查看: 12111|回复: 7
[求助] imx6 板子烧写uboot成功后,启动没有任何反应
发表于 2015-1-12 16:56:34 | 显示全部楼层 |阅读模式
公司自己设计的板子,仿照imx6_sabrelite设计的,现在制作出了对应的firware文件.当完成UBOOT烧写时,将拨码开关拨回正常启动,但是一点反应也没有,串口没有信息,mfg也是显示没有设备连接。以下是烧写uboot的串口打印信息。求解....
U-Boot 2009.08-dirty ( 1月 09 2015 - 10:38:25)
CPU: Freescale i.MX6 family TO0.0 at 792 MHz
Temperature:   22 C, calibration data 0x54849d7d
mx6q pll1: 792MHz
mx6q pll2: 528MHz
mx6q pll3: 480MHz
mx6q pll8: 50MHz
ipg clock     : 66000000Hz
ipg per clock : 66000000Hz
uart clock    : 80000000Hz
cspi clock    : 60000000Hz
ahb clock     : 132000000Hz
axi clock   : 264000000Hz
emi_slow clock: 29333333Hz
ddr clock     : 528000000Hz
usdhc1 clock  : 198000000Hz
usdhc2 clock  : 198000000Hz
usdhc3 clock  : 198000000Hz
usdhc4 clock  : 198000000Hz
nfc clock     : 24000000Hz
Board: MX6Q-SABRELITE:[ POR]
Boot Device: I2C
I2C:   ready
DRAM:   1 GB
MMC:   FSL_USDHC: 0,FSL_USDHC: 1
Using default environment
In:    serial
Out:   serial
Err:   serial
Net:   got MAC address from IIM: 00:00:00:00:00:00
FEC0 [PRIME]
## Booting kernel from Legacy Image at 10800000 ...
   Image Name:   Linux-3.0.15-gf26d083-dirty
   Image Type:   ARM Linux Kernel Image (uncompressed)
   Data Size:    3132600 Bytes =  3 MB
   Load Address: 10008000
   Entry Point:  10008000
   Verifying Checksum ... OK
## Loading init Ramdisk from Legacy Image at 10c00000 ...
   Image Name:   uboot initramfs rootfs
   Image Type:   ARM Linux RAMDisk Image (gzip compressed)
   Data Size:    4737975 Bytes =  4.5 MB
   Load Address: 00000000
   Entry Point:  00000000
   Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
Linux version 3.0.15-gf26d083-dirty (root@mark-Vostro-270s) (gcc version 4.4.3 (GCC) ) #7 SMP PREEMPT Mon Jan 12 12:03:18 CST 2015
CPU: ARMv7 Processor [412fc09a] revision 10 (ARMv7), cr=10c53c7d
CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
Machine: Freescale i.MX 6Quad Sabre-Lite Board
Memory policy: ECC disabled, Data cache writealloc
PERCPU: Embedded 7 pages/cpu @8c008000 s5184 r8192 d15296 u32768
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 210944
Kernel command line: console=ttymxc1,115200 rdinit=/linuxrc
PID hash table entries: 4096 (order: 2, 16384 bytes)
Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Memory: 640MB 192MB = 832MB total
Memory: 831996k/831996k available, 216580k reserved, 0K highmem
Virtual kernel memory layout:
    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
    DMA     : 0xf4600000 - 0xffe00000   ( 184 MB)
    vmalloc : 0xc0800000 - 0xf2000000   ( 792 MB)
    lowmem  : 0x80000000 - 0xc0000000   (1024 MB)
    pkmap   : 0x7fe00000 - 0x80000000   (   2 MB)
    modules : 0x7f000000 - 0x7fe00000   (  14 MB)
      .init : 0x80008000 - 0x80038000   ( 192 kB)
      .text : 0x80038000 - 0x805a0528   (5538 kB)
      .data : 0x805a2000 - 0x805e6680   ( 274 kB)
       .bss : 0x805e66a4 - 0x8060e870   ( 161 kB)
SLUB: Genslabs=13, HWalign=32, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
Preemptible hierarchical RCU implementation.
