查看: 5471|回复: 5
[求助] IMX6 uboot无法启动内核
发表于 2015-1-27 09:45:22 | 显示全部楼层 |阅读模式
现在我将UBOOT 下到SPI nor 里,将KERNEL 下在emmc里,uboot参数设置好以后,无法启动内核,出现MMC read: dev # 0, block # 2048, count 8192 ... 8192 blocks read: OK
Wrong Image Format for bootm command
ERROR: can't get kernel image
求解!!
uboot的环境变量:
MX6Q SABRELITE U-Boot > print
bootdelay=3
baudrate=115200
ipaddr=192.168.1.103
serverip=_SERVER_IP_ADDR_
netmask=255.255.255.0
loadaddr=0x10800000
rd_loadaddr=0x11000000
netdev=eth0
ethprime=FEC0
ethaddr=00:01:02:03:04:05
uboot=u-boot.bin
kernel=uImage
bootargs_base=setenv bootargs console=ttymxc0,115200
bootargs_mmc=setenv bootargs ${bootargs} root=/dev/mmcblk0p5 rootwait rw video=mxcfb0:dev=ldb,LDB-XGA,if=RGB666 video=mxcfb0:dev=hdmi,1920x1080M@60,if=RGB24
bootcmd_mmc=run bootargs_base bootargs_mmc;mmc dev 1;mmc read ${loadaddr} 0x800 0x2000;bootm
bootcmd=run bootcmd_mmc
stdin=serial
stdout=serial
stderr=serial
ethact=FEC0
bootargs=console=ttymxc0,115200 root=/dev/mmcblk0p5 rootwait rw video=mxcfb0:dev=ldb,LDB-XGA,if=RGB666 video=mxcfb0:dev=hdmi,1920x1080M@60,if=RGB24
xml的烧写步骤:
  <CMD type="push" body="$ flash_eraseall /dev/mtd0">Erasing Boot partition</CMD>
    <CMD type="push" body="send" file="files/android/u-boot.bin">Sending U-Boot</CMD>
    <CMD type="push" body="$ dd if=$FILE of=/dev/mtd0 bs=512">write U-Boot to SPI-NOR</CMD>
    <!-- uncomment below if you store uboot env in your SD card. -->
       <CMD type="push" body="$ dd if=/dev/zero of=/dev/mmcblk0 bs=1M count=6">clean up</CMD>
    <CMD type="push" body="send" file="mksdcard-android.sh.tar">Sending partition shell</CMD>
    <CMD type="push" body="$ tar xf $FILE "> Partitioning...</CMD>
    <CMD type="push" body="$ sh mksdcard-android.sh /dev/mmcblk0"> Partitioning...</CMD>
    <CMD type="push" body="$ ls -l /dev/mmc* ">Formatting sd partition</CMD>
    <CMD type="push" body="send" file="files/android/uImage">Sending kernel uImage</CMD>
    <CMD type="push" body="$ dd if=$FILE of=/dev/mmcblk0p0">write boot.img</CMD>
    <CMD type="push" body="frf">flush the memory.</CMD>
我知道答案 目前已有5人回答
发表于 2015-1-30 16:04:48 | 显示全部楼层
看看uboot有没有修改为支持eMMC启动。
发表于 2015-1-31 21:29:59 | 显示全部楼层
修改为支持eMMC启动
发表于 2015-1-31 21:30:01 | 显示全部楼层
地板围观
发表于 2015-1-31 21:30:16 | 显示全部楼层
围观学习下
发表于 2015-2-6 10:48:30 | 显示全部楼层
楼主你好,请问你u-boot中参数设置的正确吗?看到你帖中的内容应该是u-boot中的kernel启动的参数没有设置正确。建议你把你的u-boot参数设置发给我看一下哈~~
GMT+8, 2025-10-30 07:46 , Processed in 0.077889 second(s), 25 queries , MemCache On.
