查看: 7771|回复: 5
[求助] i.mx6Q-SDB eMMC启动问题
发表于 2015-1-4 21:46:10 | 显示全部楼层 |阅读模式
i.mx6Q-SDB板,通过工具Mfgtools-Rel-4.1.0_130816_MX6Q_UPDATER,uboot kernel可以烧写到SD卡中可以正常启动,但烧写eMMC时,烧写过程正确,完成后启动系统串口没有任何打印信息。具体过程如下:
1,MFGtool版本为4.1.0_130816
2,ucl2.xml烧写eMMC的代码如下,没做任何改动。
<LIST name="SabreSD-eMMC" desc="Choose eMMC Linux as media">
    <CMD state="BootStrap" type="boot" body="BootStrap" file ="u-boot-mx6q-sabresd.bin" >Loading U-boot</CMD>
    <CMD state="BootStrap" type="load" file="uImage" address="0x10800000"
        loadSection="OTH" setSection="OTH" HasFlashHeader="FALSE" >Loading Kernel.</CMD>
    <CMD state="BootStrap" type="load" file="initramfs.cpio.gz.uboot" address="0x10C00000"
        loadSection="OTH" setSection="OTH" HasFlashHeader="FALSE" >Loading Initramfs.</CMD>
    <CMD state="BootStrap" type="jump" > Jumping to OS image. </CMD>
        <CMD state="Updater" type="push" body="$ ls /dev/*"/>
        <CMD state="Updater" type="push" body="$ dd if=/dev/zero of=/dev/mmcblk0 bs=512 seek=1536 count=16">clean up u-boot parameter</CMD>
        <CMD state="Updater" type="push" body="$ echo 0 > /sys/block/mmcblk0boot0/force_ro">access boot partition 1</CMD>
        <CMD state="Updater" type="push" body="send" file="files/u-boot-mx6q-sabresd.bin">Sending U-Boot</CMD>
        <CMD state="Updater" type="push" body="$ dd if=$FILE of=/dev/mmcblk0boot0 bs=512 seek=2 skip=2">write U-Boot to sd card</CMD>
        <CMD state="Updater" type="push" body="$ echo 1 > /sys/block/mmcblk0boot0/force_ro"> re-enable read-only access </CMD>
        <CMD state="Updater" type="push" body="$ echo 8 > /sys/devices/platform/sdhci-esdhc-imx.3/mmc_host/mmc0/mmc0:0001/boot_config">enable boot partion 1 to boot</CMD>
    <CMD state="Updater" type="push" body="send" file="files/uImage">Sending kernel uImage</CMD>
    <CMD state="Updater" type="push" body="$ dd if=$FILE of=/dev/mmcblk0 bs=1M seek=1 conv=fsync">write kernel image to sd card</CMD>
    <CMD state="Updater" type="push" body="send" file="mksdcard.sh.tar">Sending partition shell</CMD>
    <CMD state="Updater" type="push" body="$ tar xf $FILE "> Partitioning...</CMD>
    <CMD state="Updater" type="push" body="$ sh mksdcard.sh /dev/mmcblk0"> Partitioning...</CMD>
    <CMD state="Updater" type="push" body="$ mkfs.ext3 -j /dev/mmcblk0p1">Formatting rootfs partition</CMD>
    <CMD state="Updater" type="push" body="$ mkdir -p /mnt/mmcblk0p1"/>
    <CMD state="Updater" type="push" body="$ mount -t ext3 /dev/mmcblk0p1 /mnt/mmcblk0p1"/>
    <CMD state="Updater" type="push" body="pipe tar -jxv -C /mnt/mmcblk0p1" file="files/rootfs.tar.bz2">Sending and writting rootfs</CMD>
    <CMD state="Updater" type="push" body="frf">Finishing rootfs write</CMD>
    <CMD state="Updater" type="push" body="$ umount /mnt/mmcblk0p1">Unmounting rootfs partition</CMD>
    <CMD state="Updater" type="push" body="$ echo Update Complete!">Done</CMD>
</LIST>
3,烧写eMMC将cfg.ini文件改写如下,和 ucl2.xml内容相对应:
[profiles]
chip = MX6Q Linux Update
[platform]
board = SabreSD
[LIST]
name = SabrSD-eMMC
4,eMMC拨码开关设置如下:在烧写过程
eMMC拨码开关应该设置如下:(download mode)
Switch D1   D2  D3  D4   D5  D6  D7 D8
SW6   OFF OFF OFF OFF ON  ON OFF OFF
烧写完成后,断电,设置eMMC拨码开关设置如下:( emmc boot mode)
SW6   ON ON OFF ON OFF ON ON OFF
给板子上电,启动。
什么原因造成的呢?难道是工具Mfgtools-Rel-4.1.0_130816_MX6Q_UPDATER的问题?
我知道答案 目前已有5人回答
发表于 2015-1-5 13:50:49 | 显示全部楼层
楼主你好,这里应该不是烧写工具的问题,我看你的设置都是OK的,并且SD卡也是可以正常启动的。这样,你手上只有一块板子吗?如果有多余的板子,建议你试一下,看是不是EMMC有问题。
发表于 2015-1-5 13:51:14 | 显示全部楼层
请问u-boot也没有起来,是吗?
 楼主| 发表于 2015-1-6 16:06:40 | 显示全部楼层
uboot没有起来的,emmc没有问题的,我用SD卡启动能挂载emmc的,都是官方的东西的
发表于 2015-1-12 18:27:39 | 显示全部楼层
楼主你好,请问现在可以正常从EMMC启动了吗?
发表于 2015-2-6 11:21:18 | 显示全部楼层
楼主你好,请问你帖中问题是否已经解决了?如果没有欢迎继续在这里讨论哈~~
GMT+8, 2026-4-15 17:48 , Processed in 0.092942 second(s), 25 queries , Redis On.