NR_IRQS:496
MXC GPIO hardware
sched_clock: 32 bits at 3000kHz, resolution 333ns, wraps every 1431655ms
MXC_Early serial console at MMIO 0x21e8000 (options '115200')
bootconsole [ttymxc1] enabled
Console: colour dummy device 80x30
Calibrating delay loop... 1581.05 BogoMIPS (lpj=7905280)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
hw perfevents: enabled with ARMv7 Cortex-A9 PMU driver, 7 counters available
CPU1: Booted secondary processor
CPU2: Booted secondary processor
CPU3: Booted secondary processor
Brought up 4 CPUs
SMP: Total of 4 processors activated (6324.22 BogoMIPS).
print_constraints: dummy:
NET: Registered protocol family 16
print_constraints: vddpu: 725 <--> 1300 mV at 1150 mV fast normal
print_constraints: vddcore: 725 <--> 1300 mV at 1150 mV fast normal
print_constraints: vddsoc: 725 <--> 1300 mV at 1200 mV fast normal
print_constraints: vdd2p5: 2000 <--> 2775 mV at 2400 mV fast normal
print_constraints: vdd1p1: 800 <--> 1400 mV at 1100 mV fast normal
print_constraints: vdd3p0: 2800 <--> 3150 mV at 3000 mV fast normal
hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
hw-breakpoint: 1 breakpoint(s) reserved for watchpoint single-step.
hw-breakpoint: maximum watchpoint size is 4 bytes.
L310 cache controller enabled
l2x0: 16 ways, CACHE_ID 0x410000c7, AUX_CTRL 0x02070000, Cache size: 1048576 B
IMX usb wakeup probe
bio: create slab <bio-0> at 0
print_constraints: vmmc: 3300 mV
SCSI subsystem initialized
spi_imx imx6q-ecspi.0: probed
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
imx-ipuv3 imx-ipuv3.0: IPU DMFC NORMAL mode: 1(0~1), 5B(4,5), 5F(6,7)
imx-ipuv3 imx-ipuv3.1: IPU DMFC NORMAL mode: 1(0~1), 5B(4,5), 5F(6,7)
Advanced Linux Sound Architecture Driver Version 1.0.24.
Bluetooth: Core ver 2.16
NET: Registered protocol family 31
Bluetooth: HCI device and connection manager initialized
Bluetooth: HCI socket layer initialized
Bluetooth: L2CAP socket layer initialized
Bluetooth: SCO socket layer initialized
i2c-core: driver [max17135] using legacy suspend method
i2c-core: driver [max17135] using legacy resume method
Switching to clocksource mxc_timer1
Clockevents: could not switch to one-shot mode:
Clockevents: could not switch to one-shot mode: dummy_timer is not functional.
Could not switch to high resolution mode on CPU 2
Could not switch to high resolution mode on CPU 1
Could not switch to high resolution mode on CPU 0
NET: Registered protocol family 2
IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
TCP bind hash table entries: 65536 (order: 7, 786432 bytes)
TCP: Hash tables configured (established 131072 bind 65536)
TCP reno registered
UDP hash table entries: 512 (order: 2, 16384 bytes)
UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
RPC: Registered named UNIX socket transport module.
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
Unpacking initramfs...
Could not switch to high resolution mode on CPU 3
Freeing initrd memory: 4624K
Static Power Management for Freescale i.MX6
cpaddr = c0884000 suspend_iram_base=c092c000
PM driver module loaded
i.MXC CPU frequency driver
JFFS2 version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
msgmni has been set to 1634
cryptodev: driver loaded.
