查看: 3709|回复: 8
[分享] KL02Z使用IAR6.70+J-Link单步调试不了,提示Warning
  • 签到天数: 64 天
    发表于 2015-1-28 10:51:24 | 显示全部楼层 |阅读模式
    KL02Z的mcu使用IAR6.70+J-Link单步debug,工程中点击Download and Debug时,弹出Driver对话框,提示如下:
    Waring:__vector_table symbol not found.
    e_entry value:0x00002F90 does not match resrt vector value:0x00000410  Intitial SP_main value:0x200005F8 uncertain.
    点击确定,然后Stack Warning对话框提示:The stack plug-in failed to set a breakpoint on "main".The Stack window wil not be able to display stack contents.(You can change this setting in the Tool>Options dialog box.)最后进不了main函数调试。是设置哪里有问题吗?为什么另一份工程设置和这个一样,可以单步,而这个工程不行呢?icf文件配置如下:/*###ICF### Section handled by ICF editor, don't touch! ****//*-Editor annotation file-*//* IcfEditorFile="$TOOLKIT_DIR$\config\ide\IcfEditor\cortex_v1_0.xml" *//*-Memory Regions-*/define symbol __ICFEDIT_region_ROM_start__ = 0x0;define symbol __ICFEDIT_region_ROM_end__   = (16*1024);                                                              //********0x0;define symbol __ICFEDIT_region_RAM_end__   = 0x20000000;define symbol __ICFEDIT_region_RAM_start__ = __ICFEDIT_region_RAM_end__ - (2*1024)/4;  //********/*-Specials-*/define symbol __ICFEDIT_intvec_start__ = __ICFEDIT_region_ROM_start__ + 0x1400;       //app start address/*-Sizes-*/define symbol __ICFEDIT_size_cstack__ = (0x200);  //********define symbol __ICFEDIT_size_heap__   = (0x200);  //********/**** End of ICF editor section. ###ICF###*/define symbol __region_RAM2_start__        = 0x20000000;define symbol __region_RAM2_end__          = __region_RAM2_start__ + ((2*1024)*3)/4;//********/*boot and app devide*/define symbol __region_BOOT_start__        = __ICFEDIT_region_ROM_start__;define symbol __region_BOOT_end__          = 0x00000FFF;define symbol __region_APP_start__         = 0x00001400;define symbol __region_APP_end__           = __ICFEDIT_region_ROM_end__;define symbol __region_BOOT_VECTOR_start__        = __ICFEDIT_region_ROM_start__;        define symbol __region_APP_VECTOR_start__         = __region_APP_start__;        define exported symbol __VECTOR_TABLE      = __region_APP_VECTOR_start__;define exported symbol __VECTOR_RAM        = __ICFEDIT_region_RAM_start__ - 0x410;define exported symbol __BOOT_STACK_ADDRESS = __region_RAM2_end__ - 8;define symbol __code_start__ = __region_APP_start__ + 0x410;//********define memory mem with size = 4G;//define region ROM_region   = mem:[from __ICFEDIT_region_ROM_start__   to __ICFEDIT_region_ROM_end__];// | mem:[from __region_FlexNVM_start__ to __region_FlexNVM_end__];//********define region ROM_region   = mem:[from __ICFEDIT_intvec_start__   to __ICFEDIT_region_ROM_end__];define region RAM_region   = mem:[from __ICFEDIT_region_RAM_start__   to __region_RAM2_end__] | mem:[from __region_RAM2_start__ to __region_RAM2_end__];define block CSTACK    with alignment = 8, size = __ICFEDIT_size_cstack__   { };define block HEAP      with alignment = 8, size = __ICFEDIT_size_heap__     { };//define region FlashConfig_region = mem:[from __FlashConfig_start__ to __FlashConfig_end__];initialize manually { readwrite };initialize manually { section .data};initialize manually { section .textrw };do not initialize  { section .noinit };define block CodeRelocate { section .textrw_init };define block CodeRelocateRam { section .textrw };place at address mem:__ICFEDIT_intvec_start__ { readonly section .intvec };place at address mem:__code_start__ { readonly section .noinit };place in ROM_region   { readonly, block CodeRelocate};place in RAM_region   { readwrite, block CodeRelocateRam,                        block CSTACK, block HEAP };
    __VECTOR_TABLE 从0x00001400开始,__code_start__ 从0x00001810开始。急!在线等!盼答复!!!
  • 签到天数: 64 天
     楼主| 发表于 2015-1-28 10:53:15 | 显示全部楼层
    icf贴进去的看起来乱了,见附件
    16KB_Pflash_app_boot.rar
    939 Bytes, 下载次数: 0, 下载积分: 威望 1
  • 签到天数: 64 天
     楼主| 发表于 2015-1-28 11:41:44 | 显示全部楼层
    自己顶起来
  • 签到天数: 64 天
     楼主| 发表于 2015-1-28 11:56:32 | 显示全部楼层
    吃饭前在顶下
  • 签到天数: 64 天
     楼主| 发表于 2015-1-28 14:03:47 | 显示全部楼层
  • 签到天数: 64 天
     楼主| 发表于 2015-1-28 17:08:41 | 显示全部楼层
    沉了?
    发表于 2015-1-29 09:15:41 | 显示全部楼层
    看你的第一帖看得眼睛都肿了,下次直接截图吧!
    你将对话框提示也截图出来,这样形象一点。最后一点,你这个工程是官方例程吗?
    发表于 2015-1-29 09:32:37 | 显示全部楼层
    代码贴的好
  • 签到天数: 64 天
     楼主| 发表于 2015-1-29 12:00:33 | 显示全部楼层
    1111111111111111111
    Driver_Warning.rar
    51.82 KB, 下载次数: 2, 下载积分: 威望 1
    warning.rar
    106.82 KB, 下载次数: 1, 下载积分: 威望 1
    GMT+8, 2025-11-10 03:43 , Processed in 0.132972 second(s), 28 queries , MemCache On.
