查看: 14695|回复: 2
[已解决] imx6 qt5编译出错“ QM***E_INCDIR_OPENGL_ES2, QM***E_LIBDIR_OPENGL_ES2"
发表于 2015-8-13 15:27:03 | 显示全部楼层 |阅读模式
编译Imx6 qt5。
使用L3.0.35_4.1.0_130816_source。
按照文档”Building QT for i.MX6“,”http://community.freescale.com/docs/DOC-94066“。
编译时提示
”You have already accepted the terms of the Open Source license.
<srcbase> = /home/work/qt5/qtbase
<outbase> = /home/work/qt5/qtbase
Creating qmake...
.Done.
Running configuration tests...
Warning: Disabling pkg-config since PKG_CONFIG_LIBDIR is not set.
Warning: Disabling pkg-config since PKG_CONFIG_SYSROOT_DIR is not set.
Could not determine the target architecture!
Turn on verbose messaging (-v) to see the final report.
The OpenGL ES 2.0 functionality test failed!
Use of pkg-config is not enabled, maybe you want to pass -force-pkg-config?
You might need to modify the include and library search paths by editing
QM***E_INCDIR_OPENGL_ES2, QM***E_LIBDIR_OPENGL_ES2 and QM***E_LIBS_OPENGL_ES2 in
/home/work/qt5/qtbase/mkspecs/devices/linux-imx6-g++.
我从L3.0.35_4.1.0_130816_source里面找到gpu-viv-bin-mx6q-3.0.35-4.1.0,
找出里面的so和include 文件,放到rootfs/usr/.
同时修改了 /home/work/qt5/qtbase/mkspecs/devices/linux-imx6-g++/qmake.conf,
添加了
QM***E_INCDIR_OPENGL_ES2           += /home/work/ltib/ltib/rootfs/usr/include
QM***E_LIBDIR_OPENGL_ES2           += /homw/work/ltib/ltib/rootfs/usr/lib
QM***E_LIBS_OPENGL_ES2  += -lGLESv2 -lEGL -lGAL
但是还是提示这个问题。
configure是:
./configure -opensource -confirm-license -make libs -device imx6 \
-device-option CROSS_COMPILE=/opt/freescale/usr/local/gcc-4.6.2-glibc-2.13-linaro-multilib-2011.12/fsl-linaro-toolchain/bin/arm-fsl-linux-gnueabi- \
-no-pch -no-opengl -no-icu  -no-c++11 \
-opengl es2 \
-eglfs \
-compile-examples \
先前我也遇到這個問題,請在該qmake.conf檔案中, 確認一下有沒有,以下兩個參數及路徑 QM***E_INCDIR           += [rootfs patch]/usr/include QM***E_LIBDIR  &nbs ...
参与人数 1NXP金币 +2 收起 理由
小七 + 2
发表于 2015-8-18 11:47:55 | 显示全部楼层
確認一下有沒有,以下兩個參數及路徑
QM***E_LIBDIR           += [rootfs patch]/usr/lib
如果沒有的話,請將上面兩個參數加入,應該就可以編譯出Makefile
参与人数 1NXP金币 +10 收起 理由
小七 + 10
发表于 2018-8-6 14:03:10 | 显示全部楼层
请问楼主解决没有?我现在也遇到这个问题,求指教
GMT+8, 2026-4-15 19:45 , Processed in 0.100300 second(s), 29 queries , Redis On.
