查看: 3166|回复: 7
[求助] iMX6Q ov3640摄像头调试问题
发表于 2015-8-25 14:04:42 | 显示全部楼层 |阅读模式
我用iMX6Q官方的Android4.4.3的BSP,在ov5640的驱动基础上修改成ov3640摄像头驱动。初始化参数是网上找的驱动参数,通过几个参数比较后,觉得都差不多所以就用了这个。android代码中hardware部分也是根据ov5640修改的。现在发现预览图像是有的,但是都是偏绿的颜色,而拍照后拍出来的是全绿的图片。这个是什么原因的?还是初始化参数有问题?
我知道答案 目前已有7人回答
参与人数 1NXP金币 +3 收起 理由
小七 + 3
发表于 2015-8-25 14:29:32 | 显示全部楼层
是不是摄像头参数设置有问题?
 楼主| 发表于 2015-8-25 14:35:53 | 显示全部楼层
  1. static struct reg_value ov3640_setting_15fps_VGA_640_480[] = {
  2.         {0x3012, 0x80, 0, 0}, {0x304d, 0x45, 0, 0}, {0x30a7, 0x5e, 0, 0},
  3.         {0x3087, 0x16, 0, 0}, {0x309c, 0x1a, 0, 0}, {0x30a2, 0xe4, 0, 0},
  4.         {0x30aa, 0x42, 0, 0}, {0x30b0, 0xff, 0, 0}, {0x30b1, 0xff, 0, 0},
  5.         {0x30b2, 0x10, 0, 0}, {0x300e, 0x32, 0, 0}, {0x300f, 0x21, 0, 0},
  6.         {0x3010, 0x20, 0, 0}, {0x3011, 0x00, 0, 0}, {0x304c, 0x81, 0, 0},
  7.         {0x30d7, 0x10, 0, 0}, {0x30d9, 0x0d, 0, 0}, {0x30db, 0x08, 0, 0},
  8.         {0x3016, 0x82, 0, 0}, {0x3018, 0x38, 0, 0}, {0x3019, 0x30, 0, 0},
  9.         {0x301a, 0x61, 0, 0}, {0x307d, 0x00, 0, 0}, {0x3087, 0x02, 0, 0},
  10.         {0x3082, 0x20, 0, 0}, {0x3015, 0x12, 0, 0}, {0x3014, 0x04, 0, 0},
  11.         {0x3013, 0xf7, 0, 0}, {0x303c, 0x08, 0, 0}, {0x303d, 0x18, 0, 0},
  12.         {0x303e, 0x06, 0, 0}, {0x303f, 0x0c, 0, 0}, {0x3030, 0x62, 0, 0},
  13.         {0x3031, 0x26, 0, 0}, {0x3032, 0xe6, 0, 0}, {0x3033, 0x6e, 0, 0},
  14.         {0x3034, 0xea, 0, 0}, {0x3035, 0xae, 0, 0}, {0x3036, 0xa6, 0, 0},
  15.         {0x3037, 0x6a, 0, 0}, {0x3104, 0x02, 0, 0}, {0x3105, 0xfd, 0, 0},
  16.         {0x3106, 0x00, 0, 0}, {0x3107, 0xff, 0, 0}, {0x3300, 0x12, 0, 0},
  17.         {0x3301, 0xde, 0, 0}, {0x3302, 0xcf, 0, 0}, {0x3312, 0x26, 0, 0},
  18.         {0x3314, 0x42, 0, 0}, {0x3313, 0x2b, 0, 0}, {0x3315, 0x42, 0, 0},
  19.         {0x3310, 0xd0, 0, 0}, {0x3311, 0xbd, 0, 0}, {0x330c, 0x18, 0, 0},
  20.         {0x330d, 0x18, 0, 0}, {0x330e, 0x56, 0, 0}, {0x330f, 0x5c, 0, 0},
  21.         {0x330b, 0x1c, 0, 0}, {0x3306, 0x5c, 0, 0}, {0x3307, 0x11, 0, 0},
  22.         {0x336a, 0x52, 0, 0}, {0x3370, 0x46, 0, 0}, {0x3376, 0x38, 0, 0},
  23.         {0x30b8, 0x20, 0, 0}, {0x30b9, 0x17, 0, 0}, {0x30ba, 0x04, 0, 0},
  24.         {0x30bb, 0x08, 0, 0}, {0x3507, 0x06, 0, 0}, {0x350a, 0x4f, 0, 0},
  25.         {0x3100, 0x02, 0, 0}, {0x3301, 0xde, 0, 0}, {0x3304, 0x00, 0, 0},
  26.         {0x3400, 0x00, 0, 0}, {0x3404, 0x02, 0, 0}, {0x3600, 0xc4, 0, 0},
  27.         {0x3302, 0xef, 0, 0}, {0x3020, 0x01, 0, 0}, {0x3021, 0x1d, 0, 0},
  28.         {0x3022, 0x00, 0, 0}, {0x3023, 0x0a, 0, 0}, {0x3024, 0x08, 0, 0},
  29.         {0x3025, 0x00, 0, 0}, {0x3026, 0x06, 0, 0}, {0x3027, 0x00, 0, 0},
  30.         {0x335f, 0x68, 0, 0}, {0x3360, 0x00, 0, 0}, {0x3361, 0x00, 0, 0},
  31.         {0x3362, 0x12, 0, 0}, {0x3363, 0x80, 0, 0}, {0x3364, 0xe0, 0, 0},
  32.         {0x3403, 0x00, 0, 0}, {0x3088, 0x02, 0, 0}, {0x3089, 0x80, 0, 0},
  33.         {0x308a, 0x01, 0, 0}, {0x308b, 0xe0, 0, 0}, {0x307c, 0x10, 0, 0},
  34.         {0x3090, 0xc0, 0, 0}, {0x304c, 0x84, 0, 0}, {0x308d, 0x04, 0, 0},
  35.         {0x3086, 0x03, 0, 0}, {0x3086, 0x00, 0, 0}, {0x3011, 0x00, 0, 0},
  36. };
  37. static struct reg_value ov3640_setting_30fps_VGA_640_480[] = {
  38.         {0x3012, 0x80, 0, 0}, {0x304d, 0x45, 0, 0}, {0x30a7, 0x5e, 0, 0},
  39.         {0x3087, 0x16, 0, 0}, {0x309c, 0x1a, 0, 0}, {0x30a2, 0xe4, 0, 0},
  40.         {0x30aa, 0x42, 0, 0}, {0x30b0, 0xff, 0, 0}, {0x30b1, 0xff, 0, 0},
  41.         {0x30b2, 0x10, 0, 0}, {0x300e, 0x32, 0, 0}, {0x300f, 0x21, 0, 0},
  42.         {0x3010, 0x20, 0, 0}, {0x3011, 0x01, 0, 0}, {0x304c, 0x82, 0, 0},
  43.         {0x30d7, 0x10, 0, 0}, {0x30d9, 0x0d, 0, 0}, {0x30db, 0x08, 0, 0},
  44.         {0x3016, 0x82, 0, 0}, {0x3018, 0x38, 0, 0}, {0x3019, 0x30, 0, 0},
  45.         {0x301a, 0x61, 0, 0}, {0x307d, 0x00, 0, 0}, {0x3087, 0x02, 0, 0},
  46.         {0x3082, 0x20, 0, 0}, {0x3015, 0x12, 0, 0}, {0x3014, 0x0c, 0, 0},
  47.         {0x3013, 0xf7, 0, 0}, {0x303c, 0x08, 0, 0}, {0x303d, 0x18, 0, 0},
  48.         {0x303e, 0x06, 0, 0}, {0x303f, 0x0c, 0, 0}, {0x3030, 0x62, 0, 0},
  49.         {0x3031, 0x26, 0, 0}, {0x3032, 0xe6, 0, 0}, {0x3033, 0x6e, 0, 0},
  50.         {0x3034, 0xea, 0, 0}, {0x3035, 0xae, 0, 0}, {0x3036, 0xa6, 0, 0},
  51.         {0x3037, 0x6a, 0, 0}, {0x3104, 0x02, 0, 0}, {0x3105, 0xfd, 0, 0},
  52.         {0x3106, 0x00, 0, 0}, {0x3107, 0xff, 0, 0}, {0x3300, 0x12, 0, 0},
  53.         {0x3301, 0xde, 0, 0}, {0x3302, 0xcf, 0, 0}, {0x3312, 0x26, 0, 0},
  54.         {0x3314, 0x42, 0, 0}, {0x3313, 0x2b, 0, 0}, {0x3315, 0x42, 0, 0},
  55.         {0x3310, 0xd0, 0, 0}, {0x3311, 0xbd, 0, 0}, {0x330c, 0x18, 0, 0},
  56.         {0x330d, 0x18, 0, 0}, {0x330e, 0x56, 0, 0}, {0x330f, 0x5c, 0, 0},
  57.         {0x330b, 0x1c, 0, 0}, {0x3306, 0x5c, 0, 0}, {0x3307, 0x11, 0, 0},
  58.         {0x336a, 0x52, 0, 0}, {0x3370, 0x46, 0, 0}, {0x3376, 0x38, 0, 0},
  59.         {0x3300, 0x13, 0, 0}, {0x30b8, 0x20, 0, 0}, {0x30b9, 0x17, 0, 0},
  60.         {0x30ba, 0x04, 0, 0}, {0x30bb, 0x08, 0, 0}, {0x3100, 0x02, 0, 0},
  61.         {0x3301, 0x10, 0x30, 0}, {0x3304, 0x00, 0x03, 0}, {0x3400, 0x00, 0, 0},
  62.         {0x3404, 0x02, 0, 0}, {0x3600, 0xc0, 0, 0}, {0x308d, 0x04, 0, 0},
  63.         {0x3086, 0x03, 0, 0}, {0x3086, 0x00, 0, 0}, {0x3012, 0x10, 0, 0},
  64.         {0x3023, 0x06, 0, 0}, {0x3026, 0x03, 0, 0}, {0x3027, 0x04, 0, 0},
  65.         {0x302a, 0x03, 0, 0}, {0x302b, 0x10, 0, 0}, {0x3075, 0x24, 0, 0},
  66.         {0x300d, 0x01, 0, 0}, {0x30d7, 0x80, 0x80, 0}, {0x3069, 0x00, 0x40, 0},
  67.         {0x303e, 0x00, 0, 0}, {0x303f, 0xc0, 0, 0}, {0x3302, 0x20, 0x20, 0},
  68.         {0x335f, 0x34, 0, 0}, {0x3360, 0x0c, 0, 0}, {0x3361, 0x04, 0, 0},
  69.         {0x3362, 0x12, 0, 0}, {0x3363, 0x88, 0, 0}, {0x3364, 0xe4, 0, 0},
  70.         {0x3403, 0x42, 0, 0}, {0x3088, 0x02, 0, 0}, {0x3089, 0x80, 0, 0},
  71.         {0x308a, 0x01, 0, 0}, {0x308b, 0xe0, 0, 0}, {0x3362, 0x12, 0, 0},
  72.         {0x3363, 0x88, 0, 0}, {0x3364, 0xe4, 0, 0}, {0x3403, 0x42, 0, 0},
  73.         {0x3088, 0x02, 0, 0}, {0x3089, 0x80, 0, 0}, {0x308a, 0x01, 0, 0},
  74.         {0x308b, 0xe0, 0, 0}, {0x300e, 0x37, 0, 0}, {0x300f, 0xe1, 0, 0},
  75.         {0x3010, 0x22, 0, 0}, {0x3011, 0x01, 0, 0}, {0x304c, 0x84, 0, 0},
  76.         {0x3014, 0x04, 0, 0}, {0x3015, 0x02, 0, 0}, {0x302e, 0x00, 0, 0},
  77.         {0x302d, 0x00, 0, 0},
  78. };
  79. static struct reg_value ov3640_setting_15fps_QVGA_320_240[] = {
  80.         {0x3012, 0x80, 0, 0}, {0x304d, 0x45, 0, 0}, {0x30a7, 0x5e, 0, 0},
  81.         {0x3087, 0x16, 0, 0}, {0x309c, 0x1a, 0, 0}, {0x30a2, 0xe4, 0, 0},
  82.         {0x30aa, 0x42, 0, 0}, {0x30b0, 0xff, 0, 0}, {0x30b1, 0xff, 0, 0},
  83.         {0x30b2, 0x10, 0, 0}, {0x300e, 0x32, 0, 0}, {0x300f, 0x21, 0, 0},
  84.         {0x3010, 0x20, 0, 0}, {0x3011, 0x00, 0, 0}, {0x304c, 0x81, 0, 0},
