查看: 3442|回复: 3
[分享] 使用K64 配置input capture ,没有输入波形不断进入中断
发表于 2015-9-8 16:50:19 | 显示全部楼层 |阅读模式
使用K64 配置input capture ,没有输入波形不断进入中断。是什么原因啊。
下函数加入了参数的实际赋值
FTM_DRV_SetupChnInputCapture(BOARD_FTM_INSTANCE1= 1,ftm_ic_mode=1,BOARD_FTM_CHANNEL0=0,0);
void FTM_DRV_SetupChnInputCapture(uint32_t instance, ftm_input_capture_edge_mode_t captureMode,
                                            uint8_t channel, uint8_t filterVal)
    assert(instance < HW_FTM_INSTANCE_COUNT);
    assert(channel < FSL_FEATURE_FTM_CHANNEL_COUNTn(instance));
                uint32_t ftmBaseAddr = g_ftmBaseAddr[instance];
    uint32_t chnlPairnum = FTM_HAL_GetChnPairIndex(channel);
    FTM_HAL_SetClockSource(ftmBaseAddr, kClock_source_FTM_None);
    FTM_HAL_SetCounterInitVal(ftmBaseAddr,0);
    FTM_HAL_SetMod(ftmBaseAddr, 0xFFFF);
    FTM_HAL_SetCpwms(ftmBaseAddr, 0);
    FTM_HAL_SetDualChnCombineCmd(ftmBaseAddr, chnlPairnum, false);
    FTM_HAL_SetDualEdgeCaptureCmd(ftmBaseAddr, chnlPairnum, false);
    FTM_HAL_SetChnEdgeLevel(ftmBaseAddr, channel, captureMode);
    if (channel < CHAN4_IDX)
        FTM_HAL_SetChnInputCaptureFilter(ftmBaseAddr, channel, filterVal);
    FTM_HAL_SetChnMSnBAMode(ftmBaseAddr, channel, 0);
                FTM_DRV_SetTimeOverflowIntCmd(instance, true);
    /* Set clock source to start the counter */
    FTM_HAL_SetClockSource(ftmBaseAddr, kClock_source_FTM_SystemClk);
中断函数加1
void FTM1_IRQHandler(void)
                int_number++;
    FTM_DRV_IRQHandler(1U);
打印值
int_number =496690
int_number =496863
int_number =497035
int_number =497208
int_number =497381
int_number =497554
int_number =497727
int_number =497900
int_number =498073
int_number =498246
int_number =498419
int_number =498592
int_number =498765
int_number =498938
int_number =499111
int_number =499284
int_number =499457
int_number =499630
int_number =499803
int_number =499976
int_number =500149
int_number =500322
int_number =500495
发表于 2015-9-9 09:33:53 | 显示全部楼层
建议你可以设置断点,查看一下引起中断的标志位是哪一个?
发表于 2015-9-9 12:58:40 | 显示全部楼层
配置好输入脚,估计有毛刺什么都会引起中断的。
 楼主| 发表于 2015-9-9 16:29:00 | 显示全部楼层
哪这么脆弱,有filter的,不开启时filter为3个个时钟
GMT+8, 2025-11-6 01:56 , Processed in 0.079499 second(s), 22 queries , MemCache On.
