查看: 4128|回复: 7
[分享] KL-26Z的TSI
发表于 2015-3-19 20:33:41 | 显示全部楼层 |阅读模式
KL-46的TSI非常好用,手册上面这样介绍
The touch sensing input (TSI) module provides capacitive touch sensing detection with
high sensitivity and enhanced robustness. Each TSI pin implements the capacitive
measurement by a current source scan, charging and discharging the electrode, once or
several times.
大致就是TSI电容触摸感应探测有着高可靠性,原理是触摸触发那个不停的电极改变。
A reference oscillator ticks the scan
time and stores the result in a 16-bit register when the scan completes. Meanwhile, an
interrupt request is submitted to CPU for post-processing if TSI interrupt is enabled and
DMA function is not selected.The TSI module can be periodically triggered to work in
low power mode with ultra-low current adder and wake CPU at the end of scan or the
conversion result is out of the range specified by TSI threshold. It provides a solid
capacitive measurement module to the implementation of touch keyboard, rotaries and
sliders.
先学习一下它的宏定义
typedef struct TSI_MemMap {
  uint32_t GENCS;                                  /**< TSI General Control and Status Register, offset: 0x0 */
  uint32_t DATA;                                   /**< TSI DATA Register, offset: 0x4 */
  uint32_t TSHD;                                   /**< TSI Threshold Register, offset: 0x8 */
} volatile *TSI_MemMapPtr;
   -- TSI - Register accessor macros
* @addtogroup TSI_Register_Accessor_Macros TSI - Register accessor macros
/* TSI - Register accessors */
#define TSI_GENCS_REG(base)                      ((base)->GENCS)
#define TSI_DATA_REG(base)                       ((base)->DATA)
#define TSI_TSHD_REG(base)                       ((base)->TSHD)
*/ /* end of group TSI_Register_Accessor_Macros */
   -- TSI Register Masks
* @addtogroup TSI_Register_Masks TSI Register Masks
/* GENCS Bit Fields */
#define TSI_GENCS_CURSW_MASK                     0x2u
#define TSI_GENCS_CURSW_SHIFT                    1
#define TSI_GENCS_EOSF_MASK                      0x4u
#define TSI_GENCS_EOSF_SHIFT                     2
#define TSI_GENCS_SCNIP_MASK                     0x8u
#define TSI_GENCS_SCNIP_SHIFT                    3
#define TSI_GENCS_STM_MASK                       0x10u
#define TSI_GENCS_STM_SHIFT                      4
#define TSI_GENCS_STPE_MASK                      0x20u
#define TSI_GENCS_STPE_SHIFT                     5
#define TSI_GENCS_TSIIEN_MASK                    0x40u
#define TSI_GENCS_TSIIEN_SHIFT                   6
#define TSI_GENCS_TSIEN_MASK                     0x80u
#define TSI_GENCS_TSIEN_SHIFT                    7
#define TSI_GENCS_NSCN_MASK                      0x1F00u
#define TSI_GENCS_NSCN_SHIFT                     8
#define TSI_GENCS_NSCN(x)                        (((uint32_t)(((uint32_t)(x))<<TSI_GENCS_NSCN_SHIFT))&TSI_GENCS_NSCN_MASK)
#define TSI_GENCS_PS_MASK                        0xE000u
