查看: 3721|回复: 2
[求助] 【Sabrelite参考设计,将DDR3型号更换,板子不通】
发表于 2015-2-3 21:47:57 | 显示全部楼层 |阅读模式
根据Sabrelite的公版参考设计,更改了电源,Sabrelite是用RT8070产生了几组电压,现在改成MMPF0100F0EP产生电压,主要区别是VDD_ARM_IN和VDD_ARM23_IN电压变化,Sabrelite原来是1.2V,现在是1.37V。将DDR3由MT41J128M16HA-15EIT换成了H5TQ2G63DFR-PBC,板子不通了。
参考FAE的http://bbs.21ic.com/icview-792090-1-1.html这个帖子
下载了DDR Stress Tester工具。用DDR3脚本设置参数,如下图所示(图11)
生成的inc文件
//init script for i.Mx6Q DDR3
// Revision History
// v01
wait = on
// Disable WDOG
//setmem /16 0x020bc000 = 0x30
// Enable all clocks (they are disabled by ROM code)
setmem /32 0x020c4068 = 0xffffffff
setmem /32 0x020c406c = 0xffffffff
setmem /32 0x020c4070 = 0xffffffff
setmem /32 0x020c4074 = 0xffffffff
setmem /32 0x020c4078 = 0xffffffff
setmem /32 0x020c407c = 0xffffffff
setmem /32 0x020c4080 = 0xffffffff
setmem /32 0x020c4084 = 0xffffffff
// IOMUX
//DDR IO TYPE:
setmem /32 0x020e0798 = 0x000C0000 // IOMUXC_SW_PAD_CTL_GRP_DDR_TYPE
setmem /32 0x020e0758 = 0x00000000 // IOMUXC_SW_PAD_CTL_GRP_DDRPKE
//CLOCK:
setmem /32 0x020e0588 = 0x00000028 // IOMUXC_SW_PAD_CTL_PAD_DRAM_SDCLK_0
setmem /32 0x020e0594 = 0x00000028 // IOMUXC_SW_PAD_CTL_PAD_DRAM_SDCLK_1
//ADDRESS:
setmem /32 0x020e056c = 0x00000028 // IOMUXC_SW_PAD_CTL_PAD_DRAM_CAS
setmem /32 0x020e0578 = 0x00000028 // IOMUXC_SW_PAD_CTL_PAD_DRAM_RAS
setmem /32 0x020e074c = 0x00000028 // IOMUXC_SW_PAD_CTL_GRP_ADDDS
//Control:
setmem /32 0x020e057c = 0x00000028 // IOMUXC_SW_PAD_CTL_PAD_DRAM_RESET
setmem /32 0x020e058c = 0x00000000 // IOMUXC_SW_PAD_CTL_PAD_DRAM_SDBA2 - DSE can be configured using Group Control Register: IOMUXC_SW_PAD_CTL_GRP_CTLDS
setmem /32 0x020e059c = 0x00000028 // IOMUXC_SW_PAD_CTL_PAD_DRAM_SDODT0
setmem /32 0x020e05a0 = 0x00000028 // IOMUXC_SW_PAD_CTL_PAD_DRAM_SDODT1
setmem /32 0x020e078c = 0x00000028 // IOMUXC_SW_PAD_CTL_GRP_CTLDS
//Data Strobes:
setmem /32 0x020e0750 = 0x00020000 // IOMUXC_SW_PAD_CTL_GRP_DDRMODE_CTL
setmem /32 0x020e05a8 = 0x00000028 // IOMUXC_SW_PAD_CTL_PAD_DRAM_SDQS0
setmem /32 0x020e05b0 = 0x00000028 // IOMUXC_SW_PAD_CTL_PAD_DRAM_SDQS1
setmem /32 0x020e0524 = 0x00000028 // IOMUXC_SW_PAD_CTL_PAD_DRAM_SDQS2
setmem /32 0x020e051c = 0x00000028 // IOMUXC_SW_PAD_CTL_PAD_DRAM_SDQS3
setmem /32 0x020e0518 = 0x00000028 // IOMUXC_SW_PAD_CTL_PAD_DRAM_SDQS4
setmem /32 0x020e050c = 0x00000028 // IOMUXC_SW_PAD_CTL_PAD_DRAM_SDQS5
setmem /32 0x020e05b8 = 0x00000028 // IOMUXC_SW_PAD_CTL_PAD_DRAM_SDQS6
setmem /32 0x020e05c0 = 0x00000028 // IOMUXC_SW_PAD_CTL_PAD_DRAM_SDQS7
//Data:
setmem /32 0x020e0774 = 0x00020000 // IOMUXC_SW_PAD_CTL_GRP_DDRMODE
setmem /32 0x020e0784 = 0x00000028 // IOMUXC_SW_PAD_CTL_GRP_B0DS
setmem /32 0x020e0788 = 0x00000028 // IOMUXC_SW_PAD_CTL_GRP_B1DS
setmem /32 0x020e0794 = 0x00000028 // IOMUXC_SW_PAD_CTL_GRP_B2DS
setmem /32 0x020e079c = 0x00000028 // IOMUXC_SW_PAD_CTL_GRP_B3DS
setmem /32 0x020e07a0 = 0x00000028 // IOMUXC_SW_PAD_CTL_GRP_B4DS
setmem /32 0x020e07a4 = 0x00000028 // IOMUXC_SW_PAD_CTL_GRP_B5DS
setmem /32 0x020e07a8 = 0x00000028 // IOMUXC_SW_PAD_CTL_GRP_B6DS
setmem /32 0x020e0748 = 0x00000028 // IOMUXC_SW_PAD_CTL_GRP_B7DS
setmem /32 0x020e05ac = 0x00000028 // IOMUXC_SW_PAD_CTL_PAD_DRAM_DQM0
