查看: 3529|回复: 1
[求助] 请教QT5向开发板移植的问题。
发表于 2015-9-20 15:16:35 | 显示全部楼层 |阅读模式
Hello!
我下载了Qt5.5.0的源码后,按照官网配置说明(http://doc.qt.io/qt-5/embedded-l ... r-a-specific-device)进行configure,提示了如下错误。
Could not determine the target architecture!
Turn on verbose messaging (-v) to see the final report.
The OpenGL ES 2.0 functionality test failed!
Use of pkg-config is not enabled, maybe you want to pass -force-pkg-config?
You might need to modify the include and library search paths by editing
QMAKE_INCDIR_OPENGL_ES2, QMAKE_LIBDIR_OPENGL_ES2 and QMAKE_LIBS_OPENGL_ES2 in
/home/tangbin/qt-5.5.0-arm/qt-everywhere-opensource-src-5.5.0/qtbase/mkspecs/devices/linux-imx6-g++.
在/linux-imx6-g++路径下的qmake.conf文件中,加入了OPENGL的头文件和库文件仍然提示一样的错误,请问有谁知道解决方法吗?
configure配置如下:
./configure -release -opengl es2 -device linux-imx6-g++ -device-option CROSS_COMPILE=/opt/freescale/usr/local/gcc-4.6.2-glibc-2.13-linaro-multilib-2011.12/fsl-linaro-toolchain/bin/arm-fsl-linux-gnueabi- -sysroot /usr/local/qt5.5.0-arm/rootfs -prefix /usr/local/qt5.5.0-arm
我知道答案 目前已有1人回答
发表于 2015-9-21 09:28:32 | 显示全部楼层
好像学这个
GMT+8, 2025-10-29 05:44 , Processed in 0.088712 second(s), 22 queries , MemCache On.
