查看: 3343|回复: 7
[求助] sata接口配置与cpu版本兼容问题
发表于 2015-3-16 13:46:59 | 显示全部楼层 |阅读模式
我们公司使用飞思卡尔公司imx6系列处理器已经2年多了,现在简单描述下sata接口配置与cpu版本兼容问题。
之前我们一直用的是飞思卡尔MCIMX6Q6AVT10AC(芯片ID rev1.2)芯片的,我们用这个芯片做了一些开发板,上面接了个SATA硬盘测试一直都是没问题的,自从飞思卡尔官网上面买不到这种芯片(不知道是不是停产),而改用MCIMX6Q6AVT10AD(芯片ID rev1.5)后,将芯片焊接在原来的板子上面,sata接口就通讯不正常了,具体启动信息贴在下面:
正常的MCIMX6Q6AVT10AC(芯片ID rev1.2)启动信息如下:
U-Boot 2013.01 (Aug 11 2014 - 01:16:03)
CPU:   Freescale i.MX6Q rev1.2 at 792 MHz
Reset cause: POR
Board: SABRE Lite
DRAM:  256 MiB
WARNING: Caches not enabled
MMC:   FSL_SDHC: 0, FSL_SDHC: 1
SF: Detected SST25VF016B with page size 4 KiB, total 2 MiB
*** Warning - bad CRC, using default environment
No panel detected: default to HDMI
unsupported panel HDMI
In:    serial
Out:   serial
Err:   serial
Thermal fuse is 0x5844e67d, raw_25c=1412 raw_hot=1254 hot_temp=125 C scale=0.63
Temperature raw=1391 temperature= 38.29 C
Net:   Phy not found
using phy at 4
PHY reset timed out
FEC [PRIME]
Warning: failed to set MAC address
AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl SATA mode
flags: ncq stag pm led clo only pmp pio slum part
SATA Device Info:
S/N:             9QE0M77K
Product model number: ST3250820AS
Firmware version: 3.AAC
Capacity: 488397168 sectors
SATA device 0: Model: ST3250820AS Firm: 3.AAC Ser#:             9QE0M77K
            Type: Hard Disk
            Supports 48-bit addressing
            Capacity: 238475.1 MB = 232.8 GB (488397168 x 512)
... is now current device
硬盘ID可以正常读取出来。
不正常MCIMX6Q6AVT10AD(芯片ID rev1.5)启动信息:
CPU:   Freescale i.MX6Q rev1.5 at 792 MHz
Reset cause: POR
Board: SABRE Lite
DRAM:  256 MiB
In:    serial
Out:   serial
Err:   serial
Thermal fuse is 0x5714bc7d, raw_25c=1393 raw_hot=1212 hot_temp=125 C scale=0.55
Temperature raw=1396 temperature= 23.34 C
Net:   Phy not found
using phy at 4
PHY reset timed out
FEC [PRIME]
timeout exit!
timeout exit!
SATA Device Info:
S/N:
Firmware version: 5
Capacity: 0 sectors
SATA device 0: Model:  Firm:  Ser#:
            Type: Hard Disk
            Capacity: not available
** Bad device size - sata 0 **
硬盘ID读取出来都是空的。
已经焊接过几块板子了,可以排除是电路版焊接问题
用的都是同一块硬盘和线,也可以排除硬盘和线的问题。
另外,发现rev1.5版本也不是完全100%读不到硬盘ID的,就是有时候能正常读取出ID,试个几十次会有一两次能读取出ID的。
而旧版的rev1.2的是可以100%读到ID的。
请版主帮忙解决下这个问题了,谢谢!
我知道答案 目前已有7人回答
发表于 2015-3-17 17:13:57 | 显示全部楼层
楼主你好,这个问题我需要帮你确认一下。请耐心等待~~
发表于 2015-3-17 18:10:07 | 显示全部楼层
楼主你好,我这边帮你确认了一下,MCIMX6Q6AVT10AD(芯片ID rev1.5)芯片ID是 rev1.3版本的,不是1.5。它和MCIMX6Q6AVT10AC是完全兼容的。你这里会遇到时不时读不到SATA的ID,有可能是芯片接触不好的问题。不知道你这里是怎么把芯片换上去的呢?
兼容是没有任何问题的。
 楼主| 发表于 2015-3-18 13:08:28 | 显示全部楼层
嗯,这两种芯片都是我们自己焊接的,另外问下 b-boot启动是显示的cpu信息 “CPU:   Freescale i.MX6Q rev1.5 at 792 MHz” 这里的rev1.5不是芯片ID版本吗?
 楼主| 发表于 2015-3-18 13:10:18 | 显示全部楼层
我看了下源代码,确实是读取芯片ID,为什么我读取的芯片是1.5版本呢?真是奇怪啊!
发表于 2015-3-18 16:33:05 | 显示全部楼层
目前我们官网上更新出来的产品最新的是rev 1.3版本的,我帮你再确认一下哈~~请耐心等待。
发表于 2015-3-31 02:30:47 | 显示全部楼层
楼主你好,很抱歉才给您回复哈,我最近一直在出差,现在刚有时间看论坛,关于你帖中的问题,我这边正在帮你确认。请问你这里使用的是哪个版本的BSP?还有你的这批芯片是通过什么途径购买的呢?
发表于 2015-4-9 16:57:18 | 显示全部楼层
楼主你好,请问你这里使用的是哪个版本的BSP呢?目前我们这边正在帮你处理这个问题。
GMT+8, 2026-4-9 01:16 , Processed in 0.097254 second(s), 29 queries , Redis On.
