查看: 2035|回复: 4
[求助] KL25利用I2C写EEPROMCAT1023求解为什么写不进去
发表于 2015-4-24 18:21:19 | 显示全部楼层 |阅读模式
个人觉得可能是以下问题:1、I2C的速率,这个是移植别的程序 以前的I2C速率设置为400K
2、I2C中断的问题
程序如下:
** Function name:           myDelay
** Descriptions:            软件延时
** input parameters:        ulTime:延时时间
** output parameters:       none
** Returned value:          none
** Created by:              Li Xiang
** Created Date:            2012-12-14   myDelay (100)  --85ms
** Modified by:
** Modified date:
void myDelay (INT32U ulTime)
    INT32U i;
    i = 0;
    while (ulTime--) {
        for (i = 0; i < 7000; i++);
** Function name:           main
** Descriptions:            I2C驱动EEPROM Demo
** input parameters:        none
** Modified by:
** Modified date:
int  main (void)
    INT8U ucData[8] = {0};
    INT8U i = 0;
    SystemCoreClockUpdate();
    PORT_ENABLE_CLK(MKL_PORTC);                                         /* GPIO 时钟使能                */
    PORT_ENABLE_CLK(MKL_PORTD);
    uart0Init(9600,0,0,8,1);
    printf("MCU start\r\n");
    i2c0Init();                                                         /* I2C外设初始化                */
    IO_FUN_SEL(MKL_PORTC,1,1);                                         /* LED初始化                    */
    IO_FUN_SEL(MKL_PORTC,2,1);
    IO_FUN_SEL(MKL_PORTD,1,1);
    GPIO_DDR_OUTPUT(MKL_PORTC,1);
    GPIO_DDR_OUTPUT(MKL_PORTC,2);
    GPIO_SET(MKL_PORTC,1);
    GPIO_SET(MKL_PORTC,2);
// while(1)
//     GPIO_CLR(MKL_PORTC,1);
//     myDelay(100);
//     GPIO_SET(MKL_PORTC,1);
//     myDelay(100);
    for (i = 0; i < 8; i++) {                                          /* 数组初始化                   */
        ucData[i] = i+1;
    i2c0WriteNByte(0xA0, ONE_BYTE_SUBA, 0, ucData, 8);              /* 写数据操作                   */
    myDelay(1000);
        ucData[i] = 0;
    i2c0ReadNByte(0xA0, ONE_BYTE_SUBA, 0, ucData, 8);               /* 读数据操作                   */
    myDelay(1000);
       if (ucData[i] != i+1)
            GPIO_TOGGLE(MKL_PORTC,1);                                  /* 验证失败,红灯亮             */
            myDelay(100);
      else
        GPIO_TOGGLE(MKL_PORTC,2);
        myDelay(100);
    }        /* 验证正确,绿灯亮             */
    while(1);
#include "includes.h"
** 全局变量
const INT16U GusSCLDivider[64] = {
    20, 22, 24, 26, 28, 30, 34, 40, 28, 32, 36, 40, 44, 48, 56, 68, 48, 56, 64, 72, 80, 88, 104, 128,
    80, 96, 112, 128, 144, 160, 192, 240, 160, 192, 224, 256, 288, 320, 384, 480, 320, 384, 448, 512,
    576, 640, 768, 960, 640, 768, 896, 1024, 1152, 1280, 1536, 1920, 1280, 1536, 1792, 2048, 2304,
    2560, 3072, 3840};
* 用于进行I2C通讯的全局变量
volatile INT8U     I2C_sla;                                             /* I2C器件从地址                */
volatile INT32U    I2C_suba;                                            /* I2C器件内子地址              */
volatile INT8U     I2C_suba_num;                                        /* I2C子地址长度                */
volatile INT8U     *I2C_buf;                                            /* 数据缓冲区指针               */
volatile INT32U    I2C_num;                                             /* 要读取/写入的数据个数        */
volatile INT8U     I2C_end;                                             /* I2C总线结束标志              */
volatile INT8U     I2C_restart;                                         /* I2C总线结重复起始标?         */
static   INT8U     I2C_irq_status;                                      /* I2C中断读写操作控制          */
        /* 1--读模式                    */
        /* 0--写模式                    */
volatile INT8U     I2C_sla_dir;         /*  从机控制
                                         *  1--读取操作
