查看: 2853|回复: 0
[求助] 自制的imx6板子Android启动不起来
发表于 2015-9-21 14:02:45 | 显示全部楼层 |阅读模式
请各位大侠帮忙看看打印信息,为什么Android启动不起来。
自制的imx6的板子,用的是imx6Q的CPU。板子是参照sabrelite和sabreSD设计的。原先的工程师已经用uboot2009、kernel3.0.35和Android4.0跑通了,现在要升级到Android5.0。现使用uboot、kernel、Android版本如下:
uboot用的是2014.04;Kernel用的是3.10.53;Android用的是L5.0
打印信息如下:
U-Boot 2014.04 (Sep 18 2015 - 08:20:26)
CPU:   Freescale i.MX6Q rev1.2 at 792 MHz
CPU:   Temperature 25 C, calibration data: 0x5764bf7d
Reset cause: POR
Board: ACM imx6q
I2C:   ready
DRAM:  1 GiB
MMC:   FSL_SDHC: 0, FSL_SDHC: 1
SF: Detected SST25VF016B with page size 256 Bytes, erase size 4 KiB, total 2 MiB
phy link never came up
DEBUG_R0: 0x00e2d000, DEBUG_R1: 0x08200000
No panel detected: default to HDMI
Display: HDMI (1024x768)
In:    serial
Out:   serial
Err:   serial
unsupported boot devices
check_and_clean: reg 0, flag_set 0
Fastboot: Normal
flash target is MMC:0
Net:   using phy at 7
FEC [PRIME]
Warning: failed to set MAC address
Normal Boot
booti mmc0
kernel   @ 14008000 (6819520)
ramdisk  @ 15000000 (726337)
fdt      @ 14f00000 (47210)
kernel cmdline:
        use boot.img command line:
        console=ttymxc1,115200 init=/init rw video=mxcfb1:dev=ldb,LDB-XGA,if=RGB24,bpp=24 video=mxcfb0:dev=hdmi,1920x1080M@60,if=RGB24,video=mxcfb2ff vmalloc=400M androidboot.console=ttymxc1 consoleblank=0 androidboot.hardware=freescale androidboot.bootdev=mmcblk2 cma=384M
   Using Device Tree in place at 14f00000, end 14f0e869
Starting kernel ...
Booting Linux on physical CPU 0x0
Initializing cgroup subsys cpu
Initializing cgroup subsys cpuacct
Linux version 3.10.53-88204-g4f0dd92-dirty (dj@ubuntu) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #1 SMP PREEMPT Mon Sep 21 13:24:15 CST 2015
CPU: ARMv7 Processor [412fc09a] revision 10 (ARMv7), cr=10c53c7d
CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
Machine: Freescale i.MX6 Quad/DualLite (Device Tree), model: Freescale i.MX6 Quad ACM Board
cma: CMA: reserved 384 MiB at 32000000
Memory policy: ECC disabled, Data cache writealloc
PERCPU: Embedded 8 pages/cpu @81801000 s9728 r8192 d14848 u32768
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 259840
Kernel command line: console=ttymxc1,115200 init=/init rw video=mxcfb1:dev=ldb,LDB-XGA,if=RGB24,bpp=24 video=mxcfb0:dev=hdmi,1920x1080M@60,if=RGB24,video=mxcfb2ff vmalloc=400M androidboot.console=ttymxc1 consoleblank=0 androidboot.hardware=freescale androidboot.bootdev=mmcblk2 cma=384M
PID hash table entries: 4096 (order: 2, 16384 bytes)
Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Memory: 959MB 64MB = 1023MB total
Memory: 627288k/627288k available, 421288k reserved, 0K highmem
Virtual kernel memory layout:
    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
    vmalloc : 0xc0800000 - 0xff000000   (1000 MB)
    lowmem  : 0x80000000 - 0xc0000000   (1024 MB)
    pkmap   : 0x7fe00000 - 0x80000000   (   2 MB)
    modules : 0x7f000000 - 0x7fe00000   (  14 MB)
      .text : 0x80008000 - 0x80e7a48c   (14794 kB)
      .init : 0x80e7b000 - 0x80ed0600   ( 342 kB)
      .data : 0x80ed2000 - 0x80f56000   ( 528 kB)
       .bss : 0x80f56000 - 0x80feacf8   ( 596 kB)
SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
Preemptible hierarchical RCU implementation.