  85.         {0x30d7, 0x10, 0, 0}, {0x30d9, 0x0d, 0, 0}, {0x30db, 0x08, 0, 0},
  86.         {0x3016, 0x82, 0, 0}, {0x3018, 0x38, 0, 0}, {0x3019, 0x30, 0, 0},
  87.         {0x301a, 0x61, 0, 0}, {0x307d, 0x00, 0, 0}, {0x3087, 0x02, 0, 0},
  88.         {0x3082, 0x20, 0, 0}, {0x3015, 0x12, 0, 0}, {0x3014, 0x04, 0, 0},
  89.         {0x3013, 0xf7, 0, 0}, {0x303c, 0x08, 0, 0}, {0x303d, 0x18, 0, 0},
  90.         {0x303e, 0x06, 0, 0}, {0x303f, 0x0c, 0, 0}, {0x3030, 0x62, 0, 0},
  91.         {0x3031, 0x26, 0, 0}, {0x3032, 0xe6, 0, 0}, {0x3033, 0x6e, 0, 0},
  92.         {0x3034, 0xea, 0, 0}, {0x3035, 0xae, 0, 0}, {0x3036, 0xa6, 0, 0},
  93.         {0x3037, 0x6a, 0, 0}, {0x3104, 0x02, 0, 0}, {0x3105, 0xfd, 0, 0},
  94.         {0x3106, 0x00, 0, 0}, {0x3107, 0xff, 0, 0}, {0x3300, 0x12, 0, 0},
  95.         {0x3301, 0xde, 0, 0}, {0x3302, 0xcf, 0, 0}, {0x3312, 0x26, 0, 0},
  96.         {0x3314, 0x42, 0, 0}, {0x3313, 0x2b, 0, 0}, {0x3315, 0x42, 0, 0},
  97.         {0x3310, 0xd0, 0, 0}, {0x3311, 0xbd, 0, 0}, {0x330c, 0x18, 0, 0},
  98.         {0x330d, 0x18, 0, 0}, {0x330e, 0x56, 0, 0}, {0x330f, 0x5c, 0, 0},
  99.         {0x330b, 0x1c, 0, 0}, {0x3306, 0x5c, 0, 0}, {0x3307, 0x11, 0, 0},
  100.         {0x336a, 0x52, 0, 0}, {0x3370, 0x46, 0, 0}, {0x3376, 0x38, 0, 0},
  101.         {0x30b8, 0x20, 0, 0}, {0x30b9, 0x17, 0, 0}, {0x30ba, 0x04, 0, 0},
  102.         {0x30bb, 0x08, 0, 0}, {0x3507, 0x06, 0, 0}, {0x350a, 0x4f, 0, 0},
  103.         {0x3100, 0x02, 0, 0}, {0x3301, 0xde, 0, 0}, {0x3304, 0x00, 0, 0},
  104.         {0x3400, 0x00, 0, 0}, {0x3404, 0x42, 0, 0}, {0x3600, 0xc4, 0, 0},
  105.         {0x3302, 0xef, 0, 0}, {0x3020, 0x01, 0, 0}, {0x3021, 0x1d, 0, 0},
  106.         {0x3022, 0x00, 0, 0}, {0x3023, 0x0a, 0, 0}, {0x3024, 0x08, 0, 0},
  107.         {0x3025, 0x00, 0, 0}, {0x3026, 0x06, 0, 0}, {0x3027, 0x00, 0, 0},
  108.         {0x335f, 0x68, 0, 0}, {0x3360, 0x00, 0, 0}, {0x3361, 0x00, 0, 0},
  109.         {0x3362, 0x01, 0, 0}, {0x3363, 0x40, 0, 0}, {0x3364, 0xf0, 0, 0},
  110.         {0x3403, 0x00, 0, 0}, {0x3088, 0x01, 0, 0}, {0x3089, 0x40, 0, 0},
  111.         {0x308a, 0x00, 0, 0}, {0x308b, 0xf0, 0, 0}, {0x307c, 0x10, 0, 0},
  112.         {0x3090, 0xc0, 0, 0}, {0x304c, 0x84, 0, 0}, {0x308d, 0x04, 0, 0},
  113.         {0x3086, 0x03, 0, 0}, {0x3086, 0x00, 0, 0}, {0x3011, 0x01, 0, 0},
  114. };
  115. static struct reg_value ov3640_setting_30fps_QVGA_320_240[] = {
  116.         {0x3012, 0x80, 0, 0}, {0x304d, 0x45, 0, 0}, {0x30a7, 0x5e, 0, 0},
  117.         {0x3087, 0x16, 0, 0}, {0x309c, 0x1a, 0, 0}, {0x30a2, 0xe4, 0, 0},
  118.         {0x30aa, 0x42, 0, 0}, {0x30b0, 0xff, 0, 0}, {0x30b1, 0xff, 0, 0},
  119.         {0x30b2, 0x10, 0, 0}, {0x300e, 0x32, 0, 0}, {0x300f, 0x21, 0, 0},
  120.         {0x3010, 0x20, 0, 0}, {0x3011, 0x01, 0, 0}, {0x304c, 0x82, 0, 0},
  121.         {0x30d7, 0x10, 0, 0}, {0x30d9, 0x0d, 0, 0}, {0x30db, 0x08, 0, 0},
  122.         {0x3016, 0x82, 0, 0}, {0x3018, 0x38, 0, 0}, {0x3019, 0x30, 0, 0},
  123.         {0x301a, 0x61, 0, 0}, {0x307d, 0x00, 0, 0}, {0x3087, 0x02, 0, 0},
  124.         {0x3082, 0x20, 0, 0}, {0x3015, 0x12, 0, 0}, {0x3014, 0x0c, 0, 0},
  125.         {0x3013, 0xf7, 0, 0}, {0x303c, 0x08, 0, 0}, {0x303d, 0x18, 0, 0},
  126.         {0x303e, 0x06, 0, 0}, {0x303f, 0x0c, 0, 0}, {0x3030, 0x62, 0, 0},
  127.         {0x3031, 0x26, 0, 0}, {0x3032, 0xe6, 0, 0}, {0x3033, 0x6e, 0, 0},
  128.         {0x3034, 0xea, 0, 0}, {0x3035, 0xae, 0, 0}, {0x3036, 0xa6, 0, 0},
  129.         {0x3037, 0x6a, 0, 0}, {0x3104, 0x02, 0, 0}, {0x3105, 0xfd, 0, 0},
  130.         {0x3106, 0x00, 0, 0}, {0x3107, 0xff, 0, 0}, {0x3300, 0x12, 0, 0},
  131.         {0x3301, 0xde, 0, 0}, {0x3302, 0xcf, 0, 0}, {0x3312, 0x26, 0, 0},
  132.         {0x3314, 0x42, 0, 0}, {0x3313, 0x2b, 0, 0}, {0x3315, 0x42, 0, 0},
  133.         {0x3310, 0xd0, 0, 0}, {0x3311, 0xbd, 0, 0}, {0x330c, 0x18, 0, 0},
  134.         {0x330d, 0x18, 0, 0}, {0x330e, 0x56, 0, 0}, {0x330f, 0x5c, 0, 0},
  135.         {0x330b, 0x1c, 0, 0}, {0x3306, 0x5c, 0, 0}, {0x3307, 0x11, 0, 0},
  136.         {0x336a, 0x52, 0, 0}, {0x3370, 0x46, 0, 0}, {0x3376, 0x38, 0, 0},
  137.         {0x3300, 0x13, 0, 0}, {0x30b8, 0x20, 0, 0}, {0x30b9, 0x17, 0, 0},
  138.         {0x30ba, 0x04, 0, 0}, {0x30bb, 0x08, 0, 0}, {0x3100, 0x02, 0, 0},
  139.         {0x3301, 0x10, 0x30, 0}, {0x3304, 0x00, 0x03, 0}, {0x3400, 0x00, 0, 0},
  140.         {0x3404, 0x02, 0, 0}, {0x3600, 0xc0, 0, 0}, {0x308d, 0x04, 0, 0},
  141.         {0x3086, 0x03, 0, 0}, {0x3086, 0x00, 0, 0}, {0x3012, 0x10, 0, 0},
  142.         {0x3023, 0x06, 0, 0}, {0x3026, 0x03, 0, 0}, {0x3027, 0x04, 0, 0},
  143.         {0x302a, 0x03, 0, 0}, {0x302b, 0x10, 0, 0}, {0x3075, 0x24, 0, 0},
  144.         {0x300d, 0x01, 0, 0}, {0x30d7, 0x80, 0x80, 0}, {0x3069, 0x00, 0x40, 0},
  145.         {0x303e, 0x00, 0, 0}, {0x303f, 0xc0, 0, 0}, {0x3302, 0x20, 0x20, 0},
  146.         {0x335f, 0x34, 0, 0}, {0x3360, 0x0c, 0, 0}, {0x3361, 0x04, 0, 0},
  147.         {0x3362, 0x34, 0, 0}, {0x3363, 0x08, 0, 0}, {0x3364, 0x04, 0, 0},
  148.         {0x3403, 0x42, 0, 0}, {0x3088, 0x04, 0, 0}, {0x3089, 0x00, 0, 0},
  149.         {0x308a, 0x03, 0, 0}, {0x308b, 0x00, 0, 0}, {0x3362, 0x12, 0, 0},
  150.         {0x3363, 0x88, 0, 0}, {0x3364, 0xe4, 0, 0}, {0x3403, 0x42, 0, 0},
  151.         {0x3088, 0x02, 0, 0}, {0x3089, 0x80, 0, 0}, {0x308a, 0x01, 0, 0},
  152.         {0x308b, 0xe0, 0, 0}, {0x300e, 0x37, 0, 0}, {0x300f, 0xe1, 0, 0},
  153.         {0x3010, 0x22, 0, 0}, {0x3011, 0x01, 0, 0}, {0x304c, 0x84, 0, 0},
  154. };
  155. static struct reg_value ov3640_setting_15fps_NTSC_720_480[] = {
  156.         {0x3012, 0x80, 0, 0}, {0x304d, 0x45, 0, 0}, {0x30a7, 0x5e, 0, 0},
  157.         {0x3087, 0x16, 0, 0}, {0x309C, 0x1a, 0, 0}, {0x30a2, 0xe4, 0, 0},
  158.         {0x30aa, 0x42, 0, 0}, {0x30b0, 0xff, 0, 0}, {0x30b1, 0xff, 0, 0},
  159.         {0x30b2, 0x10, 0, 0}, {0x300e, 0x39, 0, 0}, {0x300f, 0x21, 0, 0},
  160.         {0x3010, 0x20, 0, 0}, {0x304c, 0x81, 0, 0}, {0x30d7, 0x10, 0, 0},
  161.         {0x30d9, 0x0d, 0, 0}, {0x30db, 0x08, 0, 0}, {0x3016, 0x82, 0, 0},
  162.         {0x3018, 0x48, 0, 0}, {0x3019, 0x40, 0, 0}, {0x301a, 0x82, 0, 0},
  163.         {0x307d, 0x00, 0, 0}, {0x3087, 0x02, 0, 0}, {0x3082, 0x20, 0, 0},
  164.         {0x3015, 0x12, 0, 0}, {0x3014, 0x84, 0, 0}, {0x3013, 0xf7, 0, 0},
  165.         {0x303c, 0x08, 0, 0}, {0x303d, 0x18, 0, 0}, {0x303e, 0x06, 0, 0},
  166.         {0x303F, 0x0c, 0, 0}, {0x3030, 0x62, 0, 0}, {0x3031, 0x26, 0, 0},
  167.         {0x3032, 0xe6, 0, 0}, {0x3033, 0x6e, 0, 0}, {0x3034, 0xea, 0, 0},
  168.         {0x3035, 0xae, 0, 0}, {0x3036, 0xa6, 0, 0}, {0x3037, 0x6a, 0, 0},
  169.         {0x3104, 0x02, 0, 0}, {0x3105, 0xfd, 0, 0}, {0x3106, 0x00, 0, 0},
  170.         {0x3107, 0xff, 0, 0}, {0x3300, 0x13, 0, 0}, {0x3301, 0xde, 0, 0},
