查看: 1771|回复: 1
[分享] KL26Z DAC模块学习
发表于 2015-3-18 16:20:10 | 显示全部楼层 |阅读模式
DAC初始化
void  dacInit (void)
    SIM_SCGC5   |= SIM_SCGC5_PORTE_MASK;                                /* 开启PE GPIO时钟              */
    PORTE_PCR30 |= PORT_PCR_MUX(0);                                     /* 开启PE30管脚模拟功能         */
    SIM_SCGC6   |= SIM_SCGC6_DAC0_MASK;                                 /* 开启DAC时钟                  */
     * 配置DAC相关功能
    DAC0_C0 |= DAC_C0_DACEN_MASK | DAC_C0_DACRFS_MASK | DAC_C0_LPEN_MASK | DAC_C0_DACTRGSEL_MASK;
dac软件触发函数
void  dacTrigger (INT16U  uiData)
     *  DAC寄存器赋值
    DAC0_DATL(0) = uiData & 0x00ff;                                     /* 选择DAC低位寄存器赋值        */
    DAC0_DATH(0) = uiData >> 8;                                         /* 选择DAC高位寄存器赋值        */
    DAC0_C0 |= DAC_C0_DACSWTRG_MASK;                                    /* DAC软件触发                  */
附带的用户源代码里面是有部分有些问题的。
/** DAC - Peripheral register structure */
typedef struct DAC_MemMap {
  struct {                                         /* offset: 0x0, array step: 0x2 */
    uint8_t DATL;                                    /**< DAC Data Low Register, array offset: 0x0, array step: 0x2 */
    uint8_t DATH;                                    /**< DAC Data High Register, array offset: 0x1, array step: 0x2 */
  } DAT[2];
  uint8_t RESERVED_0[28];
  uint8_t SR;                                      /**< DAC Status Register, offset: 0x20 */
  uint8_t C0;                                      /**< DAC Control Register, offset: 0x21 */
  uint8_t C1;                                      /**< DAC Control Register 1, offset: 0x22 */
  uint8_t C2;                                      /**< DAC Control Register 2, offset: 0x23 */
} volatile *DAC_MemMapPtr;
   -- DAC - Register accessor macros
* @addtogroup DAC_Register_Accessor_Macros DAC - Register accessor macros
/* DAC - Register accessors */
#define DAC_DATL_REG(base,index)                 ((base)->DAT[index].DATL)
#define DAC_DATH_REG(base,index)                 ((base)->DAT[index].DATH)
#define DAC_SR_REG(base)                         ((base)->SR)
#define DAC_C0_REG(base)                         ((base)->C0)
#define DAC_C1_REG(base)                         ((base)->C1)
#define DAC_C2_REG(base)                         ((base)->C2)
*/ /* end of group DAC_Register_Accessor_Macros */
   -- DAC Register Masks
* @addtogroup DAC_Register_Masks DAC Register Masks
/* DATL Bit Fields */
#define DAC_DATL_DATA0_MASK                      0xFFu
#define DAC_DATL_DATA0_SHIFT                     0
#define DAC_DATL_DATA0(x)                        (((uint8_t)(((uint8_t)(x))<<DAC_DATL_DATA0_SHIFT))&DAC_DATL_DATA0_MASK)
/* DATH Bit Fields */
#define DAC_DATH_DATA1_MASK                      0xFu
#define DAC_DATH_DATA1_SHIFT                     0
#define DAC_DATH_DATA1(x)                        (((uint8_t)(((uint8_t)(x))<<DAC_DATH_DATA1_SHIFT))&DAC_DATH_DATA1_MASK)
/* SR Bit Fields */
#define DAC_SR_DACBFRPBF_MASK                    0x1u
#define DAC_SR_DACBFRPBF_SHIFT                   0
#define DAC_SR_DACBFRPTF_MASK                    0x2u
#define DAC_SR_DACBFRPTF_SHIFT                   1
/* C0 Bit Fields */
#define DAC_C0_DACBBIEN_MASK                     0x1u
#define DAC_C0_DACBBIEN_SHIFT                    0
#define DAC_C0_DACBTIEN_MASK                     0x2u
#define DAC_C0_DACBTIEN_SHIFT                    1
#define DAC_C0_LPEN_MASK                         0x8u
#define DAC_C0_LPEN_SHIFT                        3
#define DAC_C0_DACSWTRG_MASK                     0x10u
#define DAC_C0_DACSWTRG_SHIFT                    4
#define DAC_C0_DACTRGSEL_MASK                    0x20u
#define DAC_C0_DACTRGSEL_SHIFT                   5
#define DAC_C0_DACRFS_MASK                       0x40u
#define DAC_C0_DACRFS_SHIFT                      6
#define DAC_C0_DACEN_MASK                        0x80u
#define DAC_C0_DACEN_SHIFT                       7
/* C1 Bit Fields */
#define DAC_C1_DACBFEN_MASK                      0x1u
#define DAC_C1_DACBFEN_SHIFT                     0
#define DAC_C1_DACBFMD_MASK                      0x4u
#define DAC_C1_DACBFMD_SHIFT                     2
#define DAC_C1_DMAEN_MASK                        0x80u
#define DAC_C1_DMAEN_SHIFT                       7
/* C2 Bit Fields */
#define DAC_C2_DACBFUP_MASK                      0x1u
#define DAC_C2_DACBFUP_SHIFT                     0
#define DAC_C2_DACBFRP_MASK                      0x10u
#define DAC_C2_DACBFRP_SHIFT                     4
*/ /* end of group DAC_Register_Masks */
/* DAC - Peripheral instance base addresses */
/** Peripheral DAC0 base pointer */
#define DAC0_BASE_PTR                            ((DAC_MemMapPtr)0x4003F000u)
/** Array initializer of DAC peripheral base pointers */
#define DAC_BASE_PTRS                            { DAC0_BASE_PTR }
/* DAC - Register instance definitions */
/* DAC0 */
#define DAC0_DAT0L                               DAC_DATL_REG(DAC0_BASE_PTR,0)
#define DAC0_DAT0H                               DAC_DATH_REG(DAC0_BASE_PTR,0)
#define DAC0_DAT1L                               DAC_DATL_REG(DAC0_BASE_PTR,1)
#define DAC0_DAT1H                               DAC_DATH_REG(DAC0_BASE_PTR,1)
#define DAC0_SR                                  DAC_SR_REG(DAC0_BASE_PTR)
#define DAC0_C0                                  DAC_C0_REG(DAC0_BASE_PTR)
#define DAC0_C1                                  DAC_C1_REG(DAC0_BASE_PTR)
#define DAC0_C2                                  DAC_C2_REG(DAC0_BASE_PTR)
但是这些可以直接使用
可以承受一些自己重新写的风险,但是我的DAC_Init()就编译什么的都可以,却没办法运行!之后再看DAC了
发表于 2015-3-23 09:47:22 | 显示全部楼层
楼主,你好!
你这个帖子,是你自己写的DAC出问题,还是跑YL的板子的DAC代码跑不通呢?
GMT+8, 2025-11-9 19:19 , Processed in 0.066233 second(s), 19 queries , MemCache On.