NR_IRQS:16 nr_irqs:16 16
L310 cache controller enabled
l2x0: 16 ways, CACHE_ID 0x410000c7, AUX_CTRL 0x32070000, Cache size: 1048576 B
sched_clock: 32 bits at 3000kHz, resolution 333ns, wraps every 1431655ms
CPU identified as i.MX6Q, silicon rev 1.2
Console: colour dummy device 80x30
Calibrating delay loop... 1581.05 BogoMIPS (lpj=7905280)
pid_max: default: 32768 minimum: 301
Security Framework initialized
SELinux:  Initializing.
Mount-cache hash table entries: 512
Initializing cgroup subsys debug
Initializing cgroup subsys freezer
CPU: Testing write buffer coherency: ok
CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
Setting up static identity map for 0x807e23e8 - 0x807e2440
CPU1: Booted secondary processor
CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
CPU2: Booted secondary processor
CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
CPU3: Booted secondary processor
CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
Brought up 4 CPUs
SMP: Total of 4 processors activated (6324.22 BogoMIPS).
CPU: All CPU(s) started in SVC mode.
devtmpfs: initialized
pinctrl core: initialized pinctrl subsystem
regulator-dummy: no parameters
NET: Registered protocol family 16
DMA: preallocated 256 KiB pool for atomic coherent allocations
Use WDOG1 as reset source
syscon 20c8000.anatop: regmap [mem 0x020c8000-0x020c8fff] registered
vdd1p1: 800 <--> 1375 mV at 1100 mV
vdd3p0: 2625 <--> 3400 mV at 3000 mV
vdd2p5: 2000 <--> 2750 mV at 2400 mV
cpu: 725 <--> 1450 mV at 1150 mV
vddpu: 725 <--> 1450 mV
vddsoc: 725 <--> 1450 mV at 1175 mV
syscon 20e0000.iomuxc-gpr: regmap [mem 0x020e0000-0x020e0037] registered
syscon 21bc000.ocotp-ctrl: regmap [mem 0x021bc000-0x021bffff] registered
hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
hw-breakpoint: maximum watchpoint size is 4 bytes.
imx6q-pinctrl 20e0000.iomuxc: initialized IMX pinctrl driver
bio: create slab <bio-0> at 0
mxs-dma 110000.dma-apbh: initialized
1P8V: 1800 mV
2P5V: 2500 mV
3P3V: 3300 mV
usb_otg_vbus: 5000 mV
i2c-core: driver [max17135] using legacy suspend method
i2c-core: driver [max17135] using legacy resume method
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
i2c i2c-0: IMX I2C adapter registered
i2c i2c-1: IMX I2C adapter registered
i2c i2c-2: IMX I2C adapter registered
Linux video capture interface: v2.00
pps_core: LinuxPPS API ver. 1 registered
pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
PTP clock support registered
imx-ipuv3 2400000.ipu: IPU DMFC NORMAL mode: 1(0~1), 5B(4,5), 5F(6,7)
imx-ipuv3 2800000.ipu: IPU DMFC NORMAL mode: 1(0~1), 5B(4,5), 5F(6,7)
mxc_mipi_csi2 21dc000.mipi_csi: ipu_id missing or invalid
mxc_mipi_csi2 21dc000.mipi_csi: i.MX MIPI CSI2 driver probed -  error
mxc_mipi_csi2: probe of 21dc000.mipi_csi failed with error -22
MIPI CSI2 driver module loaded
Advanced Linux Sound Architecture Driver Initialized.
Bluetooth: Core ver 2.16
NET: Registered protocol family 31
Bluetooth: HCI device and connection manager initialized
Bluetooth: HCI socket layer initialized
Bluetooth: L2CAP socket layer initialized
Bluetooth: SCO socket layer initialized
pureg-dummy: no parameters
Switching to clocksource mxc_timer1
NET: Registered protocol family 2
TCP established hash table entries: 8192 (order: 4, 65536 bytes)
TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
TCP: Hash tables configured (established 8192 bind 8192)
TCP: reno registered
UDP hash table entries: 512 (order: 2, 16384 bytes)
UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
RPC: Registered named UNIX socket transport module.
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
Trying to unpack rootfs image as initramfs...
