查看: 2096|回复: 0
[其他] HEXFILE: Link Hex File with Application_命令求解释
发表于 2015-2-13 16:47:40 | 显示全部楼层 |阅读模式
Description
Use this command to link an S-Record or Intel Hex file with the application.
HEXFILE fiboram.s1 OFFSET 0xFFFF9800 /* 0x800 - 0x7000 */
The above code adds the optional offset specified in the HEXFILE command to each
record in the Freescale S-record file, and encodes the code at address 0x7000 at address
0x800. The offset 0xFFFF9800 used above is the unsigned representation of -0x68000. To
calculate it, use a hex-capable calculator and subtract 0x7000 from 0x800.
这句话是什么意思?
我知道答案 目前已有0人回答
GMT+8, 2025-10-28 07:49 , Processed in 0.085482 second(s), 20 queries , MemCache On.