  171.         {0x3302, 0xcf, 0, 0}, {0x3312, 0x26, 0, 0}, {0x3314, 0x42, 0, 0},
  172.         {0x3313, 0x2b, 0, 0}, {0x3315, 0x42, 0, 0}, {0x3310, 0xd0, 0, 0},
  173.         {0x3311, 0xbd, 0, 0}, {0x330c, 0x18, 0, 0}, {0x330d, 0x18, 0, 0},
  174.         {0x330e, 0x56, 0, 0}, {0x330f, 0x5c, 0, 0}, {0x330b, 0x1c, 0, 0},
  175.         {0x3306, 0x5c, 0, 0}, {0x3307, 0x11, 0, 0}, {0x336a, 0x52, 0, 0},
  176.         {0x3370, 0x46, 0, 0}, {0x3376, 0x38, 0, 0}, {0x30b8, 0x20, 0, 0},
  177.         {0x30b9, 0x17, 0, 0}, {0x30ba, 0x04, 0, 0}, {0x30bb, 0x08, 0, 0},
  178.         {0x3507, 0x06, 0, 0}, {0x350a, 0x4f, 0, 0}, {0x3100, 0x02, 0, 0},
  179.         {0x3301, 0xde, 0, 0}, {0x3304, 0xfc, 0, 0}, {0x3400, 0x00, 0, 0},
  180.         {0x3404, 0x00, 0, 0}, {0x3600, 0xc0, 0, 0}, {0x3088, 0x08, 0, 0},
  181.         {0x3089, 0x00, 0, 0}, {0x308a, 0x06, 0, 0}, {0x308b, 0x00, 0, 0},
  182.         {0x308d, 0x04, 0, 0}, {0x3086, 0x03, 0, 0}, {0x3086, 0x00, 0, 0},
  183.         {0x30a9, 0xb5, 0, 0}, {0x3317, 0x04, 0, 0}, {0x3316, 0xf8, 0, 0},
  184.         {0x3312, 0x17, 0, 0}, {0x3314, 0x30, 0, 0}, {0x3313, 0x23, 0, 0},
  185.         {0x3315, 0x3e, 0, 0}, {0x3311, 0x9e, 0, 0}, {0x3310, 0xc0, 0, 0},
  186.         {0x330c, 0x18, 0, 0}, {0x330d, 0x18, 0, 0}, {0x330e, 0x5e, 0, 0},
  187.         {0x330f, 0x6c, 0, 0}, {0x330b, 0x1c, 0, 0}, {0x3306, 0x5c, 0, 0},
  188.         {0x3307, 0x11, 0, 0}, {0x3308, 0x25, 0, 0}, {0x3340, 0x20, 0, 0},
  189.         {0x3341, 0x50, 0, 0}, {0x3342, 0x18, 0, 0}, {0x3343, 0x23, 0, 0},
  190.         {0x3344, 0xad, 0, 0}, {0x3345, 0xd0, 0, 0}, {0x3346, 0xb8, 0, 0},
  191.         {0x3347, 0xb4, 0, 0}, {0x3348, 0x04, 0, 0}, {0x3349, 0x98, 0, 0},
  192.         {0x3355, 0x02, 0, 0}, {0x3358, 0x44, 0, 0}, {0x3359, 0x44, 0, 0},
  193.         {0x3300, 0x13, 0, 0}, {0x3367, 0x23, 0, 0}, {0x3368, 0xBB, 0, 0},
  194.         {0x3369, 0xD6, 0, 0}, {0x336A, 0x2A, 0, 0}, {0x336B, 0x07, 0, 0},
  195.         {0x336C, 0x00, 0, 0}, {0x336D, 0x23, 0, 0}, {0x336E, 0xC3, 0, 0},
  196.         {0x336F, 0xDE, 0, 0}, {0x3370, 0x2b, 0, 0}, {0x3371, 0x07, 0, 0},
  197.         {0x3372, 0x00, 0, 0}, {0x3373, 0x23, 0, 0}, {0x3374, 0x9e, 0, 0},
  198.         {0x3375, 0xD6, 0, 0}, {0x3376, 0x29, 0, 0}, {0x3377, 0x07, 0, 0},
  199.         {0x3378, 0x00, 0, 0}, {0x332a, 0x1d, 0, 0}, {0x331b, 0x08, 0, 0},
  200.         {0x331c, 0x16, 0, 0}, {0x331d, 0x2d, 0, 0}, {0x331e, 0x54, 0, 0},
  201.         {0x331f, 0x66, 0, 0}, {0x3320, 0x73, 0, 0}, {0x3321, 0x80, 0, 0},
  202.         {0x3322, 0x8c, 0, 0}, {0x3323, 0x95, 0, 0}, {0x3324, 0x9d, 0, 0},
  203.         {0x3325, 0xac, 0, 0}, {0x3326, 0xb8, 0, 0}, {0x3327, 0xcc, 0, 0},
  204.         {0x3328, 0xdd, 0, 0}, {0x3329, 0xee, 0, 0}, {0x332e, 0x04, 0, 0},
  205.         {0x332f, 0x04, 0, 0}, {0x3331, 0x02, 0, 0}, {0x3100, 0x02, 0, 0},
  206.         {0x3301, 0xde, 0, 0}, {0x3304, 0xfc, 0, 0}, {0x3400, 0x00, 0, 0},
  207.         {0x3404, 0x00, 0, 0}, {0x3610, 0x40, 0, 0}, {0x304c, 0x81, 0, 0},
  208.         {0x307C, 0x10, 0, 0}, {0x3012, 0x10, 0, 0}, {0x3023, 0x06, 0, 0},
  209.         {0x3026, 0x03, 0, 0}, {0x3027, 0x04, 0, 0}, {0x302a, 0x03, 0, 0},
  210.         {0x302b, 0x10, 0, 0}, {0x3075, 0x24, 0, 0}, {0x300d, 0x01, 0, 0},
  211.         {0x30d7, 0x90, 0, 0}, {0x3069, 0x04, 0, 0}, {0x303e, 0x00, 0, 0},
  212.         {0x303f, 0xc0, 0, 0}, {0x3302, 0xef, 0, 0}, {0x335f, 0x34, 0, 0},
  213.         {0x3360, 0x0c, 0, 0}, {0x3361, 0x04, 0, 0}, {0x3362, 0x34, 0, 0},
  214.         {0x3363, 0x08, 0, 0}, {0x3364, 0x04, 0, 0}, {0x3403, 0x42, 0, 0},
  215.         {0x3088, 0x04, 0, 0}, {0x3089, 0x00, 0, 0}, {0x308a, 0x03, 0, 0},
  216.         {0x308b, 0x00, 0, 0}, {0x300e, 0x32, 0, 0}, {0x300f, 0x21, 0, 0},
  217.         {0x3010, 0x20, 0, 0}, {0x3011, 0x01, 0, 0}, {0x304c, 0x82, 0, 0},
  218.         {0x3302, 0xef, 0, 0}, {0x335f, 0x34, 0, 0}, {0x3360, 0x0c, 0, 0},
  219.         {0x3361, 0x04, 0, 0}, {0x3362, 0x23, 0, 0}, {0x3363, 0x28, 0, 0},
  220.         {0x3364, 0x5c, 0, 0}, {0x3403, 0x42, 0, 0}, {0x3088, 0x02, 0, 0},
  221.         {0x3089, 0xD0, 0, 0}, {0x308a, 0x01, 0, 0}, {0x308b, 0xe0, 0, 0},
  222.         {0x304c, 0x83, 0, 0}, {0x300e, 0x39, 0, 0}, {0x300f, 0x21, 0, 0},
  223.         {0x3011, 0x00, 0, 0}, {0x3010, 0x81, 0, 0}, {0x302e, 0x00, 0, 0},
  224.         {0x302d, 0x00, 0, 0}, {0x3071, 0xeb, 0, 0}, {0x301C, 0x02, 0, 0},
  225.         {0x3404, 0x02, 0, 0},
  226. };
  227. static struct reg_value ov3640_setting_30fps_NTSC_720_480[] = {
  228.         {0x3012, 0x80, 0, 0}, {0x304d, 0x45, 0, 0}, {0x30a7, 0x5e, 0, 0},
  229.         {0x3087, 0x16, 0, 0}, {0x309C, 0x1a, 0, 0}, {0x30a2, 0xe4, 0, 0},
  230.         {0x30aa, 0x42, 0, 0}, {0x30b0, 0xff, 0, 0}, {0x30b1, 0xff, 0, 0},
  231.         {0x30b2, 0x10, 0, 0}, {0x300e, 0x39, 0, 0}, {0x300f, 0x21, 0, 0},
  232.         {0x3010, 0x20, 0, 0}, {0x304c, 0x81, 0, 0}, {0x30d7, 0x10, 0, 0},
  233.         {0x30d9, 0x0d, 0, 0}, {0x30db, 0x08, 0, 0}, {0x3016, 0x82, 0, 0},
  234.         {0x3018, 0x48, 0, 0}, {0x3019, 0x40, 0, 0}, {0x301a, 0x82, 0, 0},
  235.         {0x307d, 0x00, 0, 0}, {0x3087, 0x02, 0, 0}, {0x3082, 0x20, 0, 0},
  236.         {0x3015, 0x12, 0, 0}, {0x3014, 0x84, 0, 0}, {0x3013, 0xf7, 0, 0},
  237.         {0x303c, 0x08, 0, 0}, {0x303d, 0x18, 0, 0}, {0x303e, 0x06, 0, 0},
  238.         {0x303F, 0x0c, 0, 0}, {0x3030, 0x62, 0, 0}, {0x3031, 0x26, 0, 0},
  239.         {0x3032, 0xe6, 0, 0}, {0x3033, 0x6e, 0, 0}, {0x3034, 0xea, 0, 0},
  240.         {0x3035, 0xae, 0, 0}, {0x3036, 0xa6, 0, 0}, {0x3037, 0x6a, 0, 0},
  241.         {0x3104, 0x02, 0, 0}, {0x3105, 0xfd, 0, 0}, {0x3106, 0x00, 0, 0},
  242.         {0x3107, 0xff, 0, 0}, {0x3300, 0x13, 0, 0}, {0x3301, 0xde, 0, 0},
  243.         {0x3302, 0xcf, 0, 0}, {0x3312, 0x26, 0, 0}, {0x3314, 0x42, 0, 0},
  244.         {0x3313, 0x2b, 0, 0}, {0x3315, 0x42, 0, 0}, {0x3310, 0xd0, 0, 0},
  245.         {0x3311, 0xbd, 0, 0}, {0x330c, 0x18, 0, 0}, {0x330d, 0x18, 0, 0},
  246.         {0x330e, 0x56, 0, 0}, {0x330f, 0x5c, 0, 0}, {0x330b, 0x1c, 0, 0},
  247.         {0x3306, 0x5c, 0, 0}, {0x3307, 0x11, 0, 0}, {0x336a, 0x52, 0, 0},
  248.         {0x3370, 0x46, 0, 0}, {0x3376, 0x38, 0, 0}, {0x30b8, 0x20, 0, 0},
  249.         {0x30b9, 0x17, 0, 0}, {0x30ba, 0x04, 0, 0}, {0x30bb, 0x08, 0, 0},
  250.         {0x3507, 0x06, 0, 0}, {0x350a, 0x4f, 0, 0}, {0x3100, 0x02, 0, 0},
  251.         {0x3301, 0xde, 0, 0}, {0x3304, 0xfc, 0, 0}, {0x3400, 0x00, 0, 0},
  252.         {0x3404, 0x00, 0, 0}, {0x3600, 0xc0, 0, 0}, {0x3088, 0x08, 0, 0},
  253.         {0x3089, 0x00, 0, 0}, {0x308a, 0x06, 0, 0}, {0x308b, 0x00, 0, 0},
  254.         {0x308d, 0x04, 0, 0}, {0x3086, 0x03, 0, 0}, {0x3086, 0x00, 0, 0},
  255.         {0x30a9, 0xb5, 0, 0}, {0x3317, 0x04, 0, 0}, {0x3316, 0xf8, 0, 0},
  256.         {0x3312, 0x17, 0, 0}, {0x3314, 0x30, 0, 0}, {0x3313, 0x23, 0, 0},
