查看: 5702|回复: 3
[分享] MCIMX6Q-SDB:使用mfgtool烧录linux系统
发表于 2015-8-6 15:34:15 | 显示全部楼层 |阅读模式
通过Mfgtools工具烧写官网提供Mfgtools-Rel-4.1.0_130816_MX6Q_UPDATER中,我使用的是2G的SD卡,在下载模式下SW6中D2余D7为ON 其余为OFF,在启动模式下D2余D7位ON其余为OFF。通过串口调试工具看到以下信息:
U-Boot 2009.08 (Aug 16 2013 - 12:04:20)
CPU: Freescale i.MX6 family TO1.2 at 792 MHz
Thermal sensor with ratio = 189
Temperature:   39 C, calibration data 0x5ae4f87d
mx6q pll1: 792MHz
mx6q pll2: 528MHz
mx6q pll3: 480MHz
mx6q pll8: 50MHz
ipg clock     : 66000000Hz
ipg per clock : 66000000Hz
uart clock    : 80000000Hz
cspi clock    : 60000000Hz
ahb clock     : 132000000Hz
axi clock   : 264000000Hz
emi_slow clock: 132000000Hz
ddr clock     : 528000000Hz
usdhc1 clock  : 198000000Hz
usdhc2 clock  : 198000000Hz
usdhc3 clock  : 198000000Hz
usdhc4 clock  : 198000000Hz
nfc clock     : 24000000Hz
Board: i.MX6Q-SABRESD: unknown-board Board: 0x63012 [POR ]
Boot Device: SD
I2C:   ready
DRAM:   1 GB
MMC:   FSL_USDHC: 0,FSL_USDHC: 1,FSL_USDHC: 2,FSL_USDHC: 3
In:    serial
Out:   serial
Err:   serial
Found PFUZE100! deviceid=10,revid=11
Net:   got MAC address from IIM: 00:04:9f:03:cd:c8
FEC0 [PRIME]
Warning: FEC0 MAC addresses don't match:
Address in SROM is         00:04:9f:03:cd:c8
Address in environment is  00:01:02:03:04:05
PHY indentify @ 0x1 = 0x004dd074
FEC: Link is down 7949
Using FEC0 device
TFTP from server 10.3.20.199; our IP address is 10.3.20.204
Filename 'uImage'.
Load address: 0x10800000
Loading: FEC: Link is down 7949
后面就会重复出现以上启动信息。
参与人数 1NXP金币 +10 收起 理由
小七 + 10 打赏!
 楼主| 发表于 2015-8-6 16:07:27 | 显示全部楼层
将开发板启动后,进入boot加入  i.MX_6Dual6Quad_SABRE-SD_Linux_User's_Guide.pdf  文中提到的从SD卡启动的配置信息,启动后串口打印以下数据:
Temperature:   40 C, calibration data 0x5ae4f87d
mx6q pll1: 792MHz
mx6q pll2: 528MHz
mx6q pll3: 480MHz
mx6q pll8: 50MHz
Boot Device: SD
I2C:   ready
DRAM:   1 GB
In:    serial
Out:   serial
Err:   serial
i2c: I2C3 SDA is low, start i2c recovery...
I2C3 Recovery success
FEC0 [PRIME]
mmc2 is current device
Unknown command 'mmcread' - try 'help'
Wrong Image Format for bootm command
ERROR: can't get kernel image!
MX6Q SABRESD U-Boot >
发表于 2015-8-7 12:32:31 | 显示全部楼层
这个蛮牛逼的啊
发表于 2015-8-10 09:38:22 | 显示全部楼层
帮忙顶一下
GMT+8, 2025-10-29 09:00 , Processed in 0.128290 second(s), 23 queries , MemCache On.
