在线时间25 小时
UID3040700
注册时间2014-12-30
NXP金币0
TA的每日心情 | 无聊 2018-7-3 10:22 |
- 116
- 2020-3-26
大家好:
目前在做一个项目,是通过TFTP下载应用程序。我用的是FNET bootloader,这个开源项目支持tftp下载。
开发环境是IAR7.2,TWR-K64F120M开发板。
我用了两个应用程序做测试,其中KSDK中的hello_world已经能成功下载到flash并能正常运行,在串口中打印出Hello World! 但是用带MQX系统的hello工程就不能正常运行。
根据 http://community.freescale.com/message/332455#332455这个帖子做完了相关配置:
我修改后的icf文件:
/*###ICF### Section handled by ICF editor, don't touch! ****/
/*-Editor annotation file-*/
/* IcfEditorFile="$TOOLKIT_DIR$\config\ide\IcfEditor\cortex_v1_0.xml" */
/*-Specials-*/
define symbol __ICFEDIT_intvec_start__ = 0x0000C000;
/*-Memory Regions-*/
define symbol __ICFEDIT_region_ROM_start__ = 0x0000C420 ;
define symbol __ICFEDIT_region_ROM_end__ = 0x000FEFFF;
define symbol __ICFEDIT_region_RAM_start__ = 0x1FFF0000;
define symbol __ICFEDIT_region_RAM_end__ = 0x2002FFF0;
/*-Sizes-*/
define symbol __ICFEDIT_size_cstack__ = 0;
define symbol __ICFEDIT_size_heap__ = 0;
/**** End of ICF editor section. ###ICF###*/
define exported symbol __EXTERNAL_MRAM_ROM_BASE = 0x60000000;
define exported symbol __EXTERNAL_MRAM_ROM_SIZE = 0x00000000;
define exported symbol __EXTERNAL_MRAM_RAM_BASE = 0x60000000;
define exported symbol __EXTERNAL_MRAM_RAM_SIZE = 0x00080000;
define exported symbol __EXTERNAL_LCD_BASE = 0x60000000;
define exported symbol __EXTERNAL_LCD_SIZE = 0x1FFFF;
define exported symbol __EXTERNAL_LCD_DC_BASE = 0x60010000;
define exported symbol __INTERNAL_FLASH_BASE = 0x0000C000;
define exported symbol __INTERNAL_FLASH_SIZE = 0x000F2BE0;
define exported symbol __INTERNAL_SRAM_BASE = 0x1FFF0000;
define exported symbol __INTERNAL_SRAM_SIZE = 0x00040000;
define exported symbol __SRAM_POOL = 0x1FFF0000;
define exported symbol __INTERNAL_FLEXNVM_BASE = 0;
define exported symbol __INTERNAL_FLEXNVM_SIZE = 0;
define exported symbol __VECTOR_TABLE_ROM_START = 0x0000C000;
define exported symbol __VECTOR_TABLE_RAM_START = __ICFEDIT_region_RAM_start__;
define exported symbol __DEFAULT_PROCESSOR_NUMBER = 1;
define exported symbol __DEFAULT_INTERRUPT_STACK_SIZE = 1024;
/* mem_init writes a storeblock_struct at the end of kernel data, max size 32 bytes, so use 0x100 offset */
define exported symbol __BOOT_STACK_ADDRESS = __ICFEDIT_region_RAM_end__ - 0x100;
define exported symbol __KERNEL_DATA_END = __ICFEDIT_region_RAM_end__;
define memory mem with size = 4G;
define region ROM_region = mem:[from __ICFEDIT_region_ROM_start__ to __ICFEDIT_region_ROM_end__];
define region RAM_region = mem:[from __ICFEDIT_region_RAM_start__ to __ICFEDIT_region_RAM_end__];
define block KERNEL_DATA with alignment = 8 { section .kernel_data };
define exported symbol __FLASHX_SECT_SIZE = 0x1000;
define exported symbol __FLASHX_END_ADDR = __INTERNAL_FLASH_BASE + __INTERNAL_FLASH_SIZE;
define block CFMPROTROM with size = 20 { section .cfmconfig };
define block FLASHX_POOL with alignment = __FLASHX_SECT_SIZE { section .flashx };
define block TEXTSECTION with alignment = 4 { section .text };
keep { section .cfmconfig };
keep { section .flashx };
initialize by copy { readwrite };
do not initialize { section .noinit };
do not initialize { section .kernel_data };
do not initialize { section .flashx };
place at address mem:__ICFEDIT_intvec_start__ { readonly section .intvec, block CFMPROTROM };
place in ROM_region { first block TEXTSECTION, readonly, last block FLASHX_POOL };
place at address mem:__ICFEDIT_region_RAM_start__ { readwrite section .vectors_ram };
/* each block/segment must be in one line (association to region) because I need kernel data start after other datas */
place in RAM_region { readwrite, last block KERNEL_DATA };
在user_config.h文件中定义:
#define MQX_ROM_VECTORS 0
重新编译MQX lib工程。再重新编译hello工程(应用程序)。
修改IAR默认程序入口
通过bootloader下载后发送go命令,不能跳到应用程序执行。调试运行在go命令做了个断点,不带MQX系统(KSDK)工程直接在go命令后直接执行。带MQX系统的工程go命令后出现了个警告:Fri May 15, 2015 15:05:54: The stack pointer for stack 'CSTACK' (currently 0x1FFF0900) is outside the stack range (0x2002F000 to 0x20030000) 然后就停止运行了。
什么超出堆栈范围。不知道是不是icf文件没配置好,因为帖子里是k60的,我用的是k64,有人用过嘛?
这是飞思卡尔官方论坛中的类似帖子。
http://community.freescale.com/message/114116#114116