                                         *  0--写操作
void i2cDelay (INT32U ulTime)
    INT32U i;
    i = 0;
    while (ulTime--) {
        for (i = 0; i < 5000; i++);
** Function name:           Wait_I2c_End
** Descriptions:            软件延时,提供给I2C总线等待超时使用
** input parameters:        dly        延时参数,值越大,延时越久
** Output parameters:       NONE
** Returned value:          NONE
static INT8U  Wait_I2c_End(INT32U  dly)
    INT32U  i = 0;
    if( I2C_end == 1 )     return (1);
    for(; dly > 0; dly--)
    for(i = 0; i<5000; i++)
    return (0);
** Function name:           Wait_I2c_Restart
** Descriptions:            等待I2C发送Restart
static INT8U  Wait_I2c_Restart(INT32U  dly)
    INT32U  i = 0;
    for(; dly > 0; dly--) {
        for(i = 0; i< 5000; i++) {
            if( I2C_restart == 1 ) {
                for(i = 0; i< 200; i++) {
                return (1);
    return (0);
** Function name:           i2c0ClkEnable
** Descriptions:            I2C时钟使能
** Modified by:
** Modified date:
__INLINE void i2c0ClkEnable(void)
    SIM_SCGC4 |= SIM_SCGC4_I2C0_MASK;
** Function name:           i2c0ClkDisable
** Descriptions:            I2C时钟禁能
** Modified by:
** Modified date:
__INLINE void i2c0ClkDisable(void)
    SIM_SCGC4 &= ~SIM_SCGC4_I2C0_MASK;
** Function name:           i2c1ClkEnable
** Modified by:
** Modified date:
__INLINE void i2c1ClkEnable(void)
    SIM_SCGC4 |= SIM_SCGC4_I2C1_MASK;
** Function name:           i2c1ClkDisable
** Modified by:
** Modified date:
__INLINE void i2c1ClkDisable(void)
    SIM_SCGC4 &= ~SIM_SCGC4_I2C1_MASK;
** Function name:           i2c0Init
** Descriptions:            I2C初始化
** Modified by:
** Modified date:
void i2c0Init(void)
    INT32U ulBaudRate = 0;
    INT32U i = 0;
    INT32U j = 0;
#if 0
    PORT_ENABLE_CLK(MKL_PORTE);
    IO_FUN_SEL(MKL_PORTE,24,5);                                         /* SCL初始化                    */
    IO_FUN_SEL(MKL_PORTE,25,5);                                         /* SDA初始化                    */
#endif
#if 0
    PORT_ENABLE_CLK(MKL_PORTB);
    IO_FUN_SEL(MKL_PORTB,0,2);                                          /* SCL初始化                    */
    IO_FUN_SEL(MKL_PORTB,1,2);                                          /* SDA初始化                    */
#endif
#if 0
    IO_FUN_SEL(MKL_PORTB,2,2);                                          /* SCL初始化                    */
    IO_FUN_SEL(MKL_PORTB,3,2);                                          /* SDA初始化                    */
#endif
#if 1
    IO_FUN_SEL(MKL_PORTC,8,2);                                          /* SCL初始化                    */
    IO_FUN_SEL(MKL_PORTC,9,2);                                          /* SDA初始化                    */
#endif
    i2c0ClkEnable();                                                    /* 打开I2C0时钟                 */
#if (I2C0_MODE == I2C_MASTER)
    ulBaudRate = SystemBusClock / (I2C0_BAUD_RATE << I2C0_MUL);         /* 计算SCL divider              */
    for(j = 0; j < I2C0_BT_ERROR; j++) {
        for(i = 0; i < 64; i++) {
            if(((ulBaudRate - GusSCLDivider[i]) <= j) || ((GusSCLDivider[i] - ulBaudRate) <= j) ){
                break;
        if (i != 64) {
            break;
    if (j == I2C0_BT_ERROR) {
        printf("I2C0 BT SET ERROR\r\n");
        while(1);
    I2C0_F = (I2C0_MUL << 6) | i;                                       /* 配置波特率                   */
//     I2C0_C1 |=  (1 << 5);                                            /* 选择主机模式                 */
#endif
#if (I2C0_MODE == I2C_SLAVER)
    I2C0_C1 |=  (1 << 7)|                                               /* 响应地址                     */
