查看: 3380|回复: 5
[求助] 求助,如何用Mfgtools烧录下载的linux文件到283开发板
发表于 2015-6-18 22:35:45 | 显示全部楼层 |阅读模式
使用 MCIMX28EVKJ: i.MX28评估套件,软件是Mfgtools-Rel-1.1.0_130205_MX28_UP,从官网下载,使用工具自带的Linux系统,烧录到SD卡已经成功,并且能够启动登录。遇到问题:从官网下载了L2.6.35_1.1.0_130130_images_MX28.tar.gz 这个Demo,如何用Mfgtools下载到开发板(SD卡)中运行,目前遇到:更新错误: 0xffffffea (-22) - ,串口停在cpu_id is 28
g_file_storage gadget: high speed config #1
UTP: received command 'mknod bloutp_exec: exit with status -22
ck,mmcblk0,/dev/mmcblk0,block'
class = 'block'
item = 'mmcblk0'
node = /dev/mmcblk0
type = block
UTP: running utp_mk_devnode(block,mmcblk0,/dev/mmcblk0,0x6000)
UTP: sending Non-success
按照user guide的方法:copying your files in “Profiles\MX28 Linux Update\OSFirmware\files” directory. You can replace the files inside this folder. Note that you willfind updater.sb and updater_ivt.sb binaries in “Profiles\MX28 Linux Update\OSFirmware” folder; you must not replace these files(把L2.6.35_1.1.0_130130_images_MX28.tar.gz解压缩后L2.6.35_1.1.0_130130_images_MX28目录下的文件全部复制到C:\Freescale\Mfgtools-Rel-1.1.0_130205_MX28_UPDATER\Profiles\MX28 Linux Update\OS Firmware下面,提示替换是点的替换),无法成功烧录,求解决(我是Linux文盲,还请见谅),急切期待回复。
我知道答案 目前已有5人回答
 楼主| 发表于 2015-6-18 22:37:15 | 显示全部楼层
拷贝文件的路径为:C:\Freescale\Mfgtools-Rel-1.1.0_130205_MX28_UPDATER\Profiles\MX28 Linux Update\OS Firmware\files,帖子上少写了一级目录
    2022-3-3 09:56
  • 签到天数: 4 天
    发表于 2015-6-18 22:39:39 | 显示全部楼层
    可以找周立功的手册看看
  • 签到天数: 19 天
    发表于 2015-6-18 22:41:54 | 显示全部楼层
    不懂,帮顶!
     楼主| 发表于 2015-6-18 22:58:03 | 显示全部楼层
    如果把原来Files下的文件全部删除,用L2.6.35_1.1.0_130130_images_MX28全部黏贴烧录是出现:L2.6.35_1.1.0_130130_images_MX28。串口停在:
    Writing inode tables: done
    Creating journal (8192 blocks): done
    Writing superblocks and filesystem accounting information: done
    This filesystem will be automatically checked every 28 mounts or
    180 days, whichever comes first.  Use tune2fs -c or -i to override.
    UTP: sending Success
    utp_poll: pass returned.
    UTP: received command '$ mount /dev/mmcblk0p3 /mnt/mmcblk0p3'
    UTP: sending Busy
    UTP: executing "mount /dev/mmcblk0p3 /mnt/mmcblk0p3"
    EXT3-fs: barriers not enabled
    kjournald starting.  Commit interval 5 seconds
    EXT3-fs (mmcblk0p3): using internal journal
    EXT3-fs (mmcblk0p3): mounted filesystem with ordered data mode
    请教下什么问题来的,急切需要回复,非常感谢。
     楼主| 发表于 2015-6-18 22:58:51 | 显示全部楼层
    出现:更新错误: 0x6e (110) - 系统无法打开指定的设备或文件。
    GMT+8, 2025-10-29 09:07 , Processed in 0.084808 second(s), 26 queries , MemCache On.
