查看: 2297|回复: 3
[其他] ltib安装gcc失败
发表于 2015-8-29 21:16:50 | 显示全部楼层 |阅读模式
大家好,最近小弟在试图在mx6q的板子上安装gcc,文件系统是用ltib编译的fsl-gnome,第一步./ltib -m prep -p gcc通过,第二部./ltib -m scbuild -p gcc出错,错误信息如下:
In file included from /home/yxq/ltib/rpm/BUILD/gcc-4.2.1/libstdc++-v3/libsupc++/eh_alloc.cc:37:0:
/home/yxq/ltib/rpm/BUILD/gcc-4.2.1/build-gcc/arm-none-linux-gnueabi/libstdc++-v3/include/cstring: In function 'void* std::memchr(void*, int, size_t)':
/home/yxq/ltib/rpm/BUILD/gcc-4.2.1/build-gcc/arm-none-linux-gnueabi/libstdc++-v3/include/cstring:101:40: error: 'void* std::memchr(void*, int, size_t)' conflicts with previous using declaration 'void* memchr(void*, int, size_t)'
/home/yxq/ltib/rpm/BUILD/gcc-4.2.1/build-gcc/arm-none-linux-gnueabi/libstdc++-v3/include/cstring:102:57: error: invalid conversion from 'const void*' to 'void*' [-fpermissive]
/home/yxq/ltib/rpm/BUILD/gcc-4.2.1/build-gcc/arm-none-linux-gnueabi/libstdc++-v3/include/cstring: In function 'char* std::strchr(char*, int)':
/home/yxq/ltib/rpm/BUILD/gcc-4.2.1/build-gcc/arm-none-linux-gnueabi/libstdc++-v3/include/cstring:107:29: error: 'char* std::strchr(char*, int)' conflicts with previous using declaration 'char* strchr(char*, int)'
/home/yxq/ltib/rpm/BUILD/gcc-4.2.1/build-gcc/arm-none-linux-gnueabi/libstdc++-v3/include/cstring: In function 'char* std::strpbrk(char*, const char*)':
/home/yxq/ltib/rpm/BUILD/gcc-4.2.1/build-gcc/arm-none-linux-gnueabi/libstdc++-v3/include/cstring:113:39: error: 'char* std::strpbrk(char*, const char*)' conflicts with previous using declaration 'char* strpbrk(char*, const char*)'
/home/yxq/ltib/rpm/BUILD/gcc-4.2.1/build-gcc/arm-none-linux-gnueabi/libstdc++-v3/include/cstring: In function 'char* std::strrchr(char*, int)':
/home/yxq/ltib/rpm/BUILD/gcc-4.2.1/build-gcc/arm-none-linux-gnueabi/libstdc++-v3/include/cstring:119:30: error: 'char* std::strrchr(char*, int)' conflicts with previous using declaration 'char* strrchr(char*, int)'
/home/yxq/ltib/rpm/BUILD/gcc-4.2.1/build-gcc/arm-none-linux-gnueabi/libstdc++-v3/include/cstring: In function 'char* std::strstr(char*, const char*)':
/home/yxq/ltib/rpm/BUILD/gcc-4.2.1/build-gcc/arm-none-linux-gnueabi/libstdc++-v3/include/cstring:125:38: error: 'char* std::strstr(char*, const char*)' conflicts with previous using declaration 'char* strstr(char*, const char*)'
make[4]: *** [eh_alloc.lo] Error 1
make[4]: Leaving directory `/home/yxq/ltib/rpm/BUILD/gcc-4.2.1/build-gcc/arm-none-linux-gnueabi/libstdc++-v3/libsupc++'
make[3]: *** [all-recursive] Error 1
make[3]: Leaving directory `/home/yxq/ltib/rpm/BUILD/gcc-4.2.1/build-gcc/arm-none-linux-gnueabi/libstdc++-v3'
make[2]: *** [all] Error 2
make[2]: Leaving directory `/home/yxq/ltib/rpm/BUILD/gcc-4.2.1/build-gcc/arm-none-linux-gnueabi/libstdc++-v3'
make[1]: *** [all-target-libstdc++-v3] Error 2
make[1]: Leaving directory `/home/yxq/ltib/rpm/BUILD/gcc-4.2.1/build-gcc'
make: *** [all] Error 2
error: Bad exit status from /home/yxq/ltib/tmp/rpm-tmp.39200 (%build)
请问能否帮忙分析一下,谢谢!
参与人数 1NXP金币 +3 收起 理由
小七 + 3
    发表于 2015-8-29 23:46:25 | 显示全部楼层
    回帖奖励 +1 NXP金币
    exit status from /home/yxq/ltib/tmp/rpm-tmp.39200 没有该路径
     楼主| 发表于 2015-8-30 16:13:47 | 显示全部楼层
    我看了,确实有这个路径,而且rpm-tmp.39200也存在,是不是却啥依赖库啊?或者在gcc.spec里面configure参数改一下?
    发表于 2015-8-30 20:10:27 | 显示全部楼层
    yxqlf 发表于 2015-8-30 16:13
    我看了,确实有这个路径,而且rpm-tmp.39200也存在,是不是却啥依赖库啊?或者在gcc.spec里面configure参 ...
    这个板子我也没用过,不知道怎么处理,请别人帮忙吧
    GMT+8, 2025-11-5 09:03 , Processed in 0.096909 second(s), 25 queries , MemCache On.
