查看: 1705|回复: 0
[求助] 【求助】K20模拟EEPROM出问题
发表于 2015-6-18 10:34:41 | 显示全部楼层 |阅读模式
__ramfunc INT32U dvFlexEE_partition_flash(INT32U eeprom_size, INT32U dflash_size)
      /* Test to make sure the device is not already partitioned. If it
       * is already partitioned, then return with no action performed.
      if ((SIM_FCFG1 & SIM_FCFG1_DEPART(0xF)) != 0x00000F00)
           return PARTED_FAIL;
      /* Write the FCCOB registers */
      FTFL_FCCOB0 = FTFL_FCCOB0_CCOBn(0x80); // Selects the PGMPART command
      FTFL_FCCOB1 = 0x00;
      FTFL_FCCOB2 = 0x00;
      FTFL_FCCOB3 = 0x00;
      /* FCCOB4 is written with the code for the subsystem sizes (eeprom_size define) */
      FTFL_FCCOB4 = eeprom_size;
      /* FFCOB5 is written with the code for the Dflash size (dflash_size define) */
      FTFL_FCCOB5 = dflash_size;
      /* All required FCCOBx registers are written, so launch the command */
      FTFL_FSTAT = FTFL_FSTAT_CCIF_MASK;
      /* Wait for the command to complete */
      while(!(FTFL_FSTAT & FTFL_FSTAT_CCIF_MASK));
      return 1;
我知道答案 目前已有0人回答
GMT+8, 2025-11-7 01:59 , Processed in 0.081623 second(s), 22 queries , MemCache On.
