查看: 1760|回复: 5
[其他] 每天解决一个问题25天2问 :使用word实现图片大小转换
    发表于 2015-9-18 22:51:55 | 显示全部楼层 |阅读模式
    之前给大家分享了excel实现正弦波数据,今天给大家分享一个word的小用法。
    一、问题提出:
    在学习OLED时,想显示个图片,但是原始图片的大小一般不符合要求,这就需要图片大小的裁剪、缩放等调整。但是电脑上又没有PS之类的专业图片编辑工具,怎么办?
    二、解决办法:
    估计每个人电脑上都会装word,使用word就可以很方便的实现转换。
    我们以社区的logo为例吧。
    把图片插入到word!但是显示的单位是厘米。
    而我们想要像素为单位,也可以的,在选项,高级中,勾选如图的设置。
    重新查看,发现显示像素了。
    调整成列128即可
    另存为html格式
    然后放到画图中另存为bmp文件
    最后生成的图片提取字模
    生成的字模为:
    1. <font size="3">const uint8_t logoBmp[] = {
    2. 0x00,0x00,0x00,0x00,0x00,0x00,0x80,0xC0,0xC0,0xC0,0xC0,0xC0,0xC0,0xC0,0xC0,0xC0,
    3. 0xC0,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x00,0x80,0xC0,0xC0,0x40,0x40,0x40,
    4. 0x40,0x40,0x40,0x40,0x40,0x40,0x40,0x40,0x40,0x40,0x40,0xC0,0xC0,0x80,0x00,0x00,
    5. 0x00,0x00,0xC0,0xE0,0x60,0x60,0xE0,0xC0,0x80,0x80,0x80,0x80,0x80,0x80,0x00,0x00,
    6. 0x00,0x80,0xC0,0xE0,0x60,0x60,0xE0,0xE0,0xC0,0x80,0x80,0x80,0x80,0x80,0x80,0x80,
    7. 0x80,0x00,0x00,0x00,0x00,0xC0,0xE0,0x60,0xE0,0xC0,0xC0,0x00,0x00,0x00,0x80,0xC0,
    8. 0xC0,0xC0,0xC0,0xC0,0x00,0x00,0x00,0x00,0x00,0x80,0xC0,0xC0,0xC0,0xC0,0xC0,0xC0,
    9. 0xC0,0xC0,0xC0,0xC0,0xC0,0xC0,0xC0,0xC0,0xC0,0xC0,0x80,0x80,0x00,0x00,0x00,0x00,
    10. 0x00,0x00,0x00,0x00,0x00,0x06,0x0F,0x8F,0xEC,0xFC,0x1C,0x04,0xC0,0xF0,0x7C,0x5F,
    11. 0x4F,0xC3,0xC1,0xF1,0x39,0x1D,0x0F,0x07,0x01,0xF8,0xFF,0x07,0x00,0x20,0x66,0x66,
    12. 0x66,0x26,0x00,0x00,0x60,0x66,0x66,0x66,0x06,0x00,0xE0,0xFE,0xFF,0x31,0x30,0x30,
    13. 0x30,0x3F,0x0F,0x01,0x00,0x30,0x39,0x39,0x39,0x39,0x39,0x39,0xB9,0xFF,0x7F,0x7E,
    14. 0xE7,0xE3,0x71,0x78,0xF8,0xF8,0x08,0x09,0x89,0xF9,0x79,0x79,0xF9,0xF9,0x61,0x71,
    15. 0x3F,0x3F,0x7E,0xE2,0xE3,0x63,0x03,0x00,0xC0,0xF3,0xFF,0xDE,0xC4,0xC6,0x87,0x03,
    16. 0x00,0xC0,0xC7,0xC7,0xE4,0x7C,0x18,0xE0,0xFF,0x0F,0x01,0x81,0xF9,0xF9,0xC9,0xC9,
    17. 0x89,0x19,0x39,0x39,0x89,0xC9,0xC9,0x69,0x39,0x19,0x0F,0x07,0x00,0x00,0x00,0x00,