                (I2C0_SLAVER_ADDRESS_MODE << 6)|                        /* 从机地址类型定义             */
                (I2C0_SLAVER_ADR_MATCH << 3)|                           /* 地址匹配设置                 */
                ((I2C0_SLAVER_ADR >> 8) & 7UL);                         /* 高位地址设置                 */
    I2C0_A1 = I2C0_SLAVER_ADR;                                          /* 从机地址定义                 */
    I2C0_RA = I2C0_RANGE_SLAVER_ADR;
//     I2C0_C1 &=  ~(1 << 5);                                           /* 选择从机模式                 */
#endif
//     I2C0_C1 |=  (1 << 5);                                            /* 发送起始位与停止位           */
//     I2C0_C1 &=  ~(1 << 5);                                           /* 初始化总线                   */
    I2C0_S |= (1 << 1)|                                                 /* 清除标志                     */
              (1 << 4);
    I2C0_FLT    |= 1 << 6;
    I2C0_C1 |=  (1 << 7)|                                               /* 使能I2C0                     */
                (1 << 6);                                               /* 使能IRQ                      */
    I2C0_FLT  |= 1 << 5;                                                /* 使能停止中断                 */
    NVIC_EnableIRQ(I2C0_IRQn);
    NVIC_SetPriority(I2C0_IRQn,3);                                      /* 用户自己定义                 */
** Function name:           i2c0SendByte
** Descriptions:            I2C0发送单字节函数
** input parameters:        sla:从机地址 dat:数据缓冲区指针
** Modified by:
** Modified date:
INT8U i2c0SendByte(INT8U sla, INT8U *dat)
    I2C_sla         = sla;                                              /* 写操作的器件地址             */
    I2C_buf         = dat;                                              /* 待发送的数据缓冲区指针       */
    I2C_num         = 1;                                                /* 发送1字节数据                */
    I2C_suba_num    = 0;                                                /* 无子地址                     */
    I2C_sla_dir     = 0;                                                /* 写操作                       */
    I2C_irq_status  = 0;                                                /* 写模式                       */
    I2C_end         = 0;
    I2C0_C1 |=  (1 << 5);                                               /* 发送起始位,主模式           */
    I2C0_D   = I2C_sla & 0xFE;                                          /* 将写地址写入数据寄存器       */
    I2C0_C1 |=  (1 << 4);                                               /* 发送模式                     */
    return( Wait_I2c_End(20));
** Function name:           i2c0WriteNByte
** Descriptions:            I2C0发送多字节函数
** input parameters:        sla:从机地址 suba_type: 子地址类型
**                          suba:子地址 s:数据缓冲区指针 num:数据长度
** Created by:              qhx
** Created Date:            2015-04-22
** Modified by:
** Modified date:
INT8U i2c0WriteNByte(INT8U sla, INT8U suba_type, INT32U suba, INT8U *s, INT32U num)
    I2C_suba        = suba;                                             /* 子地址类型                   */
    I2C_num         = num;                                              /* 发送n字节数据                */
    I2C_suba_num    = suba_type;                                        /* 子地址类型                   */
    I2C_buf         = s;                                                /* 待发送的数据缓冲区指针       */
    I2C_end         = 0;
    I2C_restart     = 0;
** Function name:           i2c0ReadNByte
** Descriptions:            I2C0接收多字节函数
**                          suba:子地址 s:接收数据缓冲区指针 num:数据长度
** Modified by:
** Modified date:
INT8U i2c0ReadNByte(INT8U sla, INT8U suba_type, INT32U suba, INT8U *s, INT32U num)