  257.         {0x3315, 0x3e, 0, 0}, {0x3311, 0x9e, 0, 0}, {0x3310, 0xc0, 0, 0},
  258.         {0x330c, 0x18, 0, 0}, {0x330d, 0x18, 0, 0}, {0x330e, 0x5e, 0, 0},
  259.         {0x330f, 0x6c, 0, 0}, {0x330b, 0x1c, 0, 0}, {0x3306, 0x5c, 0, 0},
  260.         {0x3307, 0x11, 0, 0}, {0x3308, 0x25, 0, 0}, {0x3340, 0x20, 0, 0},
  261.         {0x3341, 0x50, 0, 0}, {0x3342, 0x18, 0, 0}, {0x3343, 0x23, 0, 0},
  262.         {0x3344, 0xad, 0, 0}, {0x3345, 0xd0, 0, 0}, {0x3346, 0xb8, 0, 0},
  263.         {0x3347, 0xb4, 0, 0}, {0x3348, 0x04, 0, 0}, {0x3349, 0x98, 0, 0},
  264.         {0x3355, 0x02, 0, 0}, {0x3358, 0x44, 0, 0}, {0x3359, 0x44, 0, 0},
  265.         {0x3300, 0x13, 0, 0}, {0x3367, 0x23, 0, 0}, {0x3368, 0xBB, 0, 0},
  266.         {0x3369, 0xD6, 0, 0}, {0x336A, 0x2A, 0, 0}, {0x336B, 0x07, 0, 0},
  267.         {0x336C, 0x00, 0, 0}, {0x336D, 0x23, 0, 0}, {0x336E, 0xC3, 0, 0},
  268.         {0x336F, 0xDE, 0, 0}, {0x3370, 0x2b, 0, 0}, {0x3371, 0x07, 0, 0},
  269.         {0x3372, 0x00, 0, 0}, {0x3373, 0x23, 0, 0}, {0x3374, 0x9e, 0, 0},
  270.         {0x3375, 0xD6, 0, 0}, {0x3376, 0x29, 0, 0}, {0x3377, 0x07, 0, 0},
  271.         {0x3378, 0x00, 0, 0}, {0x332a, 0x1d, 0, 0}, {0x331b, 0x08, 0, 0},
  272.         {0x331c, 0x16, 0, 0}, {0x331d, 0x2d, 0, 0}, {0x331e, 0x54, 0, 0},
  273.         {0x331f, 0x66, 0, 0}, {0x3320, 0x73, 0, 0}, {0x3321, 0x80, 0, 0},
  274.         {0x3322, 0x8c, 0, 0}, {0x3323, 0x95, 0, 0}, {0x3324, 0x9d, 0, 0},
  275.         {0x3325, 0xac, 0, 0}, {0x3326, 0xb8, 0, 0}, {0x3327, 0xcc, 0, 0},
  276.         {0x3328, 0xdd, 0, 0}, {0x3329, 0xee, 0, 0}, {0x332e, 0x04, 0, 0},
  277.         {0x332f, 0x04, 0, 0}, {0x3331, 0x02, 0, 0}, {0x3100, 0x02, 0, 0},
  278.         {0x3301, 0xde, 0, 0}, {0x3304, 0xfc, 0, 0}, {0x3400, 0x00, 0, 0},
  279.         {0x3404, 0x00, 0, 0}, {0x3610, 0x40, 0, 0}, {0x304c, 0x81, 0, 0},
  280.         {0x307C, 0x10, 0, 0}, {0x3012, 0x10, 0, 0}, {0x3023, 0x06, 0, 0},
  281.         {0x3026, 0x03, 0, 0}, {0x3027, 0x04, 0, 0}, {0x302a, 0x03, 0, 0},
  282.         {0x302b, 0x10, 0, 0}, {0x3075, 0x24, 0, 0}, {0x300d, 0x01, 0, 0},
  283.         {0x30d7, 0x90, 0, 0}, {0x3069, 0x04, 0, 0}, {0x303e, 0x00, 0, 0},
  284.         {0x303f, 0xc0, 0, 0}, {0x3302, 0xef, 0, 0}, {0x335f, 0x34, 0, 0},
  285.         {0x3360, 0x0c, 0, 0}, {0x3361, 0x04, 0, 0}, {0x3362, 0x34, 0, 0},
  286.         {0x3363, 0x08, 0, 0}, {0x3364, 0x04, 0, 0}, {0x3403, 0x42, 0, 0},
  287.         {0x3088, 0x04, 0, 0}, {0x3089, 0x00, 0, 0}, {0x308a, 0x03, 0, 0},
  288.         {0x308b, 0x00, 0, 0}, {0x300e, 0x32, 0, 0}, {0x300f, 0x21, 0, 0},
  289.         {0x3010, 0x20, 0, 0}, {0x3011, 0x01, 0, 0}, {0x304c, 0x82, 0, 0},
  290.         {0x3302, 0xef, 0, 0}, {0x335f, 0x34, 0, 0}, {0x3360, 0x0c, 0, 0},
  291.         {0x3361, 0x04, 0, 0}, {0x3362, 0x23, 0, 0}, {0x3363, 0x28, 0, 0},
  292.         {0x3364, 0x5c, 0, 0}, {0x3403, 0x42, 0, 0}, {0x3088, 0x02, 0, 0},
  293.         {0x3089, 0xD0, 0, 0}, {0x308a, 0x01, 0, 0}, {0x308b, 0xe0, 0, 0},
  294.         {0x304c, 0x83, 0, 0}, {0x300e, 0x39, 0, 0}, {0x300f, 0xA1, 0, 0},
  295.         {0x3011, 0x00, 0, 0}, {0x3010, 0x81, 0, 0}, {0x3014, 0x84, 0, 0},
  296.         {0x302e, 0x00, 0, 0}, {0x302d, 0x00, 0, 0}, {0x3071, 0xeb, 0, 0},
  297.         {0x301C, 0x02, 0, 0}, {0x3404, 0x02, 0, 0},
  298. };
  299. static struct reg_value ov3640_setting_15fps_PAL_720_576[] = {
  300.         {0x3012, 0x80, 0, 0}, {0x304d, 0x45, 0, 0}, {0x30a7, 0x5e, 0, 0},
  301.         {0x3087, 0x16, 0, 0}, {0x309C, 0x1a, 0, 0}, {0x30a2, 0xe4, 0, 0},
  302.         {0x30aa, 0x42, 0, 0}, {0x30b0, 0xff, 0, 0}, {0x30b1, 0xff, 0, 0},
  303.         {0x30b2, 0x10, 0, 0}, {0x300e, 0x39, 0, 0}, {0x300f, 0x21, 0, 0},
  304.         {0x3010, 0x20, 0, 0}, {0x304c, 0x81, 0, 0}, {0x30d7, 0x10, 0, 0},
  305.         {0x30d9, 0x0d, 0, 0}, {0x30db, 0x08, 0, 0}, {0x3016, 0x82, 0, 0},
  306.         {0x3018, 0x48, 0, 0}, {0x3019, 0x40, 0, 0}, {0x301a, 0x82, 0, 0},
  307.         {0x307d, 0x00, 0, 0}, {0x3087, 0x02, 0, 0}, {0x3082, 0x20, 0, 0},
  308.         {0x3015, 0x12, 0, 0}, {0x3014, 0x84, 0, 0}, {0x3013, 0xf7, 0, 0},
  309.         {0x303c, 0x08, 0, 0}, {0x303d, 0x18, 0, 0}, {0x303e, 0x06, 0, 0},
  310.         {0x303F, 0x0c, 0, 0}, {0x3030, 0x62, 0, 0}, {0x3031, 0x26, 0, 0},
  311.         {0x3032, 0xe6, 0, 0}, {0x3033, 0x6e, 0, 0}, {0x3034, 0xea, 0, 0},
  312.         {0x3035, 0xae, 0, 0}, {0x3036, 0xa6, 0, 0}, {0x3037, 0x6a, 0, 0},
  313.         {0x3104, 0x02, 0, 0}, {0x3105, 0xfd, 0, 0}, {0x3106, 0x00, 0, 0},
  314.         {0x3107, 0xff, 0, 0}, {0x3300, 0x13, 0, 0}, {0x3301, 0xde, 0, 0},
  315.         {0x3302, 0xcf, 0, 0}, {0x3312, 0x26, 0, 0}, {0x3314, 0x42, 0, 0},
  316.         {0x3313, 0x2b, 0, 0}, {0x3315, 0x42, 0, 0}, {0x3310, 0xd0, 0, 0},
  317.         {0x3311, 0xbd, 0, 0}, {0x330c, 0x18, 0, 0}, {0x330d, 0x18, 0, 0},
  318.         {0x330e, 0x56, 0, 0}, {0x330f, 0x5c, 0, 0}, {0x330b, 0x1c, 0, 0},
  319.         {0x3306, 0x5c, 0, 0}, {0x3307, 0x11, 0, 0}, {0x336a, 0x52, 0, 0},
  320.         {0x3370, 0x46, 0, 0}, {0x3376, 0x38, 0, 0}, {0x30b8, 0x20, 0, 0},
  321.         {0x30b9, 0x17, 0, 0}, {0x30ba, 0x04, 0, 0}, {0x30bb, 0x08, 0, 0},
  322.         {0x3507, 0x06, 0, 0}, {0x350a, 0x4f, 0, 0}, {0x3100, 0x02, 0, 0},
  323.         {0x3301, 0xde, 0, 0}, {0x3304, 0xfc, 0, 0}, {0x3400, 0x00, 0, 0},
  324.         {0x3404, 0x00, 0, 0}, {0x3600, 0xc0, 0, 0}, {0x3088, 0x08, 0, 0},
  325.         {0x3089, 0x00, 0, 0}, {0x308a, 0x06, 0, 0}, {0x308b, 0x00, 0, 0},
  326.         {0x308d, 0x04, 0, 0}, {0x3086, 0x03, 0, 0}, {0x3086, 0x00, 0, 0},
  327.         {0x30a9, 0xb5, 0, 0}, {0x3317, 0x04, 0, 0}, {0x3316, 0xf8, 0, 0},
  328.         {0x3312, 0x17, 0, 0}, {0x3314, 0x30, 0, 0}, {0x3313, 0x23, 0, 0},
  329.         {0x3315, 0x3e, 0, 0}, {0x3311, 0x9e, 0, 0}, {0x3310, 0xc0, 0, 0},
  330.         {0x330c, 0x18, 0, 0}, {0x330d, 0x18, 0, 0}, {0x330e, 0x5e, 0, 0},
  331.         {0x330f, 0x6c, 0, 0}, {0x330b, 0x1c, 0, 0}, {0x3306, 0x5c, 0, 0},
  332.         {0x3307, 0x11, 0, 0}, {0x3308, 0x25, 0, 0}, {0x3340, 0x20, 0, 0},
  333.         {0x3341, 0x50, 0, 0}, {0x3342, 0x18, 0, 0}, {0x3343, 0x23, 0, 0},
  334.         {0x3344, 0xad, 0, 0}, {0x3345, 0xd0, 0, 0}, {0x3346, 0xb8, 0, 0},
  335.         {0x3347, 0xb4, 0, 0}, {0x3348, 0x04, 0, 0}, {0x3349, 0x98, 0, 0},
  336.         {0x3355, 0x02, 0, 0}, {0x3358, 0x44, 0, 0}, {0x3359, 0x44, 0, 0},
  337.         {0x3300, 0x13, 0, 0}, {0x3367, 0x23, 0, 0}, {0x3368, 0xBB, 0, 0},
  338.         {0x3369, 0xD6, 0, 0}, {0x336A, 0x2A, 0, 0}, {0x336B, 0x07, 0, 0},
  339.         {0x336C, 0x00, 0, 0}, {0x336D, 0x23, 0, 0}, {0x336E, 0xC3, 0, 0},
  340.         {0x336F, 0xDE, 0, 0}, {0x3370, 0x2b, 0, 0}, {0x3371, 0x07, 0, 0},
  341.         {0x3372, 0x00, 0, 0}, {0x3373, 0x23, 0, 0}, {0x3374, 0x9e, 0, 0},
  342.         {0x3375, 0xD6, 0, 0}, {0x3376, 0x29, 0, 0}, {0x3377, 0x07, 0, 0},