    18. 0x00,0x00,0x00,0x00,0xC0,0xF8,0x3E,0x0F,0x03,0x20,0x3C,0x3F,0x37,0x37,0x3E,0x3C,
    19. 0x30,0x30,0x31,0x37,0xBF,0xFC,0xF0,0xF0,0x7E,0x0F,0x83,0xE2,0xFE,0x0A,0x02,0x32,
    20. 0x3E,0x3E,0x26,0x22,0x22,0x3E,0xBE,0xFE,0x03,0x83,0xFF,0xFF,0x03,0x03,0x83,0xFF,
    21. 0xFF,0x03,0x80,0xF4,0xFF,0x39,0x31,0x73,0xE7,0xCF,0xFF,0x33,0x01,0x01,0xF0,0x7F,
    22. 0x1F,0x00,0xE0,0xFE,0x7F,0x07,0x00,0xC0,0xFE,0x7F,0xFE,0xE0,0x01,0x0F,0xFF,0xF8,
    23. 0x0E,0x1F,0xFF,0xFD,0x1C,0x00,0x80,0xFE,0x7B,0x38,0x3E,0x3F,0x3F,0x07,0x00,0x00,
    24. 0x3F,0x3F,0x31,0x70,0xE0,0xE0,0xFE,0xFF,0x01,0x00,0x3C,0x3F,0x3F,0x2F,0x27,0x33,
    25. 0x39,0x3C,0x3C,0x38,0x31,0x23,0x27,0x2E,0x3C,0xF8,0xF0,0x00,0x00,0x00,0x00,0x00,
    26. 0x00,0x00,0x00,0x00,0x03,0x03,0x03,0x03,0x03,0x03,0x03,0x03,0x03,0x03,0x03,0x03,
    27. 0x03,0x03,0x03,0x03,0x03,0x01,0x03,0x03,0x03,0x03,0x03,0x01,0x03,0x03,0x02,0x02,
    28. 0x02,0x02,0x02,0x02,0x03,0x03,0x03,0x03,0x03,0x03,0x01,0x00,0x00,0x00,0x03,0x03,
    29. 0x07,0x03,0x03,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x03,0x03,
    30. 0x03,0x03,0x03,0x03,0x07,0x06,0x03,0x03,0x01,0x00,0x00,0x03,0x03,0x03,0x03,0x03,
    31. 0x00,0x00,0x03,0x03,0x02,0x03,0x03,0x07,0x06,0x06,0x06,0x06,0x06,0x06,0x06,0x06,
    32. 0x06,0x06,0x06,0x07,0x03,0x01,0x03,0x03,0x07,0x06,0x06,0x06,0x06,0x06,0x06,0x06,
    33. 0x06,0x06,0x06,0x06,0x06,0x06,0x06,0x06,0x07,0x03,0x00,0x00,0x00,0x00,0x00,0x00
    34. };</font>
    三、感想与收获:
    虽然这个方法略显麻烦些,但是不用安装专业图片工具,每个电脑上都能用,在一些情况下还是不错的选择
    我知道答案 目前已有5人回答
    发表于 2015-9-18 22:57:44 | 显示全部楼层
    温馨提示:一天两个帖子不算
     楼主| 发表于 2015-9-18 23:08:03 | 显示全部楼层
    suoma 发表于 2015-9-18 22:57
    温馨提示:一天两个帖子不算
  • 签到天数: 3 天
    发表于 2015-9-19 08:33:28 来自手机 | 显示全部楼层
    画图可以实现的为什么这么麻烦呢?
    发表于 2015-9-19 08:38:37 | 显示全部楼层
    学习了,谢谢分享
    发表于 2015-9-19 12:11:33 | 显示全部楼层
    这也算问题,这是另一种技巧吧
    GMT+8, 2025-11-5 09:49 , Processed in 0.111242 second(s), 27 queries , MemCache On.