setmem /32 0x020e05b4 = 0x00000028 // IOMUXC_SW_PAD_CTL_PAD_DRAM_DQM1
setmem /32 0x020e0528 = 0x00000028 // IOMUXC_SW_PAD_CTL_PAD_DRAM_DQM2
setmem /32 0x020e0520 = 0x00000028 // IOMUXC_SW_PAD_CTL_PAD_DRAM_DQM3
setmem /32 0x020e0514 = 0x00000028 // IOMUXC_SW_PAD_CTL_PAD_DRAM_DQM4
setmem /32 0x020e0510 = 0x00000028 // IOMUXC_SW_PAD_CTL_PAD_DRAM_DQM5
setmem /32 0x020e05bc = 0x00000028 // IOMUXC_SW_PAD_CTL_PAD_DRAM_DQM6
setmem /32 0x020e05c4 = 0x00000028 // IOMUXC_SW_PAD_CTL_PAD_DRAM_DQM7
// DDR Controller Registers
// Manufacturer: hynix
// Device Part Number: H5TQ2G63DFR-PBC
// Clock Freq.:  528MHz
// Density per CS in Gb:  8
// Chip Selects used: 1
// Number of Banks: 8
// Row address:     14
// Column address:  10
// Data bus width 64
setmem /32 0x021b001c = 0x00008000 MMDC0_MDSCR, set the Configuration request bit during MMDC set up
// Calibration setup.
setmem /32 0x021b0800 = 0xA1390003 // DDR_PHY_P0_MPZQHWCTRL, enable both one-time & periodic HW ZQ calibration.
// For target board, may need to run write leveling calibration to fine tune these settings.
setmem /32 0x021b080c  = 0x00000000
setmem /32 0x021b0810 = 0x00000000
setmem /32 0x021b480c  = 0x00000000
setmem /32 0x021b4810 = 0x00000000
////Read DQS Gating calibration
setmem /32 0x021b083c = 0x00000000 // MPDGCTRL0 PHY0
setmem /32 0x021b0840 = 0x00000000 // MPDGCTRL1 PHY0
setmem /32 0x021b483c = 0x00000000 // MPDGCTRL0 PHY1
setmem /32 0x021b4840 = 0x00000000 // MPDGCTRL1 PHY1
//Read calibration
setmem /32 0x021b0848 = 0x40404040 // MPRDDLCTL PHY0
setmem /32 0x021b4848 = 0x40404040 // MPRDDLCTL PHY1
//Write calibration
setmem /32 0x021b0850 = 0x40404040 // MPWRDLCTL PHY0
setmem /32 0x021b4850 = 0x40404040 // MPWRDLCTL PHY1
//read data bit delay: (3 is the reccommended default value, although out of reset value is 0)
setmem /32 0x021b081c = 0x33333333 // DDR_PHY_P0_MPREDQBY0DL3
setmem /32 0x021b0820 = 0x33333333 // DDR_PHY_P0_MPREDQBY1DL3
setmem /32 0x021b0824 = 0x33333333 // DDR_PHY_P0_MPREDQBY2DL3
setmem /32 0x021b0828 = 0x33333333 // DDR_PHY_P0_MPREDQBY3DL3
setmem /32 0x021b481c = 0x33333333 // DDR_PHY_P1_MPREDQBY0DL3
setmem /32 0x021b4820 = 0x33333333 // DDR_PHY_P1_MPREDQBY1DL3
setmem /32 0x021b4824 = 0x33333333 // DDR_PHY_P1_MPREDQBY2DL3
setmem /32 0x021b4828 = 0x33333333 // DDR_PHY_P1_MPREDQBY3DL3
//For i.mx6qd parts of versions A & B (v1.0, v1.1), uncomment the following lines. For version C (v1.2), keep commented
//setmem /32 0x021b08c0 = 0x24911492 // fine tune SDCLK duty cyc to low - seen to improve measured duty cycle of i.mx6
//setmem /32 0x021b48c0 = 0x24911492
// Complete calibration by forced measurement:
setmem /32 0x021b08b8 =  0x00000800 // DDR_PHY_P0_MPMUR0, frc_msr
setmem /32 0x021b48b8 =  0x00000800 // DDR_PHY_P0_MPMUR0, frc_msr
// Calibration setup end
//MMDC init:
setmem /32 0x021b0004 = 0x00020036 // MMDC0_MDPDC
setmem /32 0x021b0008 = 0x09444040 // MMDC0_MDOTC
setmem /32 0x021b000c = 0x54597955 // MMDC0_MDCFG0
setmem /32 0x021b0010 = 0xFF328F64 // MMDC0_MDCFG1
setmem /32 0x021b0014 = 0x01FF00DB // MMDC0_MDCFG2
//MDMISC: RALAT kept to the high level of 5.
