部楼层
想要让单片机按照设定的一些参数工作啊
GMT+8, 2025-11-23 06:35 , Processed in 0.092840 second(s), 23 queries , Redis On.
