查看: 2200|回复: 1
MC9S08DZ60串口问题(已解决!)
发表于 2015-7-21 16:26:10 | 显示全部楼层 |阅读模式
就是单片机不停的发送数据,突然接收数据就会死掉 。单独的发送和接收是没有问题的。
参与人数 1NXP金币 +5 收起 理由
小七 + 5 问题描述不够详细,至少代码啥的贴上来.
 楼主| 发表于 2015-7-22 09:42:00 | 显示全部楼层
void SCI_INIT(void) {
    SCI1BD =8000000/16/scibandrate;
    SCI1C1=0x00;
    SCI1C2=0x2C;//使能接受中断
UINT8 SCI1_TxMsg(UINT8 *pTxMsg,UINT16 length)
    SCI1_TxMsgLength = length;
    FLAG_SCI1_TX_COMPLETE = 0;
    if(pTxMsg == NULL)
                return FALSE;
    else
        memcpy(Tx_Buffer,pTxMsg,length);   //copy the message to transmit buffer
        SCI1TXON;                          //sci1 transmit enable
        SCI1TIE;                           //transmit register buffer empty interrupt enable
        //SCI1D = Tx_Buffer[0];                           //sending first byte
        return TRUE;
interrupt void isr_SCI1tx(void)
    static UINT16 SCI1_TxMsgIndex = 0;
    if(SCI1_TxMsgIndex < (SCI1_TxMsgLength))
        SCI1S1;
        SCI1D = Tx_Buffer[SCI1_TxMsgIndex];
        SCI1_TxMsgIndex++;
    else
        SCI1TXOFF;                         //transmit function off
        SCI1TID;                           //transmit interrupt disable
        SCI1TCID;
        SCI1_TxMsgIndex = 0;               //transmit message index reset to 0
        FLAG_SCI1_TX_COMPLETE = 1;                   //transmit complete flag set
        if(NULL != SCI1TxCmptEvent)
                (*SCI1TxCmptEvent)();
interrupt void isr_SCI1rx(void)
        UINT8 temp = 0;
        SCI1S1;                //clear RDRF flag
        temp = SCI1D;
GMT+8, 2026-4-15 18:18 , Processed in 0.094077 second(s), 24 queries , Redis On.