  343.         {0x3378, 0x00, 0, 0}, {0x332a, 0x1d, 0, 0}, {0x331b, 0x08, 0, 0},
  344.         {0x331c, 0x16, 0, 0}, {0x331d, 0x2d, 0, 0}, {0x331e, 0x54, 0, 0},
  345.         {0x331f, 0x66, 0, 0}, {0x3320, 0x73, 0, 0}, {0x3321, 0x80, 0, 0},
  346.         {0x3322, 0x8c, 0, 0}, {0x3323, 0x95, 0, 0}, {0x3324, 0x9d, 0, 0},
  347.         {0x3325, 0xac, 0, 0}, {0x3326, 0xb8, 0, 0}, {0x3327, 0xcc, 0, 0},
  348.         {0x3328, 0xdd, 0, 0}, {0x3329, 0xee, 0, 0}, {0x332e, 0x04, 0, 0},
  349.         {0x332f, 0x04, 0, 0}, {0x3331, 0x02, 0, 0}, {0x3100, 0x02, 0, 0},
  350.         {0x3301, 0xde, 0, 0}, {0x3304, 0xfc, 0, 0}, {0x3400, 0x00, 0, 0},
  351.         {0x3404, 0x00, 0, 0}, {0x3610, 0x40, 0, 0}, {0x304c, 0x81, 0, 0},
  352.         {0x307C, 0x10, 0, 0}, {0x3012, 0x10, 0, 0}, {0x3023, 0x06, 0, 0},
  353.         {0x3026, 0x03, 0, 0}, {0x3027, 0x04, 0, 0}, {0x302a, 0x03, 0, 0},
  354.         {0x302b, 0x10, 0, 0}, {0x3075, 0x24, 0, 0}, {0x300d, 0x01, 0, 0},
  355.         {0x30d7, 0x90, 0, 0}, {0x3069, 0x04, 0, 0}, {0x303e, 0x00, 0, 0},
  356.         {0x303f, 0xc0, 0, 0}, {0x3302, 0xef, 0, 0}, {0x335f, 0x34, 0, 0},
  357.         {0x3360, 0x0c, 0, 0}, {0x3361, 0x04, 0, 0}, {0x3362, 0x34, 0, 0},
  358.         {0x3363, 0x08, 0, 0}, {0x3364, 0x04, 0, 0}, {0x3403, 0x42, 0, 0},
  359.         {0x3088, 0x04, 0, 0}, {0x3089, 0x00, 0, 0}, {0x308a, 0x03, 0, 0},
  360.         {0x308b, 0x00, 0, 0}, {0x300e, 0x32, 0, 0}, {0x300f, 0x21, 0, 0},
  361.         {0x3010, 0x20, 0, 0}, {0x3011, 0x01, 0, 0}, {0x304c, 0x82, 0, 0},
  362.         {0x3302, 0xef, 0, 0}, {0x335f, 0x34, 0, 0}, {0x3360, 0x0c, 0, 0},
  363.         {0x3361, 0x04, 0, 0}, {0x3362, 0x23, 0, 0}, {0x3363, 0x28, 0, 0},
  364.         {0x3364, 0x5c, 0, 0}, {0x3403, 0x42, 0, 0}, {0x3088, 0x02, 0, 0},
  365.         {0x3089, 0xD0, 0, 0}, {0x308a, 0x02, 0, 0}, {0x308b, 0x40, 0, 0},
  366.         {0x304c, 0x83, 0, 0}, {0x300e, 0x39, 0, 0}, {0x300f, 0x21, 0, 0},
  367.         {0x3011, 0x00, 0, 0}, {0x3010, 0x81, 0, 0}, {0x302e, 0x00, 0, 0},
  368.         {0x302d, 0x00, 0, 0}, {0x3071, 0xeb, 0, 0}, {0x301C, 0x02, 0, 0},
  369.         {0x3404, 0x02, 0, 0},
  370. };
  371. static struct reg_value ov3640_setting_30fps_PAL_720_576[] = {
  372.         {0x3012, 0x80, 0, 0}, {0x304d, 0x45, 0, 0}, {0x30a7, 0x5e, 0, 0},
  373.         {0x3086, 0x16, 0, 0}, {0x309C, 0x1a, 0, 0}, {0x30a2, 0xe4, 0, 0},
  374.         {0x30aa, 0x42, 0, 0}, {0x30b0, 0xff, 0, 0}, {0x30b1, 0xff, 0, 0},
  375.         {0x30b2, 0x10, 0, 0}, {0x300e, 0x39, 0, 0}, {0x300f, 0x21, 0, 0},
  376.         {0x3010, 0x20, 0, 0}, {0x304c, 0x81, 0, 0}, {0x30d7, 0x10, 0, 0},
  377.         {0x30d9, 0x0d, 0, 0}, {0x30db, 0x08, 0, 0}, {0x3016, 0x82, 0, 0},
  378.         {0x3018, 0x48, 0, 0}, {0x3019, 0x40, 0, 0}, {0x301a, 0x82, 0, 0},
  379.         {0x307d, 0x00, 0, 0}, {0x3087, 0x02, 0, 0}, {0x3082, 0x20, 0, 0},
  380.         {0x3015, 0x12, 0, 0}, {0x3014, 0x84, 0, 0}, {0x3013, 0xf7, 0, 0},
  381.         {0x303c, 0x08, 0, 0}, {0x303d, 0x18, 0, 0}, {0x303e, 0x06, 0, 0},
  382.         {0x303F, 0x0c, 0, 0}, {0x3030, 0x62, 0, 0}, {0x3031, 0x26, 0, 0},
  383.         {0x3032, 0xe6, 0, 0}, {0x3033, 0x6e, 0, 0}, {0x3034, 0xea, 0, 0},
  384.         {0x3035, 0xae, 0, 0}, {0x3036, 0xa6, 0, 0}, {0x3037, 0x6a, 0, 0},
  385.         {0x3104, 0x02, 0, 0}, {0x3105, 0xfd, 0, 0}, {0x3106, 0x00, 0, 0},
  386.         {0x3107, 0xff, 0, 0}, {0x3300, 0x13, 0, 0}, {0x3301, 0xde, 0, 0},
  387.         {0x3302, 0xcf, 0, 0}, {0x3312, 0x26, 0, 0}, {0x3314, 0x42, 0, 0},
  388.         {0x3313, 0x2b, 0, 0}, {0x3315, 0x42, 0, 0}, {0x3310, 0xd0, 0, 0},
  389.         {0x3311, 0xbd, 0, 0}, {0x330c, 0x18, 0, 0}, {0x330d, 0x18, 0, 0},
  390.         {0x330e, 0x56, 0, 0}, {0x330f, 0x5c, 0, 0}, {0x330b, 0x1c, 0, 0},
  391.         {0x3306, 0x5c, 0, 0}, {0x3307, 0x11, 0, 0}, {0x336a, 0x52, 0, 0},
  392.         {0x3370, 0x46, 0, 0}, {0x3376, 0x38, 0, 0}, {0x30b8, 0x20, 0, 0},
  393.         {0x30b9, 0x17, 0, 0}, {0x30ba, 0x04, 0, 0}, {0x30bb, 0x08, 0, 0},
  394.         {0x3507, 0x06, 0, 0}, {0x350a, 0x4f, 0, 0}, {0x3100, 0x02, 0, 0},
  395.         {0x3301, 0xde, 0, 0}, {0x3304, 0xfc, 0, 0}, {0x3400, 0x00, 0, 0},
  396.         {0x3404, 0x00, 0, 0}, {0x3600, 0xc0, 0, 0}, {0x3088, 0x08, 0, 0},
  397.         {0x3089, 0x00, 0, 0}, {0x308a, 0x06, 0, 0}, {0x308b, 0x00, 0, 0},
  398.         {0x308d, 0x04, 0, 0}, {0x3086, 0x03, 0, 0}, {0x3086, 0x00, 0, 0},
  399.         {0x30a9, 0xb5, 0, 0}, {0x3317, 0x04, 0, 0}, {0x3316, 0xf8, 0, 0},
  400.         {0x3312, 0x17, 0, 0}, {0x3314, 0x30, 0, 0}, {0x3313, 0x23, 0, 0},
  401.         {0x3315, 0x3e, 0, 0}, {0x3311, 0x9e, 0, 0}, {0x3310, 0xc0, 0, 0},
  402.         {0x330c, 0x18, 0, 0}, {0x330d, 0x18, 0, 0}, {0x330e, 0x5e, 0, 0},
  403.         {0x330f, 0x6c, 0, 0}, {0x330b, 0x1c, 0, 0}, {0x3306, 0x5c, 0, 0},
  404.         {0x3307, 0x11, 0, 0}, {0x3308, 0x25, 0, 0}, {0x3340, 0x20, 0, 0},
  405.         {0x3341, 0x50, 0, 0}, {0x3342, 0x18, 0, 0}, {0x3343, 0x23, 0, 0},
  406.         {0x3344, 0xad, 0, 0}, {0x3345, 0xd0, 0, 0}, {0x3346, 0xb8, 0, 0},
  407.         {0x3347, 0xb4, 0, 0}, {0x3348, 0x04, 0, 0}, {0x3349, 0x98, 0, 0},
  408.         {0x3355, 0x02, 0, 0}, {0x3358, 0x44, 0, 0}, {0x3359, 0x44, 0, 0},
  409.         {0x3300, 0x13, 0, 0}, {0x3367, 0x23, 0, 0}, {0x3368, 0xBB, 0, 0},
  410.         {0x3369, 0xD6, 0, 0}, {0x336A, 0x2A, 0, 0}, {0x336B, 0x07, 0, 0},
  411.         {0x336C, 0x00, 0, 0}, {0x336D, 0x23, 0, 0}, {0x336E, 0xC3, 0, 0},
  412.         {0x336F, 0xDE, 0, 0}, {0x3370, 0x2b, 0, 0}, {0x3371, 0x07, 0, 0},
  413.         {0x3372, 0x00, 0, 0}, {0x3373, 0x23, 0, 0}, {0x3374, 0x9e, 0, 0},
  414.         {0x3375, 0xD6, 0, 0}, {0x3376, 0x29, 0, 0}, {0x3377, 0x07, 0, 0},
  415.         {0x3378, 0x00, 0, 0}, {0x332a, 0x1d, 0, 0}, {0x331b, 0x08, 0, 0},
  416.         {0x331c, 0x16, 0, 0}, {0x331d, 0x2d, 0, 0}, {0x331e, 0x54, 0, 0},
  417.         {0x331f, 0x66, 0, 0}, {0x3320, 0x73, 0, 0}, {0x3321, 0x80, 0, 0},
  418.         {0x3322, 0x8c, 0, 0}, {0x3323, 0x95, 0, 0}, {0x3324, 0x9d, 0, 0},
  419.         {0x3325, 0xac, 0, 0}, {0x3326, 0xb8, 0, 0}, {0x3327, 0xcc, 0, 0},
  420.         {0x3328, 0xdd, 0, 0}, {0x3329, 0xee, 0, 0}, {0x332e, 0x04, 0, 0},
  421.         {0x332f, 0x04, 0, 0}, {0x3331, 0x02, 0, 0}, {0x3100, 0x02, 0, 0},
  422.         {0x3301, 0xde, 0, 0}, {0x3304, 0xfc, 0, 0}, {0x3400, 0x00, 0, 0},
  423.         {0x3404, 0x00, 0, 0}, {0x3610, 0x40, 0, 0}, {0x304c, 0x81, 0, 0},
  424.         {0x307C, 0x10, 0, 0}, {0x3012, 0x10, 0, 0}, {0x3023, 0x06, 0, 0},
  425.         {0x3026, 0x03, 0, 0}, {0x3027, 0x04, 0, 0}, {0x302a, 0x03, 0, 0},
  426.         {0x302b, 0x10, 0, 0}, {0x3075, 0x24, 0, 0}, {0x300d, 0x01, 0, 0},
  427.         {0x30d7, 0x90, 0, 0}, {0x3069, 0x04, 0, 0}, {0x303e, 0x00, 0, 0},
  428.         {0x303f, 0xc0, 0, 0}, {0x3302, 0xef, 0, 0}, {0x335f, 0x34, 0, 0},
  429.         {0x3360, 0x0c, 0, 0}, {0x3361, 0x04, 0, 0}, {0x3362, 0x34, 0, 0},