Freeing initrd memory: 708K (85000000 - 850b1000)
hw perfevents: enabled with ARMv7 Cortex-A9 PMU driver, 7 counters available
mxc_epit: probe of 20d0000.epit failed with error -22
mxc_epit: probe of 20d4000.epit failed with error -22
imx6_busfreq busfreq.17: DDR medium rate not supported.
Bus freq driver module loaded
futex hash table entries: 1024 (order: 4, 65536 bytes)
audit: initializing netlink socket (disabled)
type=2000 audit(0.480:1): initialized
VFS: Disk quotas dquot_6.5.2
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
NFS: Registering the id_resolver key type
Key type id_resolver registered
Key type id_legacy registered
NTFS driver 2.1.30 [Flags: R/W DEBUG].
jffs2: version 2.2. (NAND) 漏 2001-2006 Red Hat, Inc.
fuse init (API version 7.22)
msgmni has been set to 1994
io scheduler noop registered
io scheduler deadline registered
io scheduler cfq registered (default)
imx-weim 21b8000.weim: WEIM driver registered.
pwm-backlight backlight_lvds.32: failed to request GPIO#2: -16
pwm-backlight: probe of backlight_lvds.32 failed with error -16
MIPI DSI driver module loaded
mxc_sdc_fb fb.27: registered mxc display driver ldb
Console: switching to colour frame buffer device 160x50
mxc_sdc_fb fb.28: registered mxc display driver lcd
mxc_hdmi 20e0000.hdmi_video: Detected HDMI controller 0x13:0xa:0xa0:0xc1
mxc_sdc_fb fb.29: registered mxc display driver hdmi
imx-sdma 20ec000.sdma: no iram assigned, using external mem
imx-sdma 20ec000.sdma: loaded firmware 1.1
imx-sdma 20ec000.sdma: initialized
Serial: IMX driver
21e8000.serial: ttymxc1 at MMIO 0x21e8000 (irq = 59) is a IMX
console [ttymxc1] enabled
21f0000.serial: ttymxc3 at MMIO 0x21f0000 (irq = 61) is a IMX
21f4000.serial: ttymxc4 at MMIO 0x21f4000 (irq = 62) is a IMX
serial: Freescale lpuart driver
imx sema4 driver is registered.
[drm] Initialized drm 1.1.0 20060810
[drm] Initialized vivante 1.0.0 20120216 on minor 0
brd: module loaded
loop: module loaded
Wait for CR ACK error!
sata phy RX_PLL is stable!
ahci: SSS flag set, parallel bus scan disabled
ahci ahci: AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl platform mode
ahci ahci: flags: ncq sntf stag pm led clo only pmp pio slum part ccc apst
scsi0 : ahci_platform
ata1: SATA max UDMA/133 mmio [mem 0x02200000-0x02203fff] port 0x100 irq 71
m25p80 spi32766.0: sst25vf016b (2048 Kbytes)
3 ofpart partitions found on MTD device spi32766.0
Creating 3 MTD partitions on "spi32766.0":
0x000000000000-0x0000000c0000 : "U-Boot"
0x0000000c0000-0x0000000c2000 : "env"
0x0000000c2000-0x000000200000 : "splash"
spi_imx 2008000.ecspi: probed
tun: Universal TUN/TAP device driver, 1.6
tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
CAN device driver interface
imx6q-pinctrl 20e0000.iomuxc: pin MX6Q_PAD_KEY_COL2 already requested by 20e0000.iomuxc; cannot claim for 2090000.can
imx6q-pinctrl 20e0000.iomuxc: pin-130 (2090000.can) status -22
imx6q-pinctrl 20e0000.iomuxc: could not request pin 130 on device 20e0000.iomuxc
flexcan 2090000.can: Error applying setting, reverse things back
flexcan: probe of 2090000.can failed with error -22
fec 2188000.ethernet (unregistered net_device): Invalid MAC address: 00:00:00:00:00:00
fec 2188000.ethernet (unregistered net_device): Using random MAC address: 4e:d3:39:b5:d8:d8
libphy: fec_enet_mii_bus: probed
fec 2188000.ethernet eth0: registered PHC device 0
PPP generic driver version 2.4.2
PPP BSD Compression module registered