io scheduler noop registered
io scheduler deadline registered
io scheduler cfq registered (default)
mxc_sdc_fb mxc_sdc_fb.0: register mxc display driver ldb
_regulator_get: get() with no identifier
imx-ipuv3 imx-ipuv3.1: IPU DMFC DP HIGH RESOLUTION: 1(0,1), 5B(2~5), 5F(6,7)
Console: switching to colour frame buffer device 128x48
mxc_sdc_fb mxc_sdc_fb.1: register mxc display driver lcd
mxc_sdc_fb mxc_sdc_fb.2: register mxc display driver ldb
mxc_sdc_fb mxc_sdc_fb.3: register mxc display driver ldb
mxc_sdc_fb mxc_sdc_fb.3: ipu1-di1 already in use
mxc_sdc_fb: probe of mxc_sdc_fb.3 failed with error -16
imx-sdma imx-sdma: loaded firmware 1.1
imx-sdma imx-sdma: initialized
Serial: IMX driver
imx-uart.0: ttymxc0 at MMIO 0x2020000 (irq = 58) is a IMX
imx-uart.1: ttymxc1 at MMIO 0x21e8000 (irq = 59) is a IMX
console [ttymxc1] enabled, bootconsole disabled
loop: module loaded
m25p80 spi0.0: sst25vf016b (2048 Kbytes)
Creating 2 MTD partitions on "m25p80":
0x000000000000-0x000000040000 : "bootloader"
0x000000040000-0x000000200000 : "kernel"
vcan: Virtual CAN interface driver
FEC Ethernet Driver
fec_enet_mii_bus: probed
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
ARC USBOTG Device Controller driver (1 August 2005)
add wake up source irq 75
g_file_storage gadget: controller 'fsl-usb2-udc' not recognized
check_parameters:UTP settings are in place now, overriding defaults
g_file_storage gadget: No serial-number string provided!
g_file_storage gadget: File-backed Storage Gadget, version: 1 September 2010
g_file_storage gadget: Number of LUNs=1
fsl-usb2-udc: bind to driver g_file_storage
mousedev: PS/2 mouse device common for all mice
egalax_ts 2-0004: egalax_ts: failed to read firmware version
egalax_ts: probe of 2-0004 failed with error -5
generic touchscreen driver, <@>.
g_file_storage gadget: high speed config #1
>>>>> ct360_get_vendor() called <<<<<
Chip ID: 0x0
Chip data allocation failed: 0x0
i2c-core: driver [generic_ts] using legacy suspend method
i2c-core: driver [generic_ts] using legacy resume method
using rtc device, snvs_rtc, for alarms
snvs_rtc snvs_rtc.0: rtc core: registered snvs_rtc as rtc0
i2c /dev entries driver
Linux video capture interface: v2.00
mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as video16
mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as video17
mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as video18
mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as video19
mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as video20
imx2-wdt imx2-wdt.0: IMX2+ Watchdog Timer enabled. timeout=60s (nowayout=1)
Bluetooth: Virtual HCI driver ver 1.3
Bluetooth: Generic Bluetooth USB driver ver 0.6
usbcore: registered new interface driver btusb
sdhci: Secure Digital Host Controller Interface driver
sdhci: Copyright(c) Pierre Ossman
mmc0: Unknown controller version (3). You may experience problems.
mmc0: SDHCI controller on platform [sdhci-esdhc-imx.3] using ADMA
mmc1: Unknown controller version (3). You may experience problems.
mmc1: SDHCI controller on platform [sdhci-esdhc-imx.2] using ADMA
mxc_vdoa mxc_vdoa: i.MX Video Data Order Adapter(VDOA) driver probed
VPU initialized
mxc_asrc registered
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
Cirrus Logic CS42888 ALSA SoC Codec Driver
i2c-core: driver [cs42888] using legacy suspend method
i2c-core: driver [cs42888] using legacy resume method
imx_3stack asoc driver
ALSA device list:
  No soundcards found.
TCP cubic registered
NET: Registered protocol family 17
can: controller area network core (rev 20090105 abi 8)
NET: Registered protocol family 29
can: raw protocol (rev 20090105)
can: broadcast manager protocol (rev 20090105 t)
Bluetooth: RFCOMM TTY layer initialized
Bluetooth: RFCOMM socket layer initialized
Bluetooth: RFCOMM ver 1.11
Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Bluetooth: BNEP filters: protocol multicast
Bluetooth: HIDP (Human Interface Emulation) ver 1.2
VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
Bus freq driver module loaded
mxc_dvfs_core_probe
DVFS driver module loaded
Freeing init memory: 192K
Starting UTP
ln: /etc/mtab: File exists
disable turn off display
Starting the hotplug events dispatcher udevd
udevd (1949): /proc/1949/oom_adj is deprecated, please use /proc/1949/oom_score_adj instead.
