查看: 2315|回复: 3
[求助] 当eboot从sd卡里启动后,从sd里download eboot和nk到nand flash时,...
发表于 2015-4-28 14:33:56 | 显示全部楼层 |阅读模式
Use SdUse Sd Hi, All 我用的是 IMX287evk , when I use the sd card to boot and want to use sd card to download image to nandflash, but the information show as follows:
Freescale iMX SOC Menu Item (UNSAVED CHANGES)
INFO: Storing boot configuration to NAND block [0x1A6].
INFO: Successfully store boot configuration to NAND!
+InitSpecifiedEthDevice
INFO: MAC address: 0-2-B3-92-A8-C4
-BLMenu .
INFO: Using device name: 'MX2843204'
SDMMCDownload : eboot.bin
SDMMCDownload : FATInitDisk Fail
>ERROR: read image data failure
ERROR: Unable to read image signature.
BL_IMAGE_TYPE_UNKNOWN
INFO: OEMMultiBINNotify (dwNumRegions = 0, dwRegionStart = 0x0).
WARNING: Unsupported binary format.  Image not remapped.
ERROR:OALVAtoPA: invalid virtual address 0x00000000
INFO: OEMVerifyMemory (CA = 0x0, PA = 0x0, length = 0x0)
ERROR: Invalid address range.
!OEMVERIFYMEMORY: Invalid image
INFO: OEMReportError Reason 0xFFFFFFF7
To Download Image To Nandflash Error On Imx287evkTo Download Image To Nandflash Error OnUse Sd To Download Image To Nandflash Error On Imx287evkImx287evk
发表于 2015-4-28 15:29:59 | 显示全部楼层
楼主你好,你这里可以直接使用mfgtool将images下载到Nand中。
发表于 2015-4-28 15:34:11 | 显示全部楼层
文件太大了,我这里没有办法附件给你。
这样你可以到官网去下载,链接为:
[url=https://www.freescale.co
m/webapp/sps/site/prod_summary.jsp?code=MCIMX28EVKJ&fpsp=1&tab=Design_Tools_Tab]https://www.freescale.co
m/webapp/sps/site/prod_summary.jsp?code=MCIMX28EVKJ&fpsp=1&tab=Design_Tools_Tab[/url]
m/webapp/sps/site/prod_summary.jsp?code=MCIMX28EVKJ&fpsp=1&tab=Design_Tools_Tab#]Hardware Development Tools  (9)[/url]----->
                       Programmers (Flash, etc.) (5)----->
m/webapp/sps/site/prod_summary.jsp?code=MCIMX28EVKJ&fpsp=1&tab=Design_Tools_Tab#]IMX_MFG_TOOL[/url]
你可以看到[url=https://www.freescale.co
m/webapp/sps/site/prod_summary.jsp?code=MCIMX28EVKJ&fpsp=1&tab=Design_Tools_Tab#]IMX_MFG_TOOL[/url]就是了。
发表于 2015-4-28 15:34:20 | 显示全部楼层
非常感谢你关于i.mx的技术问题。如果你没有其他问题,我们将此帖默认为已解决。
如果没有解决,欢迎继续在这里讨论哈~~
GMT+8, 2025-10-29 20:16 , Processed in 0.081219 second(s), 23 queries , MemCache On.