#define TSI_GENCS_PS_SHIFT                       13
#define TSI_GENCS_PS(x)                          (((uint32_t)(((uint32_t)(x))<<TSI_GENCS_PS_SHIFT))&TSI_GENCS_PS_MASK)
#define TSI_GENCS_EXTCHRG_MASK                   0x70000u
#define TSI_GENCS_EXTCHRG_SHIFT                  16
#define TSI_GENCS_EXTCHRG(x)                     (((uint32_t)(((uint32_t)(x))<<TSI_GENCS_EXTCHRG_SHIFT))&TSI_GENCS_EXTCHRG_MASK)
#define TSI_GENCS_DVOLT_MASK                     0x180000u
#define TSI_GENCS_DVOLT_SHIFT                    19
#define TSI_GENCS_DVOLT(x)                       (((uint32_t)(((uint32_t)(x))<<TSI_GENCS_DVOLT_SHIFT))&TSI_GENCS_DVOLT_MASK)
#define TSI_GENCS_REFCHRG_MASK                   0xE00000u
#define TSI_GENCS_REFCHRG_SHIFT                  21
#define TSI_GENCS_REFCHRG(x)                     (((uint32_t)(((uint32_t)(x))<<TSI_GENCS_REFCHRG_SHIFT))&TSI_GENCS_REFCHRG_MASK)
#define TSI_GENCS_MODE_MASK                      0xF000000u
#define TSI_GENCS_MODE_SHIFT                     24
#define TSI_GENCS_MODE(x)                        (((uint32_t)(((uint32_t)(x))<<TSI_GENCS_MODE_SHIFT))&TSI_GENCS_MODE_MASK)
#define TSI_GENCS_ESOR_MASK                      0x10000000u
#define TSI_GENCS_ESOR_SHIFT                     28
#define TSI_GENCS_OUTRGF_MASK                    0x80000000u
#define TSI_GENCS_OUTRGF_SHIFT                   31
/* DATA Bit Fields */
#define TSI_DATA_TSICNT_MASK                     0xFFFFu
#define TSI_DATA_TSICNT_SHIFT                    0
#define TSI_DATA_TSICNT(x)                       (((uint32_t)(((uint32_t)(x))<<TSI_DATA_TSICNT_SHIFT))&TSI_DATA_TSICNT_MASK)
#define TSI_DATA_SWTS_MASK                       0x400000u
#define TSI_DATA_SWTS_SHIFT                      22
#define TSI_DATA_DMAEN_MASK                      0x800000u
#define TSI_DATA_DMAEN_SHIFT                     23
#define TSI_DATA_TSICH_MASK                      0xF0000000u
#define TSI_DATA_TSICH_SHIFT                     28
#define TSI_DATA_TSICH(x)                        (((uint32_t)(((uint32_t)(x))<<TSI_DATA_TSICH_SHIFT))&TSI_DATA_TSICH_MASK)
/* TSHD Bit Fields */
#define TSI_TSHD_THRESL_MASK                     0xFFFFu
#define TSI_TSHD_THRESL_SHIFT                    0
#define TSI_TSHD_THRESL(x)                       (((uint32_t)(((uint32_t)(x))<<TSI_TSHD_THRESL_SHIFT))&TSI_TSHD_THRESL_MASK)
#define TSI_TSHD_THRESH_MASK                     0xFFFF0000u
#define TSI_TSHD_THRESH_SHIFT                    16
#define TSI_TSHD_THRESH(x)                       (((uint32_t)(((uint32_t)(x))<<TSI_TSHD_THRESH_SHIFT))&TSI_TSHD_THRESH_MASK)
*/ /* end of group TSI_Register_Masks */
/* TSI - Peripheral instance base addresses */
/** Peripheral TSI0 base pointer */
#define TSI0_BASE_PTR                            ((TSI_MemMapPtr)0x40045000u)
/** Array initializer of TSI peripheral base pointers */