PPP Deflate Compression module registered
PPP MPPE Compression module registered
NET: Registered protocol family 24
usbcore: registered new interface driver asix
usbcore: registered new interface driver ax88179_178a
usbcore: registered new interface driver cdc_ether
usbcore: registered new interface driver net1080
usbcore: registered new interface driver cdc_subset
usbcore: registered new interface driver zaurus
usbcore: registered new interface driver cdc_ncm
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
usbcore: registered new interface driver cdc_acm
cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
usbcore: registered new interface driver usb-storage
usbcore: registered new interface driver usbserial
usbcore: registered new interface driver option
usbserial: USB Serial support registered for GSM modem (1-port)
ci_hdrc ci_hdrc.1: doesn't support gadget
ci_hdrc ci_hdrc.1: EHCI Host Controller
ci_hdrc ci_hdrc.1: new USB bus registered, assigned bus number 1
ci_hdrc ci_hdrc.1: USB 2.0 started, EHCI 1.00
usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb1: Product: EHCI Host Controller
usb usb1: Manufacturer: Linux 3.10.53-88204-g4f0dd92-dirty ehci_hcd
usb usb1: SerialNumber: ci_hdrc.1
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
mousedev: PS/2 mouse device common for all mice
usbcore: registered new interface driver xpad
usbcore: registered new interface driver usb_acecad
usbcore: registered new interface driver aiptek
usbcore: registered new interface driver gtco
usbcore: registered new interface driver hanwang
usbcore: registered new interface driver kbtab
usbcore: registered new interface driver wacom
i2c-core: driver [isl29023] using legacy suspend method
i2c-core: driver [isl29023] using legacy resume method
snvs_rtc 20cc034.snvs-rtc-lp: rtc core: registered 20cc034.snvs-rtc-lp as rtc0
i2c /dev entries driver
ata1: SATA link down (SStatus 0 SControl 300)
mxc_v4l2_output v4l2_out.37: V4L2 device registered as video16
mxc_v4l2_output v4l2_out.37: V4L2 device registered as video17
mxc_v4l2_output v4l2_out.37: V4L2 device registered as video18
mxc_v4l2_output v4l2_out.37: V4L2 device registered as video19
mxc_v4l2_output v4l2_out.37: V4L2 device registered as video20
usbcore: registered new interface driver uvcvideo
USB Video Class driver (1.1.1)
gspca_main: v2.14.0 registered
imx2-wdt 20bc000.wdog: IMX2+ Watchdog Timer enabled. timeout=60s (nowayout=0)
device-mapper: uevent: version 1.0.3
device-mapper: ioctl: 4.24.0-ioctl (2013-01-15) initialised: dm-devel@redhat.com
Bluetooth: Virtual HCI driver ver 1.3
Bluetooth: HCI UART driver ver 2.2
Bluetooth: HCIATH3K protocol initialized
usbcore: registered new interface driver btusb
cpuidle: using governor ladder
cpuidle: using governor menu
sdhci: Secure Digital Host Controller Interface driver
sdhci: Copyright(c) Pierre Ossman
sdhci-pltfm: SDHCI platform and OF driver helper
mmc2: no vqmmc regulator found
mmc2: no vmmc regulator found
mmc2: SDHCI controller on 2198000.usdhc [2198000.usdhc] using ADMA
mmc3: no vqmmc regulator found
mmc3: no vmmc regulator found
mmc3: SDHCI controller on 219c000.usdhc [219c000.usdhc] using ADMA
Galcore version 5.0.11.25762
mmc2: new high speed DDR MMC card at address 0001
mmcblk2: mmc2:0001 SEM16G 14.8 GiB
mmcblk2boot0: mmc2:0001 SEM16G partition 1 2.00 MiB
mmcblk2boot1: mmc2:0001 SEM16G partition 2 2.00 MiB
mmcblk2rpmb: mmc2:0001 SEM16G partition 3 128 KiB