  430.         {0x3363, 0x08, 0, 0}, {0x3364, 0x04, 0, 0}, {0x3403, 0x42, 0, 0},
  431.         {0x3088, 0x04, 0, 0}, {0x3089, 0x00, 0, 0}, {0x308a, 0x03, 0, 0},
  432.         {0x308b, 0x00, 0, 0}, {0x300e, 0x32, 0, 0}, {0x300f, 0x21, 0, 0},
  433.         {0x3010, 0x20, 0, 0}, {0x3011, 0x01, 0, 0}, {0x304c, 0x82, 0, 0},
  434.         {0x3302, 0xef, 0, 0}, {0x335f, 0x34, 0, 0}, {0x3360, 0x0c, 0, 0},
  435.         {0x3361, 0x04, 0, 0}, {0x3362, 0x23, 0, 0}, {0x3363, 0x28, 0, 0},
  436.         {0x3364, 0x5c, 0, 0}, {0x3403, 0x42, 0, 0}, {0x3088, 0x02, 0, 0},
  437.         {0x3089, 0xD0, 0, 0}, {0x308a, 0x02, 0, 0}, {0x308b, 0x40, 0, 0},
  438.         {0x304c, 0x83, 0, 0}, {0x300e, 0x39, 0, 0}, {0x300f, 0xA1, 0, 0},
  439.         {0x3011, 0x00, 0, 0}, {0x3010, 0x81, 0, 0}, {0x3014, 0x84, 0, 0},
  440.         {0x302e, 0x00, 0, 0}, {0x302d, 0x00, 0, 0}, {0x3071, 0xeb, 0, 0},
  441.         {0x301C, 0x02, 0, 0}, {0x3404, 0x02, 0, 0},
  442. };
  443. static struct reg_value ov3640_setting_15fps_720P_1280_720[] = {
  444.         {0x3012, 0x80, 0, 0}, {0x304d, 0x45, 0, 0}, {0x30a7, 0x5e, 0, 0},
  445.         {0x3087, 0x16, 0, 0}, {0x309C, 0x1a, 0, 0}, {0x30a2, 0xe4, 0, 0},
  446.         {0x30aa, 0x42, 0, 0}, {0x30b0, 0xff, 0, 0}, {0x30b1, 0xff, 0, 0},
  447.         {0x30b2, 0x10, 0, 0}, {0x300e, 0x32, 0, 0}, {0x300f, 0x21, 0, 0},
  448.         {0x3010, 0x20, 0, 0}, {0x3011, 0x01, 0, 0}, {0x304c, 0x82, 0, 0},
  449.         {0x30d7, 0x10, 0, 0}, {0x30d9, 0x0d, 0, 0}, {0x30db, 0x08, 0, 0},
  450.         {0x3016, 0x82, 0, 0}, {0x3018, 0x38, 0, 0}, {0x3019, 0x30, 0, 0},
  451.         {0x301a, 0x61, 0, 0}, {0x307d, 0x00, 0, 0}, {0x3087, 0x02, 0, 0},
  452.         {0x3082, 0x20, 0, 0}, {0x3015, 0x12, 0, 0}, {0x3014, 0x0c, 0, 0},
  453.         {0x3013, 0xf7, 0, 0}, {0x303c, 0x08, 0, 0}, {0x303d, 0x18, 0, 0},
  454.         {0x303e, 0x06, 0, 0}, {0x303F, 0x0c, 0, 0}, {0x3030, 0x62, 0, 0},
  455.         {0x3031, 0x26, 0, 0}, {0x3032, 0xe6, 0, 0}, {0x3033, 0x6e, 0, 0},
  456.         {0x3034, 0xea, 0, 0}, {0x3035, 0xae, 0, 0}, {0x3036, 0xa6, 0, 0},
  457.         {0x3037, 0x6a, 0, 0}, {0x3104, 0x02, 0, 0}, {0x3105, 0xfd, 0, 0},
  458.         {0x3106, 0x00, 0, 0}, {0x3107, 0xff, 0, 0}, {0x3300, 0x12, 0, 0},
  459.         {0x3301, 0xde, 0, 0}, {0x3302, 0xcf, 0, 0}, {0x3312, 0x26, 0, 0},
  460.         {0x3314, 0x42, 0, 0}, {0x3313, 0x2b, 0, 0}, {0x3315, 0x42, 0, 0},
  461.         {0x3310, 0xd0, 0, 0}, {0x3311, 0xbd, 0, 0}, {0x330c, 0x18, 0, 0},
  462.         {0x330d, 0x18, 0, 0}, {0x330e, 0x56, 0, 0}, {0x330f, 0x5c, 0, 0},
  463.         {0x330b, 0x1c, 0, 0}, {0x3306, 0x5c, 0, 0}, {0x3307, 0x11, 0, 0},
  464.         {0x336a, 0x52, 0, 0}, {0x3370, 0x46, 0, 0}, {0x3376, 0x38, 0, 0},
  465.         {0x3300, 0x13, 0, 0}, {0x30b8, 0x20, 0, 0}, {0x30b9, 0x17, 0, 0},
  466.         {0x30ba, 0x04, 0, 0}, {0x30bb, 0x08, 0, 0}, {0x3100, 0x02, 0, 0},
  467.         {0x3301, 0xde, 0, 0}, {0x3304, 0xfc, 0, 0}, {0x3400, 0x02, 0, 0},
  468.         {0x3404, 0x00, 0, 0}, {0x3088, 0x08, 0, 0}, {0x3089, 0x00, 0, 0},
  469.         {0x308a, 0x06, 0, 0}, {0x308b, 0x00, 0, 0}, {0x308d, 0x04, 0, 0},
  470.         {0x3086, 0x03, 0, 0}, {0x3086, 0x00, 0, 0}, {0x3020, 0x01, 0, 0},
  471.         {0x3021, 0x1d, 0, 0}, {0x3022, 0x00, 0, 0}, {0x3023, 0x0a, 0, 0},
  472.         {0x3024, 0x08, 0, 0}, {0x3025, 0x18, 0, 0}, {0x3026, 0x06, 0, 0},
  473.         {0x3027, 0x0c, 0, 0}, {0x302a, 0x06, 0, 0}, {0x302b, 0x20, 0, 0},
  474.         {0x3075, 0x44, 0, 0}, {0x300d, 0x00, 0, 0}, {0x30d7, 0x10, 0, 0},
  475.         {0x3069, 0x44, 0, 0}, {0x303e, 0x01, 0, 0}, {0x303f, 0x80, 0, 0},
  476.         {0x3302, 0xef, 0, 0}, {0x335f, 0x68, 0, 0}, {0x3360, 0x18, 0, 0},
  477.         {0x3361, 0x0c, 0, 0}, {0x3362, 0x68, 0, 0}, {0x3363, 0x08, 0, 0},
  478.         {0x3364, 0x04, 0, 0}, {0x3403, 0x42, 0, 0}, {0x304c, 0x81, 0, 0},
  479.         {0x3011, 0x01, 0, 0}, {0x3301, 0xde, 0, 0}, {0x3304, 0x00, 0, 0},
  480.         {0x3400, 0x00, 0, 0}, {0x3404, 0x42, 0, 0}, {0x3600, 0xc4, 0, 0},
  481.         {0x3362, 0x25, 0, 0}, {0x3363, 0x08, 0, 0}, {0x3364, 0xd4, 0, 0},
  482.         {0x3403, 0x42, 0, 0}, {0x3088, 0x05, 0, 0}, {0x3089, 0x00, 0, 0},
  483.         {0x308a, 0x02, 0, 0}, {0x308b, 0xd0, 0, 0},
  484. };
  485. static struct reg_value ov3640_setting_15fps_1080P_1920_1080[] = {
  486.         {0x3012, 0x80, 0, 0}, {0x304d, 0x45, 0, 0}, {0x30a7, 0x5e, 0, 0},
  487.         {0x3087, 0x16, 0, 0}, {0x309C, 0x1a, 0, 0}, {0x30a2, 0xe4, 0, 0},
  488.         {0x30aa, 0x42, 0, 0}, {0x30b0, 0xff, 0, 0}, {0x30b1, 0xff, 0, 0},
  489.         {0x30b2, 0x10, 0, 0}, {0x300e, 0x32, 0, 0}, {0x300f, 0x21, 0, 0},
  490.         {0x3010, 0x20, 0, 0}, {0x3011, 0x01, 0, 0}, {0x304c, 0x82, 0, 0},
  491.         {0x30d7, 0x10, 0, 0}, {0x30d9, 0x0d, 0, 0}, {0x30db, 0x08, 0, 0},
  492.         {0x3016, 0x82, 0, 0}, {0x3018, 0x38, 0, 0}, {0x3019, 0x30, 0, 0},
  493.         {0x301a, 0x61, 0, 0}, {0x307d, 0x00, 0, 0}, {0x3087, 0x02, 0, 0},
  494.         {0x3082, 0x20, 0, 0}, {0x3015, 0x12, 0, 0}, {0x3014, 0x0c, 0, 0},
  495.         {0x3013, 0xf7, 0, 0}, {0x303c, 0x08, 0, 0}, {0x303d, 0x18, 0, 0},
  496.         {0x303e, 0x06, 0, 0}, {0x303F, 0x0c, 0, 0}, {0x3030, 0x62, 0, 0},
  497.         {0x3031, 0x26, 0, 0}, {0x3032, 0xe6, 0, 0}, {0x3033, 0x6e, 0, 0},
  498.         {0x3034, 0xea, 0, 0}, {0x3035, 0xae, 0, 0}, {0x3036, 0xa6, 0, 0},
  499.         {0x3037, 0x6a, 0, 0}, {0x3104, 0x02, 0, 0}, {0x3105, 0xfd, 0, 0},
  500.         {0x3106, 0x00, 0, 0}, {0x3107, 0xff, 0, 0}, {0x3300, 0x12, 0, 0},
  501.         {0x3301, 0xde, 0, 0}, {0x3302, 0xcf, 0, 0}, {0x3312, 0x26, 0, 0},
  502.         {0x3314, 0x42, 0, 0}, {0x3313, 0x2b, 0, 0}, {0x3315, 0x42, 0, 0},
  503.         {0x3310, 0xd0, 0, 0}, {0x3311, 0xbd, 0, 0}, {0x330c, 0x18, 0, 0},
  504.         {0x330d, 0x18, 0, 0}, {0x330e, 0x56, 0, 0}, {0x330f, 0x5c, 0, 0},
  505.         {0x330b, 0x1c, 0, 0}, {0x3306, 0x5c, 0, 0}, {0x3307, 0x11, 0, 0},
  506.         {0x336a, 0x52, 0, 0}, {0x3370, 0x46, 0, 0}, {0x3376, 0x38, 0, 0},
  507.         {0x3300, 0x13, 0, 0}, {0x30b8, 0x20, 0, 0}, {0x30b9, 0x17, 0, 0},
  508.         {0x30ba, 0x04, 0, 0}, {0x30bb, 0x08, 0, 0}, {0x3100, 0x02, 0, 0},
  509.         {0x3301, 0xde, 0, 0}, {0x3304, 0xfc, 0, 0}, {0x3400, 0x02, 0, 0},
  510.         {0x3404, 0x00, 0, 0}, {0x3088, 0x08, 0, 0}, {0x3089, 0x00, 0, 0},
  511.         {0x308a, 0x06, 0, 0}, {0x308b, 0x00, 0, 0}, {0x308d, 0x04, 0, 0},
  512.         {0x3086, 0x03, 0, 0}, {0x3086, 0x00, 0, 0}, {0x3020, 0x01, 0, 0},
  513.         {0x3021, 0x1d, 0, 0}, {0x3022, 0x00, 0, 0}, {0x3023, 0x0a, 0, 0},
  514.         {0x3024, 0x08, 0, 0}, {0x3025, 0x18, 0, 0}, {0x3026, 0x06, 0, 0},
  515.         {0x3027, 0x0c, 0, 0}, {0x302a, 0x06, 0, 0}, {0x302b, 0x20, 0, 0},
  516.         {0x3075, 0x44, 0, 0}, {0x300d, 0x00, 0, 0}, {0x30d7, 0x10, 0, 0},