Synthesizing initial hotplug events
mmc1: new high speed MMC card at address 0001
mmcblk0: mmc1:0001 SEM16G 14.8 GiB
mmcblk0boot0: mmc1:0001 SEM16G partition 1 2.00 MiB
mmcblk0boot1: mmc1:0001 SEM16G partition 2 2.00 MiB
mmcblk0: p1 p2 p3 < p5 p6 p7 p8 p9 > p4
mmcblk0: p4 size 27287552 extends beyond EOD, truncated
mmcblk0boot1: unknown partition table
mmcblk0boot0: unknown partition table
uuc 0.4 [built May  1 2012 02:47:36]
UTP: Waiting for device to appear
UTP: file/device node /dev/utp already exists
cpu_id is 0
UTP: received command '$ flash_eraseall /dev/mtd0'
UTP: executing "flash_eraseall /dev/mtd0"
Erasing 4 Kibyte @ 40000 -- 100 % complete.
UTP: sending Success to kernel for command $ flash_eraseall /dev/mtd0.
utp_poll: pass returned.
UTP: received command 'send'
UTP: sending Success to kernel for command send.
UTP: received command '$ dd if=$FILE of=/dev/mtd0 bs=512'
UTP: executing "dd if=$FILE of=/dev/mtd0 bs=512"
387+1 records in
387+1 records out
198460 bytes (193.8KB) copied, 6.230347 seconds, 31.1KB/s
UTP: sending Success to kernel for command $ dd if=$FILE of=/dev/mtd0 bs=512.
UTP: received command '$ tar xf $FILE '
UTP: executing "tar xf $FILE "
UTP: sending Success to kernel for command $ tar xf $FILE .
UTP: received command '$ sh mksdcard-android.sh /dev/mmcblk0'
UTP: executing "sh mksdcard-android.sh /dev/mmcblk0"
BOOT   : 16MB
RECOVERY: 8MB
SYSTEM : 512MB
CACHE  : 256MB
DATA   : 1024MB
VENDER : 8MB
MISC   : 8MB
VF mmcblk0: unknown partition table
AT   : 13324MB
1+0 records in
1+0 records out
1024 bytes (1.0KB) copied, 0.001870 seconds, 534.8KB/s
Checking that no-one is using this disk right now ...
OK
Disk /dev/mmcblk0: 486016 cylinders, 4 heads, 16 sectors/track
sfdisk: ERROR: sector 0 does not have an msdos signature
/dev/mmcblk0: unrecognized partition table type
Old situation:
No partitions found
Warning: given size (13324) exceeds max allowable size (13316)
New situation:
Units = mebibytes of 1048576 bytes, blocks of 1024 bytes, counting from 0
   Device Boot Start   End    MiB    #blocks   Id  System
/dev/mmcblk0p1         0+    15     16-     16383+  83  Linux
/dev/mmcblk0p2        16     23      8       8192   83  Linux
/dev/mmcblk0p3        24   1871   1848    1892352    5  Extended
/dev/mmcblk0p4      1872  15195  13324   13643776    b  W95 FAT32
/dev/mmcblk0p5        24+   535    512-    524287+  83  Linux
/dev/mmcblk0p6       536+   791    256-    262143+  83  Linux
/dev/mmcblk0p7       792+  1815   1024-   1048575+  83  Linux
/dev/mmcblk0p8      1816+  1823      8-      8191+  83  Linux
/dev/mmcblk0p9      1824+  1831      8-      8191+  83  Linux
Warning: partition 4 extends past end of disk
Successfully wrote the new partition table
Re-reading the partition table ...
If you created or changed a DOS partition, /dev/foo7, say, then use dd(1)
to zero the first 512 bytes:  dd if=/dev/zero of=/dev/foo7 bs=512 count=1
(See fdisk(8).)
OK
Old situation:
New situation:
/dev/mmcblk0p1         8     15      8       8192   83  Linux
(See fdisk(8).)
UTP: sending Success to kernel for command $ sh mksdcard-android.sh /dev/mmcblk0.