mmcblk2: p1 p2 p3 < p5 p6 p7 p8 > p4
mmcblk2: p4 size 28925952 extends beyond EOD, truncated
mmcblk2boot1: unknown partition table
mmcblk2boot0: unknown partition table
mxc_vdoa 21e4000.vdoa: i.MX Video Data Order Adapter(VDOA) driver probed
mxc_asrc 2034000.asrc: mxc_asrc registered
mxc_vpu 2040000.vpu: VPU initialized
caam 2100000.caam: Instantiated RNG4 SH0
caam 2100000.caam: Instantiated RNG4 SH1
caam 2100000.caam: device ID = 0x0a160100 (Era 4)
caam 2100000.caam: job rings = 2, qi = 0
caam algorithms registered in /proc/crypto
caam_jr 2101000.jr0: registering rng-caam
platform caam_sm: blkkey_ex: 4 keystore units available
platform caam_sm: 64-bit clear key:
platform caam_sm: [0000] 00 01 02 03 04 0f 06 07
platform caam_sm: 64-bit black key:
platform caam_sm: [0000] bb 8c 55 dc cf 5f da 1b
platform caam_sm: [0008] fb bc a7 a3 d0 d0 67 04
platform caam_sm: 128-bit clear key:
platform caam_sm: [0008] 08 09 0a 0b 0c 0d 0e 0f
platform caam_sm: 128-bit black key:
platform caam_sm: [0000] bf cf 87 4b 6b bf c8 76
platform caam_sm: [0008] 7d 77 6d 77 85 35 da 6b
platform caam_sm: 192-bit clear key:
platform caam_sm: [0016] 10 11 12 13 14 15 16 17
platform caam_sm: 192-bit black key:
platform caam_sm: [0000] 92 88 25 0f 65 3c e6 48
platform caam_sm: [0008] 65 9d 11 fd 22 b3 29 24
platform caam_sm: [0016] 6a 71 93 5a 61 18 67 a8
platform caam_sm: [0024] c8 56 17 00 02 7a 03 22
platform caam_sm: 256-bit clear key:
platform caam_sm: [0024] 18 19 1a 1b 1c 1d 1e 1f
platform caam_sm: 256-bit black key:
platform caam_sm: [0000] 58 44 15 27 09 39 fd 62
platform caam_sm: [0008] 99 e9 78 5c dd d7 32 cc
platform caam_sm: [0016] 90 94 71 af 48 40 89 61
platform caam_sm: [0024] 6f 26 19 dd 4e 6d ff 0a
platform caam_sm: 64-bit unwritten blob:
platform caam_sm: [0000] 00 00 00 00 00 00 00 00
platform caam_sm: [0008] 00 00 00 00 00 00 00 00
platform caam_sm: [0016] 00 00 00 00 00 00 00 00
platform caam_sm: [0024] 00 00 00 00 00 00 00 00
platform caam_sm: [0032] 00 00 00 00 00 00 00 00
platform caam_sm: [0040] 00 00 00 00 00 00 00 00
platform caam_sm: [0048] 00 00 00 00 00 00 00 00
platform caam_sm: [0056] 00 00 00 00 00 00 00 00
platform caam_sm: [0064] 00 00 00 00 00 00 00 00
platform caam_sm: [0072] 00 00 00 00 00 00 00 00
platform caam_sm: [0080] 00 00 00 00 00 00 00 00
platform caam_sm: [0088] 00 00 00 00 00 00 00 00
platform caam_sm: 128-bit unwritten blob:
platform caam_sm: 196-bit unwritten blob:
platform caam_sm: 256-bit unwritten blob:
platform caam_sm: 64-bit black key in blob:
platform caam_sm: [0000] 11 ef 09 5a cd e9 33 df
platform caam_sm: [0008] ad 67 4b 77 ec ba e0 a2
platform caam_sm: [0016] 0a cd 1b 55 b2 49 67 47
platform caam_sm: [0024] a2 20 1e a6 b7 01 3a 7e
platform caam_sm: [0032] 7d 54 dd cb 2c 3d 96 8a
platform caam_sm: [0040] 06 fa cf 2b 76 8b 8e 87
platform caam_sm: [0048] b2 67 16 56 10 3b aa a8
platform caam_sm: 128-bit black key in blob:
platform caam_sm: [0000] 8a b9 f6 bb 8d e1 f6 d7
platform caam_sm: [0008] 3e df c8 de 5d a9 4f fd
platform caam_sm: [0016] bc 68 d0 f3 fc e4 19 f2
platform caam_sm: [0024] ca 27 a5 8a d7 4f b5 37
platform caam_sm: [0032] 53 54 56 20 9e 8f 30 fd
platform caam_sm: [0040] c3 d8 0c e6 9f 2d 5e 37
platform caam_sm: [0048] f7 30 1e c2 7f f1 9c 63
platform caam_sm: [0056] f2 e3 ec b6 28 a3 ef 36
platform caam_sm: 192-bit black key in blob:
platform caam_sm: [0000] 8f e3 86 4c b4 bc e9 0c