#define TSI_BASE_PTRS                            { TSI0_BASE_PTR }
/* TSI - Register instance definitions */
/* TSI0 */
#define TSI0_GENCS                               TSI_GENCS_REG(TSI0_BASE_PTR)
#define TSI0_DATA                                TSI_DATA_REG(TSI0_BASE_PTR)
#define TSI0_TSHD                                TSI_TSHD_REG(TSI0_BASE_PTR)
接着就是各种功能的函数
void TSI_Init (void)
  SIM_SCGC5 |= SIM_SCGC5_TSI_MASK;  // Enable clock gating for TSI
  /* Enable proper GPIO as TSI channels */
  PORTB_PCR16 = PORT_PCR_MUX(0);   // PTB16 as TSI channel 9
  PORTB_PCR17 =  PORT_PCR_MUX(0);   // PTB17 as TSI channel 10
  PORTC_PCR0 =  PORT_PCR_MUX(0);   // PTB17 as TSI channel 13
  NVIC_DisableIRQ((IRQn_Type)TSI0_IRQn);
  TSI0_GENCS |= (TSI_GENCS_ESOR_MASK
                   | TSI_GENCS_MODE(0)
                   | TSI_GENCS_REFCHRG(4)
                   | TSI_GENCS_DVOLT(0)
                   | TSI_GENCS_EXTCHRG(7)
                   | TSI_GENCS_PS(4)
                   | TSI_GENCS_NSCN(11)
                   | TSI_GENCS_TSIIEN_MASK
                   | TSI_GENCS_STPE_MASK
                   //| TSI_GENCS_STM_MASK     //Trigger for the module 0=Sofware
  TSI0_GENCS |= TSI_GENCS_TSIEN_MASK;
  TSI_SelfCalibration();
TSI校验标准化感觉可以去掉
void TSI_SelfCalibration(void)
  unsigned char cnt;
  unsigned char trigger_backup;
  TSI0_GENCS |= TSI_GENCS_EOSF_MASK;      // Clear End of Scan Flag
  TSI0_GENCS &= ~TSI_GENCS_TSIEN_MASK;    // Disable TSI module
  if(TSI0_GENCS & TSI_GENCS_STM_MASK)     // Back-up TSI Trigger mode from Application
       trigger_backup = TRUE;
  else
       trigger_backup = FALSE;
  TSI0_GENCS &= ~TSI_GENCS_STM_MASK;      // Use SW trigger
  TSI0_GENCS &= ~TSI_GENCS_TSIIEN_MASK;    // Enable TSI interrupts
  TSI0_GENCS |= TSI_GENCS_TSIEN_MASK;     // Enable TSI module
  for(cnt=0; cnt < total_electrode; cnt++)  // Get Counts when Electrode not pressed
    TSI0_DATA = ((elec_array[cnt] << TSI_DATA_TSICH_SHIFT) );
    TSI0_DATA |= TSI_DATA_SWTS_MASK;
    while(!(TSI0_GENCS & TSI_GENCS_EOSF_MASK));
    gu16Baseline[cnt] = (TSI0_DATA & TSI_DATA_TSICNT_MASK);
  TSI0_GENCS |= TSI_GENCS_TSIIEN_MASK;     // Enale TSI interrupt
  if(trigger_backup)                      // Restore trigger mode
    TSI0_GENCS |= TSI_GENCS_STM_MASK;
  else
   TSI0_DATA = ((elec_array[0]<<TSI_DATA_TSICH_SHIFT) );
发表于 2015-3-23 09:29:04 | 显示全部楼层
非常感谢你关于Kinetis的经验分享!
    发表于 2015-3-24 13:53:52 | 显示全部楼层
    楼主用的究竟是KL26还是 KL46呢?
     楼主| 发表于 2015-3-26 12:51:06 | 显示全部楼层
    K26Z型号的
    发表于 2015-3-27 13:53:58 | 显示全部楼层
    楼主很矛盾 ~ 帖子的主题是 KL26z ,帖子的开头是KL46, 现在又变成了 K26Z
    发表于 2015-4-28 11:18:18 | 显示全部楼层
    感谢楼主分享!
    发表于 2015-6-5 00:22:21 | 显示全部楼层
    有点乱。。不过还是谢谢分享。。
    发表于 2015-8-8 23:41:42 | 显示全部楼层
    多谢分享
    GMT+8, 2026-4-4 02:35 , Processed in 0.108130 second(s), 27 queries , Redis On.