UTP: received command '$ ls -l /dev/mmc* '
UTP: executing "ls -l /dev/mmc* "
brw-r-----    1 root     disk      179,   0 Jan  1 00:00 /dev/mmcblk0
brw-r-----    1 root     disk      179,   8 Jan  1 00:00 /dev/mmcblk0boot0
brw-r-----    1 root     disk      179,  16 Jan  1 00:00 /dev/mmcblk0boot1
brw-r-----    1 root     disk      179,   1 Jan  1 00:00 /dev/mmcblk0p1
brw-r-----    1 root     disk      179,   2 Jan  1 00:00 /dev/mmcblk0p2
brw-r-----    1 root     disk      179,   3 Jan  1 00:00 /dev/mmcblk0p3
brw-r-----    1 root     disk      179,   4 Jan  1 00:00 /dev/mmcblk0p4
brw-r-----    1 root     disk      179,   5 Jan  1 00:00 /dev/mmcblk0p5
brw-r-----    1 root     disk      179,   6 Jan  1 00:00 /dev/mmcblk0p6
brw-r-----    1 root     disk      179,   7 Jan  1 00:00 /dev/mmcblk0p7
brw-r-----    1 root     disk      259,   0 Jan  1 00:00 /dev/mmcblk0p8
brw-r-----    1 root     disk      259,   1 Jan  1 00:00 /dev/mmcblk0p9
UTP: sending Success to kernel for command $ ls -l /dev/mmc* .
UTP: received command '$ dd if=$FILE of=/dev/mmcblk0p1'
UTP: executing "dd if=$FILE of=/dev/mmcblk0p1"
9944+0 records in
9944+0 records out
5091328 bytes (4.9MB) copied, 1.900969 seconds, 2.6MB/s
UTP: sending Success to kernel for command $ dd if=$FILE of=/dev/mmcblk0p1.
UTP: received command 'frf'
UTP: closing the file
UTP: sending Success to kernel for command frf.
UTP: received command '$ mkfs.vfat /dev/mmcblk0p4'
UTP: executing "mkfs.vfat /dev/mmcblk0p4"
mkfs.vfat 3.0.11 (24 Dec 2010)
UTP: sending Success to kernel for command $ mkfs.vfat /dev/mmcblk0p4.
UTP: received command '$ mkfs.ext4 /dev/mmcblk0p5'
UTP: executing "mkfs.ext4 /dev/mmcblk0p5"
mke2fs 1.41.4 (27-Jan-2009)
Filesystem label=
OS type: Linux
Block size=1024 (log=0)
Fragment size=1024 (log=0)
131072 inodes, 524284 blocks
26214 blocks (5.00%) reserved for the super user
First data block=1
Maximum filesystem blocks=67633152
64 block groups
8192 blocks per group, 8192 fragments per group
2048 inodes per group
Superblock backups stored on blocks:
        8193, 24577, 40961, 57345, 73729, 204801, 221185, 401409
Writing inode tables: done
Creating journal (8192 blocks): done
Writing superblocks and filesystem accounting information: done
This filesystem will be automatically checked every 31 mounts or
180 days, whichever comes first.  Use tune2fs -c or -i to override.
UTP: sending Success to kernel for command $ mkfs.ext4 /dev/mmcblk0p5.
UTP: received command '$ mkfs.ext4 -O^extent /dev/mmcblk0p6'
UTP: executing "mkfs.ext4 -O^extent /dev/mmcblk0p6"
Filesystem label=
OS type: Linux
65536 inodes, 262140 blocks
13107 blocks (5.00%) reserved for the super user
First data block=1
Maximum filesystem blocks=67371008
32 block groups
Creating journal (4096 blocks): done
This filesystem will be automatically checked every 36 mounts or
UTP: sending Success to kernel for command $ mkfs.ext4 -O^extent /dev/mmcblk0p6.
UTP: received command '$ mkfs.ext4 /dev/mmcblk0p7'
UTP: executing "mkfs.ext4 /dev/mmcblk0p7"
Filesystem label=
OS type: Linux
Block size=4096 (log=2)
Fragment size=4096 (log=2)
65536 inodes, 262143 blocks
First data block=0
Maximum filesystem blocks=268435456
8 block groups
32768 blocks per group, 32768 fragments per group
8192 inodes per group
        32768, 98304, 163840, 229376
This filesystem will be automatically checked every 37 mounts or
UTP: sending Success to kernel for command $ mkfs.ext4 /dev/mmcblk0p7.