platform caam_sm: [0008] 8f 06 4a 56 26 12 4d 15
platform caam_sm: [0016] ea 94 f0 7e c1 ce da dd
platform caam_sm: [0024] bf 7d f6 3b e3 ef 10 9e
platform caam_sm: [0032] 17 e7 a9 9d 8f 6f 50 e7
platform caam_sm: [0040] 9e a3 aa 09 b8 be e9 33
platform caam_sm: [0048] 44 80 12 94 0f 72 75 27
platform caam_sm: [0056] 9a dc 3e 64 fa 82 ea 3d
platform caam_sm: [0064] fb 8e 2d 44 b5 93 22 23
platform caam_sm: 256-bit black key in blob:
platform caam_sm: [0000] 45 af 0d 2c 7a a9 37 f7
platform caam_sm: [0008] 40 7d fa 9e 07 3a 69 ea
platform caam_sm: [0016] ad a4 31 aa 52 58 2d 8a
platform caam_sm: [0024] 81 37 b7 3d a4 b4 a3 79
platform caam_sm: [0032] b0 e2 6c a3 97 63 ca f5
platform caam_sm: [0040] 1a c9 fe ec 75 35 d4 a3
platform caam_sm: [0048] eb e7 62 dc 1c bb cd e1
platform caam_sm: [0056] ba f1 0f 37 e0 fc 2a 3c
platform caam_sm: [0064] 66 d5 43 fa 6f 6d 0a 8b
platform caam_sm: [0072] 43 07 68 d5 3d 11 bb 6b
platform caam_sm: restored 64-bit black key:
platform caam_sm: [0000] 04 cf 2c 03 5e 2c 7c 9b
platform caam_sm: [0008] d9 1e 95 42 14 6d 3f 86
platform caam_sm: restored 128-bit black key:
platform caam_sm: restored 192-bit black key:
platform caam_sm: [0016] f3 e6 6b ab b3 13 b9 dc
platform caam_sm: [0024] c5 4c bb 91 a7 5b ff 70
platform caam_sm: restored 256-bit black key:
snvs-secvio 20cc000.caam-snvs: violation handlers armed - non-secure state
hidraw: raw HID events driver (C) Jiri Kosina
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
ashmem: initialized
logger: created 256K log 'log_main'
logger: created 256K log 'log_events'
logger: created 256K log 'log_radio'
logger: created 256K log 'log_system'
usbcore: registered new interface driver snd-usb-audio
sgtl5000 0-000a: Failed to get supply 'VDDD': -19
0-000a: 1200 mV normal
sgtl5000 0-000a: Using internal LDO instead of VDDD
sgtl5000 0-000a: sgtl5000 revision 0x11
imx-sgtl5000 sound.25:  sgtl5000 <-> 2028000.ssi mapping ok
imx-audio-hdmi sound-hdmi.26:  hdmi-hifi <-> hdmi_audio.18 mapping ok
NET: Registered protocol family 26
u32 classifier
    Actions configured
Netfilter messages via NETLINK v0.30.
nf_conntrack version 0.5.0 (15956 buckets, 63824 max)
ctnetlink v0.93: registering with nfnetlink.
NF_TPROXY: Transparent proxy support initialized, version 4.1.0
NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
xt_time: kernel timezone is -0000
ip_tables: (C) 2000-2006 Netfilter Core Team
arp_tables: (C) 2002 David S. Miller
TCP: cubic registered
Initializing XFRM netlink socket
NET: Registered protocol family 10
mip6: Mobile IPv6
ip6_tables: (C) 2000-2006 Netfilter Core Team
NET: Registered protocol family 17
NET: Registered protocol family 15
can: controller area network core (rev 20120528 abi 9)
NET: Registered protocol family 29
can: raw protocol (rev 20120528)
can: broadcast manager protocol (rev 20120528 t)
can: netlink gateway (rev 20130117) max_hops=1
Bluetooth: RFCOMM TTY layer initialized
Bluetooth: RFCOMM socket layer initialized
Bluetooth: RFCOMM ver 1.11
Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Bluetooth: BNEP filters: protocol multicast
Bluetooth: BNEP socket layer initialized
Bluetooth: HIDP (Human Interface Emulation) ver 1.2
Bluetooth: HIDP socket layer initialized
8021q: 802.1Q VLAN Support v1.8
Key type dns_resolver registered
VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
usb_otg_vbus: disabling
regulator-dummy: disabling
imx mcc test is registered.