    I2C_buf         = s;                                                /* 接收数据缓冲区指针           */
    I2C_sla_dir     = 1;                                                /* 写操作                       */
    I2C_end         = 0;
    I2C_restart     = 0;
    Wait_I2c_Restart(20);
    I2C0_D   = (I2C_sla & 0xFE) + 1;                                    /* 将读地址写入数据寄存器       */
** Function name:           I2C0_IRQHandler
** Descriptions:            I2C中断服务函数
** Modified by:
** Modified date:
void I2C0_IRQHandler(void)
    if (I2C0_FLT & (1 << 6)) {
        I2C_end = 1;
        I2C0_FLT    |= (1 << 6);                                        /* 清零停止中断标志             */
        I2C0_S      |= (1 << 1);                                        /* 清零中断标志                 */
        return;                                                         /* 中断返回                     */
    switch (I2C_irq_status)
        case 0:                                                         /* 发送模式                     */
            if (I2C0_S & 0x01)
                {                                            /* 应答检测                     */
                I2C_end = 1;                                                /* 无应答,传输结束             */
                I2C0_C1 &=  ~(1 << 5);                                      /* 发送STOP                     */
            if (I2C_suba_num == TWO_BYTE_SUBA)
                {                            /* 两字节从机子地址处理         */
                I2C0_D = ((I2C_suba >> 8) & 0xff);
                I2C_suba_num --;
            else if (I2C_suba_num == ONE_BYTE_SUBA)
                {                     /* 单字节从机子地址处理         */
                I2C0_D = (I2C_suba & 0xff);
                I2C_suba_num --;
            else if (I2C_suba_num == NONE_SUBA)
                {                         /* 无从机子地址处理             */
                if (I2C_sla_dir == 1)
                    {                                     /* 主机读操作处理               */
                    I2C0_C1 |= 1 << 2;                                      /* 发送Restart                  */
                    I2C_suba_num --;
                    I2C_restart = 1;                                        /* 重复起始信号标志置位         */
                else
                    if (I2C_num > 0)
                        {                                      /* 发送数据                     */
                            I2C0_D = *I2C_buf++;
                            I2C_num --;
                    else
            else
                I2C0_C1 &= ~(1 << 4);                                       /* 转为接收模式                 */
                I2C_irq_status = 1;
                *I2C_buf = I2C0_D;
            break;
        case 1:                                                         /* 接收模式                     */
            I2C_num--;
            if (I2C_num == 1) {                                             /* 接收最后一个字节,返回NACK   */
                I2C0_C1 |= 1 << 3;
            if (I2C_num == 0) {                                             /* 接收完成,结束总线           */
            *I2C_buf++ = I2C0_D;
            break;
        default:
        break;
#endif
#endif
我知道答案 目前已有4人回答
发表于 2015-4-27 11:27:42 | 显示全部楼层
很简单,你用逻辑分析仪看一下数据通信过程中的波形就可以,看看通信问题到底出在那个阶段啊!
 楼主| 发表于 2015-5-6 19:00:37 | 显示全部楼层
FSL_TICS_ZP 发表于 2015-4-27 11:27
很简单,你用逻辑分析仪看一下数据通信过程中的波形就可以,看看通信问题到底出在那个阶段啊! ...
能再具体点吗 没这样操作过
发表于 2015-5-14 09:38:23 | 显示全部楼层
就是检查一下I2C通信时的波形是否正常
发表于 2015-5-14 09:38:37 | 显示全部楼层
GMT+8, 2025-11-8 01:11 , Processed in 0.104892 second(s), 25 queries , MemCache On.
