查看: 2580|回复: 1
[其他] MAG3110的校准问题
发表于 2015-6-8 22:42:58 | 显示全部楼层 |阅读模式
4.2 Factory Calibration
MAG3110 is factory calibrated for sensitivity, offset and temperature coefficient. All factory calibration coefficients are applied
automatically by the MAG3110 ASIC before the magnetic field readings are written to registers 0x01 to 0x06 (see section 5).
There is no need for the user to apply the calibration correction in the software and the calibration coefficients are not therefore
accessible to the user.
The offset registers in the addresses 0x09 to 0x0E are not a factory calibration offset but allow the user to define a hard iron
offset which can be automatically subtracted from the magnetic field readings (see section 4.3.3).+
这里面说工厂校准已经很完备,无需用户校准。是不是说读出来的磁场数据可以直接使用,不用再进行换算和零点处理?
我知道答案 目前已有1人回答
发表于 2016-6-2 20:08:01 | 显示全部楼层
我也想知道,楼主现在有结果了么?
GMT+8, 2025-10-29 21:39 , Processed in 0.082692 second(s), 23 queries , MemCache On.
