在线时间1 小时
UID258195
注册时间2011-1-6
NXP金币0
 - 51
 - 1970-1-1
MPC5606B在程序上电或重启后会对RAM空间进初始化,codewarrior V2.10工程下初始化代码为汇编语言,如下所示:
/* MPC5606B derivative specific hardware initialization */
/* Symbol L2SRAM_LOCATION is defined in the application linker command
   file (.lcf)  It is defined to the start of the internal SRAM in the
   MPC5606B.
/*lint -esym(752, L2SRAM_LOCATION) */
extern long L2SRAM_LOCATION;
__asm void INIT_Derivative(void)
nofralloc
    /* MPC5606B SRAM initialization code                              */
    lis r11,L2SRAM_LOCATION@h       /* Base of SRAM, 64-bit word aligned */
    ori r11,r11,L2SRAM_LOCATION@l
    li r12,640                                        /* Loops to cover 80K SRAM; 80k/4 bytes/32 GPRs = 640 */
    mtctr r12
    init_l2sram_loop:
        stmw r0,0(r11)        /* Write 32 GPRs to SRAM                     */
        addi r11,r11,128      /* Inc the ram ptr; 32 GPRs * 4 bytes = 128B */
        bdnz init_l2sram_loop /* Loop for 80k of SRAM                      */
    blr
现在希望在软复位(指令跳转或时钟复位)的情况,不对RAM空间进行初始化,不知道该如何修改代码,还请各位大神给予帮助,谢谢!
