12
返回列表 发新帖
楼主: 七七bb
[其他] 我用lptmr做定时器,遇到IO口中断后,lptmr就不工作了
  • 签到天数: 392 天
     楼主| 发表于 2015-4-29 09:58:28 | 显示全部楼层
    找到了。time_delay_ms(30);按键里面这个函数,
    void time_delay_ms(unsigned int count_val)
      /* Make sure the clock to the LPTMR is enabled */
      SIM_SCGC5|=SIM_SCGC5_LPTMR_MASK;
      /* Reset LPTMR settings */
      LPTMR0_CSR=0;
      /* Set the compare value to the number of ms to delay */
      LPTMR0_CMR = count_val;
      /* Set up LPTMR to use 1kHz LPO with no prescaler as its clock source */
      LPTMR0_PSR = LPTMR_PSR_PCS(1)|LPTMR_PSR_PBYP_MASK;
      /* Start the timer */
      LPTMR0_CSR |= LPTMR_CSR_TEN_MASK;
      /* Wait for counter to reach compare value */
      while (!(LPTMR0_CSR & LPTMR_CSR_TCF_MASK));
      /* Disable counter and Clear Timer Compare Flag */
      LPTMR0_CSR &= ~LPTMR_CSR_TEN_MASK;
      return;
    今天天气不错!签到!
  • 签到天数: 392 天
     楼主| 发表于 2015-4-29 09:59:01 | 显示全部楼层
    改变了它计数的值,晕晕晕
    今天天气不错!签到!
    发表于 2015-4-30 08:54:05 | 显示全部楼层
    ok,以后有问题再交流!
    发表于 2015-4-30 09:10:00 | 显示全部楼层
    仿真一下看按键中断后,按键中断的标志位清空成功没有呢
    发表于 2015-5-14 10:14:12 | 显示全部楼层
    GMT+8, 2025-11-3 10:46 , Processed in 0.110675 second(s), 24 queries , MemCache On.