UTP: received command '$ mkfs.ext4 /dev/mmcblk0p8'
UTP: executing "mkfs.ext4 /dev/mmcblk0p8"
Filesystem label=
OS type: Linux
2048 inodes, 8188 blocks
409 blocks (5.00%) reserved for the super user
First data block=1
Maximum filesystem blocks=8388608
1 block group
Creating journal (1024 blocks): done
UTP: sending Success to kernel for command $ mkfs.ext4 /dev/mmcblk0p8.
UTP: received command 'pipe dd of=/dev/mmcblk0p5 bs=512'
pid is 3200, UTP: executing "dd of=/dev/mmcblk0p5 bs=512"
UTP: sending Success to kernel for command pipe dd of=/dev/mmcblk0p5 bs=512.
409600+0 records in
409600+0 records out
209715200 bytes (200.0MB) copied, 51.530922 seconds, 3.9MB/s
UTP: received command 'pipe dd of=/dev/mmcblk0p2 bs=512'
pid is 3202, UTP: executing "dd of=/dev/mmcblk0p2 bs=512"
UTP: sending Success to kernel for command pipe dd of=/dev/mmcblk0p2 bs=512.
11460+0 records in
11460+0 records out
5867520 bytes (5.6MB) copied, 1.547250 seconds, 3.6MB/s
UTP: received command '$ echo Update Complete!'
UTP: executing "echo Update Complete!"
Update Complete!
UTP: sending Success to kernel for command $ echo Update Complete!.
我知道答案 目前已有7人回答
发表于 2015-1-12 18:04:35 | 显示全部楼层
楼主你好,烧写过程没有什么问题,你看一下你的boot mode是否设置正确了?
发表于 2015-2-6 11:16:31 | 显示全部楼层
楼主你好,请问你问题是否已经解决了?
    发表于 2015-6-9 16:34:00 | 显示全部楼层
    遇到同样的问题,请问如何解决的啊?
    碎发碎
    发表于 2015-6-9 18:19:10 | 显示全部楼层
    看不懂什么意思
    发表于 2015-6-9 20:16:34 | 显示全部楼层
    看来问题是解决了
    falajf
    发表于 2015-9-8 10:29:28 | 显示全部楼层
    楼主,你的问题解决了吗?我也遇到同样的问题,卡住了。使用MFGtools烧写完以后,上电:
    U-Boot 2009.08-dirty (Apr 14 2015 - 17:23:22)
    CPU: Freescale i.MX6 family TO1.2 at 792 MHz
    Thermal sensor with ratio = 188
    Temperature:   41 C, calibration data 0x5a750b69
    mx6q pll1: 792MHz
    mx6q pll2: 528MHz
    mx6q pll3: 480MHz
    mx6q pll8: 50MHz
    emi_slow clock: 132000000Hz
    Board: i.MX6Q-SABRESD: unknown-board Board: 0x63012 [WDOG ]
    Boot Device: SPI NOR
    I2C:   ready
    DRAM:   1 GB
    MMC:   FSL_USDHC: 0,FSL_USDHC: 1,FSL_USDHC: 2
    JEDEC ID: 0xbf:0x25:0x41
    Reading SPI NOR flash 0xc0000 [0x2000 bytes] -> ram 0x27600ac0
    SUCCESS
    In:    serial
    Out:   serial
    Err:   serial
    FEC0 [PRIME]
    kernel   @ 14008000 (6723120)
    ramdisk  @ 15000000 (497370)
    kernel cmdline:
            use boot.img command line:
            console=ttymxc0,115200 init=/init video=mxcfb0:dev=ldb,bpp=32 video=mxcfb1ff video=mxcfb2ff video=mxcfb3ff vmalloc=400M androidboot.console=ttymxc0 consoleblank=0 androidboot.hardware=freescale cma=384M
    Starting kernel ...
    就一直卡在这里不动了
    发表于 2015-9-8 10:44:18 | 显示全部楼层
    感觉还是kernel没有配置好吧
    GMT+8, 2025-10-28 23:54 , Processed in 0.094711 second(s), 28 queries , MemCache On.
