在线时间828 小时
UID3079326
注册时间2015-2-11
NXP金币32
TA的每日心情 | 奋斗 2025-5-7 09:07 |
签到天数: 353 天 连续签到: 1 天 [LV.8]以坛为家I
- 5789
- 2025-5-7
使用官方源码程序生成工具,程序已经在初始化时打开了端口A\B\C\D\E时钟,为什么在main里不起作用。
void sysinit (void)
/* Enable all of the port clocks. These have to be enabled to configure
* pin muxing options, so most code will need all of these on anyway.
SIM_SCGC5 |= (SIM_SCGC5_PORTA_MASK
| SIM_SCGC5_PORTB_MASK
| SIM_SCGC5_PORTC_MASK
| SIM_SCGC5_PORTD_MASK
| SIM_SCGC5_PORTE_MASK );
// Release hold with ACKISO: Only has an effect if recovering from VLLS1, VLLS2, or VLLS3
// if ACKISO is set you must clear ackiso before calling pll_init
// or pll init hangs waiting for OSC to initialize
// if osc enabled in low power modes - enable it first before ack
// if I/O needs to be maintained without glitches enable outputs and modules first before ack.
if (PMC_REGSC & PMC_REGSC_ACKISO_MASK)
PMC_REGSC |= PMC_REGSC_ACKISO_MASK;
#ifdef ENABLE_CLKOUT
// Initialize trace clk functionality
clk_out_init();
#endif
#ifndef CMSIS
/* Ramp up the system clock */
/* Set the system dividers */
/* NOTE: The PLL init will not configure the system clock dividers,
* so they must be configured appropriately before calling the PLL
* init function to ensure that clocks remain in valid ranges.
SIM_CLKDIV1 = ( 0
| SIM_CLKDIV1_OUTDIV1(OUTDIV1_VAL)
| SIM_CLKDIV1_OUTDIV4(OUTDIV4_VAL) );
#if defined(NO_PLL_INIT)
// If PLL initialization is not desired, set FLL to 48 MHz clock in default FEI mode
// Set DMX32 and DRST_DRS values accordingly
MCG_C4 = ((MCG_C4 & ~(MCG_C4_DRST_DRS_MASK)) | ((FLL_DMX32 << MCG_C4_DMX32_SHIFT)
| (FLL_DRST_DRS << MCG_C4_DRST_DRS_SHIFT)));
if (FLL_DMX32 == 0)
mcg_clk_hz = 640 * (FLL_DRST_DRS + 1) * FLL_REF_FREQ;
else
mcg_clk_hz = 732 * (FLL_DRST_DRS + 1) * FLL_REF_FREQ;
SIM_SOPT2 &= ~SIM_SOPT2_PLLFLLSEL_MASK; // clear PLLFLLSEL to select the FLL for this clock source
uart0_clk_khz = (mcg_clk_hz / 1000); // the uart0 clock frequency will equal the FLL frequency
SIM_SOPT2 = ((SIM_SOPT2 & ~SIM_SOPT2_UART0SRC_MASK) | SIM_SOPT2_UART0SRC(1));
#else
/* Initialize PLL */
/* PLL will be the source for MCG CLKOUT so the core, system, and flash clocks are derived from it */
mcg_clk_hz = pll_init(CLK0_FREQ_HZ, /* CLKIN0 frequency */
LOW_POWER, /* Set the oscillator for low power mode */
CLK0_TYPE, /* Crystal or canned oscillator clock input */
PLL0_PRDIV, /* PLL predivider value */
PLL0_VDIV, /* PLL multiplier */
MCGOUT); /* Use the output from this PLL as the MCGOUT */
/* Check the value returned from pll_init() to make sure there wasn't an error */
if (mcg_clk_hz < 0x100)
while(1);
SIM_SOPT2 |= SIM_SOPT2_PLLFLLSEL_MASK; // set PLLFLLSEL to select the PLL for this clock source
uart0_clk_khz = ((mcg_clk_hz / 2) / 1000); // UART0 clock frequency will equal half the PLL frequency
#endif
#else
mcg_clk_hz = SystemCoreClock;
if (CLOCK_SETUP == 3)
MCG_C4 |= (MCG_C4_DRST_DRS(1) | MCG_C4_DMX32_MASK);
else
#endif
* Use the value obtained from the pll_init function to define variables
* for the core clock in kHz and also the peripheral clock. These
* variables can be used by other functions that need awareness of the
* system frequency.
mcg_clk_khz = mcg_clk_hz / 1000;
core_clk_khz = mcg_clk_khz / (((SIM_CLKDIV1 & SIM_CLKDIV1_OUTDIV1_MASK) >> 28)+ 1);
periph_clk_khz = core_clk_khz / (((SIM_CLKDIV1 & SIM_CLKDIV1_OUTDIV4_MASK) >> 16)+ 1);
#ifdef USE_ABORT_BUTTON
/* Enable pin interrupt for the abort button - PTA4 */
/* This pin could also be used as the NMI interrupt, but since the NMI
* is level sensitive each button press will cause multiple interrupts.
* Using the GPIO interrupt instead means we can configure for an edge
* sensitive interrupt instead = one interrupt per button press.
enable_abort_button();
#endif
* Configure the UART terminal port pins. These definitions are
* defined in the platform header file.
PORT_PCR_REG(TERM_PIN_PORT, TERM_RX_PIN) = PORT_PCR_MUX(TERM_MUX_ALT);
PORT_PCR_REG(TERM_PIN_PORT, TERM_TX_PIN) = PORT_PCR_MUX(TERM_MUX_ALT);
/* UART0 is clocked asynchronously to the core clock, but all other UARTs are
* clocked from the peripheral clock. So we have to determine which clock
* to send to the UART_init function.
if (TERM_PORT_NUM == 0)
uart0_init (UART0_BASE_PTR, uart0_clk_khz, TERMINAL_BAUD);
else if (TERM_PORT_NUM == 1)
uart_init (UART1_BASE_PTR, periph_clk_khz, TERMINAL_BAUD);
else if (TERM_PORT_NUM == 2)
uart_init (UART2_BASE_PTR, periph_clk_khz, TERMINAL_BAUD);
else
while(1);