file system registered
android_usb gadget: Mass Storage Function, version: 2009/09/11
android_usb gadget: Number of LUNs=1
lun0: LUN: removable file: (no medium)
android_usb gadget: android_usb ready
input: gpio-keys.24 as /devices/soc0/gpio-keys.24/input/input0
snvs_rtc 20cc034.snvs-rtc-lp: setting system clock to 1970-01-01 00:00:02 UTC (2)
ALSA device list:
  #0: sgtl5000-audio
  #1: imx-hdmi-soc
Freeing unused kernel memory: 340K (80e7b000 - 80ed0000)
type=1403 audit(2.750:2): policy loaded auid=4294967295 ses=4294967295
type=1404 audit(2.760:3): enforcing=1 old_enforcing=0 auid=4294967295 ses=4294967295
Console: switching to colour dummy device 80x30
fs_mgr: boot device base == mmcblk2
EXT4-fs (mmcblk2p1): VFS: Can't find ext4 filesystem
fs_mgr: __mount(source=/dev/block/mmcblk2p1,target=/boot,type=ext4)=-1
fs_mgr: Failed to mount an un-encryptable or wiped partition on/dev/block/mmcblk2p1 at /boot options: errors=remount-ro error: Invalid argument
EXT4-fs (mmcblk2p2): VFS: Can't find ext4 filesystem
fs_mgr: __mount(source=/dev/block/mmcblk2p2,target=/recovery,type=ext4)=-1
fs_mgr: Failed to mount an un-encryptable or wiped partition on/dev/block/mmcblk2p2 at /recovery options: errors=remount-ro error: Invalid argument
EXT4-fs (mmcblk2p5): mounted filesystem with ordered data mode. Opts: (null)
fs_mgr: __mount(source=/dev/block/mmcblk2p5,target=/system,type=ext4)=0
EXT4-fs (mmcblk2p4): Ignoring removed nomblk_io_submit option
EXT4-fs (mmcblk2p4): recovery complete
EXT4-fs (mmcblk2p4): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,noauto_da_alloc,errors=panic
fs_mgr: __mount(source=/dev/block/mmcblk2p4,target=/data,type=ext4)=0
EXT4-fs (mmcblk2p6): Ignoring removed nomblk_io_submit option
EXT4-fs (mmcblk2p6): recovery complete
EXT4-fs (mmcblk2p6): mounted filesystem with ordered data mode. Opts: nomblk_io_submit
fs_mgr: __mount(source=/dev/block/mmcblk2p6,target=/cache,type=ext4)=0
EXT4-fs (mmcblk2p7): mounted filesystem with ordered data mode. Opts: (null)
fs_mgr: __mount(source=/dev/block/mmcblk2p7,target=/device,type=ext4)=0
init: fs_mgr_mount_all returned an error
init: fs_mgr_mount_all returned unexpected error 255
binder: 168:168 transaction failed 29189, size 0-0
init: cannot fi畊7?U\qIj桫踚nit: cannot expand '${ro.serialno}' while writing to '/sys/class/android_usb/android0/iSerial'
android_usb: already disabled
read descriptors
read strings
mtp_bind_config
root@sabresd_6dq:/ # imx-ipuv3 2400000.ipu: IPU DMFC DP HIGH RESOLUTION: 1(0,1), 5B(2~5), 5F(6,7)
healthd: No charger supplies found
healthd: No battery devices found
Uboot的环境变量设置信息如下:
ACM-IMX6Q > printenv
baudrate=115200
bootargs=console=ttymxc1,115200 init=/init rw video=mxcfb1:dev=ldb,LDB-XGA,if=RGB24,bpp=24 video=mxcfb0:dev=hdmi,1920x1080M@60,if=RGB24,video=mxcfb2ff vmalloc=400M androidboot.console=ttymxc1 consoleblank=0 androidboot.hardware=freescale androidboot.bootdev=mmcblk2 cma=384M
bootcmd=booti mmc0
bootdelay=3
ethact=FEC
ethprime=FEC
fastboot_dev=mmc0
fdt_high=0xffffffff
initrd_high=0xffffffff
loadaddr=0x12000000
splashpos=m,m
Environment size: 466/8188 bytes
我知道答案 目前已有0人回答
GMT+8, 2025-10-29 05:44 , Processed in 0.077166 second(s), 21 queries , MemCache On.
