查看: 4045|回复: 2
[求助] SGTl5000录音失败
发表于 2015-2-6 09:20:34 | 显示全部楼层 |阅读模式
大家好,最近我在调试SGTL5000,播放功能已经没有问题,但是录音功能还没调通,不知是哪里出了问题,录音操作和播放可以进行,也可以形成音频文件,但是播放没有声音,以下是测试过程:
arecord -l
**** List of CAPTURE Hardware Devices ****
card 0: sgtl5000audio [sgtl5000-audio], device 0: HiFi sgtl5000-0 []
  Subdevices: 1/1
  Subdevice #0: subdevice #0
aplay -l
**** List of PLAYBACK Hardware Devices ****
  Subdevices: 1/1
arecord -Dplughw:0,0 -r 48000 -f S16_LE -c 2 -d 5 record.wav
Recording WAVE 'record.wav' : Signed 16 bit Little Endian, Rate 48000 Hz, Stereo
aplay -Dplughw:0,0 record.wav
Playing WAVE 'record.wav' : Signed 16 bit Little Endian, Rate 48000 Hz, Stereo
耳机和音响听不到任何声音,有没有人知道是哪里出了问题?谢谢!
我知道答案 目前已有2人回答
 楼主| 发表于 2015-2-27 17:03:27 | 显示全部楼层
运行alsamixer也没有任何帮助,一下是amixer输出结果:
root@linaro-ubuntu-desktop:~# amixer
Simple mixer control 'Headphone',0
  Capabilities: pvolume penum
  Playback channels: Front Left - Front Right
  Limits: Playback 0 - 127
  Mono:
  Front Left: Playback 106 [83%] [1.50dB]
  Front Right: Playback 106 [83%] [1.50dB]
Simple mixer control 'Headphone Mux',0
  Capabilities: enum
  Items: 'DAC' 'LINE_IN'
  Item0: 'DAC'
Simple mixer control 'Headphone Playback ZC',0
  Capabilities: pswitch pswitch-joined penum
  Playback channels: Mono
  Mono: Playback [on]
Simple mixer control 'Speaker Function',0
  Capabilities: enum
  Items: 'off' 'on'
  Item0: 'off'
Simple mixer control 'Bass',0
  Capabilities: volume volume-joined penum
  Capture channels: Mono
  Limits: 0 - 63
  Mono: 58 [92%]
Simple mixer control 'Bass Enable',0
  Mono: Playback [off]
Simple mixer control 'Bass Filter Feq',0
  Limits: 0 - 7
  Mono: 1 [14%]
Simple mixer control 'Bass Level',0
  Limits: 0 - 127
  Mono: 96 [76%]
Simple mixer control 'PCM',0
  Limits: Playback 0 - 156
  Mono:
  Front Left: Playback 117 [75%]
  Front Right: Playback 117 [75%]
Simple mixer control 'Surround Width',0
  Limits: 0 - 7
  Mono: 4 [57%]
Simple mixer control 'Line In Function',0
  Capabilities: enum
  Items: 'off' 'on'
  Item0: 'off'
Simple mixer control 'Mic',0
  Limits: 0 - 4
  Mono: 3 [75%] [40.00dB]
Simple mixer control 'I2S_OUT',0
  Capabilities: enum
  Items: 'ADC' 'I2S_IN' 'reserved' 'DAP'
  Item0: 'I2S_IN'
Simple mixer control 'Capture',0
  Capabilities: cvolume penum
  Capture channels: Front Left - Front Right
  Limits: Capture 0 - 15
  Front Left: Capture 12 [80%]
  Front Right: Capture 12 [80%]
Simple mixer control 'Capture Attenuate Switch (-6dB)',0
  Limits: 0 - 2
  Mono: 1 [50%]
Simple mixer control 'Capture Mux',0
  Capabilities: enum
  Items: 'MIC_IN' 'LINE_IN'
  Item0: 'MIC_IN'
Simple mixer control 'Capture ZC',0
  Mono: Playback [on]
Simple mixer control 'Mixer Channel',0
  Limits: 0 - 200
  Mono: 52 [26%] [0.52dB]
Simple mixer control 'AVC Enable',0
Simple mixer control 'AVC Hard Limit',0
Simple mixer control 'AVC Max Gain',0
  Limits: 0 - 2
  Mono: 1 [50%]
Simple mixer control 'AVC Threshold (-dB)',0
  Limits: 0 - 96
  Mono: 12 [12%]
Simple mixer control 'DAC_IN',0
  Capabilities: enum
  Item0: 'I2S_IN'
Simple mixer control 'DAP_IN',0
  Capabilities: enum
  Item0: 'ADC'
Simple mixer control 'DAP_MIXER Mixer Channel',0
Simple mixer control 'Jack Function',0
  Capabilities: enum
  Items: 'off' 'on'
  Item0: 'off'
Simple mixer control 'MIX_MUX',0
  Capabilities: enum
  Item0: 'ADC'
Simple mixer control 'Main Channel',0
  Limits: 0 - 200
  Mono: 110 [55%] [1.10dB]
发表于 2015-3-2 13:00:26 | 显示全部楼层
回帖奖励 +1 NXP金币
楼主你好
建议你将此问题按照帖子   飞思卡尔产品论坛快速购买通道及SR提交流程,小伙伴速来!   提交一个服务请求:
如果你尚未注册飞思卡尔官网账号,请先点击注册按钮:右侧图标完成注册。
如果你已有飞思卡尔官网账号,可以点击申请SR按钮:右侧图标提交一个服务请求。
最好使用英文详细描述一下遇到的问题,以便国内外工程师都能够帮助到你
GMT+8, 2026-4-7 00:08 , Processed in 0.089172 second(s), 24 queries , Redis On.