//MDMISC: consider reducing RALAT if your 528MHz board design allow that. Lower RALAT benefits:
//a. better operation at low frequency, for LPDDR2 freq < 100MHz, change RALAT to 3
//b. Small performence improvment
setmem /32 0x021b0018 = 0x00011740 // MMDC0_MDMISC
setmem /32 0x021b001c = 0x00008000 // MMDC0_MDSCR, set the Configuration request bit during MMDC set up
setmem /32 0x021b002c = 0x000026D2 // MMDC0_MDRWD
setmem /32 0x021b0030 = 0x00591023 // MMDC0_MDOR
setmem /32 0x021b0040 = 0x00000027 // Chan0 CS0_END
setmem /32 0x021b0000 = 0x831A0000 // MMDC0_MDCTL
//Mode register writes
setmem /32 0x021b001c = 0x02088032 // MMDC0_MDSCR, MR2 write, CS0
setmem /32 0x021b001c = 0x00008033 // MMDC0_MDSCR, MR3 write, CS0
setmem /32 0x021b001c = 0x00048031 // MMDC0_MDSCR, MR1 write, CS0
setmem /32 0x021b001c = 0x19408030 // MMDC0_MDSCR, MR0write, CS0
setmem /32 0x021b001c = 0x04008040 // MMDC0_MDSCR, ZQ calibration command sent to device on CS0
//setmem /32 0x021b001c = 0x0208803A // MMDC0_MDSCR, MR2 write, CS1
//setmem /32 0x021b001c = 0x0000803B // MMDC0_MDSCR, MR3 write, CS1
//setmem /32 0x021b001c = 0x00048039 // MMDC0_MDSCR, MR1 write, CS1
//setmem /32 0x021b001c = 0x19408038 // MMDC0_MDSCR, MR0write, CS1
//setmem /32 0x021b001c = 0x04008048 // MMDC0_MDSCR, ZQ calibration command sent to device on CS1
setmem /32 0x021b0020 = 0x00007800 // MMDC0_MDREF
setmem /32 0x021b0818 = 0x00022227 // DDR_PHY_P0_MPODTCTRL
setmem /32 0x021b4818 = 0x00022227 // DDR_PHY_P1_MPODTCTRL
setmem /32 0x021b0004 = 0x00025576 // MMDC0_MDPDC now SDCTL power down enabled
setmem /32 0x021b0404 = 0x00011006 // MMDC0_MAPSR ADOPT power down enabled, MMDC will enter automatically to self-refresh while the number of idle cycle reached.
setmem /32 0x021b001c = 0x00000000 // MMDC0_MDSCR, clear this register (especially the configuration bit as initialization is complete)
根据Userguid,运行Tester工具,出现如下显示(22)
请问可能是什么问题:
1、核电压的改变,对DDR3控制器有什么影响?
2、DDR3型号改变,有什么影响?
我知道答案 目前已有2人回答
 楼主| 发表于 2015-2-3 22:14:34 | 显示全部楼层
1、核电压的变更,对DDR控制器有什么影响,1.2V->1.37V,
2、DDR3的型号变更,有什么影响,如果要换型号,应该改哪些东西?
发表于 2015-3-8 15:40:01 | 显示全部楼层
楼主你好,很抱歉才给你回复。DDR型号变更的话,首先你要根据i.Mx6DQSDL DDR3 ScriptAid中的选项参考你的DDR3的数据手册修改相关参数,然后修改相关BSP中的内容,然后做DDR 压力测试,校准以后,DDR3就可以正常工作了,详细的步骤参考文档:
http://bbs.21ic.com/icview-788962-1-1.html
GMT+8, 2025-10-29 19:45 , Processed in 0.167219 second(s), 24 queries , MemCache On.
