查看: 1947|回复: 3
[分享] KL-26Z之UID
发表于 2015-3-21 18:11:47 | 显示全部楼层 |阅读模式
UID就像是身份证,需要一些基本信息
typedef struct {
    INT32U uiSIM_UIDMH;
    INT32U uiSIM_UIDML;
    INT32U uiSIM_UIDL;
} UIDs;
UID读取函数
void uidRead(UIDs *UID)
    UID->uiSIM_UIDMH = SIM_UIDMH;
    UID->uiSIM_UIDML = SIM_UIDML;
    UID->uiSIM_UIDL  = SIM_UIDL;
UID另外有些信息
#define SIM_UIDMH                                SIM_UIDMH_REG(SIM_BASE_PTR)
#define SIM_UIDML                                SIM_UIDML_REG(SIM_BASE_PTR)
#define SIM_UIDL                                 SIM_UIDL_REG(SIM_BASE_PTR)
#define SIM_UIDMH_REG(base)                      ((base)->UIDMH)
#define SIM_UIDML_REG(base)                      ((base)->UIDML)
#define SIM_UIDL_REG(base)                       ((base)->UIDL)
typedef struct {
  __IO uint32_t SOPT1;                             /**< System Options Register 1, offset: 0x0 */
  __IO uint32_t SOPT1CFG;                          /**< SOPT1 Configuration Register, offset: 0x4 */
       uint8_t RESERVED_0[4092];
  __IO uint32_t SOPT2;                             /**< System Options Register 2, offset: 0x1004 */
       uint8_t RESERVED_1[4];
  __IO uint32_t SOPT4;                             /**< System Options Register 4, offset: 0x100C */
  __IO uint32_t SOPT5;                             /**< System Options Register 5, offset: 0x1010 */
       uint8_t RESERVED_2[4];
  __IO uint32_t SOPT7;                             /**< System Options Register 7, offset: 0x1018 */
       uint8_t RESERVED_3[8];
  __I  uint32_t SDID;                              /**< System Device Identification Register, offset: 0x1024 */
       uint8_t RESERVED_4[12];
  __IO uint32_t SCGC4;                             /**< System Clock Gating Control Register 4, offset: 0x1034 */
  __IO uint32_t SCGC5;                             /**< System Clock Gating Control Register 5, offset: 0x1038 */
  __IO uint32_t SCGC6;                             /**< System Clock Gating Control Register 6, offset: 0x103C */
  __IO uint32_t SCGC7;                             /**< System Clock Gating Control Register 7, offset: 0x1040 */
  __IO uint32_t CLKDIV1;                           /**< System Clock Divider Register 1, offset: 0x1044 */
       uint8_t RESERVED_5[4];
  __IO uint32_t FCFG1;                             /**< Flash Configuration Register 1, offset: 0x104C */
  __I  uint32_t FCFG2;                             /**< Flash Configuration Register 2, offset: 0x1050 */
       uint8_t RESERVED_6[4];
  __I  uint32_t UIDMH;                             /**< Unique Identification Register Mid-High, offset: 0x1058 */
  __I  uint32_t UIDML;                             /**< Unique Identification Register Mid Low, offset: 0x105C */
  __I  uint32_t UIDL;                              /**< Unique Identification Register Low, offset: 0x1060 */
       uint8_t RESERVED_7[156];
  __IO uint32_t COPC;                              /**< COP Control Register, offset: 0x1100 */
  __O  uint32_t SRVCOP;                            /**< Service COP Register, offset: 0x1104 */
} SIM_Type;
发表于 2015-3-23 07:55:59 | 显示全部楼层
。。。。。lz是啥意思
    发表于 2015-3-23 10:07:36 | 显示全部楼层
    同问~ 楼主是实现还是验证啥呢? 建议添加 图文描述~ 方便大家一起学习讨论哦
    发表于 2015-3-23 10:16:40 | 显示全部楼层
    楼主如果是写经验分享,建议你调出来之后,一并分享结果,这样才显的完整些哦。
    GMT+8, 2025-11-9 19:21 , Processed in 0.089024 second(s), 22 queries , MemCache On.
