查看: 3930|回复: 6
[求助] MKL26Z128VHL4中断向量表问题
发表于 2015-1-14 10:28:24 | 显示全部楼层 |阅读模式
以下是官方KEIL工程startup_MKL26Z4.s向量表定义
                AREA    RESET, DATA, READONLY
                EXPORT  __Vectors
                EXPORT  __Vectors_End
                EXPORT  __Vectors_Size
__Vectors       DCD     __initial_sp  ; Top of Stack
                DCD     Reset_Handler  ; Reset Handler
                DCD     NMI_Handler  ; NMI Handler
                DCD     HardFault_Handler  ; Hard Fault Handler
                DCD     0  ; Reserved
                DCD     0  ; Reserved
                DCD     0  ; Reserved
                DCD     0  ; Reserved
                DCD     0  ; Reserved
                DCD     0  ; Reserved
                DCD     0  ; Reserved
                DCD     SVC_Handler  ; SVCall Handler
                DCD     0  ; Reserved
                DCD     0  ; Reserved
                DCD     PendSV_Handler  ; PendSV Handler
                DCD     SysTick_Handler  ; SysTick Handler
                ; External Interrupts
                DCD     DMA0_IRQHandler  ; DMA channel 0 transfer complete/error interrupt
                DCD     DMA1_IRQHandler  ; DMA channel 1 transfer complete/error interrupt
                DCD     DMA2_IRQHandler  ; DMA channel 2 transfer complete/error interrupt
                DCD     DMA3_IRQHandler  ; DMA channel 3 transfer complete/error interrupt
                DCD     Reserved20_IRQHandler  ; Reserved interrupt 20
                DCD     FTFA_IRQHandler  ; FTFA command complete/read collision interrupt
                DCD     LVD_LVW_IRQHandler  ; Low Voltage Detect, Low Voltage Warning
                DCD     LLW_IRQHandler  ; Low Leakage Wakeup
                DCD     I2C0_IRQHandler  ; I2C0 interrupt
                DCD     I2C1_IRQHandler  ; I2C0 interrupt 25
                DCD     SPI0_IRQHandler  ; SPI0 interrupt
                DCD     SPI1_IRQHandler  ; SPI1 interrupt
                DCD     UART0_IRQHandler  ; UART0 status/error interrupt
                DCD     UART1_IRQHandler  ; UART1 status/error interrupt
                DCD     UART2_IRQHandler  ; UART2 status/error interrupt
                DCD     ADC0_IRQHandler  ; ADC0 interrupt
                DCD     CMP0_IRQHandler  ; CMP0 interrupt
                DCD     TPM0_IRQHandler  ; TPM0 fault, overflow and channels interrupt
                DCD     TPM1_IRQHandler  ; TPM1 fault, overflow and channels interrupt
                DCD     TPM2_IRQHandler  ; TPM2 fault, overflow and channels interrupt
                DCD     RTC_IRQHandler  ; RTC interrupt
                DCD     RTC_Seconds_IRQHandler  ; RTC seconds interrupt
                DCD     PIT_IRQHandler  ; PIT timer interrupt
                DCD     I2S0_IRQHandler  ; I2S0 transmit interrupt
                DCD     USB0_IRQHandler  ; USB0 interrupt
                DCD     DAC0_IRQHandler  ; DAC0 interrupt
                DCD     TSI0_IRQHandler  ; TSI0 interrupt
                DCD     MCG_IRQHandler  ; MCG interrupt
                DCD     LPTimer_IRQHandler  ; LPTimer interrupt
                DCD     Reserved45_IRQHandler  ; Reserved interrupt 45
                DCD     PORTA_IRQHandler  ; Port A interrupt
                DCD     PORTD_IRQHandler  ; Port D interrupt
__Vectors_End
__Vectors_Size         EQU     __Vectors_End - __Vectors
KL26P121M48SF4RM.pdf(支持MKL26Z128VLH4)描述:
可以看到多了一个PMC中断,是否有人验证过这个问题
我知道答案 目前已有6人回答
    发表于 2015-1-14 11:19:25 | 显示全部楼层
    没有测试过,楼主有兴趣可以开启低电压检测中断,在电压跌落时是否会进入中断。
     楼主| 发表于 2015-1-14 13:26:13 | 显示全部楼层
    安 发表于 2015-1-14 11:19
    没有测试过,楼主有兴趣可以开启低电压检测中断,在电压跌落时是否会进入中断。 ...
    不单是PCM问题,后面的向量表全乱了
    发表于 2015-1-14 14:04:37 | 显示全部楼层
    hdfghd 发表于 2015-1-14 13:26
    不单是PCM问题,后面的向量表全乱了
    你好,
    参考手册中的PMC中断就是对应 DCD     LVD_LVW_IRQHandler  ; Low Voltage Detect, Low Voltage Warning
    你看两者的功能描述是一致的
    发表于 2015-1-14 14:52:58 | 显示全部楼层
    楼主,向量表不是一一对应吗?能说一下哪儿乱了吗?
     楼主| 发表于 2015-1-14 15:08:45 | 显示全部楼层
    抱歉,把LVD_LVW_IRQHandler  看成LLW_IRQHandler  了
    发表于 2015-1-15 09:44:37 | 显示全部楼层
    OK,有问题再交流!
    GMT+8, 2025-11-10 09:39 , Processed in 0.094260 second(s), 27 queries , MemCache On.