  517.         {0x3069, 0x44, 0, 0}, {0x303e, 0x01, 0, 0}, {0x303f, 0x80, 0, 0},
  518.         {0x3302, 0xef, 0, 0}, {0x335f, 0x68, 0, 0}, {0x3360, 0x18, 0, 0},
  519.         {0x3361, 0x0c, 0, 0}, {0x3362, 0x68, 0, 0}, {0x3363, 0x08, 0, 0},
  520.         {0x3364, 0x04, 0, 0}, {0x3403, 0x42, 0, 0}, {0x304c, 0x81, 0, 0},
  521.         {0x3011, 0x01, 0, 0}, {0x3301, 0xde, 0, 0}, {0x3304, 0x00, 0, 0},
  522.         {0x3400, 0x00, 0, 0}, {0x3404, 0x42, 0, 0}, {0x3600, 0xc4, 0, 0},
  523.         {0x3362, 0x47, 0, 0}, {0x3363, 0x88, 0, 0}, {0x3364, 0x3c, 0, 0},
  524.         {0x3403, 0x42, 0, 0}, {0x3088, 0x07, 0, 0}, {0x3089, 0x80, 0, 0},
  525.         {0x308a, 0x04, 0, 0}, {0x308b, 0x38, 0, 0},
  526. };
  527. static struct reg_value ov3640_setting_15fps_QXGA_2048_1536[] = {
  528. #if 0
  529.         /* The true 15fps QXGA setting. */
  530.         {0x3012, 0x80, 0, 0}, {0x304d, 0x41, 0, 0}, {0x3087, 0x16, 0, 0},
  531.         {0x30aa, 0x45, 0, 0}, {0x30b0, 0xff, 0, 0}, {0x30b1, 0xff, 0, 0},
  532.         {0x30b2, 0x13, 0, 0}, {0x30d7, 0x10, 0, 0}, {0x309e, 0x00, 0, 0},
  533.         {0x3602, 0x26, 0, 0}, {0x3603, 0x4D, 0, 0}, {0x364c, 0x04, 0, 0},
  534.         {0x360c, 0x12, 0, 0}, {0x361e, 0x00, 0, 0}, {0x361f, 0x11, 0, 0},
  535.         {0x3633, 0x03, 0, 0}, {0x3629, 0x3c, 0, 0}, {0x300e, 0x33, 0, 0},
  536.         {0x300f, 0x21, 0, 0}, {0x3010, 0x20, 0, 0}, {0x3011, 0x00, 0, 0},
  537.         {0x304c, 0x81, 0, 0}, {0x3029, 0x47, 0, 0}, {0x3070, 0x00, 0, 0},
  538.         {0x3071, 0xEC, 0, 0}, {0x301C, 0x06, 0, 0}, {0x3072, 0x00, 0, 0},
  539.         {0x3073, 0xC5, 0, 0}, {0x301D, 0x07, 0, 0}, {0x3018, 0x38, 0, 0},
  540.         {0x3019, 0x30, 0, 0}, {0x301a, 0x61, 0, 0}, {0x307d, 0x00, 0, 0},
  541.         {0x3087, 0x02, 0, 0}, {0x3082, 0x20, 0, 0}, {0x303c, 0x08, 0, 0},
  542.         {0x303d, 0x18, 0, 0}, {0x303e, 0x06, 0, 0}, {0x303F, 0x0c, 0, 0},
  543.         {0x3030, 0x62, 0, 0}, {0x3031, 0x26, 0, 0}, {0x3032, 0xe6, 0, 0},
  544.         {0x3033, 0x6e, 0, 0}, {0x3034, 0xea, 0, 0}, {0x3035, 0xae, 0, 0},
  545.         {0x3036, 0xa6, 0, 0}, {0x3037, 0x6a, 0, 0}, {0x3015, 0x12, 0, 0},
  546.         {0x3014, 0x04, 0, 0}, {0x3013, 0xf7, 0, 0}, {0x3104, 0x02, 0, 0},
  547.         {0x3105, 0xfd, 0, 0}, {0x3106, 0x00, 0, 0}, {0x3107, 0xff, 0, 0},
  548.         {0x3308, 0xa5, 0, 0}, {0x3316, 0xff, 0, 0}, {0x3317, 0x00, 0, 0},
  549.         {0x3087, 0x02, 0, 0}, {0x3082, 0x20, 0, 0}, {0x3300, 0x13, 0, 0},
  550.         {0x3301, 0xd6, 0, 0}, {0x3302, 0xef, 0, 0}, {0x30b8, 0x20, 0, 0},
  551.         {0x30b9, 0x17, 0, 0}, {0x30ba, 0x04, 0, 0}, {0x30bb, 0x08, 0, 0},
  552.         {0x3100, 0x02, 0, 0}, {0x3304, 0x00, 0, 0}, {0x3400, 0x00, 0, 0},
  553.         {0x3404, 0x02, 0, 0}, {0x3020, 0x01, 0, 0}, {0x3021, 0x1d, 0, 0},
  554.         {0x3022, 0x00, 0, 0}, {0x3023, 0x0a, 0, 0}, {0x3024, 0x08, 0, 0},
  555.         {0x3025, 0x18, 0, 0}, {0x3026, 0x06, 0, 0}, {0x3027, 0x0c, 0, 0},
  556.         {0x335f, 0x68, 0, 0}, {0x3360, 0x18, 0, 0}, {0x3361, 0x0c, 0, 0},
  557.         {0x3362, 0x68, 0, 0}, {0x3363, 0x08, 0, 0}, {0x3364, 0x04, 0, 0},
  558.         {0x3403, 0x42, 0, 0}, {0x3088, 0x08, 0, 0}, {0x3089, 0x00, 0, 0},
  559.         {0x308a, 0x06, 0, 0}, {0x308b, 0x00, 0, 0}, {0x3507, 0x06, 0, 0},
  560.         {0x350a, 0x4f, 0, 0}, {0x3600, 0xc4, 0, 0},
  561. #else
  562.         /*
  563.          * Only support 7.5fps for QXGA to workaround screen tearing issue
  564.          * for 15fps when capturing still image.
  565.          */
  566.         {0x3012, 0x80, 0, 0}, {0x304d, 0x45, 0, 0}, {0x30a7, 0x5e, 0, 0},
  567.         {0x3087, 0x16, 0, 0}, {0x309c, 0x1a, 0, 0}, {0x30a2, 0xe4, 0, 0},
  568.         {0x30aa, 0x42, 0, 0}, {0x30b0, 0xff, 0, 0}, {0x30b1, 0xff, 0, 0},
  569.         {0x30b2, 0x10, 0, 0}, {0x300e, 0x32, 0, 0}, {0x300f, 0x21, 0, 0},
  570.         {0x3010, 0x20, 0, 0}, {0x3011, 0x00, 0, 0}, {0x304c, 0x81, 0, 0},
  571.         {0x30d7, 0x10, 0, 0}, {0x30d9, 0x0d, 0, 0}, {0x30db, 0x08, 0, 0},
  572.         {0x3016, 0x82, 0, 0}, {0x3018, 0x38, 0, 0}, {0x3019, 0x30, 0, 0},
  573.         {0x301a, 0x61, 0, 0}, {0x307d, 0x00, 0, 0}, {0x3087, 0x02, 0, 0},
  574.         {0x3082, 0x20, 0, 0}, {0x3015, 0x12, 0, 0}, {0x3014, 0x04, 0, 0},
  575.         {0x3013, 0xf7, 0, 0}, {0x303c, 0x08, 0, 0}, {0x303d, 0x18, 0, 0},
  576.         {0x303e, 0x06, 0, 0}, {0x303f, 0x0c, 0, 0}, {0x3030, 0x62, 0, 0},
  577.         {0x3031, 0x26, 0, 0}, {0x3032, 0xe6, 0, 0}, {0x3033, 0x6e, 0, 0},
  578.         {0x3034, 0xea, 0, 0}, {0x3035, 0xae, 0, 0}, {0x3036, 0xa6, 0, 0},
  579.         {0x3037, 0x6a, 0, 0}, {0x3104, 0x02, 0, 0}, {0x3105, 0xfd, 0, 0},
  580.         {0x3106, 0x00, 0, 0}, {0x3107, 0xff, 0, 0}, {0x3300, 0x12, 0, 0},
  581.         {0x3301, 0xde, 0, 0}, {0x3302, 0xcf, 0, 0}, {0x3312, 0x26, 0, 0},
  582.         {0x3314, 0x42, 0, 0}, {0x3313, 0x2b, 0, 0}, {0x3315, 0x42, 0, 0},
  583.         {0x3310, 0xd0, 0, 0}, {0x3311, 0xbd, 0, 0}, {0x330c, 0x18, 0, 0},
  584.         {0x330d, 0x18, 0, 0}, {0x330e, 0x56, 0, 0}, {0x330f, 0x5c, 0, 0},
  585.         {0x330b, 0x1c, 0, 0}, {0x3306, 0x5c, 0, 0}, {0x3307, 0x11, 0, 0},
  586.         {0x336a, 0x52, 0, 0}, {0x3370, 0x46, 0, 0}, {0x3376, 0x38, 0, 0},
  587.         {0x30b8, 0x20, 0, 0}, {0x30b9, 0x17, 0, 0}, {0x30ba, 0x04, 0, 0},
  588.         {0x30bb, 0x08, 0, 0}, {0x3507, 0x06, 0, 0}, {0x350a, 0x4f, 0, 0},
  589.         {0x3100, 0x02, 0, 0}, {0x3301, 0xde, 0, 0}, {0x3304, 0x00, 0, 0},
  590.         {0x3400, 0x00, 0, 0}, {0x3404, 0x02, 0, 0}, {0x3600, 0xc4, 0, 0},
  591.         {0x3088, 0x08, 0, 0}, {0x3089, 0x00, 0, 0}, {0x308a, 0x06, 0, 0},
  592.         {0x308b, 0x00, 0, 0}, {0x308d, 0x04, 0, 0}, {0x3086, 0x03, 0, 0},
  593.         {0x3086, 0x00, 0, 0}, {0x3011, 0x01, 0, 0},
  594. #endif
  595. };
  596. static struct reg_value ov3640_setting_15fps_XGA_1024_768[] = {
  597.         {0x3012, 0x80, 0, 5}, {0x304d, 0x45, 0, 0}, {0x30a7, 0x5e, 0, 0},
  598.         {0x3087, 0x16, 0, 0}, {0x309c, 0x1a, 0, 0}, {0x30a2, 0xe4, 0, 0},
  599.         {0x30aa, 0x42, 0, 0}, {0x30b0, 0xff, 0, 0}, {0x30b1, 0xff, 0, 0},
  600.         {0x30b2, 0x10, 0, 0}, {0x300e, 0x32, 0, 0}, {0x300f, 0x21, 0, 0},
  601.         {0x3010, 0x20, 0, 0}, {0x3011, 0x00, 0, 0}, {0x304c, 0x81, 0, 0},
  602.         {0x30d7, 0x10, 0, 0}, {0x30d9, 0x0d, 0, 0}, {0x30db, 0x08, 0, 0},
  603.         {0x3016, 0x82, 0, 0}, {0x3018, 0x38, 0, 0}, {0x3019, 0x30, 0, 0},
  604.         {0x301a, 0x61, 0, 0}, {0x307d, 0x00, 0, 0}, {0x3087, 0x02, 0, 0},
  605.         {0x3082, 0x20, 0, 0}, {0x3015, 0x12, 0, 0}, {0x3014, 0x04, 0, 0},
  606.         {0x3013, 0xf7, 0, 0}, {0x303c, 0x08, 0, 0}, {0x303d, 0x18, 0, 0},
  607.         {0x303e, 0x06, 0, 0}, {0x303f, 0x0c, 0, 0}, {0x3030, 0x62, 0, 0},
  608.         {0x3031, 0x26, 0, 0}, {0x3032, 0xe6, 0, 0}, {0x3033, 0x6e, 0, 0},
