12
返回列表 发新帖
楼主: wweeww
[已解决] YL-KL26Z 使用Code warrior环境的问题(已解决)
  • 签到天数: 2310 天
    发表于 2015-5-21 09:53:04 | 显示全部楼层
    FSL_TICS_Robin 发表于 2015-5-21 09:05
    补充一下OpenSDA变成JLink的固件链接,大家可以根据自己OpenSDA版本下载对应的固件。OpenSDA / OpenSDA V2 ...
    Jlink固件的限制太多,还不如CMSIS-DAP方便。
    Limitations
    The firmware that makes the OpenSDA platform J-Link compatible has some limitations in contrast to an original, industry leading SEGGER J-Link:
    • May be used with ARM based Freescale devices only.
    • Only debugging on evaluation boards is allowed. Debugging on custom hardware is not supported and not allowed.
    • No production flash programming support.
    • Unlimited breakpoints in flash available for evaluation only.
    • No support is given.
  • 签到天数: 127 天
     楼主| 发表于 2015-5-25 10:55:26 | 显示全部楼层
    谢谢
    发表于 2015-5-25 14:14:04 | 显示全部楼层
    GMT+8, 2025-11-7 10:48 , Processed in 0.097652 second(s), 22 queries , MemCache On.