  609.         {0x3034, 0xea, 0, 0}, {0x3035, 0xae, 0, 0}, {0x3036, 0xa6, 0, 0},
  610.         {0x3037, 0x6a, 0, 0}, {0x3104, 0x02, 0, 0}, {0x3105, 0xfd, 0, 0},
  611.         {0x3106, 0x00, 0, 0}, {0x3107, 0xff, 0, 0}, {0x3300, 0x12, 0, 0},
  612.         {0x3301, 0xde, 0, 0}, {0x3302, 0xcf, 0, 0}, {0x3312, 0x26, 0, 0},
  613.         {0x3314, 0x42, 0, 0}, {0x3313, 0x2b, 0, 0}, {0x3315, 0x42, 0, 0},
  614.         {0x3310, 0xd0, 0, 0}, {0x3311, 0xbd, 0, 0}, {0x330c, 0x18, 0, 0},
  615.         {0x330d, 0x18, 0, 0}, {0x330e, 0x56, 0, 0}, {0x330f, 0x5c, 0, 0},
  616.         {0x330b, 0x1c, 0, 0}, {0x3306, 0x5c, 0, 0}, {0x3307, 0x11, 0, 0},
  617.         {0x336a, 0x52, 0, 0}, {0x3370, 0x46, 0, 0}, {0x3376, 0x38, 0, 0},
  618.         {0x30b8, 0x20, 0, 0}, {0x30b9, 0x17, 0, 0}, {0x30ba, 0x04, 0, 0},
  619.         {0x30bb, 0x08, 0, 0}, {0x3507, 0x06, 0, 0}, {0x350a, 0x4f, 0, 0},
  620.         {0x3100, 0x02, 0, 0}, {0x3301, 0xde, 0, 0}, {0x3304, 0x00, 0, 0},
  621.         {0x3400, 0x01, 0, 0}, {0x3404, 0x1d, 0, 0}, {0x3600, 0xc4, 0, 0},
  622.         {0x3302, 0xef, 0, 0}, {0x3020, 0x01, 0, 0}, {0x3021, 0x1d, 0, 0},
  623.         {0x3022, 0x00, 0, 0}, {0x3023, 0x0a, 0, 0}, {0x3024, 0x08, 0, 0},
  624.         {0x3025, 0x18, 0, 0}, {0x3026, 0x06, 0, 0}, {0x3027, 0x0c, 0, 0},
  625.         {0x335f, 0x68, 0, 0}, {0x3360, 0x18, 0, 0}, {0x3361, 0x0c, 0, 0},
  626.         {0x3362, 0x68, 0, 0}, {0x3363, 0x08, 0, 0}, {0x3364, 0x04, 0, 0},
  627.         {0x3403, 0x42, 0, 0}, {0x3088, 0x08, 0, 0}, {0x3089, 0x00, 0, 0},
  628.         {0x308a, 0x06, 0, 0}, {0x308b, 0x00, 0, 0}, {0x307c, 0x10, 0, 0},
  629.         {0x3090, 0xc0, 0, 0}, {0x304c, 0x84, 0, 0}, {0x308d, 0x04, 0, 0},
  630.         {0x3086, 0x03, 0, 0}, {0x3086, 0x00, 0, 0}, {0x3301, 0xde, 0, 0},
  631.         {0x3304, 0x00, 0, 0}, {0x3400, 0x00, 0, 0}, {0x3404, 0x42, 0, 0},
  632.         {0x3600, 0xc4, 0, 0}, {0x3362, 0x34, 0, 0}, {0x3363, 0x08, 0, 0},
  633.         {0x3364, 0x04, 0, 0}, {0x3403, 0x42, 0, 0}, {0x3088, 0x04, 0, 0},
  634.         {0x3089, 0x00, 0, 0}, {0x308a, 0x03, 0, 0}, {0x308b, 0x00, 0, 0},
  635. };
  636. static struct reg_value ov3640_setting_30fps_XGA_1024_768[] = {
  637.         {0x3012, 0x80, 0, 5}, {0x304d, 0x45, 0, 0}, {0x30a7, 0x5e, 0, 0},
  638.         {0x3087, 0x16, 0, 0}, {0x309c, 0x1a, 0, 0}, {0x30a2, 0xe4, 0, 0},
  639.         {0x30aa, 0x42, 0, 0}, {0x30b0, 0xff, 0, 0}, {0x30b1, 0xff, 0, 0},
  640.         {0x30b2, 0x08, 0, 0}, {0x300e, 0x32, 0, 0}, {0x300f, 0x21, 0, 0},
  641.         {0x3010, 0x20, 0, 0}, {0x3011, 0x04, 0, 0}, {0x304c, 0x81, 0, 0},
  642.         {0x30d7, 0x10, 0, 0}, {0x30d9, 0x0d, 0, 0}, {0x30db, 0x08, 0, 0},
  643.         {0x3016, 0x82, 0, 0}, {0x3018, 0x38, 0, 0}, {0x3019, 0x30, 0, 0},
  644.         {0x301a, 0x61, 0, 0}, {0x307d, 0x00, 0, 0}, {0x3087, 0x02, 0, 0},
  645.         {0x3082, 0x20, 0, 0}, {0x3015, 0x12, 0, 0}, {0x3014, 0x84, 0, 0},
  646.         {0x3013, 0xf7, 0, 0}, {0x303c, 0x08, 0, 0}, {0x303d, 0x18, 0, 0},
  647.         {0x303e, 0x06, 0, 0}, {0x303f, 0x0c, 0, 0}, {0x3030, 0x62, 0, 0},
  648.         {0x3031, 0x26, 0, 0}, {0x3032, 0xe6, 0, 0}, {0x3033, 0x6e, 0, 0},
  649.         {0x3034, 0xea, 0, 0}, {0x3035, 0xae, 0, 0}, {0x3036, 0xa6, 0, 0},
  650.         {0x3037, 0x6a, 0, 0}, {0x3104, 0x02, 0, 0}, {0x3105, 0xfd, 0, 0},
  651.         {0x3106, 0x00, 0, 0}, {0x3107, 0xff, 0, 0}, {0x3300, 0x12, 0, 0},
  652.         {0x3301, 0xde, 0, 0}, {0x3302, 0xef, 0, 0}, {0x3316, 0xff, 0, 0},
  653.         {0x3317, 0x00, 0, 0}, {0x3312, 0x26, 0, 0}, {0x3314, 0x42, 0, 0},
  654.         {0x3313, 0x2b, 0, 0}, {0x3315, 0x42, 0, 0}, {0x3310, 0xd0, 0, 0},
  655.         {0x3311, 0xbd, 0, 0}, {0x330c, 0x18, 0, 0}, {0x330d, 0x18, 0, 0},
  656.         {0x330e, 0x56, 0, 0}, {0x330f, 0x5c, 0, 0}, {0x330b, 0x1c, 0, 0},
  657.         {0x3306, 0x5c, 0, 0}, {0x3307, 0x11, 0, 0}, {0x336a, 0x52, 0, 0},
  658.         {0x3370, 0x46, 0, 0}, {0x3376, 0x38, 0, 0}, {0x3300, 0x13, 0, 0},
  659.         {0x30b8, 0x20, 0, 0}, {0x30b9, 0x17, 0, 0}, {0x30ba, 0x04, 0, 0},
  660.         {0x30bb, 0x08, 0, 0}, {0x3507, 0x06, 0, 0}, {0x350a, 0x4f, 0, 0},
  661.         {0x3100, 0x02, 0, 0}, {0x3301, 0xde, 0, 0}, {0x3304, 0x00, 0, 0},
  662.         {0x3400, 0x00, 0, 0}, {0x3404, 0x00, 0, 0}, {0x335f, 0x68, 0, 0},
  663.         {0x3360, 0x18, 0, 0}, {0x3361, 0x0c, 0, 0}, {0x3362, 0x12, 0, 0},
  664.         {0x3363, 0x88, 0, 0}, {0x3364, 0xe4, 0, 0}, {0x3403, 0x42, 0, 0},
  665.         {0x3088, 0x02, 0, 0}, {0x3089, 0x80, 0, 0}, {0x308a, 0x01, 0, 0},
  666.         {0x308b, 0xe0, 0, 0}, {0x308d, 0x04, 0, 0}, {0x3086, 0x03, 0, 0},
  667.         {0x3086, 0x00, 0, 0}, {0x3011, 0x00, 0, 0}, {0x304c, 0x84, 0, 0},
  668.         {0x332a, 0x1d, 0, 0}, {0x331b, 0x08, 0, 0}, {0x331c, 0x16, 0, 0},
  669.         {0x331d, 0x2d, 0, 0}, {0x331e, 0x54, 0, 0}, {0x331f, 0x66, 0, 0},
  670.         {0x3320, 0x73, 0, 0}, {0x3321, 0x80, 0, 0}, {0x3322, 0x8c, 0, 0},
  671.         {0x3323, 0x95, 0, 0}, {0x3324, 0x9d, 0, 0}, {0x3325, 0xac, 0, 0},
  672.         {0x3326, 0xb8, 0, 0}, {0x3327, 0xcc, 0, 0}, {0x3328, 0xdd, 0, 0},
  673.         {0x3329, 0xee, 0, 0}, {0x3340, 0x20, 0, 0}, {0x3341, 0x58, 0, 0},
  674.         {0x3342, 0x08, 0, 0}, {0x3343, 0x23, 0, 0}, {0x3344, 0xad, 0, 0},
  675.         {0x3345, 0xd0, 0, 0}, {0x3346, 0xb8, 0, 0}, {0x3347, 0xb4, 0, 0},
  676.         {0x3348, 0x04, 0, 0}, {0x3349, 0x98, 0, 0}, {0x333F, 0x06, 0, 0},
  677.         {0x3012, 0x10, 0, 0}, {0x3023, 0x06, 0, 0}, {0x3026, 0x03, 0, 0},
  678.         {0x3027, 0x04, 0, 0}, {0x302a, 0x03, 0, 0}, {0x302b, 0x10, 0, 0},
  679.         {0x3075, 0x24, 0, 0}, {0x300d, 0x01, 0, 0}, {0x30d7, 0x90, 0, 0},
  680.         {0x3069, 0x04, 0, 0}, {0x303e, 0x00, 0, 0}, {0x303f, 0xc0, 0, 0},
  681.         {0x3302, 0xef, 0, 0}, {0x335f, 0x34, 0, 0}, {0x3360, 0x0c, 0, 0},
  682.         {0x3361, 0x04, 0, 0}, {0x3362, 0x34, 0, 0}, {0x3363, 0x08, 0, 0},
  683.         {0x3364, 0x04, 0, 0}, {0x3403, 0x42, 0, 0}, {0x3088, 0x04, 0, 0},
  684.         {0x3089, 0x00, 0, 0}, {0x308a, 0x03, 0, 0}, {0x308b, 0x00, 0, 0},
  685.         {0x3100, 0x02, 0, 0}, {0x3301, 0xde, 0, 0}, {0x3304, 0x00, 0, 0},
  686.         {0x3400, 0x00, 0, 0}, {0x3404, 0x42, 0, 0}, {0x304c, 0x82, 0, 0},
  687.         {0x3011, 0x00, 0, 0}, {0x302a, 0x03, 0, 0}, {0x302b, 0x10, 0, 0},
  688.         {0x3070, 0x00, 0, 0}, {0x3071, 0xec, 0, 0}, {0x3072, 0x00, 0, 0},
  689.         {0x3073, 0xc4, 0, 0}, {0x301c, 0x02, 0, 0}, {0x301d, 0x03, 0, 0},
  690. };
上面是我用的参数配置
 楼主| 发表于 2015-8-25 15:00:55 | 显示全部楼层
现在预览是可以了,原因是初始化的时候把fixelformat弄错了,应该是UYVY的格式。但是现在拍照和录像还是有点问题。
 楼主| 发表于 2015-8-25 15:04:24 | 显示全部楼层
现在拍照拍出来的是黑色的图片,而一转到录像功能程序就崩溃了。
 楼主| 发表于 2015-8-27 17:55:44 | 显示全部楼层
自己顶一下。
发表于 2015-8-28 11:25:05 | 显示全部楼层
帮顶
发表于 2015-9-2 16:14:53 | 显示全部楼层
GMT+8, 2025-10-27 19:27 , Processed in 0.147128 second(s), 29 queries , MemCache On.
